[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@Brairw
Du hast auch die OC Variante?
Das Bios Update File sagt auf jeden Fall das es explizit dafür ist.
@Brairw
Klingt nicht normal. Wo hast du die gekauft?
Bei Mindfactory Neu Versiegelt, ich möchte die Karte ungern wieder zurückschicken weil die kein Spulenfiepen hat 😥
@Brairw
Ne ist die non Oc ich hab alle Bios Versionen von der PNY Seite versucht keiner funktioniert. Auch komisch ist das ich unter GPU-Z das Bios nicht sichern/speichern kann, ich wollte es erneuert wieder drauf flashen mit NVflash.
Die 4090 PNY ist heute angekommen, das erste was mir aufgefallen ist das die Lüfter sehr laut waren und mit 1459rpm konstant liefen,wtf? Auch das Bios Update von PNY lässt die Karte nicht zu da steht Gpu: Status / Nvidia Geforce Rtx 4090 unsupported.
Ist die Karte defekt?
Welche Version des Flashtools?
Mit "-6" probiert?
Ja immer. Auch habe ich unter GeräteManager die Gpu Treiber deaktiviert.
Werde ich heute Abend mal versuchen, schon komisch das ganze.. ich hatte schon mal eine 4090 PNY gehabt die ging leider wegen Lüfter rasseln wieder zurück.. mit der konnte ich ganz normal das Bios Update durchführen, sogar die Msi Suprim lief auf der PNY ohne Probleme.
Da sehe ich PNY schon in der Pflicht, wenn das jetzt eine 1.07V 4090 ist müssen sie schon Updates anbieten, die auch damit laufen.
ich bin kein experte, oder mal mit der patched version versuchen
Diese Methode ist mir unbekannt und wäre mir zu riskant, da es bei der PNY keinen Dual-Bios gibt wenn irgendetwas schief laufen sollte beim flashen.
Es kann auch sein das ich vielleicht die neuste Charge erwischt habe und PNY etwas an der Karte rumgespielt hat das jetzt die Lüfter mit min. 1450rpm laufen bei 30%.
Also das Spiel hatte immer noch hin und wieder ein paar Ruckler, aber es wirklich gut spielbar. Ohne war ne Frechheit, hatte auf der 4090 teilweise unter 40fps, absoluter Schmutz.
Hoffe der nächste Patch fixt die Performance..
Hier gab's doch schon diverse Spekulationen, dass das wohl eher nicht gefixt wird? Ich hatte halt schon EA Pro abonniert und dann gemerkt wie dreckig es läuft, dann hab ich mir das Addon geholt um es wenigstens schnell durch zu zocken. Aber das wars jetzt, beim nächsten EA Game kriegen die kein Cent mehr bevor die Reviews nicht positiv sind.
Sorry habe eine 4070ti keine 4090.. bei mir ist das auch das Problem das die Lüfter nicht wie in den Tests mit 1100 laufen sondern gleich 1450.
würde auch gerne versuchen ein älteres Bios zu flashen aber weis nicht ob das geht und ob es dann was bringt.
Der neue Stecker hat die Sense Pins nach hinten versetzt. Sehen also kürzer aus.
Werde ich mir nachher mal anschauen.
Scheint aber jetzt noch einer das Problem zu haben, somit ist ein Defekt ausgeschlossen.
Einzigste option wäre ein älteres Bios drauf zu flashen aber das scheint auch nicht mehr möglich zu sein.
Also wenn die so ne weiße von der 4090 rausbringen wird die auf jeden Fall probiert.
Tun sie doch, sogar zwei:
  • MSI Geforce RTX 4090 24GB Gaming X Slim White
  • MSI Geforce RTX 4090 24GB Gaming Slim White
geht MSI das metall für die kühler aus? weil günstiger werden die karten ja nicht wirklich für uns am ende. gewinnmaximierung und dafür schlechtere karten. wohooo
Ich Spiele seit 3 Tagen auf mein neuen Gaming PC Gott sei Dank es läuft wie ein Schmitz Katze.
Was ist nun aus dem BIOS-Flash geworden?
Leider kein Erfolg, weder mit vBios Updater vom Hersteller selbst noch mit NVFlash lässt sich die Karte nicht flashen. Schade eigentlich, die PNY hätte wirklich perfekt in mein Mini Itx system gepasst wegen der Größe und zudem war der Idle verbrauch so bei 10 Watt. Bei meiner Zotac ist der verbrauch im Idle bei 30-35W das finde ich schon viel. Auch in Spielen wie Dying Light 2 verbraucht die PNY mit uV 280w und die Zotac hingehen so 330w bei gleicher Einstellung.
