[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
OMG - 834€ !!! :oops:
Linus und Jay hatte den vor paar Wochen/Monaten...
Erinnert mich stark an die ersten Wasserkühler die ich so bei Kumpels gesehen habe. Waren damals idR Dreher und Fräser und haben sich die Blöcke selbst gefräst. Radiatoren für den PC gab es damals auch noch nicht. Da hing dann idR ein Autoradiator dran. Eheim Pumpe mit 230V Anschluss und Gardena-Schläuche. Das war auch der Tod so mancher Hardware. Da saß mal was nicht, dann wurde wieder was undicht, oder verstopfte, oder man hat zuviel Anpressdruck gegeben und sich den ungeschützten DIE zerbröselt. Wilde Zeit.
Die verkaufen den Block nur mit Papierdichtung. Da werde ich „etwas“ unruhig :fresse:
Neeee. Die Raptoren sind doch die Jetzt Zeit. Damals gabs Durons, Thunderbirds und Palominos
Ich hab nen Thunderbird mit den bloßen Fingern gekillt :d
Die schwitzigen Noob-Finger dienten versehentlich als „Power-Button“ des nicht-stromlosen MBs. Ich staunte nicht schlecht über den „Mini-Atompilz“ :fresse:
Darum sollte man nicht an laufender Elektronik rumpfuschen. Das geht meist auch im abgeschalteten Zustand, kostet nur mehr Zeit. Da stimmt dann Zeit ist Geld wirklich. ;)
brauch ich nicht, meine 4090 läuft super ohne probleme mit dem wireview adapter 12vhpwr auf 3x8-pin und strimer plus v2 :)
Habe die erste Version des Kabels und behalte die natürlich.
Das Problem bei Temperaturfühlern am Stecker ist - wo genau wird gemessen? Dazu ist Plastik thermisch wenig leitfähig. So kann selbst Milimeter neben einem Hotspot bereits deutlich weniger Temperatur anliegen.
Ich habe heute in verschieden Foren gelesen, dass die Backplate bei Grafikkarten das Fiepen/Rasseln verstärken kann.
Ohne diese waren die Karten plötzlich angenehm leise. Ein User hat die Backplate bei seiner Gigabyte 4090 mit Wärmeleitpads zugeklebt (Innenseite). Damit war sie zwar lauter als ohne aber immer noch deutlich leiser als im Originalzustand.
Was haltet ihr davon? Ich könnte mir vorstellen, das so bei meiner 4090 Strix durchzuführen.
Möglich. Das fiepen kommt ja von vibrierenden spulen. So eine Backplate kann einerseits als Resonanzkörper dienen, aber andererseits auch die PCB Spannung verändern. Vielleicht bewirken minimale Veränderungen hier große akkustische wunder. Ausprobieren. Ich selber bin glücklicherweise mit einer Karte gesegnet die quasi keinen mucks von sich gibt.
Ich habe die Backplate mal abgenommen und die Platine mit Wärmeleitpads zugelegt. Dadurch wurde die Karte noch lauter. Die Pads waren mit 1,5mm auch etwas zu dick.
Nun habe ich alle Pads entfernt und das macht die Karte tatsächlich leiser.
Die originalen Pads waren nur auf den im Bild rot markierten Bereichen. Müssen die Bauteile zwangsläufig gekühlt werden?
Der Bereich ganz links, bei mir anscheinend nicht...
Das Pad hatte nicht mal ansatzweise Kontakt zum PCB (außer zur Luft). Evtl. hatten die bei mir (auch bei Anderen) ein zu dünnes Pad verwendet!?
Guck mal bitte, ob das Pad bei dir (ganz links) Kontakt hat und gib mal die Dicke des Pads durch, falls es wirklich Kontakt hatte
@Dwayne_Johnson das Pad ist doch etwas zu weit hinten, oder täusche ich mich da? Das hätte doch näher in Richtung mittlere Schraublöcher (also auf dem Bild ca. 1 cm nach rechts) gemusst, um die SMD Teile auf der Rückseite (die Dinger Links von den Schriftzügen CE, UK CA etc.) abzudecken. Dort wo das Pad aktuell sitzt ist ja quasi nichts auf dem PCB.
Man liest es schon: ich kenne mich damit nicht aus, aber bitte erklärt mir dann bitte von was dieses letzte Pad hätte Wärme abführen sollen.
Müsste nachgucken, was auf der anderen Seite ist. Die Nähe zur Aussparung (Buchse), deutet auf die Gegenseite der Kondensatoren hin. Oder die Gegenseite der Spawa‘s
Das Bild (insbesondere die BP) ist perspektivisch verzerrt. Daher kann man sich etwas verschätzen
Mich würde interessieren, ob das besagte Pad bei neueren Strixen richtigen Kontakt hat und nicht nur zur Luft
Vielleicht ist es auch nur dazu da, dass die Backplate keine. Kontakt zu den nebenliegenden Bauteilen bekommt? Quasi als Abstandshalter.
Ich habe auch gedacht, dass das Pad keinen Kontakt hat. Allerdings kann man das nicht erkennen, da dort keine Abdrücke entstehen.
Ich bestelle jetzt nochmal Pads mit 0,5 und 1,0mm und probiere etwas rum.
Läuft es nun 1A oder nicht? Wie viel FPS sind es denn ohne FG? In diesem Spiel würde mich der Input Lag nerven, da man ja relativ gut getimte Bewegungen und Sprünge ausführen muss.
Kenne aber bisher nur den Vorgänger. Mit den ganzen Bugs hole ich es mir, wenn es mal n 10er kostet.
Das ist eins dieser Games, wofür sich dann auch ein OLED Monitor lohnt. Aber es muss eben gut laufen. Dass man für ein non open World Game überhaupt eine 4090 für 60FPS in 4k braucht ist echt ein Witz.
Ich spiele gerade Jedi Survivor… Game läuft 1A in 4K.
Da wurde die FG Version 1.0.7.0 empfohlen und siehe da, wunderbar nun.
Nutze nie FG in Survivor, weil bei meinem Spiel die Frame Times dann noch schlechter werden.
Wie lässt sich die Version tauschen?
Vielleicht wird's dann besser.
Habe es auch mit FG 1.0.7.0 gezockt und irgendwann ab der Mitte sogar Raytracing ausgemacht, dann lief es sehr gut 👍
