[Sammelthread] Intel DDR5 RAM OC Thread
Thanks! I will copy your values to run Y-Chruncher. There was a debate in OCN that it should always be run unlimited, for short tests it can work (4 cycles), but for tests of 90 minutes or 6 hours, without a doubt your configuration is the best. I'm going to see if it generates any WHEA for me
Ok, I'm also interested in how it works for you.
You are in luck with the SP105. Why is this good? I already recognized it, I tested the minimum values for my cpu for a couple of frequencies. For me, the minimum Vcore (Vmin) for the 54x Y Cruncher is 1.09V. Less is enough for you, so it's cooler. It is the same on the default 57x. For example, even with 8C water, the default, throttled, is 100C immediately. This is SP93.
Default Settings
Regarding degradation, all I know is that after more than 6-700 hours of Y, the 57x Vmin has not changed at all. When I bought it, Vmin was 1.18V, currently it is still 1.18V on Vmin Cinebench.
As new - not delided yet
Now - delided
I don't want to persuade, convince, etc., I use it this way, I test it so.
For example, I don't write a single letter on ocn. I don't want a conflict with anyone. I'm not on the DDR5 forum, but I read it sometimes. In DDR4, when I posted the 90-minute Y test, I was the stupidest person in the world.
I don't think anyone has that many Y Cruncher kilometers in their cpu, but there is no degradation. Well, that's enough about this topic.
Well, what I did was Load Optimized values, set LLC4 and read the value of AC_LL in the OCTool. Since it gave me 0.2689, before, I had tried lowering it, but it had instabilities. Precisely, what I wanted to do is a UV with the curve. I just saw yours and it is very different, because it starts higher up. I don't know how the CPU behaves at frequencies up to P4.
A positive offset from 1600 helps. Don't have a lower Vcore, always raise it.
These minimum values must be experienced and known.
Can I ask you why you set Ring mim so low? I just left all in auto..
AUTO=8.
Idle 800MHz. Core Clock is now 1100MHz, because Speed Shift is on. Off = CC 800MHz too.
I like it better if there is value than the auto. It doesn't matter.
There I do want to put the entire load of YC testing. To test the CPU, SFT is better, right?
SFT is the 99.99% good Vcore. SFT stable, it means a little more Vcore for me, so I'm writing quietly, I took a little off it.
I like to set the machine to optimal, not to extreme oc. It's also good, fun, but not 24/7.
I see on forums that 6.2GHz allcore daily, but I ask myself, why? Its added value is 99% unnecessary, because almost everyone plays in 4k, with a total gpu limit. The extra 10-20 fps on the cpu side is pointless if the gpu can't handle it.
Well, yes, that's another topic. I'm not against oc, I just don't do oc unnecessarily. If I see the advantage of 57 or 60x, I will set it there.
These lines were my own thoughts, don't be fooled. As I started this post, this is how I do it. I like it when the cpu is cool, performs easily and works, rather than dying at 100C.
Aktuellste Bios war schon auf dem GA drauf?
Ja, war schon drauf. Das Board ist laut Seriennummer von Januar diesen Jahres. Das aktuellste BIOS wurde im Dezember veröffentlicht.
VDDQ Training AUS
Roundtriplatency Training AN (RTLs sind kapput auf Giga's Seite)
Das werde ich mir nochmal anschauen, danke.
SA habe ich schon auf 1,18 gesenkt, Xmp sind immer 1,3.
Es gibt ja auch ein paar Ergebnisse von Madness mit Gigabyte Boards in denen er sogar die Spannungen mitliefert. Konnte leider keine der Varianten zum laufen bringen.
Default Settings
Now - delided
AUTO=8.
Hi @zebra_hun, thanks for all your information! I just did a lot of test to compare with your screenshots. Indeed, as I have an issue with the "Trained" SVID Behavior, which is why I can't run R15 Extreme or CB24 because I either have a crash or BSOD. Therefore, since I didn{t want to execute an SVID offset, I selected "Typical Scenario", and with that voltage increase everything happened, yes, my Vcore increased.
Another test I did was in the other BIOS, I installed BIOS 0801 to see the behavior of the SVID, and I have a difference with the last version 1102. I configured everything again, and I am now testing Y Cruncher with 54-44-48 (automatic ring) . With CPU Current Limit (ICCMAX) set to 400A, PL1 300 PL2 320, the Package power while running VST is 275W. Now looking at the execution, in 54x/44x VT3, I am at 1.17xv, very different from what you told me about 1.14/1.15v for 55x. Could it be that it's consuming me more because of that? Or maybe your lower AC_LL allows you to have lower power draw? Now I take a screenshot while it runs so you can see it.
I'm going to sleep since it's early morning here :-) , but tomorrow I'll upload all the photos so you can see them, I took many.
PS: Then would you tell me about your tests with CMDVrefUp in 112? What benefit did you notice about the CTL0 that Veii shared with us? I mean, how does it help?
Thank you!
8200 TM5 durch, jetzt karhu
@Mtorrent
I prepared 3 tests for you with Vcore/Watt.
If the Vcore is unnecessarily high, it will heat up unnecessarily and consume a lot of electricity.
1.20V 292W
1.17V 276W
1.15V 265W
I raised the frequency on purpose, because Hungarian forums are also laughing at why 54x. Because that frequency is enough. Yes, there are better bit rates here, but if I never deviate from 54x, then you can compare the acceleration and possible slowdown.
It is also worth looking at the Watts and the temperatures.
