[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
DSR im Nvidia Treiber ? :unsure:
Wie heißt denn dieses Tool nochmal mit dem man die 6K bei Deadspace erzwingen kann?
Du benötigst Cru 1.4 um die 4096×2160 Auflösungen um sie aus der Ini zu löschen damit du die Multi 1,78 und 2,25 richtig nutzen kannst.
Die Auflösung ist dort mit 23 HZ 30 und glaube 59/60 HZ versteckt in den Reitern alle raus suchen und löschen.
Dann funktioniert das DL 1,78 oder 2,25 oder *4 z.b erst richtig .
Bei der PC Auflösung im NV Treiber sollte max 3840×2160 zu sehen sein.
4096×2160 muß komplett raus sein da es nur eine Interpolierte Auflösung ist und mit DSR Probleme macht.
Cru ist ein Tool zum Bearbeiten von Auflösungen.
Damit löscht man die 4096 ×2160 Auflösung.
Wenn die gelöscht sind muß es so aussehen im Treiber wen man DSR die Multis gesetzt hat.
Hab auf die schnelle keine bessere Anleitung zu Nutzung von Cru gefunden.
Ach so DSR vorher auslassen kann sonst sein das der NYv Treiber dann nicht klar kommt .
Erst Auflösung löschen dann DSR einschalten.
Danke für die Erklärung @Thunderburne, ich kenne schon Cru und weiß daher auch, was Cru macht und ich meine mich gerade zu erinnern, dass schon damals gemacht zu haben. Jedenfalls zeigt es bei mir in der Systemsteuerung exakt gleich an, wie auf deinem Bild vom Screen.
Dann hast du Cru wohl schon mal ausgeführt.
Bzw. nur bei TVs notwendig die 4096×2160 interpolieren.
Damit hatte ich es noch nicht versucht.
@Thunderburne hatte jedoch in der Vergangenheit ebenfalls einen schwarzen Bildschirm beim Einrichten der Auflösung.
Ich hab einmal etwas falsch gemacht vor einigen Jahren und da hatte ich dann auch nen Schwarzen Bildschirm das ist richtig.
Das hat mich aber nicht daran gehindert es noch Mal zu versuchen .
Das lag daran das mein Receiver mit dran hing und ich das Bild dort durchgeschliffen haben und auch dort in der ini was gelöscht habe.
Also der Receiver war das Bildausgabegerät damals .
Es war einfach mein Fehler !
Das Tool ist top ich war damals einfach zu unerfahren.
Das Tool nutzen wir im Luxx schon lange.
Nicht gleich die Flinte ins Korn werfen weiter probieren.
Wenn du im BIOS von Mainboard falsche Settings lädst gibst du ja auch nicht gleich auf nur weil es einen blauen hagelt was für das Win sogar schlimmer ist.
...und alle die im Sommer zugeschlagen haben machen Luftsprünge oder verticken ihre Karten wieder und machen dann einen Luftsprung. :d
Luftsprung?
Bei EKA sind die Preise im Keller,nimm dir 2 Tage Zeit und du bekommst eine neue 4090 für 1300-1400€...
Luftsprung?
Kommt auf das Modell an. Meine Strix White habe ich für 2100 vertickt, im Juli für 1.972 gekauft. Ist halt wie bei Autos mit dem Werterhalt. Hab grad mal bei Kleinanzeigen geschaut, da ist sogar eine MSI für unter 1.500€ dabei. Naja, stehen halt nicht nur Dumme unter den Käufern auf jeden Tag. ;)
Schaue in der letzten Zeit bei EKA nach einer 4090+WaKüblock,da gab es schon einige 4090 Schnapper.
Mit Abholung und Test vor Ort hält sich das Risiko in Grenzen.
Luftsprung?
Alle 4090 unter 1400€ sind scam. Hab da selber einige Zeit geguckt: schreib mal eine günstige 4090 an und melde die Anzeige dann als Betrug bei Kleinanzeigen. Keine 4h später hast du eine Mail von Kleinanzeigen, dass das Konto gehackt wurde.
Ja es sind günstige inseriert, aber nein die bekommst du zu dem Preis nicht. Habe ungefähr 15 Leute innerhalb einer Woche angeschrieben: scam quote 100%
Nimm z.b. die Anzeige von heute Nacht (ist die neuste die eingestellt ist)
Ich habe sie jetzt gemeldet, heute Nachmittag ist der Account gesperrt, wetten :)
@Reaver1988
Schon mal drüber nachgedacht, dass Du die gehackt-Meldung nur bekommst, weil Du die Anzeige zuvor gemeldet hast?
