[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ich tausche gegen drei zauberbohnen - würd' ich mir überlegen.
tobi
:o
Die interessanteste Änderung bei weitem:
Die Karte hat nun auch wie Asus 2x HDMI 2.1 Ports.
War für mich damals ein entscheidender Kaufgrund zur Asus zu greifen wegen meinen 2 OLED’s.
das hab ich auch gelesen, aber dafür hat die ASUS trotzdem 3x DP ;), während die MSI einen dafür streicht.
Bei ASUS kannst Du dafür halt keine Single-Slot-Blende verwenden, logischerweise
Einen Tod muss mal halt sterben :hust:
Ja den Link kannte ich aber werde da trotzdem nicht schlau draus wie man das macht, kenne es nur so, dass man die aktuelle NVFlash Version zusammen mit der umbenannten Rom in einen Ordner auf dem Desktop packt und dann die bekannten flash Befehle unter Commant eingibt.
BZW. ist der Account von User Veii nicht mehr aktiv dort in seinem post wird aber noch diese OMG flash Datei angeboten, ist das wohl die modded Version?
Was habt ihr für Alltags Settings ?
Fahre aktuell @ CURVE 0,975@ 2700 Mhz und + 500MHZ Vram . Ca 60-70 Watt Ersparnis zu Stock.
Hab 3 Profile .
0,875V 2550 /+1000Ram
0,975V 2760 /+1000Ram
1,05 2925 /+1000
In den meisten Fällen kann man aber 1 verwenden.
Zu Gute kommt es dann auch noch mal den Temps @Air.
Es kommt einfach wenig Rum z.b man hat 50 FPS bei 2760 und macht dann OC das ist dann Promille Bereich was man da noch zulegt bzw macht das Game dann auch nicht flüssiger.
Ich würde dir helfen, aber mein AW3423DWF ist vorhin angekommen und das Zimmer sieht aus, als wäre hier eine Bombe eingeschlagen :fresse:
Um 14 Uhr muss die kleine Maus vom Kindergarten abgeholt werden. Das macht zwar meine Frau, aber das fehlt mir noch, dass sie hier rumspringt xD
„Oh, Papi ein neues Trampolin“
„hüpf - hüpf - crack“ :fresse:
Ja da hatte ich damals auch ein wenig bammel als mein BX8071513900K mit dem MBAS-639 auf dem Boden lag und ich noch die F5-7600J3646G16GX2-TZ5RK dazu stecken musste.
Leben am Limit
+135 +1350 Pt 40% votlage max
standart führ desktop für zocken volles power limit 1,1V
1.1v +150+750
Wenn schon 4090 dann 3000mhz ingame volle hütte. Ich kaufe ja auch keinen Sportwagen uns fahre nur im standgas
:o
So, wie kann ich hier 1000x Danke vergeben? Best movies ever!
"Ja richtig, Hände hoch, wie bei der Apfelernte". :d
1.1v +150+750
Wenn man unter Wasser kühlt kann man das gerne machen, aber on Air wäre mir zu laut und zu warm.
Habe insgesamt etwas mehr Leistung bei weniger Verbrauch als Stock. Komme bei CP 2077 so auf max. 350 Watt gegenüber 420 Watt @ Stock.
Macht sich schon in Sachen Abwärme und Lautstärke deutlich bemerkbar, aber muss jeder selber wissen.
Hier mal eigene Benches dazu .
@ Stock 2700 MHZ 10500 MHZ Vram 420 Watt
Curve Optimize 2700MHZ + 500 Vram (11000 MHZ) 0,975V (Alltagssetting) 350 Watt
So und dann hier einmal volle Pulle OC 3015MHZ + 1400 MHZ Vram 1,1 V ca. 520 Watt
Nice ich spiel lieber mit fps 100-120fps bei 2k nur leider klappt das bei mir mit frame generation nicht
@Nuestrass
Was bringt der 7950x3d denn in den CP 2077 bench? :)
Warum funktioniert bei dir FG nicht ?
Neuste Treiber drauf machen und ggf. mal die Dateien aktuallisieren .
Die Dateien kommen in "bin" Verzeichnis und sollten die alten überschreiben.
