[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Werde es erst am WE testen können, aber ich hoffe auf ein customizable OSD.
Ich habe mit meiner Nvidia 4090 seit einiger Zeit ein ungewöhnliches Verhalten. Die Lüfter springen gelegentlich auch beim Browsen, mit niedrigster Drehzahl, kurz an - was normal ist. Einer der beiden Lüfter dreht jedoch nach dem Anlaufen für 1-2 Sekunden auf 2200rpm auf, was deutlich hörbar ist.
Habt ihr dafür eine Erklärung?
Hallo! Ich habe ebenfalls ein Problem mit meiner Zotac 4090, ggf. hat jemand mal ähnliches beobachtet oder davon gehört.
Kurze Version. Die Graka lässt das System beim Spielen random Freezen, wenn ich den VRAM (mittlerweile) nicht unterhalb Spezifikation untertakte.
Lange Version. Damals nach dem Kauf @ Stock/ LuKü auf Funktion getestet, dann auf Wasserblock umgerüstet. Erst anschließend mal mit OV/UC beschäftigt. Die Karte war immer schon ein VRAM-Krüppel. +1000 MHz Memclock im Afterburner ließen bereits beim Bestätigen Windows einfrieren. Ich habe dann monatelang mit +500 MHz gespielt. Irgendwann fingen Probleme an. Bei Release des Cinebench 2024 z. B. hat der GPU-Test das System dann komplett gelockt. VRAM @ Stock, Cinebench lief. Ob GPU V/F-Curve getweakt oder stock machte keinen Unterschied, es war eindeutig VRAM. Dann eine Zeit lang mit VRAM +0 MHz gespielt (also Stock).
Mittlerweile bin ich bei -250 MHz VRAM, da sonst Spiele random einfrieren. Insbesondere Diablo 4 ist da sehr auffällig. Manchmal freezt der PC schon bei einem Ladescreen - also ohne wirklich VRAM-Belegung o. ä. Alles andere (CPU, RAM, Software) habe ich ausführlich getestet. Das Einzige, was reproduzierbar hilft (wenn man davon sprechen mag bei solch willkürlichen Problemen) ist VRAM-Entschärfung. Diablo 4 dann ewig ohne Probleme möglich. Tendenziell wird es aber schlechter, als würde etwas degenerieren. Interessanterweise aber ohne die klassischen VRAM-Anzeichen, d. h. keine Artefakte, kein Space Invaders, keine Blöcke/ Striche o. ä. Das Problem zeigt sich wirklich "nur" durch Freeze/ Standbild. Ab dann muss der PC auch hart abgeschaltet werden per Power-Button. Die Grafikkarte ist ohne Riser verbaut.
Grundsätzlich könnte man wohl sagen, da stimmt etwas nicht. VRAM-Spezifikation (21 Gbps) wird nicht (mehr) eingehalten -> RMA. Durch den WaKü-Umbau natürlich etwas anders gelagert (Zotac gewährt 5 Jahre Garantie für Erstbesitzer, aber Kühlertausch ist untersagt. Siegel sind allerdings nicht angebracht, man könnte also zurückbauen). Momentan behelfe ich mir mit dem VRAM-Workaround, dann funktionieren auch Zicken wie CoD BO6. Aber insgesamt natürlich unbefriedigend.
Hatte das gleiche Problem mit meiner Zotac 4090. PC komplett eingefroren oder Bildschirm einfach schwarz. VRAM Takt senken hat bei mir anfangs auch geholfen. Manchmal konnte ich stundenlang ohne Fehler zocken, an anderen Tagen dann wieder nur Minuten. Musste die Karte dann auch einschicken. War letztes Jahr im September, die Austauschkarte läuft seit dem ohne Probleme.
Auch bei Grafikkarten kann man eben mal ein "Montags" Modell erwischen. Da hilft dann nur ein Austausch, was hoffentlich bei der Verfügbarkeit noch möglich ist.
Laut Bestimmungen seitens Zotac 3 Jahre Herstellergewährleistung + 2 Jahre Garantie (wenn man die Produktregistrierung rechtzeitig gemacht hat -> Check). Da befindet man sich zeitlich noch in der Herstellergewährleistung - d. h. man muss sich erst einmal an den damaligen Verkäufer (hier: Alternate) wenden und die leiten dann an Zotac weiter (falls sie nicht vorab schon den Stecker ziehen, s. u.), richtig?
