[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Freu mich schon auf den Generationswechsel wenn die vielen Kunden Ihre Gpu nichtmehr vom Stecker bekommen :)
Ich würd mal sagen, dass ist so ein klassischer Post von Dir, der in jeglicher Hinsicht Scheisse ist. Wie meinst Du das denn genau, erzähl mal.
Anti Nvidia? Also freust Du Dich, dass die Firma einen Fehler gemacht hat (siehe totes Pferd weiter oben)?
Anti User? Also freust Du Dich über das Unglück von Lovelace Karten Besitzern?
Pro Hate? Also freust Du Dich darüber, wenn sich die übertrieben und völlig unbegründeten Sorgen auf Grund der ganzen Übertreibungen einiger User bestätigen?
Pro Post Count? Hauptsache mal was geschrieben obwohl Du absolut nix beizutragen hattest?
Bin gespannt. :)
Das schreibst du bereits zum zweiten Mal...
Ja, wird vorkommen - aber die meisten, die vernünftige Kabel haben, die gerade und bis zum Ende durchgedrückt wurden, werden keine Probleme haben.
Ich glaub das wird kein einziges Mal vorkommen bei denen, die ihre Karte ganz normal genutzt haben ohne 1.000W BIOSe oder sonstige Stunts.
Könnte man so lesen, dass da einer sich freut wenn die Zeit des Wechsels gekommen ist und dann hat die teure Grafikkarte, die man sich ggfs. selbst nicht leisten konnte, bei anderen einen Schaden.
Aber weißt was? Wenn das so sein sollte, dann hab ich die paar Euro auch noch um mir von einem Reparaturdienst eine neue Buchse auflöten zu lassen.
Denn ich bin so unglaublich reich. :banana:
/edit: nö, der Kollege konnte auch zugreifen. Ich begreifs dann nicht. Verkauft er eigene Stecker?
Hier der Artikel dazu:
Gott sei Dank. mit einer Tabelle :d
Immer diese BILD Überschriften...
Was ist daran zum Freuen? Und wie lange funktioniert so eine 4090 überhaupt im verschmorten Zustand? Das dürfte doch immer schlimmer werden bis es dann irgendwann zum Kurzschluss kommt?
Wie bei schrödingers Katze:) ist der Stecker verschmort oder nicht. Es bleibt spannend. Ich vertraue hier auf meinen 50€ kabelmod Stecker:)
Mein Stecker wird täglich mit Jungfrauenblut bespritzt und dazu bete ich recht inbrünstig zu Satan.
Hat bisher ganz gut geholfen, obwohl mir langsam aber sicher die Jungfrauen ausgehen 🤘
Ach ist doch hier im Luxx ein bis zwei Fälle gewesen wegen eigener Unfähigkeit.
Ansonsten läuft es doch bei allen und manche haben ja hier mehrere 4090er durchgetestet. Sowas sind halt Igors Spezialthemen , weil der gerade elektrisch über viel Wissen verfügt und sich selber dafür interessiert. Daher ist nicht optimal der kleine Stecker, aber nun ist er da und wird denke viele Jahre bleiben . Also gewöhnt euch dran ^^
Die alten Molex Stecker sind auch nicht unbedingt das gelbe vom Ei , aber selbst diese sind bis heute in Verwendung vieler Systeme.
Freut mich sehr, Wiederverkaufspreis steigt dadurch immer weiter 🤘
Die Karten waren doch die letzten Jahre immer in den schöneren Monaten günstiger.
Naja bald kommen dann die super Karten .
Hast ja ein Jahr länger Zeit zum sparen 🤣
NVIDIA denkt an seine Kundschaft 🙏🏻
Mich graust jedoch jetzt schon die Vorstellung, wo die 5090 preislich liegen wird.
Hätte auch nie gedacht das ich mal so viel Kohle in die Hand nehme.
Aber das war beim privaten Auto das gleiche.
Und bei der Wakü.
Aber ich bereue meine 0.
Sowas kann man auch nur in Luxx sagen oder?🤣
Ist jedenfalls n feines Stück Hardware.
Mehr wert als es die 2080TI oder 3090 war und die waren auch nicht gerade günstig .
Die 1080TI war noch zu seiner Zeit ein gutes Stück Hardware zu einem fairen Preis.
Kann jmd anhand dieses Videos testen, ob er Colorbanding hat?
Egal, was ich im Treiber oder am X27 einstelle, ich hab massives Colorbanding (trotz YCbCr444 - 12bit) :cry:
Sogar ausserhalb des Videos (rot markiert) :unsure:
Es spielt also keine Rolle, ob ein Colorbanding-Test oder sonstwas läuft :heul:
Also auf diesen Test bezogen habe ich ebenfalls massives Colour Banding. Stört mich aber nicht, irl sehe ich da nix, egal ob Videos oder Games.
