[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hoffe noch auf eine starke 6090 aber dann bin ich beim Top High End auch eher raus wenn das mit den Preisen so weitergeht und danach sieht es ja aus
Ich bin jetzt auich betroffen vom guten alten 12VHPWR - Feuerwerk. Der Anschluss ist geschmolzen, die GPU sollte aber ansonsten funktionieren. Gibt es einen Reparatur-Service, den man empfehlen kann?
Im online-Auftritt wirken die jetzt nicht sonderlich vertrauenswürdig...
der 590.26 Vorschau-Treiber bringt Smooth Motion (Driver Level Frame Generation) on RTX 40 Series
https://developer.nvidia.com/downloads/shadermodel6-9-preview-driver Account erforderlich.
Vorher:
Delta GPU = 21.4K
Delta GPU Hotspot = 34.8K
Pumpe ~85%
Nachher:
Delta GPU = 14K
Delta GPU Hotspot = 22K
Pumpe 100%
Nachher2:
Delta GPU = 14.1K
Delta GPU Hotspot = 22.2K
Pumpe ~85%
Nach einem Jahr bin ich nun an der gleichen Stelle wie zuvor gelandet. Die Temparaturen sind wieder hoch. Wahrscheinlich ein Pumpout der Kryonaut Paste oder.
Delta GPU = 19.1K
Delta GPU Hotspot = 33K
Da kein sinnvolles Upgrade in Sicht ist, hatte ich mir überlegt Thermal Grizzly Duronaut + Putty Pro (30-60g) zu besorgen, damit ich mir keine Gedanken bei der Pad Dicke machen muss.
Würdet ihr das auch so machen oder habt ihr eine andere Empfehlung?
Falls die Pads noch so gut wie vor einem Jahr aussehen könnte man sie vielleicht sogar behalten...
Denke Duronaut werde ich auch als nächstes probieren.
Die ALC Apex und Termalright TFX waren zumindest schonmal nicht so gut auf meiner CPU. Deshalb kommt diese schonmal nicht auf die GPU.
Putty würde ich keine kaufen, weil die kann auch ausbluten und viel spaß die Sauerei dann zu entfernen und da du so empfindlich bist wirst du vermutlich wieder den Kühler irgendwann abbauen.
Ansonsten gibt es ja noch Kryosheet, aber würde dann auch noch um die GPU herum Kaptonband verwenden
Bin bei dem Thema selber auch noch unentschlossen, aber aktuell bleibt erstmal wie es ist,
aber kann sein, dass ich bis zur next Gen. auch nochmal den GPU Kühler runter nehme.
Das ist mir neu. Ich nutze Putty schon seit einigen Jahren und das es ausblutet ist mir noch nicht passiert.
Ich empfehle es trotzdem, weil Putty eine bessere Wärmeleitfähigkeit besitzt und Unebenheiten Zwischen PCB und Kühler besser ausgeglichen werden.
Ja gut vielleicht lasse ich die Pads auch. Das Delta beim VRAM hat sich nicht geändert und liegt immer noch bei 20K. GPU und Hotspot leider jedoch. Berichte sobald Duronaut drauf ist.
Ich werde die Duronaut-Paste stand jetzt bei GPUs erstmal nicht mehr verwenden, da sich bei meinem ersten Versuch damit das dT vom Chip sehr fix und auch deutlich verschlechtert hat:
Pump Out sein Vater:
Ich habe noch eine ungeöffnete Conductonaut Packung gefunden. Die Idee von letztes Jahr wurde nun fix umgesetzt und ich habe LM auf die 4090 gepackt. Bei der 3090 war es zumindest sehr unproblematisch und das Delta war über zwei Jahre hinweg unverändert. Hoffentlich ist es hier auch so.
Ich mach grad einen Steel Nomad Testlauf und berichte.
Edit:
Leicht enttäuscht. Delta ist knap so gut wie Kryonaut vor einem Jahr.
LM:
Delta GPU = 13.2K
Delta GPU Hotspot = 21K
Pumpe ~85%
Meine 4090 ist keine MSI, zum Glück. Aber ich hoffe meine 5080, die von MSI ist, ist weniger von so etwas betroffen. 😅
Meine Suprim werkelt seit 2 Jahren ohne Probleme und das mit schwererem Wasserkühler und ohne Stütze. Falls sie verreckt habe ich zur Not noch eine 5090 im Schrank :fresse:
bei den meisten wäre es eher andersherum :fresse:
Wer hat, der hat.
Eine Stütze zu verbauen würd doch wohl kein Problem sein?
Selbst wenn es optisch anspruchsvoll sein soll gibt's Lösungen.
Ich persönlich hab seit der Asus ROG Strix RTX 2080 eine Stütze verwendet, genauso bei der darauf folgenden RTX 3090 und mittlere 4090.
Das sich die Dinger biegen ist fix, Abwärme tut den Rest.
Ich wars nicht... ;)
Naja die sind irgendwie seltsam. Behaupten auch dass ALLE 3080 und 3080Ti sterben. Klar, in 10, 20 Jahren sind alle kaputt. Aber das meinen die wohl nicht.
Gut, dass bei meiner 4090 und auch bei der 5080 jeweils eine Stütze dabei lag.
P.S. man macht der AMD runter. :d
Wenn ich so an meine 3090 denke die 2 Jahre bei einem Kumpel lief und dann 2,5 Jahre bei mir ... und die beiden 3080 die seit ~6 Monaten bei meinem Jungs in den Rechnern werkeln und gebraucht gekauft wurden...
Sehe da kein Problem um ehrlich zu sein. Ich denke die Bedingungen unter denen die Karten sterbens sind recht speziell. Sprich hohe Wärmelasten im Gehäuse, keine / unzureichende Reinigung, schlechte Belüftung, Biegen durch Eigengewicht, da werden viele Faktoren zusammenspielen.
Also mir musst du das nicht erzählen, die zwei 3080 mit denen ich zu tun hatte laufen immer noch wie am ersten Tag in Systemen beim Bruder und Kumpel. Und die werden auch noch 10 Jahre laufen (bzw bis die dann doch mal auch upgraden werden).
Das meinte ich ja, solche reißerischen Thumbnails nerven mich. Selbst in den Videos ist es dann nicht mehr so extrem teilweise.
3000/4000 Serie sehe ich auch als unproblematisch an. Ne gebrauchte aus einem Mining System würde ich nicht kaufen, aber sonst solide Karten. Die 2080TI FE war zuletzt problematisch wegen schlechter Positionierung der Vram Baussteine.
Die aktuelle 5090 FE betrachte ich auch mit etwas Skepsis wegen den Flachbandkabeln.
Meine 4090 Frostbite Pro ist jetzt in ein neues Gehäuse umgezogen und wurde auch gleich mit neuen Pads und MX-4 verarztet.
Beim Ausbau fiel auf das die Karte/ PCB durch das Gewicht des Kühlers gut verbogen war,nach der Montage von Pads und Paste war wieder alles in Ordnung.
Suche jetzt eine GPU Stütze,von der Art her so,
Ich brauche ca. 13,5-14cm,alle üblichen Stützen der Sorte gehen aber nur bis max. 12cm.
Gibt es Hersteller die ich übersehen habe?
Wieso keine die am Mainboard befestigt wird? Da klammert man das Gehäuse als mögliches Problem aus.
Seh da nur das Jansbo VC-1 als mögliche Lösung.
Außer Du willst ein wenig basteln und machst dir selbst einen längeren Gewindebolzen rein und lackierst das Ding in schwarz.
