Sammelthread für das MSI 945GT Speedster
Beschreibung:
CPU
• Intel® Core Duo, Core2Duo(Merom) ab bios 1.21, Core Solo, Celeron M Processors
• Supports 3/4 pin CPU Fan Pin-Header with Fan Speed Control
• Supports Intel® Dual Core Technology up 667 MHz
• Supports FSB 533/ 667 MHz
Core Chipset
• North Bridge: Intel® 945GT chipset
• South Bridge: Intel® ICH7R chipset
Main Memory
• Supports DDR2 533/667 SDRAM (4GB Max.)
• Supports two 240-pin/1.8V DDR2 DIMMs
Slots
• One PCI Express x16 slots
• One PCI Express x 4 slot
• Two PCI slots
• Support 3.3V/ 5V PCI bus Interface
HDD Interface
• 1 IDE ports by ICH7R
- Supports Ultra DMA 66/100 mode
- Supports PIO, Bus Master operation mode
• SATA II ports by ICH7R
- Supports four SATA II device
- Supports storage and data transfers at up to 3.0 Gb/s
• RAID
- SATA1~4 supports RAID 0/ 1/ 0+1/ 5 by ICH7R
MSI Reminds You...
• The RAID setup floppy disk is optional depending on the districts. You can download the files from the website to make the setup disk.
Internal I/O Connectors
- 1 x PS/2 mouse port
- 1 x PS/2 keyboard port
- 2 x RJ45 Gigabit LAN
- 1 x IEEE 1394 port
- 4 x USB 2.0 Ports
- 1 x DVI + VGA connector
- 1 x S-Video + RCA connector
- 1 x 7.1 channel Audio connector
On-Board Pinheaders
- 1 IrDA pinheader
- 2 USB 2.0 pinheaders
- 1 IEEE 1394 pinheaders
MSI Reminds You...
• The floppy disk cable will be optional.
Onboard LAN
• Two PCI Express LAN GB Ethermet by two Intel 82573L
Onboard Audio
• Chip integrated by Realtek® ALC880
• Flexible 7.1 channel audio with jack sensing
• Compliant with Azalia 1.0 Spect
Onboard IEEE 1394
• Chip integrated by VIA VT 6307
• Transfer rate is up to 400Mbps
Form Factor
• Micro ATX Form Factor (24.4cm X 24.4 cm)
• 9 mounting holes
Zubehör
- MSI Treiber-/Programm-CD
- S-ATA Kabel
- S-ATA Stromkabel
- 1x IDE Kabel
- 1x Floppy Kabel
- MSI META I/O ATX Blende
Weiteren Support gebe ich hier
Beschreibung:
CPU
Core Chipset
Main Memory
Slots
• Two PCI slots
HDD Interface
• RAID
MSI Reminds You...
- 4 x USB 2.0 Ports
On-Board Pinheaders
- 1 IrDA pinheader
MSI Reminds You...
Onboard LAN
Onboard Audio
Onboard IEEE 1394
Form Factor
• 9 mounting holes
Zubehör
- S-ATA Kabel
- S-ATA Stromkabel
- 1x IDE Kabel
- 1x Floppy Kabel