OK, let's see on 56xP 44xE 48xR
SFT is a pig load, there the 1.15V dropped down to 1.128V.
I made a custom curve for this, controlled with AC LL.
0.40, 0.30 and 0.14
Above 5600MHz it's not nice, but I didn't care about that now, just to not be low there.
Edit:
Huh, this is going to be hard, but I'll try to describe my experience.
Sorry, I use Google translate because English is not my native language, so misunderstanding is possible.
Vcore/stability topic:
In principle, the sp105 is stable even with a lower Vcore.
But, for me, cold water and "delid" cpu help a lot.
This is where things get complicated.
Thinking back, when I made the 7600 profile, for example, I used too high Tx, SA, VDD voltages. It was not properly tested, finding the optimal voltage.
Even then, I tried to undervolt the cpu, but I was not able to bring it down like now.
I compensated the unstable ram oc with Vcore.
I didn't even pass the 6-hour long test, the maximum was 3.5 hours.
Now this 8000C36 is totally different, it behaves better with much lower voltages. It ran several times for 6 hours, many for 90 minutes. Vcore can also stay "low".
Even colder water was then available to me. Today the water is 15°C.
The entire cooling system is in the basement, I open the basement door in winter, it helps a lot. Condensation is dangerous, but that's another topic.
To your question, how do CTL0 and 1 help, well in that it's not auto. If there is a value there that is also correct, then it is better than "auto".
Even if it's auto, it's stable. It might help a bit with speed, although I'm not a DDR5 expert, but it can help ramps up and down. Low and High maybe at the signals. Maybe the signal is clearer. I guess I don't know.
9903 ist die neuste beta version (diese ist neuer als 2102) - sieht man auch in meinem archive , da ist sie gekennzeichnet :)
einmal die beta 9903 und einmal die offi version 2102
die 9903 basiert auf der 2102 und ist optimiert für den ks , bei mir laufen beide recht gut.
Stell mal dein karhu richtig ein du testes nicht den kompletten Speicher
hab parallel videos geschaut, als ich gestartet habe war noch 300mb frei, somit sollte das wohl passen, hat es bisher zumindest... siehe auch readme von der karhu page selbst...
joa so passt das , ich versteh nur nicht was du für videos geschaut hast weil 8gb ram für nur videos sind schon echt hart xD , ich mach das auch immer so das ich youtube oder netflix oder so offen habe und reservier dem ganzen dann ~1gb ram
chrome mit etlichen tabs, viel youtube vorgeladen discord parallel offen... beim screenshot hab ich grad chrome beendet und den screenshot gemacht...
Bei 8400 schau ich morgen mal das ich mich ins Wohnzimmer auf die Couch setze und dann halt immer wieder schaue...
ich find 8gb trotzdem sau viel für paar tabs und ein video lol , aber gut - du wirst ja am besten wissen ob und was bei dir im hintergrund werkelt.
schau mal bei mir : das sind 8 tabs + netflix
selbst 2gb wären viel.
ich sag ja vermülltes windows isses auch, chrome brauch da deutlich mehr :ROFLMAO:
Die Post hat was Schönes aus Frankreich gebracht:
Komme leider frühestens nach Ostern zum Einbau :cry:
Bin grad am überlegen ob ich mir das antue meine Speichereinstellung etwas zu optimieren. Beim DDR4 weiß ich noch war das schon sehr ätzend sich aus dem Thread die Infos zu suchen und hier wieder 500 Seiten. Naja man hat ja sonst nichts zu tun.
Frag vorab: lohnt sich das überhaupt, hab zur Zeit keine aktive Kühlung an den Riegeln? Sollte man sich da erstmal Gedanken machen, oder kann man auch so schon etwas rausholen? Wie sind da eure Erfahrungen was Ram Kühlung angeht und was habt ihr da so installiert? Weiß noch dass es beim DDR4 zwar auch Thema war, aber soll wohl bei DDR5 noch sensibler sein.
Sorry, habt ihr bestimmt schon 1000x erörtert. Werd mich die Tage wohl in das Thema reinstürzen und gucken was geht. Hab zwar nix besonderes installiert aber vielleicht hol ich noch etwas aus den Hynix M Dies raus.
Für generelle Tipps für den Start wäre ich jedem äußerst dankbar.
Edit
Zum schnellen antesten werd ich wohl ycruncher und prime nehmen.
@Mtorrent
1.20V 292W
1.17V 276W
1.15V 265W
0.40, 0.30 and 0.14
Edit:
Hi @zebra_hun, thank you so much for the test! Below a lot of pictures for you to compare. I guess you will find Vmin better than me and how my CPU is running. I'm far away from an expert, but I learn fast :)
I have been back with Intel since September of last year, before that with AMD since 2020. So, trying to learn day by day. First I focused on mem OC, but I realized that the CPU, or my knowledge about the CPU, is limiting me (and the IMC)
From what I see, you are running your processor with much less power draw, could it be because of the delid?
In my case, I don't have any professional to do it well for me. I dare to do it, but I don't want to break the processor, and from what I read about Veii, you have to be careful. Many do it just like that.
I'm going to take your VF, Tibsci's and another one that Carsalesman shared with me, so I look for the target points, to be able to adjust my curve. Because it works very well up to 5800, but it goes a little bit at 6000. From 5600 to 5800 I have a difference of 35mV, and from 5800 to 6000 I have 74mV. Much better than the KS I'm looking at, where they hit 200MHz jumps at 100mV. The issue with the UV is to compensate with AC, because I don't know if it can run CB15 Extreme (just to test the efficiency, no point in testing this, right?). What matters most to me, and I agree with you, is looking for good efficiency. And even more so when I don't have good cooling capacity. I should invest in this. The delid, plus the first steps in Water Cooling (corrosion, water flow, leaks, temperatures, fittins) all that limits me.
