[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Schade -.-
Hat sich im Windows die Hertzanzahl unter Anzeigeeinstellungen vielleicht verändert oder gar die Auflösung?
Windows nutze ich im Desktop Mode auf 60Hz, für Games schalte ich auf 144Hz und Adaptive Sync um. Das kann ich am Monitor mit einem Knopfdruck machen. Die jeweiligen Einstellungen der beiden Modi haben sich aber nicht geändert.
Dachte evtl., dass der Treiber zickt, denn es lief ja Monate lang ohne Probleme. Habe aber bereits eine ältere Version probiert, keine Änderung.
Hast du im NV-Treiber Gsyn UND Vsync aktiv?
Nur Gsync. Hab aber vsync in den Games angeschaltet und hatte das Problem trotzdem.
Im NV Treiber unter max und Hintergrund FPS-Limit 3 bis 4 Frames unter der Hertz Zahl des Monis gecappt?
Jupp. 141FPS. Habe gestern dann mal auf 120FPS gecapped, damit lief es dann problemfrei. Allerdings war es zu spät um intensiv zu testen, kann Zufall gewesen sein. Bei Madden (Cap auf 90FPS) und Total War Rome II (Cap auf 75FPS) gab es trotzdem Black Screens.
Welche Energieeinstellung haste im Windows und im NV-Treiber?
Balanced bzw. normal
Ist im Bios vielleicht irgendeine ASPM Einstellung aktiv? Evtl. mal ausschalten.
Nope.
Jensen auf dem Weg zum Weltherrscher? :d
Ich habe in Rome Total War 2 ziemlich heftige (häufig auftretende) black Screens. In anderen Games wie W3 oder Division 2 ist alles In Ordnung. In ForzaH 5 kommt es sehr selten vor.
Und zwar wird der Monitor für eine Sekunde schwarz, zeigt dann wieder das normale Bild (in Game, also kein Crash) und ich kann weiter zocken. Anhand von ausgeführten Aktionen und dem Sound ist auch klar, dass das Game normal weiter läuft. Wenn das Bild wieder da ist, sehe ich auch kurz die Statusanzeige des Monitors, so als ob er sich neu mit der DP/HDMI Source verbunden hätte, also wie wenn man die Quelle wechselt.
Dieses Problem trat mit der Inno 4090 oder anderen Karten jedoch nicht auf. Ich habe alle DP und HDMI Anschlüsse ausprobiert, es ist überall das gleiche. Weiter bin ich in der Fehlersuche allerdings noch nicht gekommen.
Kann das mit irgendwelchen inGame Einstellungen zu tun haben, die sich vielleicht mit gsync beißen oder so etwas? Habe allerdings nix verändert zur Inno, außer gleich den neuen Treiber installiert.
Die schwarz-Shice wird hier breit geballert: https://www.nvidia.com/en-us/geforc...rce-grd-53640-feedback-thread-released-62923/
Scheint heufick vorzukommen. :o Reaktion der mods: Its not a driver problem. (y)
Das ist ja höchst interessant, die haben ja fast alle den gleichen Fehler wie ich:
Ganz ehrlich, wenn man einem Fehler hinterher rennen muss, dann sollte irgendwann die Einsicht kommen das etwas nicht stimmt.
Wenn viele den selben Fehler haben aber nicht alle, dann könnte es auch durchaus ein Defekt sein. Die Berichte im Nvidia Forum sind ja schon seit Release im Umlauf und nach 9 Monaten immer noch kein Fix, bedeutet eigentlich das da auch wohl nix kommt und die Ursache woanders liegt.
Andere Karte rein(Andere Nvidia) und mal sehen ob der Fehler noch da ist, ggf. anderer Monitor wenn es ein Synchronisationsproblem sein sollte.
Sicher habt ihr doch paar Kumpels oder Freunde zum gegentesten, bei Amazon Prime Day waren leider keine im Angebot.
Die haben ein anderes Problem. Deren PCs crashen oder rebooten oder derlei. Ich bekomme für ne halbe Sekunde einen black screen und dann geht es normal weiter. Das Spiel läuft auch im Hintergrund normal weiter. Und wenn das Bild wieder da ist, zeigt der Monitor diese Input Anzeige an, so als ob ich ein Kabel neu verbunden hätte.
Ich tippe immer noch auf ein sync Problem, aber eher auf Monitor Seite. Wenn ich alles auf 60Hz stelle und adaptive sync auf aus, dann gibt es keine Probleme.
Habe Windows mal komplett neu aufgesetzt gestern Nacht, wollte ich sowieso schon länger machen. Aber leider keine Besserung. Bei Jagged Alliance dasselbe Problem. Leider kann ich über's WE nicht weiter testen, aber bis Mittwoch muss ich mich entscheiden ob die Strix zurück geht oder nicht. Bis dahin muss ich also klar haben, wo das Problem liegt.
