[Sammelthread] Assetto Corsa EVO
Patch für die Multiplayer Beta ist da hier der Changelog:
- Fixed a sporadic crash when joining MP sessions
- Server list fix to only show unique servers
- AI: additional global tweaks to the AI
- AI: bugfixes for less player hits
- Fixed crash when finishing the SE-01 and SE-03 events
- Fixed replay not showing tyre dirt/damage correctly
- Fixed replay continuously playing the dirt vfx
- Added versioning to camera settings and fixed a bug that zeroed the onboard movements
- Controls: electronics direct inputs: TC/TCC and ABS now have more input stages and TC input no longer only working when the car has TCC as well
- UI: mitigating penalty pop-ups remaining on screen when quickly restarting a session
- UI: corrected FOV slider for VR mode
- UI: vehicle setup - hide units when defined; pause menu - added ingame session info; replay menu - made "next session in" timer visible
- UI: fixed Academy failed result label missing in academy events
- UI: fixed an issue in the paintshop not showing the selected wheel design as the actual selection when changing to an optional wheel
- UI: fixed a likely crash when backing off from the tutorial of the career mode
- UI: fixed licence stars being visible in the leaderboard on some occasions
- UI: fixed an issue when the replay saved message was showing up incorrectly
- UI: fixed a couple of localization-related issues (spacing or missing items)
- UI: fix for being able to have the displayed number of opponents exceed the number of pitstalls by mode-switching
- Handling: fixed fuel limits on the Caterham Academy
- Handling: tweaked inconsistent ABS behaviour on a number of cars, including earlier content
- Minor updates to the BMW M4 GT3 Evo model
- Fixed visual stance of the Caterham Academy ingame
Patch 0.3.2
Netcode/MP:
- Removed spammy log and collision cooldown after big server time resync
- Rework for setup messages in netcode
- Safety check for results index
Physics:
- Global tyre revision with adjusted tyre damping
- Caterham Academy base setup mitigating snappy rear
- Porsche 718 GT4 Clubsport base setup tweaks
- BMW M4 GT3 fixed front suspension geometry
- Fixed Porsche 964 X88 engine rev limiter
- Fixed inconsistent ABS between the different Porsche Cup variants
- Updated default setup for the Mazda MX5 Cup
- Increased default FFB gain for the Dallara
AI:
- Improved braking abilities for a number of cars
- Increased safety in entry situations
- Improved overtake ability with large speed differences
- Improved AI ability to leave pitlane in crowded situations
Gameplay/UI:
- Added replay metadata and replay gallery item tagging
- Defaulted v-sync settings to Off
- Server list updates
- Added "no replay recorded" message and prevent modal confirmation in case of zero-length replays
- Session name display showing wrong event type when switching between different game modes
- Corrected localization for a number of items
- Set non-localizable font for certain texts in various menus
- Added parts categories in the paintshop
- MFD electronics navigation arrows are now visible at all times
- Triple screen setup no longer disables the right mirror by default (when using a fresh config file)
- Tweaked all car onboard cameras (F6)
Controls:
- New controls settings FFB default values
- Fix for ideal line not diplayed on a fresh profile with beginner assists
- Fix for triple screen settings appearing off-screen in view settings
- Disabled FFB soft lock until further improvements
- Input manager softset fix
- Logitech Trueforce audio fix
Graphics:
- Fixed the slightly offset steering wheel in the Ferrari 296 GTB
- Increased sponsors texture resolutions on the F2004
- Multi mirror default centre mirror pitch values adjusted for fixed capture
- Fixed Audi RS 6 Avant single mirror capture being flipped
Mit Patch 0.3.3 läuft's jetzt richtig smooth bei mir( 120-150 FPS mit Single Screen) . Multiplayer hat ebenso deutliche Verbesserungen bekommen. Hatte gestern einige Stunden viel Spaß mit BMW M2 auf dem Red Bull Ring. So langsam wird's was mit EVO.
Motorsounds sind echt WELTEN besser als bei der Konkurrenz, aber die Performance war bei mir nicht mehr so gut. Wann kam der Patch?
Online naja, es fahren halt ganz viele Mario Kart Fahrer mit, das merkt man.
Aber ja, der Ansatz stimmt schon mal.
Na wer macht nen neuen Thread
@everyone
Introducing Assetto Corsa Rally!
created by the Supernova game studios in technical partnership with Kunos simulazioni.
Early Access Program starts November 13th 2025
Wishlist now on Steam.
Special thanks to our partners for their support in the creation of this trailer:
Fanatec
Rseat
OMP
Bell
Sim Racing Expo
Syspack
edit: https://store.steampowered.com/app/3917090/Assetto_Corsa_Rally/
Habt ihr eigentlich auch das Problem, dass man das Mesh der Strecke sieht?
Je nach Wetter/Sonne und Lichteinfall zwischen gering bis deutlich sichtbar. Teils lenkt es mich sogar ab beim fahren.
Ich meine, dass es in Spa bisher am stärksten auffällt.
P.S.: In dieser Perspektiv sah man es am besten für den Screenshot, aber auch in der Cockpitsicht ist es deutlich wahrnehmbar.
Ich hatte das sichtbare Mesh ebenfalls in einem früheren Release, bei mir hat ein Update des Grafikkartentreibers das Problem behoben. (Der war zu dem Zeitpunkt schon etwas in die Jahre gekommen)🤭
Ja, ist einen Versuch wert. Mache ich bei Gelegenheit mal.
Ähnliche Themen
