[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wie ist den die 4090 FE? Ich habe gelesen, dass der Lüfter komische Geräusche machen soll. Brummen und nervige Resonanzen........Vom Spulenfiepen her soll die ja recht gut sein.
Gibt es noch Custom Design mit wenig Spulenfiepen? Ich habe jetzt ne 4080 SuprimX und die fiept einfach so nervig
Lüfter sind deutlich hörbar bei 1250 RPM 1190 bei der Drehzahl höre ich jedoch kein brummen
Da für sind die Spulen nicht so nervig .
Da Meine FE ca.3m weg steht hört man sie kaum oder gar nicht wenn die Lautsprecher oder Kopfhörer benutzt werden.
Die Lautstärke der TUF und der Strix die ich hier hatte waren bei 1000RPM angenehm leise.
Die Spulen haben aber alles zu nichte gemacht so daß die dann am Ende deutlich lauter waren als die 1250RPM der FE und sogar durch die Lautsprecher durchgedrungen sind wen mal nicht soviel Trubel war ingame.
Die Spulen der FE kann man zwar hören sind aber deutlich leiser als die von der TUF und Strix die ich hier hatte.
Ich weiß nicht ob ich Pech hatte oder ob die grundsätzlich so laut sind.
Da ich aber zwei unterschiedliche Modelle hier hatte hab ich bedenken ob es da auch welche gibt die Leise sind.
Die Leiseste die ich hier hatte war die Gigabyte Master .
Die hatte nur ein Problem.mit der Lüftersteuerung wollte nicht immer übernehmen was ich haben wollte die war sonst bei 950 RPM mega leise ...die Spulen für mich nicht zu hören erst bei 560 W fing man an die war zu nehmen.
Stock jedoch bis 1750 RPM hoch im OC Modus noch höher damals ...was dann natürlich nicht leise war.
Wer von euch so ein Ding unbedingt haben muss: kann man hier vorbestellen.
Hoffentlich gibt es für den Preis auch noch einen kleinen EVA dazu... ;)
Hab bei cyberpunk beim 7950x3d (smt off)8 Kerne deaktiviert und hab 20 fps mehr + 20 Watt weniger (50w) +420w bei der 4090 mit über 3000mhz in 2k pathtracing all in 160-200 fps nice
WTF :ROFLMAO:
Fast so geil, wie Crysis mit den Riesen-Hühnern :fresse:
Sooo Zelda totk habe ich nun durch und muss für mich sagen das ich hier definitiv enttäuscht wurde im Gegensatz zum ersten Teil den ich quasi vergöttert habe…
Das man auch die gleiche Welt mit den gleichen Städten benutzt hat war/ist mehr als unschön. (Warum gab es zur Abwechslung keine einzige Stadt in der Unterwelt und im Himmel?)
Überhaupt fühlte es sich insgesamt eher wie ein riesiges DLC/Addon an und eine Switch 2 ist inzwischen mehr als nur angebracht!
Naja sei‘s drum, freue mich jetzt meine 4090 wieder zu fordern mit Phantom Liberty und danach wahrscheinlich Separate Ways, wenn ich schon bei DLC‘s/Addons bin 😏
Bin ich damit durch geht’s ja wieder weg vom PC zur PS5, wo mich dann Spidey 2 begrüßt.
Bei JedI Survivor, Starfield (HDR?!) und BG3 warte ich noch auf weitere Patches, bevor die wohl Ende des Jahres angegangen werden.
Good times 🙏
Klar. Das Ding wird Wassergekühlt. Da sind zwei Moras schon auf die Karte geschraubt. Die 5090 wird ohnehin so ein Prestigeobjekt, dass sie nicht mehr zum Verbau im Gehäuse, sondern zur separaten Präsentation gebaut wird.
Bin schon gespannt was die Boardpartner da mit LED noch zaubern können. Man muss ja von der Straße aus schon sehen wer sich das Ding geleistet hat.
ich hab hier 2 x 4090FE eine auf Wasser umgebaut und nie neuere unter Luft.
beide Karten haben extrem geringes Spuhlenfiepen.
die Lüftergeräusche sind aus meiner Wahnehmung absolut in Ordnung.
Lüfter hatten bei beiden Karten auch keine unwucht.
die neuere Karte (Prod. Datum 07.2023) hat bereits den neuen 12VHPWR Anschluss mit den verkürzen Senspins.
ich kann die Founders Edition uneingeschränkt empfehlen.
Das Galax Bios 666W
Das kommt darauf an unter Custom wakü ganz klar ASUS XOC aber mit dem nachteil keine Limits sprich auch kein thermal throtteling
Die Eierlegendewollmichsau ist das Galax 666 watt bios nicht ganz so fix wie das XOC aber unter luft noch nutzbar und man hat alle sicherheitslimits Aber man muss schauen wie die lüfter sich verhalten beim luft betrieb sprich es kann sein man muss eine lüfterkurve machen bzw bearbeiten
Dann nimm das Galax Bios und hast ruhe
Du kommst eh nicht großartig über die 630watt hinaus weil die 1,1V begrenzen und du kannst das XOC auch auf 600watt begrenzen wenn du willst
habt ihr noch einen coolen guide wie genau man das macht ?
@xST4R
Siehe Startpost von diesem Thread
es ist super simple
nvflash64 -6 xxx.rom (Enter) XXX steht für den Bios name
2xY zum bestätigen und das wars dann neustart und man ist fertig
es ist super simple
danke , und das ersetzt dann das bios worauf ich gerade bin ? - wenn ich also switch bin ich wieder bei der normalen version
Ähnliche Themen
