[Sammelthread] AM5 AGESA/UEFI/BIOS Info & Laberthread
Neuer AMD Chipsatz Treiber Verfügbar!
Revision Number
8.05.04.516
Release Date
2026-05-18
Supports:
AMD Ryzen™ AI 300 Series
AMD Ryzen™ Threadripper™ PRO 3000/5000/7000/9000 Series Processors
AMD Ryzen™ 7 9800X3D Processor
AMD Ryzen™ 9000 Series Desktop Processors
AMD Ryzen™ 8000G Series Desktop Processors
AMD Ryzen™ 8X40 Series processors
AMD Ryzen™ 7040 Series Desktop Processors
AMD Ryzen™ 7000 Series Desktop Processors
AMD Ryzen™ 7000 Series Mobile Processors
AMD Ryzen™ 5000 Series Desktop Processor
AMD Ryzen™ Threadripper™ 3000/5000/7000/9000 Series Processors
3rd Gen AMD Ryzen™ Desktop Processor
2nd Gen AMD Ryzen™ Desktop Processor
AMD Ryzen™ Threadripper™ 1000/2000 Series Processors
AMD Ryzen™ Desktop Processor with Radeon™ Graphics
AMD Ryzen™ Mobile Processor with Radeon™ Graphics
7th-Gen AMD A-Series Processors
AMD X870E/X870 Chipset
AMD X670E/X670 Chipset
AMD B650E/B650 Chipset
AMD B350 Chipset
AMD A320 Chipset
AMD X370 Chipset
AMD X399 Chipset
AMD B450 Chipset
AMD X470 Chipset
AMD X570 Chipset
AMD B550 Chipset
AMD A520 Chipset
AMD A620 Chipset
AMD TRX40 Chipset
AMD TRX50 Chipset
AMD WRX80 Chipset
AMD WRX90 Chipset
Package Includes:
AMD Chipset Drivers AMD Ryzen™ Power Plans (required for UEFI CPPC2 in Windows® 10 May 2019 Update)
Release Notes zur Version 8.05.04.516
  • Treiber | Windows 10 | Windows 11 | Beschreibung
  • AMD Ryzen Power Plan / AMD Processor Power Management Support | 8.0.1.13 | 8.0.1.13 | Bug Fixes
  • AMD GPIO2 Driver | 2.2.0.137 | 2.2.0.137 | Bug Fixes
  • AMD PSP Driver | 5.44.0.0 .| 5.44.0.0 | Bug Fixes
  • AMD PPM Provisioning File Driver | 8.0.0.62 | 8.0.0.62 | Bug Fixes
  • AMD PMF-8000Series Driver | 25.5.25.0 | 26.10.9.0 | Bug Fixes
  • AMD PMF Ryzen AI 300 Series Driver 1 | Nicht vorhanden | 26.10.9.0 | Bug Fixes
  • AMD PMF Ryzen AI MAX 300 Series Driver | Nicht vorhanden | 26.10.9.0 | Bug Fixes
  • AMD PMF Ryzen AI 300 Series Driver 2 | Nicht vorhanden | 26.10.9.0 | Bug Fixes
  • AMD PMF Ryzen AI 400 Series Driver | Nicht vorhanden | 26.10.9.0 | Neue Treiberunterstützung
Bekannte Probleme​
  • Nach der Installation der AMD-Chipsatz-Installationssoftware Version „7.xx.xx.xx“ können Benutzer die Version „6.xx.xx.xx“ oder frühere Versionen nicht mehr installieren.
    Workaround:
  • Deinstallieren Sie die neueste Version der AMD-Chipsatz-Installationssoftware (Version 7.xx.xx.xx oder höher).
  • Löschen Sie den Ordner „Qt_Dependencies“ unter „C:\Program Files (x86)\AMD\Chipset_Software\“.
  • Installieren Sie eine ältere Version des AMD Chipset Installers (Version 6.xx.xx.xx oder früher).
  • Auf einem nicht englischsprachigen Betriebssystem werden einige Treiberbezeichnungen möglicherweise in Englisch angezeigt.
  • Gelegentlich kann es vorkommen, dass Ryzen PPKG nicht installiert oder aktualisiert werden kann.
  • Gelbe Warnmeldung (im Geräte-Manager) beim AMS-Mailbox-Treiber auf den AMD Ryzen™ Threadripper™ 9000-Prozessoren [AMD WRX90] unter Windows 10.
gleich mal gestern installiert. keine Probleme bisher, hatte davor aber auch keine.
mit dem Bios häng ich minimal nach, ist mir aber aktuell egal. immer noch 1.3.0.0a
MSi B650 Tomahawk Wifi
Kann wer was zu dem Eintrag sagen?