Auch das Netzteil schließe ich als Ursache noch nicht aus. Ist zwar ein gutes, aber wer weiß ob die Lastspitzen nicht irgendwas killen.
Echt nervig sowas. Hatte schon ewig kein PC Problem mehr, wo die Ursache so unklar war.
So leid es mir auch tut, aber das hört sich verdammt nach einem Samsung Problem an. Also der ultimative Pro Tipp, anderen Monitor probieren :)
(Irgendwie scheint Samsung da was nicht auf die Reihe zu bekommen, hatte mal was ähnliches,kam mit meinem G7 nie mehr ins Bios.Kein Bild.(3080 kein Thema)Ist ein ähnliches Problem beim umschalten von Frequenz und Timing zwischen Grafikkarte und Monitor.(Lösung HZ ändern im Monitor, Strom ab vom Monitor, Blind ins Bios, dann Monitor einschalten und Bild war da.) Klar ist was anderes aber war eben nur Kombination und 4080/90 + Samsung.Komischerweise meine ich es lief am Anfang mal kurz, oder ich war nie im Bios. Ggf. versuch mal einen ganz alten Treiber für die Karte.
Firmware gibt es wohl keinen aktuellen für deinen Monitor.(von 2022?)
Ja, das könnte echt gut sein. Habe nur leider wirklich niemanden mit einem high Speed Monitor greifbar. Und ich habe hier nur einen 60Hz Fernseher oder 60Hz Monitor zum Gegentesten, aber da gibt's da eh keine Probleme.
Da braucht Dir auch nix leid tun. :d Die neuste Firmware ist drauf, hatte sogar noch die alte drauf. Aber wie erwartet kein Unterschied.
Aber ich eiere ja nun schon seit Dezember mit diversen Lovelace Karten rum, und dieses Problem hatte ich bis vor kurzem nicht. Also wenn dann ist erst in den letzten Wochen was kaputt gegangen. Denn den Monitor habe ich seit Januar 21 und nie Probleme vorher. Aber Garantie ist halt durch...
Oder mal schauen, obs für genau diesen Samsung Monitor vielleicht ein Firmware Update gibt.
Bei einem Kumpel konnte so zumindest das Nichtsehen des Bios gelöst werden.
ich habe das selten mal beim Booten, dass mein oller Samsung C32HG70 schwarz bleibt beim Windows Login Bildschirm. Da hilft dann nur Monitor ausschalten, oder zweiten Monitor anschalten. Dann ist er sofort wieder da.
Mich stört das jetzt nicht sonderlich, weil das nur mein Zweitmonitor ist, der halt für statische Inhalte und deshalb auch fürs Homeoffice herhalten muss. Allerdings muss ich sagen im laufenden Betrieb hat er das noch nie gemacht. Vielleicht trotzdem wirklich irgendwas Samsung typisches.
Yes, das nutze ich. Kann ich gern mal versuchen, aber wie könnte da der Zusammenhang sein?
Ohne HDR in Windows, geht dann auch HDR in Games nicht? Der Monitor kann ja HDR, wenn auch eher, na sagen wir "unauffällig". :fresse:
Hattest du nicht noch ne neue strix white bestellt oder ist das die Karte die aktuell Probleme macht?
Doch geht, wenn das Game HDR kann schaltet er es ein, Desktop kann aus sein.
Das ist eher die Ausnahme als die Regel, bei mir hat bisher 1 Spiel automatisch auf HDR umgeschaltet, wenn's im Windows aus war... Und das war irgend ein Battlefield Teil. Ansonsten gibt es ein shortcut dafür Win + Alt + B.
Und bei den meisten Spielen muss man es vorher Windows seitig aktivieren, bei manchen kann man während sie laufen umschalten.
Na dann läuft bei mir was falsch, Elden Ring/Doom Eternal macht es zumindest in Verbindung mit dem LG 42c2. Manchmal ist das Glück mit die Dummen ;)
Servus, kann mir wer sagen welches die aktuellste Version vom MSI Afterburner ist ?
@Gurkengraeber
Ist zwar keine perfekte Alternative, aber hast du mal ein anderes MB probiert? Oder hast du NVMEs drin? Wie läuft es testweise mit SATA-SSDs?
Glaube 4.6.5 Final ist die Letzte
Das sind wirklich Ausnahmen… die wenigsten Spiele können selbstständig HDR vom TV einschalten, wenn es in Windows deaktiviert ist.
Ein Armutszeugnis durch und durch.
Ja, leider...
K.A. warum es kaum Einer hinbekommt :rolleyes2:
Hm, wundert mich eigentlich...
Ich hatte vor Monaten mal einen Praxistest (Ladezeiten von Spielen) zw. 970 EVO Plus und einer 840 (SATA) gemacht
War nur messbar, aber keinesfalls spürbar
Welche Spiele waren das bei dir?
