[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich dachte das ist längst klar, dass es ein Soulslike ist?
Mhm, dann machen die aber einen sehr schlechten Job mit der Kommunikation da in China. Wie kann denn eine Woche vor Release nicht klar sein, was für ein Spiel das überhaupt ist? Finde ich sehr komisch.
Ist aber auch Streitthema, was überhaupt Soulslike ausmacht. Manche meinen damit, es sei das Kampfsystem mit Blocken, Parieren und der Ausdauerleiste, andere wiederum die Art des Levelns durch "Bonfire" und Respawn der Gegner, oder auch den Aufbau der Welt. Aus dem oben verlinkten Artikel geht hervor, dass es schon Soulslike Anleihen hat, jedoch nicht in allen Hinsichten konsequent durchgezogen wird, wie beim Levelaufbau.
Mir persönlich reicht schon, wenn das Kampfsystem Soulslike ist, da es eins der besten Combat Gameplays im Gaming darstellt. Bitte nur bloß kein Assassins Creed Button Smashing Crap!
Absolut richtig, extrem verworrene Kommunikation.
Aber wenn man darüber nachdenkt dann auch wieder nicht:
Man will keine von beiden Parteien abschrecken, jeder soll es kaufen, vorzugsweise natürlich sogar vorbestellen.
Muss ja auch nichts schlechtes sein, wenn das Game sich nicht eindeutig in Kategorien pressen lässt. Sehe das erstmal optimistisch. Presales jibbet bei mir eh net, von daher, çay trinken und abwarten.
Vorbesteller haben ja auch einen eigenen besonders warmen Platz in der Hölle 😈👹
Besonders PS5 Vorbesteller kaufen ja aktuell wohl die Katze im Sack :ROFLMAO: Kein PS5 Gameplay gezeigt und nur digital Käufe also auch kein Weiterverkauf. Dazu die Unklarheit was das Spiel überhaupt kann außer (auf dem PC) gut auszusehen. Das ist echt mutig
Ganz ehrlich, dafür habe ich echt kein Verständnis. Gerade nach dem Cyberpunk Debakel auf den Konsolen würde ich als Vorbesteller nie mehr wieder in diese Falle tappen.
Am PC kann man ja noch mit entsprechender Hardware viel an Rohleistung ausbügeln, aber auf der Konsole biste komplett auf die Optimierungsfähigkeiten der Studios angewiesen.
Einzige Games, die ich auf der PS5 vorbestellen würde, wären die Sony Exklusives, da dort in der Regel wirklich gut optimiert wird.
Gibts irgendwo noch das klassische NV-Driver-Archiv?
Bei dem neuen "Design" bekomme ich max. 3 Treiber auf eine Seite. Anfang Juni konnte man sich min. 20 Treiber, gelistet anzeigen lassen
Ja, hatte ich nicht mehr gefunden... :)
Nur noch so...
btw:
Beim neuen Link steht "nsd" im Treiber-Namen...
Erst mal gucken, was das wieder ist
560.81-desktop-win10-win11-64bit-international-nsd-dch-whql.exe - 701.155.584 Bytes - vs - 560.81-desktop-win10-win11-64bit-international-dch-whql.exe - 701.186.056 Bytes
Scheint der Nividia Studio Treiber zu sein. Konnte ich bei der manuellen Suche nicht abwählen :rolleyes2:
Ich hab schon vorbestellt ;)
Das wär der Thread deiner Wahl:
Kannst ja die mods fragen ob Sie es ändern wenn es dich stört:)
Sorry für die DAU Frage:
Hab ein 850 Watt be quite! Straight Power 11
An einem Strang habe ich 2x8 Pin (siehe Foto).
Insgesamt hab ich 4x8 Pin an zwei Strängen.
Ginge das so in Ordnung wenn man den Adapter benutzt? Weil ich gelesen hatte (zB bei MSI), dass man jeweils individuelle Kabel nutzen soll am Netzteil oder verstehe ich hier was falsch
Du musst nicht vier einzelne Kabel verwenden, aber das ist ein nerviges Multirail Netzteil, daher musst du tatsächlich darauf achten die Rails nicht zu überlasten. Die Rail Aufteilung steht im Handbuch:
Verwende also am besten die Ausgänge PCIe 1 und 3 mit jeweils einem 2x8-Pin Kabel, um eine gleichmäße Verteilung auf die Schienen 12V3 und 12V4 zu gewährleisten.
Danke dir.
@L0rd_Helmchen ich hatte die 2 Stränge tatsächlich nebeneinander auf PCIe 2 und 3 und hatte die CPU auf 1
Hab jetzt die CPU auf PCIe 2 und die 2 Stränge auf 1 und 3. Sollte dann so passen, oder? Frag nur wegen der CPU
bei welchen RTX 4090-Karten werden bereits Wärmeleitpads auf der GPU genutzt, um dem Hotspot-Temperatur-Wahnsinn mit Billig-Wärmeleitsuppe Herr zu werden?
Oder zumindest vernünftige Wärmeleitpaste.
MSI ist wohl einer der wenigen Hersteller, die bereits Pads auf der GPU nutzen.
Gruß!
Du meinst wo zb das Thermal Grizzly Kryosheet standardmäßig verbaut ist? Gibt es nicht, nicht mal im entferntesten….
Da benutzt jeder 0815 billo scheiß, ist halt billiger. 🫤
Laut Igor verwendet MSI seit der RTX 3090 Ti Wärmeleitpads.
Kann mir bitte jemand, der z.B. eine MSI RTX 4090 GAMING X TRIO seit mehr als ein halbes Jahr hat, die Hotspot-Temperatur mitteilen?
Danke! :-)
ASUS, Gainward, GALAX, Inno3D, KFA2, Manli, Palit und PNY nutzen die billige Wärmeleitsuppe, die sich nach ca. sechs Monaten verflüchtigen kann.
Ohne Bilder/Belege ist das nur eine Behauptung.
Habe auch schon öfters gelesen, dass die Founders 4000er PTM verbaut hat. Nur sehen die Bilder davon irgendwie nicht so wirklich danach aus.
Dass nVIDIA selbst keine Pads auf der GPU verwendet, beweisen sie mit dem folgenden Video selbst:
Fals jemand intersiet Black Myth Wukong hat einen gratisbenchmark auf steam
Kann sich doch sehen lassen hab mit weniger FPS gerechnet nach den Anforderungen die der Hersteller gezeigt hat nur schade das es kein Vollbild Modus hat das spiel
Ohne RT:
Mit RT:
Das Spiel scheint gut auf ReBar zu Reagieren hab nochmal 3FPS mehr gebracht