Köszönöm a segítséget! Mindig hallottam apámat magyarul beszélni, hogy helló, itt Fodor. Fonetikusan hallgattam "Keichocolom, Fodor veches". I'm a Hungarian citizen, I don't know anything about the language, and the community in Argentina is very small. On OCN you can find me as @lmfodor
You will notice that I have a 60x boost on all cores. That's because I opened the Asus OCTool before. For some reason it must go core by core. I am using your same BIOS settings to limit the cores, 90C, Current to 420A, 300/320W and SVID Trained. Y-Cruncher runs very well, at least I don't have thermal throttling.
[2024/03/24 09:24:35]
Ai Overclock Tuner [XMP Tweaked]
XMP [DDR5-8200 38-49-49-84-2N-1.40V-1.40V]
BCLK Frequency [100.0000]
PCIE Frequency [100.0000]
Intel(R) Adaptive Boost Technology [Auto]
ASUS MultiCore Enhancement [Enabled – Remove All limits (90°C)]
SVID Behavior [Trained]
BCLK Frequency : DRAM Frequency Ratio [Auto]
Memory Controller : DRAM Frequency Ratio [Auto]
DRAM Frequency [DDR5-8200MHz]
DIMM Flex [Disabled]
Performance Core Ratio [By Core Usage]
1-Core Ratio Limit [57]
2-Core Ratio Limit [57]
3-Core Ratio Limit [56]
4-Core Ratio Limit [56]
5-Core Ratio Limit [55]
6-Core Ratio Limit [55]
7-Core Ratio Limit [54]
8-Core Ratio Limit [54]
Performance Core0 Specific Ratio Limit [Auto]
Performance Core0 specific Voltage [Auto]
Performance Core1 Specific Ratio Limit [Auto]
Performance Core1 specific Voltage [Auto]
Performance Core2 Specific Ratio Limit [Auto]
Performance Core2 specific Voltage [Auto]
Performance Core3 Specific Ratio Limit [Auto]
Performance Core3 specific Voltage [Auto]
*Performance Core4 Specific Ratio Limit [Auto]
Performance Core4 specific Voltage [Auto]
*Performance Core5 Specific Ratio Limit [Auto]
Performance Core5 specific Voltage [Auto]
Performance Core6 Specific Ratio Limit [Auto]
Performance Core6 specific Voltage [Auto]
Performance Core7 Specific Ratio Limit [Auto]
Performance Core7 specific Voltage [Auto]
Efficient Core Ratio [Auto]
Efficient Core Group0 Specific Ratio Limit [Auto]
Efficient Core Group0 specific Voltage [Auto]
Efficient Core Group1 Specific Ratio Limit [Auto]
Efficient Core Group1 specific Voltage [Auto]
Efficient Core Group2 Specific Ratio Limit [Auto]
Efficient Core Group2 specific Voltage [Auto]
Efficient Core Group3 Specific Ratio Limit [Auto]
Efficient Core Group3 specific Voltage [Auto]
AVX2 [Auto]
AVX2 Ratio Offset to per-core Ratio Limit [Auto]
AVX2 Voltage Guardband Scale Factor [Auto]
Maximus Tweak [Auto]
DRAM CAS# Latency [38]
DRAM RAS# to CAS# Delay Read [49]
DRAM RAS# to CAS# Delay Write [24]
DRAM RAS# PRE Time [49]
DRAM RAS# ACT Time [66]
DRAM Command Rate [2N]
DRAM RAS# to RAS# Delay L [12]
DRAM RAS# to RAS# Delay S [8]
DRAM REF Cycle Time 2 [704]
DRAM REF Cycle Time Same Bank [572]
DRAM Refresh Interval [131071]
DRAM WRITE Recovery Time [24]
DRAM READ to PRE Time [12]
DRAM FOUR ACT WIN Time [32]
DRAM WRITE to READ Delay L [24]
DRAM WRITE to READ Delay S [7]
DRAM CKE Minimum Pulse Width [21]
DRAM Write Latency [36]
Ctl0 dqvrefup [174]
Ctl0 dqvrefdn [92]
Ctl0 dqodtvrefup [Auto]
Ctl0 dqodtvrefdn [Auto]
Ctl1 cmdvrefup [Auto]
Ctl1 ctlvrefup [Auto]
Ctl1 clkvrefup [Auto]
Ctl1 ckecsvrefup [Auto]
Ctl2 cmdvrefdn [Auto]
Ctl2 ctlvrefdn [Auto]
Ctl2 clkvrefdn [Auto]
Read Equalization RxEq Start Sign [-]
Read Equalization RxEq Start [Auto]
Read Equalization RxEq Stop Sign [-]
Read Equalization RxEq Stop [Auto]
ODT_READ_DURATION [Auto]
ODT_READ_DELAY [Auto]
ODT_WRITE_DURATION [Auto]
ODT_WRITE_DELAY [Auto]
DQ RTT WR [Auto]
DQ RTT NOM RD [Auto]
DQ RTT NOM WR [Auto]
DQ RTT PARK [Auto]
DQ RTT PARK DQS [Auto]
GroupA CA ODT [Auto]
GroupA CS ODT [Auto]
GroupA CK ODT [Auto]
GroupB CA ODT [Auto]
GroupB CS ODT [Auto]
GroupB CK ODT [Auto]
Pull-up Output Driver Impedance [48 DRAM Clock]
Pull-Down Output Driver Impedance [40 DRAM Clock]
DQ RTT WR [Auto]
DQ RTT PARK [Auto]
Pull-up Output Driver Impedance [40 DRAM Clock]
