[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mehr intel Produkte kaufen xD
Hmmh, ziemlich knapp :d
Beste Grüße
Hat wer ein Corsair AX850 und weiß, ob das das richtige 12VHPWR Kabel ist?
CORSAIR - Stromkabel - 12VHPWR (W) zu 8-poliger PCIe Power (W) - flach, up to 600W TDP (CP-8920284)
Und dann suche ich noch die Website auf der alle GPUs mit Powerlimits aufgelistet waren. Könnte bei TechPowerUp gewesen sein. Finde sie nicht mehr.
Hier ist einer mit dem AX850. Ja, das Kabel passt. Würde aber eines von den Premium Sleeved von Corsair empfehlen, das von dir verlinkte Kabel ist recht steif.
Z. B. in schwarz:
Befördert der FE Lüfter die warme Luft aus dem Gehäuse oder verteilt dieser die Abluft im Gehäuse wie die ganzen Customs?
Ins Gehäuse, also das sollte auch jeder selbst erkennen können wenn man sich das Design mal 10 sek anschaut oO.
Der hintere (obere rechte) Lüfter pustet die Luft ins Gehäuse, das entspricht allen customs mit pass through design. Der vordere (linke) Lüfter schaufelt die meiste Luft durch die Slotblende.
Ich kann aber sagen dass bei meinen Gehäuse Temps Null Unterschied zwischen einer FE und einer Strix bspw. bestand.
Das ist nicht ganz korrekt. Der vordere Lüfter der FE im Bereich der Slotblende bewegt einen erheblichen Anteil der warmen Abluft direkt durch die Öffnungen in der Slotblende aus dem Gehäuse hinaus.
In meiner Gehäusekonfiguration bietet das Kühlerdesign der FE daher einen spür- und messbaren Vorteil gegenüber der 4090 Aorus Master, die ich auch mal besaß und stellvertretend für die Kühlkonzepte der meisten Custom-Modelle herhalten soll.
Auch wird durch die größtenteils vorhandene Umrahmung und dem somit eher geschlossenen Design des Kühlkörpers der FE, bei üblicher horizontaler Montage, nicht so viel heiße Luft auf das Mainboard und dort verbauten Komponenten geblasen. Meine NVME-SSD bleibt dadurch bspw. ebenfalls kühler.
Vielen Dank! So kommt zu mindestens ein guter Teil raus.
Wie viel lauter ist die FE als ne Tuf oder strix? Habe gerade ne 4070ti TUF die ist sehr leise!
laut Test ist die FE ne Ecke Lauter
die 4070ti gibt es nicht als FE, daher ist das nicht vergleichbar.
Ich hab mir jetzt auch die 4070ti TUF zugelegt weil die 4090 TUF nicht ins C4 passt, da der Kühler größer ist, auch wenn er gleich aussieht
4090 FE hätte übrigens ins C4 gepasst, wenn ich das richtig gesehen hab
Letzte Woche haben doch auch so viele hier bei Proshop die FE bestellt, kam aber kein Feedback, haben die Karten nun alle den neuen Chip+Stecker? Rattert der Lüfter immer noch? Spulenfiepen etc? ^^
Ich habe hier einen Ersteindruck hinterlassen.
Gerade gesehen, dass mein corsair ax850 nur 5 type4 pci-e hat.
Zwei davon gehen an das Mainboard. Glaub einer ist nicht zwingend notwendig.
Aber 3 reichen nicht für eine 4090?! Wenn die Kabelpeitsche 4x 8pin PCIe auf 12vhpwr hat.
Oder reichen 3 für 450W? Egal welche 3?
@erazr
Habe dasselbe Netzteil. Rein von der Leistung reichen 3x 8 Pin vollkommen aus. Wenn du den hässlichen Adapter nutzt und nur 3 von 4 Anschlüssen einsteckst, wirst du dich mit einem 450 Watt Limit begnügen müssen.
Anstelle des Adapters nutze ich lieber das Cablemod Kabel und kann somit meine CPU mit 2x 8 Pin und Grafikkarte mit 3x 8 Pin speisen.
Mit dem Original 12VHPWR Corsair reichen auch 2x 8 Pin Anschlüsse vom Netzteil.
Zwei Ports reichen für eine 4090, ein Port kann 300W bereitstellen. Welcher Port ist egal, es ist ein Single Rail Netzteil.
Pfff Geringverdiener!
Joa wenn das noch ein so fetten Leistungsschub gibt mit mind. doppelter Leistung ohne FG , dann ist das Ding schon gekauft , aber der 13900K wird dann wohl nicht mehr reichen . Brauchen dann nochmals deutlich schnellere CPUs . Im Moment passt es vom Verhältnis her bis 144HZ .
wäre froh wenn aktuelle Spiele überhaupt mal die 4090 ausnutzen. Siehe einige aktuelle EA Titel 😤
Naja Games zb. bei CP2077, darktide und Hogwarts Legacy in 4K muss ich schon auf DLSS Qualität und FG setzen , damit ich 100Fps + habe .
Jupp. Und selbst ältere Spiele wie RDR2 können die 144FPS nicht erreichen. Also wer die Karte für 4k gekauft hat, steht schon bereit für die 5090.
Ja finde auch deutlich stärkere CPUs mit deutlich mehr Single Thread Leistung wären gewünscht , wenn man aktuelle Games betrachtet. Gerade Games mit RT wo die 4090 mit DLSS und FG gute Leistung hat , dass die CPU bei hohen Lod Level schwächelt . Merkt man bei manchen Stellen in HWL und dying light 2 kann dank des Lod Level Regler schauen wo die CPU an ihr Limit kommt.
Meine mit dem 13900K passt es noch soweit, aber selbst da bei großen Open world Games mit hohen Lod Level , wenn halt wie in vielen Games nur bis 8 Kerne verwendet werden, dass es auch da leicht schwächeln kann . RT braucht halt auch viel CPU Power , wenn es die Karte stämmen kann . Bei Ampere ist das garnicht erst aufgefallen , weil da die RT Leistung zu schwach war.
Lese ich da etwa 5090 und überlege meine Niere zu verkaufen?
