[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei mir geht das nicht in der APP steht überall Nicht unterstützt drin. Mit NV Inspector geht es aber
Also bei mir gehts immer noch nicht. Egal welches Spiel.
Habe noch ein bisschen rum getestet.
Forza Motorsport habe ich @ max und 4k DLAA mit DLSS 3.1.1 100 FPS im Benchmark und mit DLSS 4 96 FPS im Benchmark.
Im Benchmark ist mir optisch kein Unterschied aufgefallen.
Ready or Not @ max. 4K DLAA sieht mit DLSS 4 spürbar besser aus, aber FG funktioniert mit DLSS nicht richtig.
Wo DLSS 3.1.1 mit FG Framelimit erreicht und die GPU mit paar Watt rumdümpelt und es sich gut anfühlt habe ich mit DLSS 4 und ingame FG massiv weniger Frames als ohne FG und mega Input Lag.
Also DLSS 4 scheint mit FG probleme zu haben in Ready or Not. Habe DLSS 4 an gelassen in Ready or Not und FG abgeschaltet. Komme trotzdem auf 138 FPS, aber halt wird die GPU mehr gefordert, aber sieht halt lecker aus.
Bei CP 2077 wo es im Game implementiert ist und man nicht via Treiber es erzwingen muss gibt es aber keine Probleme mit FG. Da ist alles top.
Bei Indiana Jones zb. zeigt mir an das es geht
Leider bei Indy dasselbe bei mir.
Naja, erstmal schlafen gehen und am WE schauen was da los ist.
Ich geb es jetzt auch erst mal auf. Mit DDU Treiber deinstalliert und alles noch mal frisch installiert: kein Unterschied. Nicht ein Game supported es. Was sind denn so Titel wo es auf jeden Fall funktionieren müsste?
Hm habe den Treiber über die App aktualisiert. Ausgewählt ist Game Ready Treiber bei mir.
Geht bei mir auch nicht und auch im MRTV Discord geht es nicht bei den Leuten.
NV Inspector und Global eingeschaltet und das wars. kein gefummel mehr und es geht bei allen Spielen!
Woran erkennt man denn, dass es geht?
ohne entspr. overlay eigtl. nur an der qualität. ansonsten ist eine seite vorher im anhang einer meiner posts das regfile für das dlss overlay zu finden, damit prüf ich das gern mal kurz. reg file zum ausschalten auch mit drin, im startmenu eine verknüpfung dafür angelegt macht's auf dauer ein wenig einfacher finde ich.
bei witcher 3 gibt's allerdings mit den neuen dll files problemchen: nach vier fünf stunden fängt das bild an zu flattern / flimmern, doppel- und dreifach-abbildung seitlich verschoben, kA wie ich das erklären soll :d kam jetzt zwei mal vor, trotzdem aber bis dahin mit dlss4 einfach nur sexy, wirklich gute bildquali und sonst keine anderen probleme 👍
Bezüglich Slotblende Zotac 4090:
Ich habe mal auf Verdacht zwei verschiedene Blenden bei AliE bestellt um entweder was zu basteln und/oder zu hoffen, dass so etwas passt.
Ich berichte...
Finde ich komisch, weil bei mir gehts, aber zb. geht bei mir kein RTX HDR, wenn ich dieses für das Spiel einschalte. Er übernimmt das einfach im Spiel nicht.
Es funktioniert nur, wenn ich das über den Filter mache bzw das Overlay aktiviere mit Filter. Problem ist aber mache ich das über den Filter, dann macht der das bei mir Global und das beißt sich dann mit nativ HDR Games und mit Games wo Auto HDR aktiv ist. Ist wohl noch optimierungsbedarf bei der Nvidia App.
Mache es dann nun so, wenn ich RTX HDR verwenden will für ein Spiel aktiviere ich gerade das Overlay.
Sobald ich dieses Spiel dann beende mache ich dieses dann wieder aus, damit ich mit anderen Games keine Probleme bekomme.
Wie kann ich denn im Inspector das K Preset wählen? Das ist bei mir nicht hinterlegt. Auch nicht mit der neuen XML Datei.
Und im Guru3D Forum hat hier einer ne neuere Version vom Nvidia Inspector 2.4.2.3. Kann die aber nirgends zum Download finden.
Hier findest du alles!
ja, nice :) sind wirklich angenehme zeiten für generations-überspringer: es kamen ja doch so einige neue sachen, aber es geht scheinbar noch weiter! über treiber einschaltbares "framegen":
UPDATE #2:
NVIDIA told us that support for the RTX40 series GPUs will be coming in a future update.