Praktisch habe ich bei mir alle Ansprüche durch WaKü verwirkt (streng genommen ja schon durch Nutzung von OC-Tools). Das bedeutet natürlich nicht, dass man es nicht trotzdem mit der RMA probieren kann, sauber auf LuKü zurück gebaut.
PS: Gekauft 15.12.2022, d. h. jetzt kurz vor Vollendung der ersten 24 Monate. Sollte ich das Prozedere aus rechtlichen Gründen jetzt noch kurzfristig anleiern, oder spielt das bei den o. g. Bedingungen von Zotac keine Rolle?
@Iceman021
Ich habe es damals über Alternate abwickelt. Hat ca. 2 Wochen gedauert. Meine Karte war allerdings erst 6 Monate alt. Würde aber auch zuerst Alternate kontaktieren und da mein Glück versuchen. Die genauen Garantiebestimmungen kenne ich jetzt nicht im Detail, aber ich würde es noch versuchen bevor die 24 Monate rum sind.
omg, ich hab seit beginn ja schon die hoffnung dass mit meiner kagg manli nix sein wird; den kühler davon abzubauen war die HÖLLE^^... bisher ist alles sauber, aber die zeit läuft auch in einem monat ab. bleib bloß bestehen du miststück...
Drücke dir die Daumen, aber wenn du bislang keine Probleme hast, soll es wohl weiterhin dabei bleiben. Der Zotac-Kühler war auch lästig, insbesondere ein blödes RGB-Kabel. Da bekam man den Mikro-Stecker kaum ohne Verformungen aus der Buchse heraus. Es könnte sowie sein, dass ich den Krempel nicht mehr vernünftig zusammen bekomme. Fällt dann wohl unter die Kategorie persönliches Pech. Den Service von Alternate musste ich auch noch nie ernsthaft auf die Probe stellen.
An sich wollte ich die 4090 noch bis zur 5090 mitschleppen und dann anschließend in Ruhe entscheiden, ob die 4090 a) so in den Zweit-PC wandert oder b) erst noch eine RMA probiert wird. Krissfix wäre im Zweifel auch noch eine Option.
die hoffnung besteht :) nachdem sie tats. immer noch mit seit besitz eingestelltem setting einwandfrei läuft, bin ich mittlerweile aber doch eher optimistisch.
bisher hab ich für mich die erfahrung gemacht, dass wenn lange nichts ist die geräte dann auch lange halten. selten macht sich nur langsam eine fehlfunktion bemerkbar (wie bei dir leider), oder eben ziemlich schnell nach einbau und dann auch meist gleich ein komplett-defekt: hauptsächlich aber passiert eben nichts und die hw lebt einfach nur lange.
dir aber erstmal ganz viel erfolg und glück a) beim rückbau und b) mit alternate! mit diesem geschäft hatte ich zumindest noch nie rma probleme, drück dir'nen daumen für die selbe erfahrung! :)
Bisher kann ich auch nichts negatives über mein PNY sagen, inzwischen auch schon wieder fast 1 1/2 Jahre alt. Man, die Zeit rennt. :d
Ich hab den VCore runter getaktet per Afterburner und den Speicher auf +1000, noch läuft selbst StarCitizen absolut stabil und das Spiel ist wirklich absolut zickig was OC/UC angeht, es kann alles andere stabil laufen, nur SC sagt noch immer "so nicht!". :d
Bei mir läuft das Dinge auch noch wie am ersten Tag. Sind schon zwei Jahre her.
Habe heute nach paar Jahren nochmals Shadow of the Tomb Raider installiert und NG+ angefangen. Sieht noch gut aus das Game.
Soo, Metaphor ist nun auch durch, jetzt kommt der Jahresendspurt mit Dragon Age, Stalker 2 und Indiana Jones.
Als Zwischenhäppchen dann noch das neuste Life is Strange und Vessel of Hatred. Und das war’s für dieses (sehr) schöne Gaming Jahr.
Ich muss es wohl taktisch klug anstellen und auch noch bisserl was für das nächste Jahr übrig lassen, dass nächste Game kommt erst erst Ende Januar (Greedfall 2), kurz danach kommt aber schon (das hoffentlich sehr geile) Kingdom Come 2.
Naja, was Spiele angeht... ich hab gerade vor ein paar Tagen mit Mass Effect LE angefangen, hab den zweiten und dritten Teil nie gespielt gehabt (EA Boykott). Aber da die Reihe eigentlich genau mein Ding ist, hab ich hier ne Ausnahme gemacht. Gibt einfach zu wenig Weltraum RPGs. Ob Mass Effect 1 aber weniger Ladebildschirme als Starfield hat, keine Ahnung, letzteres lass ich noch etwas reifen. :d
Mit ein paar Mods kommen gar nicht mal so viel FPS mit der 4090 raus, hänge irgendwo bei 90 FPS rum. Primär killt Reshade da die FPS um es ansehnlicher zu machen.