Pull-Down Output Driver Impedance [48 DRAM Clock]
Round Trip Latency Init Value MC0 CHA [Auto]
Round Trip Latency Max Value MC0 CHA [Auto]
Round Trip Latency Offset Value Mode Sign MC0 CHA [-]
Round Trip Latency Offset Value MC0 CHA [Auto]
Round Trip Latency Init Value MC0 CHB [Auto]
Round Trip Latency Max Value MC0 CHB [Auto]
Round Trip Latency Offset Value Mode Sign MC0 CHB [-]
Round Trip Latency Offset Value MC0 CHB [Auto]
Round Trip Latency Init Value MC1 CHA [Auto]
Round Trip Latency Max Value MC1 CHA [Auto]
Round Trip Latency Offset Value Mode Sign MC1 CHA [-]
Round Trip Latency Offset Value MC1 CHA [Auto]
Round Trip Latency Init Value MC1 CHB [Auto]
Round Trip Latency Max Value MC1 CHB [Auto]
Round Trip Latency Offset Value Mode Sign MC1 CHB [-]
Round Trip Latency Offset Value MC1 CHB [Auto]
Round Trip Latency MC0 CHA R0 [Auto]
Round Trip Latency MC0 CHA R1 [Auto]
Round Trip Latency MC0 CHA R2 [0]
Round Trip Latency MC0 CHA R3 [0]
Round Trip Latency MC0 CHA R4 [0]
Round Trip Latency MC0 CHA R5 [0]
Round Trip Latency MC0 CHA R6 [0]
Round Trip Latency MC0 CHA R7 [0]
Round Trip Latency MC0 CHB R0 [Auto]
Round Trip Latency MC0 CHB R1 [Auto]
Round Trip Latency MC0 CHB R2 [0]
Round Trip Latency MC0 CHB R3 [0]
Round Trip Latency MC0 CHB R4 [0]
Round Trip Latency MC0 CHB R5 [0]
Round Trip Latency MC0 CHB R6 [0]
Round Trip Latency MC0 CHB R7 [0]
Round Trip Latency MC1 CHA R0 [Auto]
Round Trip Latency MC1 CHA R1 [Auto]
Round Trip Latency MC1 CHA R2 [0]
Round Trip Latency MC1 CHA R3 [0]
Round Trip Latency MC1 CHA R4 [0]
Round Trip Latency MC1 CHA R5 [0]
Round Trip Latency MC1 CHA R6 [0]
Round Trip Latency MC1 CHA R7 [0]
Round Trip Latency MC1 CHB R0 [Auto]
Round Trip Latency MC1 CHB R1 [Auto]
Round Trip Latency MC1 CHB R2 [0]
Round Trip Latency MC1 CHB R3 [0]
Round Trip Latency MC1 CHB R4 [0]
Round Trip Latency MC1 CHB R5 [0]
Round Trip Latency MC1 CHB R6 [0]
Round Trip Latency MC1 CHB R7 [0]
Early Command Training [Auto]
SenseAmp Offset Training [Auto]
Early ReadMPR Timing Centering 2D [Auto]
Read MPR Training [Auto]
Receive Enable Training [Auto]
Jedec Write Leveling [Auto]
Early Write Time Centering 2D [Auto]
Early Read Time Centering 2D [Auto]
Write Timing Centering 1D [Auto]
Write Voltage Centering 1D [Auto]
Read Timing Centering 1D [Auto]
Read Timing Centering with JR [Auto]
Dimm ODT Training* [Auto]
Max RTT_WR [ODT Off]
DIMM RON Training* [Disabled]
Write Drive Strength/Equalization 2D* [Auto]
Write Slew Rate Training* [Auto]
Read ODT Training* [Auto]
Comp Optimization Training [Auto]
Read Equalization Training* [Auto]
Read Amplifier Training* [Auto]
Write Timing Centering 2D [Auto]
Read Timing Centering 2D [Auto]
Command Voltage Centering [Auto]
Early Command Voltage Centering [Auto]
Write Voltage Centering 2D [Auto]
Read Voltage Centering 2D [Auto]
Late Command Training [Auto]
Round Trip Latency [Auto]
Turn Around Timing Training [Auto]
CMD CTL CLK Slew Rate [Auto]
CMD/CTL DS & E 2D [Auto]
Read Voltage Centering 1D [Auto]
TxDqTCO Comp Training* [Auto]
ClkTCO Comp Training* [Auto]
TxDqsTCO Comp Training* [Auto]
VccDLL Bypass Training [Auto]
CMD/CTL Drive Strength Up/Dn 2D [Auto]
DIMM CA ODT Training [Auto]
PanicVttDnLp Training* [Auto]
Read Vref Decap Training* [Auto]
Vddq Training [Disabled]
Duty Cycle Correction Training [Auto]
Periodic DCC [Auto]
Rank Margin Tool Per Bit [Auto]
DIMM DFE Training [Auto]
EARLY DIMM DFE Training [Auto]
Tx Dqs Dcc Training [Auto]
DRAM DCA Training [Auto]
Write Driver Strength Training [Auto]
Rank Margin Tool [Auto]
Memory Test [Auto]
DIMM SPD Alias Test [Auto]
Receive Enable Centering 1D [Auto]
Retrain Margin Check [Auto]
Write Drive Strength Up/Dn independently [Auto]
LPDDR DqDqs Re-Training [Auto]
Margin Check Limit [Disabled]
tRDRD_sg_Training [Auto]
tRDRD_sg_Runtime [16]
tRDRD_dg_Training [Auto]
tRDRD_dg_Runtime [8]
tRDWR_sg [20]
tRDWR_dg [20]
tWRWR_sg [16]
tWRWR_dg [8]
tWRRD_sg [Auto]
tWRRD_dg [Auto]
tRDRD_dr [0]