- Disable “AmiPspCcpCopy_SUPPOR” so the TCG log shows the DMA Protection Disabled event.
keinen Plan, von daher "Fragen Sie Ihre KI"
Bei „AmiPspCcpCopy_SUPPORT“ handelt es sich um eine spezifische Konfigurations- oder Code-Variable im BIOS von Mainboards (oft im Zusammenhang mit AMD-Plattformen und AMI-BIOS), die das Verhalten des hardwarebasierten Sicherheits-Co-Prozessors steuert. [1]
Der Begriff setzt sich aus folgenden technischen Komponenten zusammen:
  • AMI: American Megatrends International (der bekannte BIOS-/UEFI-Entwickler).
  • PSP: AMD Platform Security Processor (eine integrierte Sicherheitsumgebung in AMD-CPUs, ähnlich wie Intels Management Engine).
  • CCP: Cryptographic Co-Processor (ein Teilbereich des PSP, der für Verschlüsselungsoperationen zuständig ist).
  • Copy_SUPPORT: Eine Funktion, die festlegt, wie Speicher- oder Kopierprozesse über diese sichere Hardware-Schnittstelle abgewickelt werden.
Aktueller Kontext (BIOS-Updates)
In aktuellen Mainboard-Aktualisierungen (wie beispielsweise für das MSI MAG B650 Tomahawk Wifi) taucht diese Variable in den Patch Notes auf. Die Hersteller deaktivieren diese Funktion standardmäßig im Hintergrund, damit das sogenannte TCG-Protokoll (Trusted Computing Group) das Ereignis „DMA Protection Disabled“ korrekt anzeigt. Dies dient der sauberen Protokollierung von Systemsicherheits-Features für das Betriebssystem (wie z. B. Windows Virtualization-Based Security / Kernisolierung). [1]
Wahrscheinlich hat mich Gemini jetzt gehacked:d
Was auch immer "AmiPspCcpCopy_SUPPORT" bewirkt und bedeuten mag, und allein die Benennung erzeugt ja beinahe Ehrfurcht, das BIOS funktioniert an sich jedenfalls einwandfrei auf meinem Rechner.
Alle, welche ein Godlike am Start haben sollten das 70er BIOS besser auslassen. Das BIOS ist selbst mit optimized Settings nicht stabil zu bekommen. Ich weiß nicht was die bei MSI da treiben, denn dies ist der 2. Totalausfall des bios betreffend. BTW. die 62 läuft stabil, auch mit RAM-OC und voll aufgedrehtem PBO.
Wegen Agesa 1.3 (Bios) Update und der Speicher Limitierung auf 5200 Mhz, lohnen sich aktuell keine schnelleren Speicher mehr auf Ryzen Cpu's ab 9000?
Frage, weil ich aktuell vorhabe, ein neues System zusammenzustellen.
Wen es ECC Speicher ist, stimmt das so, zumindest bis AMD die Limitierung bei späteren Agesas wieder aufhebt.
Das betrifft allerdings auch nur richtigen ECC Speicher, nicht normalen DDR5.
Dann müsste es doch mit den Timings nach unten gehen und feintuning möglich sein.
Habe nur auf Reddit paar mal gelesen.. Hilfe, mein Rechner bootet nicht mehr nach dem Update. :d
Zu Ecc.. bei den Rams z.B. mit dem möglichen MB und kompatiblen Rams, wird ECC als On-Die ECC angegeben?
Wie es scheint, hat MSI fürs Godlike das A70 getauscht, denn hier kam eine neue Option hinzu: Support für LL-RAM. Probiere ich morgen mal aus.
Würde mich wundern wenn die Bios Version augetauscht wurde bzw. unterschiedlich sein sollen, Winmerge meint das beide identisch sind...
...so toll ist das MSI Bios aber nicht.....
Folgendes : AMD Menu Overcklocking ; Curve Optimizer : "Per CCD" , er macht aus "negativ" beim nächsten Boot "positiv" - die geringere Spannung wird genau einmal übernommen - Die Einstellung "negativ" wird nicht gepseichert. Von sonstiger Software wird dahingehend nichts geändert. Man sieht es direkt nach dem nächsten Boot im Bios (ohne WIN geladen zu haben) die geringere V-Core wird angezeigt , steht aber jedoch wieder auf "positiv"........
Halte ich für einen fatalen Fehler...................
Bei "per Core" funktioniert es aber.
Edit : gemerkt habe ich es in Ropbench, das zeigt ja dann keine negativ Vorzeichen an.
@MSIToWi ; @MSIToBa vlt. lest ihr ja mit......
Ähnliche Themen