Metaphor glaube ich mein GotY, das war wirklich sehr gut . Muss echt mal die Persona Teile nachholen. Technisch natürlich leider auf dem Stand von vor 7-10 Jahren aber wenn man mal drüber hinweg sieht ist es echt geil wenn man generell JRPG affin ist. Aber 2024 war dennoch eher ein schwaches Jahr. Tekken 8 und Dragons Dogma 2 waren noch gut anfang des Jahres aber sonst hat mich nichts außer Metaphor wirklich abgeholt. Mal sehen wie Stalker 2 wird. Indiana Jones sieht vom Gameplay her langweilig aus
Ich werde dieses Jahr wohl auch nur 20 Games komplett durchgezockt haben:
- Like a Dragon: Infinite Wealth (26. Januar)
- Tekken 8 (26. Januar)
- Dragon’s Dogma 2 (22. März)
- Stellar Blade (26. April)
- Senua’s Saga: Hellblade 2 (21. Mai)
- Silent Hill 2 Remake (8. Oktober)
- Dragon Age: The Veilguard (31. Oktober)
- Indiana Jones and the Great Circle (9. Dezember)
- Warhammer 40,000: Space Marine 2 (9. September)
- Metaphor: ReFantazio (11. Oktober)
- Life is Strange: Double Exposure (29. Oktober)
- Stalker 2: Heart of Chornobyl (20. November)
- Final Fantasy VII Rebirth - 29. Februar 2024
- Frostpunk 2 (20. September)
- Age of Mythology: Retold (4. September)
- Astro Bot (6. September)
- MechWarrior 5: Clans (3. Oktober)
- Diablo 4: Vessel of Hatred (Erweiterung, 8. Oktober)
- Dragon Ball: Sparking! ZERO (11. Oktober)
- Call of Duty: Black Ops 6 Kampagne (25. Oktober)
An das epische Gaming Jahr 2023 kommt es aber diesmal tatsächlich nicht dran. Sei‘s drum 😏
Meine 4090 kommt bei mir quasi nie zu Ruhe und dafür ist sie ja schließlich da, gelle? 🤘
Von der Liste hab ich genau 0 gespielt. Mein Backlog ist so riesig, dass ich die nächsten 10 Jahre genug zu spielen hätte. :d
Zudem Konsole Spiele im 4090 Thread zu nennen, ist doppelt strange. ;)
Ich bin davon ab jedes neue Game zocken zu wollen. Ich wäge schon sehr ab und zocke vielleicht 5-7 Games pro Jahr. Und der Rest ging bei mir in Street Fighter 6 und Hunt Showdown. Singleplayer Storygames packen mich nur noch selten. Da Monster Hunter Wilds in der Beta schon recht gut auf der 4090 lief, bin ich auch eigentlich nicht besonders heiß auf die 5090. Der 9800X3D sollte reichen für gute Frames, da das ganze ja ziemlich CPU limitiert war.
Ich zocke halt viel und hart (habe zb gar kein Backlog, nie gehabt) , dabei aber tatsächlich nur Singleplayer Games.
Bei mir lohnt sich definitiv eine 5090. So ist halt jeder anders gestrickt. 👍
Vielleicht werde ich mit dem Alter auch irgendwann ruhiger und zocke dann weniger, ehrlich gesagt hoffe ich das aber nicht. Bin aber auch erst 42. 🥳
Meine bisherigen Highlights waren übrigens das Warhammer Game und definitiv Astro Bot auf der PS5.
Ein Goty lege ich erst später fest, vor allem fehlt ja noch Stalker 2!
Was ich mich halt immer frage, mit nem full time Job, wie will man denn da noch "viel und hart" zocken?
Bin aus sämtlichen DCS Squads gleich wieder raus als ich gesehen habe wie oft die sich treffen und Missionen spielen wollen. Keine Ahnung was das für Leute über 30 sind, die so viel Zeit in ihren PC investieren können.
Home Office und (sehr) viele ruhige Phasen im Job 😏
Burn Out überlasse ich schon immer gerne anderen, ich mag es entspannt und gediegen im Job wie im Leben. Bin ein extrem gemütlicher Mensch, immer gewesen.