“NVIDIA Smooth Motion is a brand-new driver technology and requires time for validation and QA across multiple products. Support for GeForce RTX 40 Series GPUs will be coming in a future update.”
hört sich wie ich finde ganz gut an, mal sehen wie das wird :bigok: :banana:
Joa man scheint diesmal als 4090 Käufer nicht in die Röhre zu schauen.
MFG ist eh für die meisten unbrauchbar und normales FG ausreichend, wenn man es überhaupt nutzen will.
Sind bei mir sehr wenige Spiele. CP2077 ist da auch so ein Ausnahmetitel wo es sehr gut funktioniert.
Gerade nun auch nach dem DLSS 4 Update.
Glaube viele die ihre 4090 verkauft haben im Vorfeld ärgern sich sehr, weil selbst eine 5080 ist langsamer als eine 4090.
Etwas wehmütig bin ich schon, aber meine 4090 FE habe ich gerade für 2400€ verkauft, nach über 2 Jahren Nutzung :fresse2:
Kumpel hat paar 5080 für MSRP (1169€) bekommen und gibt mir übergangsweise eine ab
Komisches Gefühl die 4090 FE verkauft zu haben jetzt wo die 5090 Verfügbarkeit und Preise eher unterirdisch ist, aber der Erlös war gut 🤷‍♂️
Das ist echt krank! 2.400 Euro für eine gebrauchte RTX 4090 FE! Ich kann nicht mehr :lol::wall:
Dont hate the Player, hate the Game!
5090 3.500€ nicht verfügbar
4090 2.400€ verfügbar
Das kann man keinem übelnehmen, nur NVIDIA.
Wären gestern 5090 FE gedroppt und dann zwar auch gleich genug, damit jeder eine bekommt, zum MSRP, kannst bei den Preisen überall 1.000€ abziehen und wir hätten nicht diese absurde Situation. Stattdessen würden wir uns alle freuen können mit den neuen Karten bereits spielen zu können.
Ich verfluche NVIDIA für das was sie abziehen, 150-300x 5090 oder was es gab weltweit. Die wissen genau wie hoch der Bedarf bei uns Gamern ist, mit ausreichender Verfügbarkeit hört sich das Gescalpe auch auf. Ursache (nicht Schuld) ist NVIDIA, wenn sie quasi mit 10x Karten auf den Markt gehen. Hätten sie in 3 Monaten released mit 50.000-100.000 Karten, wäre die Welt (auch bei GPUs) so wie wir sie von früher kannten. Leider läuft die letzten Jahre alles aus dem Ruder und das ist alles selbstgemacht!
In dieser Version des Inspectors ist das K Model schon enthalten, wurde Gestern geupdatet.
Am Ende war es noch Jemand, der seine 4090 verkauft hatte für die 5090 und keine bekam. :d
Meine Güte wie viele Versionen gibt's denn davon? Der AiO NVPI funktioniert bei mir nicht. Startet kurz und dann beendet es sich wieder. Net 8 ist installiert.
war das nicht net9 das nötig ist?
:ROFLMAO: So ein armer irrer der seine für 1600€ verkauft hat und nun 2400€ bezahlt hat , das wäre dann der Fail König :shot::fresse2:
So, jetzt bin ich aber auch verwirrt. Gestern nach der Treiber Installation ging es mit DLSS Override. Jetzt nach einem Neustart plötzlich not available :confused:
Genau deswegen hab ich das aufgegeben. Da scheint ordentlich etwas verbuggt zu sein. Hat NVidia wohl nicht anständig getestet.
Jepp, bei mir auch keine Veränderung, selbst wenn ich wie hier vorgeschlagen direkt bei der Installation auf optimieren gehe. Ich lass es auch erstmal.
Es geht ja zum Glück auch anders, von daher eh halb so wild.
Ich bin
Bin die Woche nach vielen Jahre Konsole mal wieder auf einen Gaming PC umgestiegen.
Habe ihn gebraucht für 2150€ gekauft. Vielleicht sollte ich meine 4090 auch mal online stellen 🤣 Aber bin viel zu begeistert von der Leistung mein letzter Rechner hatte eine GTX 690 😅
Gigabyte RTX 4090 Gaming OC 24G
Ryzen 7 7800X3D
Gigabyte X670 Aorus Elite AX
be quiet 1000Watt dark power 13
Fratal Torrent Black Solid
Samsung 980 Pro 2TB SSD
Thermalright Perlest Assassin 120
32 GB G.Skill Flare X5 DDR5 6000mHz CL30
