FB07
Legende
- Ort
- NRW
- Laptop
- MacBook M5 Pro
- AMD Ryzen 5 7600X
- ASUS ROG Strix B650E-I Gaming WIFI
- be quiet! Pure Rock 2 FX
- G.Skill Flare X5 DDR5 32GB @6000MHz
- GIGABYTE GeForce RTX 4070 Windforce OC
- LG 27GL850
- Samsung SSD 980 PRO 1TB
- FD Torrent Nano Black TG
- be quiet! Pure Power 12M 550W
- Keyboard
- Varmilo Moonlight VEM88
- Mouse
- Logitech MX Master 3S
- Windows 11 Pro
- Sonstiges
- 3x be quiet! Light Wings
- Internet
- ▼500 ▲100
Ja da hast du recht aber ich kann Entwarnung geben, habe in einem Forum eine Antwort von IMS gefunden zu diesem Thema
Thank you for pointing out this blog conversation, I confirm to you that we don't have any problem with the nanotech coating, it does not peel nor crack, we switched to this technology also for this positive feature.
the only issue is visual, since the rainbow colouring is a side effect of the coating, some item has it more evident and some other not, also sometimes it is a bit irregular, with gray parts on it, it does not affect the result, it is just a visual effect.
-> The Quartz Nanotechnology is much more resistant than Teflon or PTFE but still is a coating, so you can use a detergent if you need it but we still suggest to be careful with brushes as they might scratch the surface. Even with scratches the coating will not peel off but it will be removed only the part that has been scratched
( helle fruchtige Sorten ). Ich traue mich irgendwie nicht so richtig
Das hat für mich dann mehr von Früchtetee als von Kaffee.
