[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du polterst hier immer schön weiter Deine Agenda raus, irgendwo muss Asus Dir mal den Schnuller geklaut haben, anders lässt sich das doch nicht mehr erklären. Ich antworte auf das Geblubber auch nur, weil dieses Video ein Beispiel zeigt, wo überall Qualitätsunterschiede versteckt sein könnten, die man als User erstmal gar nicht so wahrnimmt. Ich sage nicht dass die Gigabyte Karten nun alle unten brechen, aber vielleicht sollte man einfach mal diese "alle karten sind gleich" Nummer etwas runterfahren. Bei der Spannungsversorgung wurde es ja schon mehrfach aufgezeigt. Aber nun vielleicht auch beim PCB?
Und wer weiß wo sonst alles noch. Ich sage ebenfalls nicht, dass ne MSI oder Asus Karte den Aufpreis gegenüber Manli, PNY etc. wert ist, denn das entscheidet einfach jeder für sich selbst. Aber es gibt qualitative Unterschiede, ganz einfach, auch wenn die Relevanz nicht bei jedem Used Case gleichermaßen hoch ist. Mir persönlich ist die im Video beschriebene Thematik zum Beispiel völlig latte, deswegen würde ich keinen Aufpreis zahlen. Meine Karten werden einmal eingebaut und vorm Verkauf wieder ausgebaut, da brechen keine Brackets. Aber wenn dann auch noch Lüfter, Kühlerkonstruktionen und die Spannungsversorgung einfach besser sind, darf ne Karte schon etwas mehr kosten. Wenn einem das egal ist, dann einfach bei der günstigsten zugreifen und glücklich sein, genau so cool. Es sind jedoch definitiv nicht alle Karten gleich.
Hm, habe mir Samstag gerade die Gigabyte 4090 bestellt plus Phantek Kühler. Jedoch da mein MB horizontal verbaut ist mache ich mir da keine großen Sorgen das die Stelle extrem belastet wird wie bei vertikalem Einbau. Vermutlich ist genau deswegen diese Stütze extra dabei die an das MB verschraubt werden muss bei vertikalem Einbau. Für mich hört es sich an das dieses Problem wohl bekannt war bei Gigabyte und daher die Stütze.
Da muss man sich auch keine Sorgen machen, wie gesagt, die Karten werden bei sachgemäßem Umgang alle problemlos laufen, Einzelfälle natürlich ausgenommen. Gilt ja auch für "Stecker Gate" oder all diese Themen. Aber zum Beispiel gibt es bei der FE oder der Strix auch ohne Stütze fast kein Sag.
War wie geschrieben nur ein Beispiel dafür, dass die Karten durchaus unterschiedlich konzipiert sind.
Na dann :) Wie schon geschrieben da mein MB horizontal ist mache ich mir da weniger Sorgen.
Hoffe ja das die Karte und der Kühler morgen ankommt. Leider sieht es so aus das trotz gewählten Expressversand weder bei Alternate und Caseking bis dato versendet wurde. Bei Caseking soll es laut Telefon heute noch rausgehen. Bei Alternate kommt man gar nicht durch.
Sachen gibts…
Kabel für DAUs :fresse:
Ich würde noch einen draufsetzen, wäre ich Kabelhersteller. Kunststoff, der sich je nach Temp verfärbt :d
Und was haltet ihr von nem Bluescreen mit Fehlercode 0x0000000666 melting device/connection
und anschließendem shutdown :fresse2:
Für einige wäre sicher ein PC-Führerschein das richtige. Würde einiges an Problemen schon vor der Benutzung ausschliessen.
Wenn einer im www einen Test zur Asus 4090 LC entdeckt, bitte verlinken, erste Karten müssten inzwischen bei den Reviewern angekommen sein, danke :)
Die Gigabyte RTX4090 und der Phantekkühler sind angekommen und werkeln bereits. Alter Schwede ist das ein Klopper. Dachte meine 3080ti ist groß, aber das Ding ist ja nochmal länger. Gut das ich das CaseLabs Mercury habe.
eigentlich nicht schlecht, aber irgendwie dann doch nicht so perfekt :)
So der Asus Mitarbeiter aus dem ROG Forum hat nun bestätigt, dass die Strix LC das selbe PL wie die normale Strix hat, also 600 Watt :)
Damit dürfte dann auch die wilde Theorie vom Tisch sein, dass es sich bei der LC um das das alte 3090ti PCB handelt.
Der soll mal was bestätigen von wegen welche Spulen da nun zum Einsatz kommen.
Ich könnte das auch noch fragen, nur wurde ja an anderer Stelle schon geschrieben, dass bei den neuen Strix Karten andere Spulen zum Einsatz kommen.
Das wurde nur vom 8auer erzählt, sonst "weiß" davon noch keiner was.
Achso, dache das hätte in irgendeiner News schon gestanden, dass Spulen eines anderen Herstellers verwendet werden ....
So der Wireview ist dran.
Womit kann man denn die Karte mal so richtig auslasten?
Ähnliche Themen
Antworten
7K
Aufrufe
434K
