[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So um die 40 Watt konnte ich via GPUZ ablesen.
Und nicht zu vergessen: Wenn die Graka vertikal eingebaut ist, dann ist das Display natürlich auch fürn Arsch. @TurricanM3
Das ist genau mein Problem, viel sähe man da nicht (altes Pic):
Wobei mir das Display auch nicht wichtig wäre, Hauptsache die Lösung ist safe und da schmort nichts.
Deaktivieren kann man das Display nicht oder?
@TurricanM3
was dabei zu beachten ist:
beim Heatkiller lässt sich der Wireview vermutlich nicht montieren, da es beim Core auch nicht ging.
Hat das hier jemand getestet und weiß genaues?
Man kann einen 1 Minuten-Timeout setzen, danach geht das Dispay aus.
Auf jeden Fall (jedenfalls bei mir) ist das Kabel "hinter" dem Wireview nicht gebogen.
Ich hatte Probleme mit der Biegung, da hatte ein Sense-Pin wohl einen wackligen Kontakt und der hat Blackscreens ab und zu produziert, bis die Karte dann ganz abgestürtzt ist.
Jetzt wo das gleiche Kabel "gerade" liegt, sind die ganzen Wehwehchen verschwunden.
na dann schmeiß raus das CaseLabs, damit Du die Anzeige ablesen kannst :fresse:
Wo muss ich's abholen :d? :lol:
linus kriegt sein fett weg
Gab davor noch einen Forenpost von Linus und ein GamersNexus News Video in dem Steve kurz auf den Forenpost eingeht, nur der Vollständigkeit halber
Was ist das für ein Case?
Könnt ihr bitte hier mal prüfen, ob ihr das Problem mit dem MSI AB auch habt?
Also in der Changelog steht noch nichts zu dem Fehler!
3DMark Windows 2.27.8155 — August 14, 2023​
New​
  • Added 3DMark Solar Bay, a cross-platform ray tracing benchmark.
Fixed​
  • Fixed an issue where some 3DMark tests would fail if 3DMark was installed in a directory mounted to an NTFS volume.
:d
Zelda, Baldurs Gate 3 und Starfield.
Was für ein episches Spielejahr und die beste Zeit eine 4090 zu besitzen*
(am besten in Kombi natürlich mit einem OLED 🤘)
(*Wenn da nicht die ganzen kaputten stotternden messy AAA Spiele a la Harry Potter/Jedi/Forespoken/Gollum/Wild Hearts/Wo Long/Last Of Us/Redfall zwischendurch wären…) 🤮
Und das DLC von Cyberpunk kommt ja auch noch, dazu noch: Alone in the Dark, Lords of the Fallen, AC Mirage, Spider Man 2 und evtl. im Dezember ja sogar noch Stalker 2, achja JA 3 ist ja auch erschienen.
Völlig irrsinnig dieses Jahr und tolle Zeiten ein Gamer zu sein 🙏
Wieso empfiehlst du OLED Displays ? TV oder spezielle Monitore ?
Und was hast du gegen Jedi spiele ( survivor oder wie das heißt ) ist doch ganz gut 🤔
Und das mirage AC sieht überzeugend aus ... 🤔 Sollte doch ultra mit 4090 locker gehen 😌👋
Naja… ob Starfield was taugt muss sich noch zeigen (Bethesda und Engines ist ja eher eine Horrorkombination) und die anderen beiden fordern eine 4090 nicht wirklich^^
Ich sehr zufrieden mit Last of Us, ansonsten hat mich dieses Jahr bisher nichts interessiert. Aber gibt ja viele gute ältere Spiele, die gerne maxed-out gezockt werden möchten.
So sieht es aus. :) Habe die 4090 insbesondere dafür genutzt, ältere Spiele endlich in 4k in voller Pracht genießen zu können. RDR2 ging vorher nur in 1080p und mittleren bis hohen Details mit der 2060. Das war eine ganz neue Erfahrung. Ebenso GR Wildlands oder eben Witcher 3 mit dem RT Release.
Denke auch das es vor allem die ersten Monate noch ein buggy mess wird wie immer von Beteshda.
Will es eh erst zum Weihnachtsurlaub holen 😏
Brauche dringend ein Game Anfang September :d Bis dahin habe ich Remnant 2 wohl durch. Hoffe Starfield wird zu Release zumindest spielbar. Paar Bugs und Glitches stören mich meist nicht in so einem Game solange es nicht irgendwelche Fortschrittsbugs sind, aber technisch (Performance) muss es sauber laufen. Denke inhaltlich wird es schon werden.
Gibt doch meeehr als genug gutes Zeug zur Zeit, ist dein Geschmack soo speziell das wirklich nichts dabei ist?
Oder hast du das viele gute Zeugs schon tatsächlich durch?
Hab zwar auch ne 4090 und 4k ist ok. Kein wirkliches Upgrade zu 2k aber was mich wirklich umgehauen hat war das Erlebnis von half live alyx in vr.
Hoffe es kommen mehr vr games mit der gaming Qualität
Nee im Moment ist nix dabei so wirklich außer Evergreens wie Hunt Showdown und aktuell noch Street Fighter 6. Cyberpunk kommt ja erst nach meinem Urlaub. EVENTUELL Armored Core 6 aber das muss schon sehr gut sein und Starfield sehr schlecht oder noch nicht spielbar.
Hast du nicht mit 40+ gelernt:
Man soll den Tag nicht vor dem Abend loben.
Bezogen auf Starfield 🙃
Last of Us lief mit dem 5800x3D eigentlich ganz gut. Zocke aber auch mit Controller und auf 5K auf dem OLED, ist es ok, wenn es mal hin und wieder stuttert, solange es nicht wie am Fließband vorkommt.
Dafür ist die 5K Pracht einfach zu :drool:
Warum hast du noch keinen 7800x3D?
Hattest du doch abgekündigt, den zu erwerben zu wollen.
was für ein 5k OLED genau?
Davon war aus dem Post nichts zu lesen 🤣
Passt schon. Hab wohl bet schnell genug gedacht. Mein Fehler 😌👋
55“ ist mir viel zu groß für den Schreibtisch, an 42“ musste ich mich wochenlang gewöhnen obwohl er 1m weg ist (hatte am Anfang üble Kopfschmerzen).
Mein nächster wird der 42C4, aber nur wenn MLA an Board ist.
Denke, was der hat, wird auch in einem C4 zu finden sein nächstes Jahr für wesentlich weniger Kohle. War doch bis jetzt irgendwie immer so.
10W, wird nicht 100% stimmen, aber viel ist es wohl wirklich nicht über den Slot :<