tRDRD_dd [0]
tRDWR_dr [0]
tRDWR_dd [0]
tWRWR_dr [0]
tWRWR_dd [0]
tWRRD_dr [0]
tWRRD_dd [0]
tRPRE [Auto]
tWPRE [Auto]
tWPOST [Auto]
tWRPRE [Auto]
tPRPDEN [2]
tRDPDEN [Auto]
tWRPDEN [Auto]
tCPDED [21]
tREFIX9 [Auto]
Ref Interval [Auto]
tXPDLL [Auto]
tXP [31]
tPPD [2]
tCCD_L_tDLLK [Auto]
tZQCAL [Auto]
tZQCS [Auto]
OREF_RI [Auto]
Refresh Watermarks [High]
Refresh Hp Wm [Auto]
Refresh Panic Wm [Auto]
Refresh Abr Release [Auto]
tXSDLL [2559]
tZQOPER [Auto]
tMOD [Auto]
CounttREFIWhileRefEn [Auto]
HPRefOnMRS [Auto]
SRX Ref Debits [Auto]
RAISE BLK WAIT [Auto]
Ref Stagger En [Auto]
Ref Stagger Mode [Auto]
Disable Stolen Refresh [Auto]
En Ref Type Display [Auto]
Trefipulse Stagger Disable [Auto]
tRPab ext [Auto]
derating ext [Auto]
Allow 2cyc B2B LPDDR [Auto]
tCSH [Auto]
tCSL [Auto]
powerdown Enable [Auto]
idle length [Auto]
raise cke after exit latency [Auto]
powerdown latency [Auto]
powerdown length [Auto]
selfrefresh latency [Auto]
selfrefresh length [Auto]
ckevalid length [Auto]
ckevalid enable [Auto]
idle enable [Auto]
selfrefresh enable [Auto]
Address mirror [Auto]
no gear4 param divide [Auto]
x8 device [Auto]
no gear2 param divide [Auto]
ddr 1dpc split ranks on subch [Auto]
write0 enable [Auto]
MultiCycCmd [Auto]
WCKDiffLowInIdle [Auto]
PBR Disable [Auto]
PBR OOO Dis [Auto]
PBR Disable on hot [Auto]
PBR Exit on Idle Cnt [Auto]
tXSR [745]
Dec tCWL [Auto]
Add tCWL [Auto]
Add 1Qclk delay [Auto]
MRC Fast Boot [Disabled]
MCH Full Check [Auto]
Mem Over Clock Fail Count [2]
Training Profile [Auto]
RxDfe [Auto]
Mrc Training Loop Count [Auto]
DRAM CLK Period [Auto]
Dll_bwsel [Auto]
Controller 0, Channel 0 Control [Enabled]
Controller 0, Channel 1 Control [Enabled]
Controller 1, Channel 0 Control [Enabled]
Controller 1, Channel 1 Control [Enabled]
MC_Vref0 [Auto]
MC_Vref1 [Auto]
MC_Vref2 [Auto]
Fine Granularity Refresh mode [Enabled]
SDRAM Density Per Die [Auto]
SDRAM Banks Per Bank Group [Auto]
SDRAM Bank Groups [Auto]
Dynamic Memory Boost [Disabled]
Realtime Memory Frequency [Disabled]
SA GV [Disabled]
Voltage Monitor [Die Sense]
VRM Initialization Check [Enabled]
CPU Input Voltage Load-line Calibration [Auto]
CPU Load-line Calibration [Level 4:Recommended for OC]
Synch ACDC Loadline with VRM Loadline [Disabled]
CPU Current Capability [Auto]
CPU Current Reporting [Auto]
Core Voltage Suspension [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [Auto]
CPU Power Phase Control [Auto]
CPU Power Thermal Control [125]
CPU Core/Cache Boot Voltage [Auto]
CPU Input Boot Voltage [Auto]
PLL Termination Boot Voltage [Auto]
CPU Standby Boot Voltage [Auto]
Memory Controller Boot Voltage [Auto]
CPU Core Auto Voltage Cap [Auto]
CPU Input Auto Voltage Cap [Auto]
Memory Controller Auto Voltage Cap [Auto]
Fast Throttle Threshold [Auto]
Package Temperature Threshold [Auto]
Regulate Frequency by above Threshold [Auto]
IVR Transmitter VDDQ ICCMAX [Auto]
Unlimited ICCMAX [Auto]
CPU Core/Cache Current Limit Max. [400.00]
Long Duration Package Power Limit [300]
Package Power Time Window [Auto]
Short Duration Package Power Limit [320]
Dual Tau Boost [Disabled]
IA AC Load Line [Auto]
IA DC Load Line [Auto]
IA CEP Enable [Auto]
SA CEP Enable [Auto]
IA SoC Iccmax Reactive Protector [Auto]
Inverse Temperature Dependency Throttle [Auto]
IA VR Voltage Limit [1550]
CPU SVID Support [Auto]
Cache Dynamic OC Switcher [Auto]
TVB Voltage Optimizations [Auto]
Enhanced TVB [Auto]
Overclocking TVB [Auto]
Overclocking TVB Global Temperature Offset Sign [+]
Overclocking TVB Global Temperature Offset Value [Auto]
Offset Mode Sign 1 [+]
V/F Point 1 Offset [Auto]
Offset Mode Sign 2 [+]
V/F Point 2 Offset [Auto]
Offset Mode Sign 3 [+]
V/F Point 3 Offset [Auto]
Offset Mode Sign 4 [+]
V/F Point 4 Offset [Auto]
Offset Mode Sign 5 [+]
V/F Point 5 Offset [Auto]
Offset Mode Sign 6 [+]
V/F Point 6 Offset [Auto]
Offset Mode Sign 7 [+]
V/F Point 7 Offset [Auto]
Offset Mode Sign 8 [+]
V/F Point 8 Offset [Auto]
