[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dein Ernst? Bzw. Eurer Ernst?
Liest Euch mal bei Blurbusters ein.
das ist mir schon klar aber bitte WER kauft sich ein ~1000euro monitor wenn er nicht mal in der lage ist geforderten fps zu halten ... vsync+gsync erhöht auch den input lag ...
und wenn deine fps nicht unter 240fps fallen kann man sich auch gsync sparen vorallem haben die ganzen oled monitore nicht mal ein modul an board was noch mal mehr den input lag erhöht ...
Das ist aber auch ein Traumszenario, dass deine FPS immer konstant auf der Monitorfrequenz liegen... Das geht vielleicht in Valorant oder so aber wie willst du das denn in fordernden Games gewährleisten? Auf 1080p Low spielen nur wegen ein bisschen Inputlag? Und selbst dann schafft deine CPU meist nicht die 240fps in den heutigen AAA Games.
Rollbrett hier: https://amzn.eu/d/82NWZeB
Bruce Lee Bild: Weihnachtsgeschenk meiner Schwester, daher kein Plan. 🤷‍♂️
Also der AW3423DW hat ein Modul und der AW3423DWF nicht, und wenn ich die Reviews richtig im Kopf habe ist der Input/Processing Lag beim DW höher.
Nicht das es hier nun doch jmd falsch versteht, so ist es richtig:
V-Sync im Treiber: AN
V-Sync im Spiel(Menü): AUS
Die sind mit voller Absicht schief 🤘
Nachricht gelöscht
Ich bin von meinem 4k 144hz auf 4k 240hz umgestiegen und es ist ein unterschied wie tag und nacht selbst 60/120fps fühlen sich viel viel besser an als bei 144hz
Entschuldige wie soll das gehen ?
Um die Vorteile zu spüren gegen über einem 144 HZ brauchst auch mehr FPS als 144 bei einem 240 HZ
Fühlen ist ja erstmal etwas subjektives. Objektiv kommt das dann aber nicht von den 240Hz, wenn es sich bei 60FPS schon besser anfühlt, sondern vielleicht ist das Panel des neuen Monitors einfach generell besser.
Mir ist es speziell bei overwatch 2 aufgefallen wo ich konstant 225fps habe (reflex ultra+vsync kappt nvidia bei 225) und dann ins menü gehe was ja auf 60fps gecuttet ist es um ein vielfaches smother als bei meinem 144hz bildschirm und auch eFootball was ich auf 120 fps gekappt habe (bei 225fps nimmt sich die 4090 550watt :ROFLMAO: ) ist es viel angenehmer als bei meinem 144hz bildschirm vorher
und natürlich alles oberhalb von 190+FPS ist es einfach eine andere Welt gegenüber einem 144hz monitor hätte ich selber nie gedacht weil ich auch sehr sehr skeptisch war ob 240hz was bringen und ob man es merkt aber man merkt es definitiv
Ohne Gsync oder Gsync Compatible sind Frames unterhalb der Hz grausam. Habe ich ja selbst mit dem AW3423DWF gemerkt.
Selbst OLED rettet da nichts mehr durch die beste Reaktionszeit - da hilft nur VRR und ggf. das Flickering mit FPS Lock oder weniger Hz umgehen, sofern ein Game dafür anfällig ist.
Mit meinem lg 42 oled c 120hz kann ich in die zukunft und in die Vergangenheit sehen
Zusammen mit der geforce experience sind selbst die frames einer anderen Dimension sichtbar.
Wo hast Du das Bild rechts an der Wand von Bruce Low her?
Finde den "L-Table" interessanter...
Ich nehme an, dass das gesamte "L" elekr. hochgefahren werden kann und nicht nur der "kurze", gerade Teil?
Viel interessanter ist doch die Symbolik des Witcher Bildes:
Eine attraktive Frau sitzt breitbeinig auf einer Schlange :bigok:
Sieht eher aus, wie der Buckel von nem kleinen Flusspferd :ROFLMAO:
Korrekt, lange nach etwas passendem gesucht:
ich hatte meine Schreibtische schon und hab mir nur die elektrischen Gestelle beim WÜRTH geholt und die vorhanden Tischplatten drauf montiert.
Das 'L' wäre aber auch noch ne schöne Erweiterung. Mein Brüderchen hat auch welche in seinem Büro verbaut, allerdings mit einem Radius in der Mitte (rund und nicht eckig), wenn ich mich recht entsinne. Ist schon ne Weile her
Habe auch einen Tisch mit Rundung und tieferem Maß rechts. Ist für den Mausarm irgendwie besser. Habe ich im ganzen gekauft, also inkl. höhenverstellbarem Gestell. Maße konnte man auch konfigurieren, natürlich nicht völlig frei, aber es gab einige Optionenen. So eine Ecke wäre auch nix für mich.
