lordberti
Experte
- AMD Ryzen 9 9950X3D (SP 120)
- ASUS ROG CROSSHAIR X670E EXTREME (Bios 3902)
- PHANTEKS Glacier One 360 T30 Gen2
- Corsair CMP64GX5M2B6000Z30 (ASUS ROG Certified Memory)
- ASUS ROG Astral GeForce RTX 5090 OC Edition
- LG OLED42C27LA
- WD SN850XBlack
- Phanteks NV7
- Seasonic PRIME TX-1600 ATX 3.1 Noctua Edition
- Windows 11 Pro Voll. (25H2)
- Sonstiges
- ASUS ProArt Switch PQG-U1080
ASUS: ROG CROSSHAIR/STRIX/PROART/TUF X870/B850/X670/B650 Series Beta Bios
rog-forum.asus.com
Update: Beta Bios für X670 und B650 Boards
Do not use older versions of cmo files, they may cause problems with agesa 1301b patch A bios (Compatible with same agesa version BIOS)
1. Update AGESA ComboAM5 PI 1.3.0.1b patch A
2. Support the GNR Transparent Secure Memory Encryption (TSME) feature
Re: X670 / X870 resource thread
ROG CROSSHAIR/STRIX/PROART/TUF X870 Series Beta Bios 2401 Do not use older versions of cmo files, they may cause problems with agesa 1301b patch A bios (Compatible with same agesa version BIOS) 1. Update AGESA ComboAM5 PI 1.3.0.1b patch A 2. Support the GNR Transparent Secure Memory Encryption...