Offset Mode Sign 9 [+]
V/F Point 9 Offset [Auto]
Offset Mode Sign 10 [+]
V/F Point 10 Offset [Auto]
Offset Mode Sign 11 [+]
V/F Point 11 Offset [Auto]
Initial BCLK Frequency [Auto]
Runtime BCLK OC [Auto]
BCLK Amplitude [Auto]
BCLK Slew Rate [Auto]
BCLK Spread Spectrum [Disabled]
Initial PCIE Frequency [Auto]
PCIE/DMI Amplitude [Auto]
PCIE/DMI Slew Rate [Auto]
PCIE/DMI Spread Spectrum [Disabled]
Cold Boot PCIE Frequency [Auto]
Realtime Memory Timing [Enabled]
SPD Write Disable [TRUE]
PVD Ratio Threshold [Auto]
SA PLL Frequency Override [Auto]
BCLK TSC HW Fixup [Enabled]
Core Ratio Extension Mode [Disabled]
FLL OC mode [Auto]
UnderVolt Protection [Disabled]
Switch Microcode [Current Microcode]
Xtreme Tweaking [Disabled]
Core PLL Voltage [Auto]
GT PLL Voltage [Auto]
Ring PLL Voltage [Auto]
System Agent PLL Voltage [Auto]
Memory Controller PLL Voltage [Auto]
Efficient-core PLL Voltage [Auto]
CPU 1.8V Small Rail [Auto]
PLL Termination Voltage [Auto]
CPU Standby Voltage [Auto]
PCH 1.05V Voltage [Auto]
PCH 0.82V Voltage [Auto]
CPU Input Voltage Reset Voltage [Auto]
Eventual CPU Input Voltage [Auto]
Eventual Memory Controller Voltage [Auto]
Cooler Efficiency Customize [Keep Training]
Cooler Re-evaluation Algorithm [Normal]
Optimism Scale [100]
Ring Down Bin [Auto]
Min. CPU Cache Ratio [Auto]
Max. CPU Cache Ratio [Auto]
BCLK Aware Adaptive Voltage [Auto]
Actual VRM Core Voltage [Auto]
Global Core SVID Voltage [Auto]
Cache SVID Voltage [Auto]
CPU L2 Voltage [Auto]
CPU System Agent Voltage [Manual Mode]
- CPU System Agent Voltage Override [1.18000]
High DRAM Voltage Mode [Enabled]
DRAM VDD Voltage [1.42000]
DRAM VDDQ Voltage [1.35000]
IVR Transmitter VDDQ Voltage [1.20000]
Memory Controller Voltage [1.40000]
MC Voltage Calculation Voltage Base [Auto]
VDD Calculation Voltage Base [Auto]
PMIC Voltages [Sync All PMICs]
SPD HUB VLDO (1.8V) [1.80000]
SPD HUB VDDIO (1.0V) [1.00000]
DRAM VPP Voltage [1.80000]
DRAM VDD Switching Frequency [Auto]
DRAM VDDQ Switching Frequency [Auto]
DRAM VPP Switching Frequency [Auto]
DRAM Current Capability [Auto]
PCI Express Native Power Management [Enabled]
Native ASPM [Disabled]
DMI Link ASPM Control [Disabled]
ASPM [Auto]
L1 Substates [Disabled]
DMI ASPM [Disabled]
DMI Gen3 ASPM [Disabled]
PEG - ASPM [Disabled]
PCI Express Clock Gating [Enabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetch [Enabled]
Intel (VMX) Virtualization Technology [Disabled]
Per P-Core Control [Disabled]
Per E-Core Control [Disabled]
Active Performance Cores [All]
Active Efficient Cores [All]
Hyper-Threading [Enabled]
Hyper-Threading of Core 0 [Enabled]
Hyper-Threading of Core 1 [Enabled]
Hyper-Threading of Core 2 [Enabled]
Hyper-Threading of Core 3 [Enabled]
Hyper-Threading of Core 4 [Enabled]
Hyper-Threading of Core 5 [Enabled]
Hyper-Threading of Core 6 [Enabled]
Hyper-Threading of Core 7 [Enabled]
Total Memory Encryption [Disabled]
Legacy Game Compatibility Mode [Disabled]
Boot performance mode [Auto]
Intel(R) SpeedStep(tm) [Enabled]
Intel(R) Speed Shift Technology [Enabled]
Intel(R) Turbo Boost Max Technology 3.0 [Enabled]
Turbo Mode [Enabled]
Acoustic Noise Mitigation [Disabled]
CPU C-states [Auto]
Thermal Monitor [Enabled]
VT-d [Disabled]
Memory Remap [Enabled]
Enable VMD controller [Enabled]
Map PCIE Storage under VMD [Disabled]
Map SATA Controller under VMD [Disabled]
M.2_2 Link Speed [Auto]
PCIEX16(G5)_1 Link Speed [Auto]
M.2_1 Link Speed [Auto]
PCIEX4(G4)_1 Link Speed [Auto]
PCIEX4(G4)_2 Link Speed [Auto]
M.2_3 Link Speed [Auto]
DIMM.2_1 Link Speed [Auto]
DIMM.2_2 Link Speed [Auto]
SATA Controller(s) [Enabled]
Aggressive LPM Support [Disabled]
SMART Self Test [Enabled]
M.2_3 [Enabled]
M.2_3 Hot Plug [Disabled]
SATA6G_1 [Enabled]
SATA6G_1 Hot Plug [Disabled]
SATA6G_2 [Enabled]
SATA6G_2 Hot Plug [Disabled]
SATA6G_3 [Enabled]
SATA6G_3 Hot Plug [Disabled]
SATA6G_4 [Enabled]
SATA6G_4 Hot Plug [Disabled]
PTT [Enable]
Intel(R) Dynamic Tuning Technology [Disabled]