Ich wäre mir da nicht sicher, dass Du damit eine tiefgreifende Untersuchung anstößt. Oft genug haben Verkäufer schon eine Sperre kassiert, die sich eigentlich nichts zu Schulden haben kommen lassen. Einfach nur, weil jemand eine Anzeige von denen gemeldet hat.
@Reaver1988
Ich habe schon oft gehackte Meldungen bekommen die ich nicht gemeldet hatte. Meist bei Mainstream Artikeln wie sonos Lautsprecher. Da wird mit Paypal Freunde Zahlungen abgefischt. Vor kurzem konnte ich obwohl ich kein käuferschutz hatte die Paypal Zahlung rückgängig machen sonst wäre das Geld beim bösen Fischer
@Reaver1988
Ich bin mir ziemlich sicher das Kleinanzeigen nicht blind einfach alles akzeptiert was gemeldet wird. Sondern das hier Prüfungen unternommen werden.
Ich hatte erst letzte Woche so etwas. Ganz normaler Account mit 100% Bewertung..Sehr günstig einen KEF Subwoofer angeboten. Ich schreib den an, ganz normale freundliche Antworten. Abholung klar gemacht. Kurz vor dem Termin schreibt der mich an dass doch nur Versand geht. Auf weitere Terminvorschläge von mir keine Antwort.
Etwas später bekam ich die Meldung dass der Account gehackt wurde. Ich hatte nicht gemeldet. Also ich denke das Account Fishing ist aktuell ne Seuche mal wieder.
Zurück zur 4090, bei eBay gibt es keine für diese Preise und meine ist wie gesagt für extrem gutes Geld weggegangen. Also bleibe ich bei den Luftsprüngen für die, die aktuell verkaufen wollen. ;)
Was ich mich nur Frage, eigentlich alle Hersteller, auch die aus Taiwan haben ihre Endfertigung in China. Dürfen die da auch keine mehr produzieren oder müssen die Fertigung in andere Werke verlegen sofern vorhanden? Das Embargo für die GPUs könnte wieder zu Preisen führen, die denen zu besten Mining Zeiten in nichts nachstehen.
;) genau wie der Vorposter es geschrieben hat, läuft es ab. Die scammer suchen sich auch ab und zu eine Insel aus auf der sie "wohnen" damit auch ja keiner vorbeikommt. Habe auch schon 2-3x die selben Bilder auf verschiedenen Accounts mit verschiedenen Orten gesehen. Die Angebote auf Kleinanzeigen sind zum Großteil halt Fake..die Gebrauchtpreise der 4090 sind deutlich höher, wenn man denn auch seine Ware bekommen will
Es lohnt sich tatsächlich nur die anzuschreiben die „nur Abholung“ anbieten, da ist die Scam Quote massiv geringer. Kann man inzwischen sogar direkt nach filtern.
Vor allem beliebte Produkte sind geradezu überschwemmt mit Scams, zb die PS5 oder auch der Thermomix.
Bei Apple Produkten ist es aber meiner Meinung nach am ausgeprägtesten…
Aber KA ist nicht per se schlecht, habe da über die letzten 14 Jahren seit Gründung schon unglaublich viele Schnäppchen gemacht und altes Zeugs teilweise richtig richtig gut verkauft bekommen.
Auch findet man dort ja inzwischen auch Miet und Kaufwohnungen/Häuser, ganz ohne dreckiges Abo wie bei Immoscout inzwischen üblich (ohne Abo kannst du dort fast niemanden mehr anschreiben!)
Was halt auch krass ist, dass wenn ein Account gehackt ist, kann man bei dem ganz entspannt am PC eine neue Email Adresse dafür hinterlegen und den dann mit seinen guten Bewertungen einfach umziehen lassen.
Kein 2FA System oder sonst was, da sollten die sich echt langsam mal Gedanken machen. Auch ein 2FA wird nicht alles verhindern, aber zumindest schon mal stärker einschränken.
Wie oft ich in letzter Zeit die RTX 4080 Suprim X mit Diablo Box aus nem Gewinnspiel für 800€ / 850€ gesehen habe ^^ Sogar einmal auf nem Berliner Account. Abholung ging natürlich nicht, wegen dem engen Zeitplan auf Arbeit, is klar ^^
Zur Zeit wieder echt viel los mit gehackten Accounts, liegt wahrscheinlich auch an der Vorweihnachtszeit, wo die Fischer den besten Fang wittern ^^
