[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ich hätte sie auch gern :)
Den Chip nimmt bestimmt noch ein Chinese.
1x PCB verbogen / Karte ohne Stütze benutzt
4x RAM Speicher (A0,A1, F0, F1) weißen PCB Seitig beschädigte Lötpads/Lötverbindungen auf.
1x Grafikprozessor weißt PCB seitig beschädigte Lötpads/Lötverbindungen auf.
Preis für die Rep. nenne ich nicht, aber es tut weh.
Gerade hier im Thread wäre der Preis interessant
Und bei einer 4090 kann sich das dennoch lohnen...aber das mal daher gesagt. ohne die Zahl zu kennen...
Ich will nicht, dass vielleicht mal sowas kommt wie "aber da habe ich gelesen dass... blabla".
Aber ich sag mal so: fast ne halbe 5080 ;)
Danke für die Info. Hätte ich auch so gemacht.
Selbst wenn man einen Fehler gemacht hat, braucht man hier im Forum nicht noch Leute die einen dann noch erzählen wollen wie toll sie sind und nochmal explizit einen dumm da stehen lassen.
Ich hab vor ein paar Monaten mein x79 Mainboard für 100€ reparieren lassen weil die RAM Channel defekt waren. Ja und? Ist ja mein Hobby und ich hab gern heile Sachen.
Naja der Preis verwundert nicht, das ist einfach sauviel Arbeit die GPU und noch mehrere RAMs zu reballen und von irgendwas will der gute Mann auch Leben.
Bei dem Fehlerbild hätte ich auch nichts unter 600 Euro erwartet. Aber in Anbetracht, was die Karte aktuell wert ist und was eine neue Karte (4090 oder 5090) kosten würde, muss er den Drops mit den Reparaturkosten halt lutschen. Eine Lehre sollte es für uns alle sein, die Karten niemals ohne Stütze zu verwenden.
Es ist bestimmt schon 2 Generationen oder so zurück, da hab ich nach einer Gewissen Zeit eine Karte ausgebaut und es fehlte nicht viel zur Banane(etwas übertrieben ausgedrückt), trotz Backplate etc.
Die lief auch danach noch weiter aber seitdem habe ich eine Stütze :hust:
Mit Stock Kühler.
Bei meinem Wakü hatte ich jetzt nicht das Gefühl, dass es sich stark biegt aber ich geh auch mal lieber auf Nummer sicher. Auch wenn es teuer für dich ist, schon gut zu wissen, dass es inzwischen Shops gibt wo man so ne teure Grafikkarte auch mal reparieren kann.
Was denkt der hohe Rat den zu der Lösung?
Ich habe meine gigabyte 4090 von Wakü auf Luft zurückgebaut und dann diesen Metallwinkel, den man am Gehäuse durch an den Mainboard Standoffs montiert, genutzt.
Das entlastet die Karte auch gut und ist unauffällig.
Bei Grafikkarten sollte man aktuell wirklich auf Nummer zu sicher gehen, ein Ersatz kann ja kaum jemand bezahlen. :fresse:
Meine 4090 macht zum Glück keine Probleme bisher, ist ja jetzt auch schon wieder ziemlich genau 3 Jahre alt.
Nur in der kranken Nvidia Klasse, sollte meine 4080 sterben würde ich mir eine 9070Xt holen, die ist gut und bezahlbar
Je nach Modell kann da schon die Schwerkraft unangenehm drauf einwirken.
Die 4090FE ist ja derart massiv gebaut mit dem umlaufenden Aluminiumrahmen das da keine Biegung zustande kommen kann.
Aber da lastet schon auch gut Gewicht am PCIe Slot deshalb ist meine auch unterstützt.
Ja, eben, es geht ja auch um den Schutz des PCIe Slot, denn sonst riskiert man dort einen Bruch oder gar bei den Kontakten der 4090.
Wenn Grafikkarten zukünftig alle eher schwer sind, sollte man sich da vielleicht mal eine bessere Lösung einfallen lassen.
Update:
Anmerkungen und Kommentare zu Ihrer Bestellung: Guten Tag,
Ihr Gerät hat die Technik repariert und geprüft verlassen. Die Karte wurde horizontal, sowie vertikal verbaut, getestet. Die Karte konnte erfolgreich folgende Tests abschließen:
- RAM Speicher Stresstest
- Benchmarktest
- Gaming Test (Battlefiled 6 Redsec)
- Mining Test
Bitte lassen Sie aufgrund der Kühlungsprobleme bei allen 30XX/40XX/50XX Grafikkarten, bitte den Lüfter immer beim Spielen oder aufwändigen Anwendungen bei mindestens 70 bis 80 % laufen, sodass die RAM Speicher nicht heißer als 80-90 Grad werden.
Sollten Sie noch keine Grafikkarten Stütze (GPU Support) nutzen, so würden wir Sie bitten (grundsätzlich bei allen 30XX,40XX und 50XX Karten) diese schwere Grafikkarte zu stützen, um eine Verbiegung des PCB's der Karte zu verhindern. Andernfalls wird es unweigerlich zu einem erneuten Ausfall der Karte kommen.
Erstmal ne Stütze bestellt :fresse2:
Ich zucke immer innerlich zusammen wenn ich "RAM Speicher" höre/lese....
Und 70-80% Fan Speed halte ich auch tendenziell für übertrieben :d
Schreibt man das nicht so? Random Access Memory Speicher :lol:
Ich schau mal wenn die Karte wieder da ist, die drehte zuletzt nicht höher als 30-33%.
Ich stelle die Lüfterkurven eigtl. immer etwas moderat ein, aber aber ca. 75/80Grad dafür um so höher.
Speicher mit wahlfreiem/direktem Zugriff wäre es wohl für den Deutschen Informatiker.
Wo kann ich mir den runterladen?