PCIE Tunneling over USB4 [Enabled]
Discrete Thunderbolt(TM) Support [Disabled]
Security Device Support [Enable]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Password protection of Runtime Variables [Enable]
Above 4G Decoding [Enabled]
Resize BAR Support [Enabled]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
Lexar microSD RDR 0815 [Auto]
U10G_1 [Enabled]
U5G_E5 [Enabled]
U5G_E6 [Enabled]
U5G_E7 [Enabled]
U5G_E8 [Enabled]
U20G_C3 [Enabled]
U10G_5 [Enabled]
U10G_6 [Enabled]
U10G_7 [Enabled]
U10G_8 [Enabled]
U20G_C9 [Enabled]
USB11 [Enabled]
USB12 [Enabled]
U32G1_E1 [Enabled]
U32G1_E2 [Enabled]
U32G1_E3 [Enabled]
U32G1_E4 [Enabled]
Network Stack [Disabled]
Device [N/A]
Restore AC Power Loss [Power Off]
Max Power Saving [Disabled]
ErP Ready [Disabled]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
PCIe Bandwidth Bifurcation Configuration [Auto]
USB Audio [Enabled]
Intel LAN [Enabled]
USB power delivery in Soft Off state (S5) [Enabled]
Wi-Fi Controller [Enabled]
Bluetooth Controller [Enabled]
When system is in working state [All On]
Q-Code LED Function [Auto]
When system is in sleep, hibernate or soft off states [All On]
M.2_3 Configuration [Auto]
CPU PCIE Configuration Mode [Auto]
ASMedia USB 3.2 Controller_U5G_E12 [Enabled]
ASMedia USB 3.2 Controller_U5G_E34 [Enabled]
GNA Device [Disabled]
Alteration Mode Switch [PCIE Link Speed]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
Chipset Temperature [Monitor]
T_Sensor Temperature [Monitor]
DIMM.2 Sensor 1 Temperature [Monitor]
DIMM.2 Sensor 2 Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
DIMM Thermistor Temperature [Monitor]
DIMM A1 Temperature [Monitor]
DIMM B1 Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Extra Flow Fan Speed [Monitor]
Water Pump+ Speed [Monitor]
AIO Pump Speed [Monitor]
Flow Rate [Monitor]
CPU Core Voltage [Monitor]
12V Voltage [Monitor]
5V Voltage [Monitor]
3.3V Voltage [Monitor]
Memory Controller Voltage [Monitor]
CPU Fan Q-Fan Control [PWM Mode]
CPU Fan Profile [Manual]
CPU Fan Q-Fan Source [CPU]
CPU Fan Step Up [Level 0]
CPU Fan Step Down [Level 0]
CPU Fan Speed Low Limit [200 RPM]
CPU Fan Point4 Temperature [65]
CPU Fan Point4 Duty Cycle (%) [100]
CPU Fan Point3 Temperature [52]
CPU Fan Point3 Duty Cycle (%) [80]
CPU Fan Point2 Temperature [37]
CPU Fan Point2 Duty Cycle (%) [57]
CPU Fan Point1 Temperature [20]
CPU Fan Point1 Duty Cycle (%) [33]
Chassis Fan 1 Q-Fan Control [Auto Detect]
Chassis Fan 1 Profile [Manual]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [Level 0]
Chassis Fan 1 Step Down [Level 0]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Point4 Temperature [72]
Chassis Fan 1 Point4 Duty Cycle (%) [82]
Chassis Fan 1 Point3 Temperature [65]
Chassis Fan 1 Point3 Duty Cycle (%) [82]
Chassis Fan 1 Point2 Temperature [45]
Chassis Fan 1 Point2 Duty Cycle (%) [82]
Chassis Fan 1 Point1 Temperature [14]
Chassis Fan 1 Point1 Duty Cycle (%) [82]
Chassis Fan 2 Q-Fan Control [PWM Mode]
Chassis Fan 2 Profile [Manual]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [Level 0]
Chassis Fan 2 Step Down [Level 0]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Point4 Temperature [70]
Chassis Fan 2 Point4 Duty Cycle (%) [100]
Chassis Fan 2 Point3 Temperature [65]
Chassis Fan 2 Point3 Duty Cycle (%) [100]
Chassis Fan 2 Point2 Temperature [45]
Chassis Fan 2 Point2 Duty Cycle (%) [100]
Chassis Fan 2 Point1 Temperature [22]
Chassis Fan 2 Point1 Duty Cycle (%) [100]
Extra Flow Fan Q-Fan Control [DC Mode]
Extra Flow Fan Profile [Manual]
Extra Flow Fan Q-Fan Source [DIMM Thermistor]
Extra Flow Fan Step Up [Level 0]
Extra Flow Fan Step Down [Level 0]
Extra Flow Fan Speed Low Limit [Ignore]
Extra Flow Fan Point4 Temperature [71]
Extra Flow Fan Point4 Duty Cycle (%) [0]
Extra Flow Fan Point3 Temperature [60]
Extra Flow Fan Point3 Duty Cycle (%) [0]
Extra Flow Fan Point2 Temperature [45]
Extra Flow Fan Point2 Duty Cycle (%) [0]