Meine 4 Geschwister sind noch deutlich krasser unterwegs, von denen macht inzwischen jeder nur noch Teilzeit nachdem mein Vater unter anderem durch Überarbeitung 3 Tage (!) vor der Rente vor ein ein paar Jahren gestorben ist, das prägt einen sehr nachhaltig…
Ich zocke viel, lese viel, mache viel Urlaub im Jahr und arbeite recht wenig. Gibt schlimmeres 🤘
@ssj3rd
Scheint der heilige gral zu sein. Wenn es finanziell und sonst alles auch klappt, dann glückwunsch zu diesem Status und Lebensstil
Bin bei genau 3,1K netto monatlich, der Rest um mich herum verdient teils deutlich mehr, aber die arbeiten eben auch teils bis zum Blut/burn out…
Im IT Bereich ist das recht wenig Asche habe ich mir sagen lassen, aber für mich reicht es aus und eine xx90 GPU ist auch easy drin alle 2 Jahre.
Mein Traum wäre, dass GPUs irgendwann stark genug sind, um Lieblings-Games von früher mit Echtzeit-AI-Upscaling zu zocken 😍 (also ähnlich den schon vorhandenen Upscalern - nur halt noch inkl. AI)
Jedes Pic wurde jeweils 5x durch https://www.krea.ai/apps/image/enhancer gejagt. Das erste Pic ist jeweils das Original...
Anhang anzeigen 1038411Anhang anzeigen 1038410Anhang anzeigen 1038409Anhang anzeigen 1038408Anhang anzeigen 1038407Anhang anzeigen 1038406
Anhang anzeigen 1038405Anhang anzeigen 1038404Anhang anzeigen 1038403Anhang anzeigen 1038402Anhang anzeigen 1038401Anhang anzeigen 1038400
Anhang anzeigen 1038418Anhang anzeigen 1038417Anhang anzeigen 1038416Anhang anzeigen 1038415Anhang anzeigen 1038414Anhang anzeigen 1038413
Ok, aus "San Andreas" wurde irgendwas anderes. Kann ich nicht entziffern... :fresse:
Anhang anzeigen 1038432Anhang anzeigen 1038431Anhang anzeigen 1038430Anhang anzeigen 1038429Anhang anzeigen 1038428Anhang anzeigen 1038427
Kann es kaum erwarten :)
Theoretisch sollte jedes alte Game mit Echtzeit-AI skalierbar sein
Zocke gerade DA Veilguard, läuft extrem geschmeidig mit 90-110 FPS DLSS-Q/FG 4K@maxed out.
Und es sieht umwerfend aus und spielt sich bisher sehr unterhaltsam.
Ist übrigens kein Spiel was man mit M+T zocken sollte, ist deutlich! angenehmer mit Controller.
3,1k monatlich ist im IT Bereich recht wenig? Wo lebst du? Ein Durchschnittsgehalt eines IT-Systemadmins/Fachinformatikers liegt bei 42k-46k Brutto. Das sind je nach Lohnsteuerklasse bei 44k€ Brutto 2,5k€ netto. Du verdienst weit über dem Schnitt. In meinem Freundeskreis verdienen die ITler 38-52k€ Brutto im Jahr..... Ich selbst bin Systemadmin, hatte aber das Glück das ich extern bei einem anderen Unternehmen war und dringend ein Itler gebraucht wurde. Also konnt ich mir das Gehalt glücklicherweise fast aussuchen :)
Nicht jeder ist Systemadmin. Als Projekt/Servicemanager kannst du deutlich mehr verdienen. Vor allem in größeren Firmen.
Punktlandung.
Ich bin genau in diesem Umfeld unterwegs: Projektgeschäft.
Hier verdienen IT‘ler von 60-115k, je nach Position und Verantwortung.
Und ich bin da absolut im unteren Spektrum unterwegs.
Aber es ist schon „lustig“: Je höher das Gehalt, desto mehr gesundheitliche Probleme. Da könnte jemand eine tolle Dissertation darüber schreiben.
Mir ist entspanntes Arbeiten...
...und viel Freizeit auch lieber und wichtiger. Ich "arbeite" effektiv 3-6h die Woche, bei durchschnittlich 3.700-3.800€ netto im Monat 🙈
Ich gebe zu, dass ich 5.000 (und mehr) netto auch gerne nehmen würde, aber nicht für viel Verantwortung und arbeiten am Limit. Das wäre es mir nicht wert...
Wenn Leute von gerade mal 38 Jahren "abkratzen" und man selbst älter ist, macht man sich schon Gedanken und setzt Ziele eher in naher Zukunft