Extra Flow Fan Point1 Temperature [20]
Extra Flow Fan Point1 Duty Cycle (%) [0]
Allow Fan Stop [Disabled]
Water Pump+ Q-Fan Control [Auto Detect]
Water Pump+ Profile [Full Speed]
AIO Pump Q-Fan Control [Auto Detect]
AIO Pump Profile [Full Speed]
CPU Temperature LED Switch [Enabled]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
Secure Boot Mode [Standard]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
Boot Sector (MBR/GPT) Recovery Policy [Local User Control]
Next Boot Recovery Action [Skip]
BIOS Image Rollback Support [Enabled]
Publish HII Resources [Disabled]
Flexkey [Reset]
Setup Animator [Disabled]
Load from Profile [1]
Profile Name [8200]
Save to Profile [1]
DIMM Slot Number [DIMM_A1]
Hotkey F3 [Toggle ASUS EZ Flash 3]
Hotkey F4 [Boot from UEFI USB]
Download & Install ARMOURY CRATE app [Disabled]
Download & Install MyASUS service & app [Disabled]
For CB15 Extreme and CB24, trained does not work for me. It must be like you say that it is difficult to hold 57x. Then I switch to Typical and I can pass everything (but not run YC 90min or 6hs!! :) )
9903 is the latest beta version (this is newer than 2102) - you can also see it in my archive, where it is marked:)
once the beta 9903 and once the official version 2102
The 9903 is based on the 2102 and is optimized for the KS, both run quite well for me.
Thank you! Another beta? I already missed the number of BIOSes I tried from December until now.🤯 Was it better for you than the 9902 or 2102? Now I'm testing (I mean trying to achieve 8400) in 2102 and I went back to the BIOS #2 to the 0801 since I noticed a change in the boosting of my 14900k in trained. It seems that the latest versions have a little more boost.
1.20V 292W
1.17V 276W
1.15V 265W
Can I ask you how you performed the tests? I mean, did you use a fixed voltage value for 56x? I am surprised by the result of PI 2.5. I think I achieved 42s using the Asus AI OC! But leaving everything on Auto (Cores) and limiting current, PL1 and 2, do not go from 46s to 57x. Will it be the undervolt of the curve?
Denke fürs zocken kann ich damit zufrieden sein.
mein windows läuft schon seit ~10 monaten, ist ziemlich bloated mittlerweile... rgb software und afterburner waren im hintergrund auf alle fälle an...
RGB software und Afterburner aus, gegen das Windows hilft nur neu installation...
trotzdem Top, mit 57000 wärst du schon auf Platz 24 Weltweit.
irgendwie zickt der aktuelle NVidia treiber rum, karte will den boost Takt nicht halten... Benchen mach ich ja eher so nebenbei :d
430w sind jetzt aber auch nicht wenig als zocksetup
Die last hast so doch nie beim zocken... Falls ja darfst mir gern mal nen Spiel nennen das wie Karhu die CPU belastet bin da offen und versuch das gerne mal, aber bisher bin ich nie über 150-175 watt in games...
Galax HOF bios, nochmal einen nachgelegt:
Meinte damit das der CPU für die Einstellung einiges an Strom zieht. Kannst den bei gleichen Takt nicht am Strom begrenzen?
Meinte damit der der CPU für die Einstellung einiges an Strom zieht. Kannst den bei gleichen Takt nicht am Strom begrenzen?
Über kurz oder lang bekommt der sowieso noch ein Profil mit niedrigeren Leistungseinstellungen aber bisher zieh er soviel nur bei Cinebench bzw Karhu bzw y-cruncher
wie sind solche Bios Einstellungen zu verstehen?
tRDRD_dg_Training
tRDRD_dg_Runtime
bei den anderen wie tRWRWR_dg ist es normal nur 1 Einstellung.
edit:
ok habs raus.
die liegen auch bei weiten beim gaming nicht an. das ist ja auch das problem was viele amd fanboys nicht verstehen ... nur weil es die leistungsaufnahme haben KANN bedeutet das nicht das er die leistungsaufnahme auch wirklich HAT
für gaming sollte man aufjedenfall auch ht deaktivieren , dadurch senkt man die leistungsaufnahme , die temperaturen und latenzen und kann den takt der pcores noch weiter erhöhen. dadurch wird ein 14900k schneller als jede amd x3d cpu (+ ddr5 oc) bei gleichzeitig viel viel viel niedrigerer latenz
