Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
[Sammelthread]ASUS X570 Strix Series (X570-E Gaming, X570-E Gaming Wifi II, X570-F Gaming, X570-I Gaming)
AMD AM4 Socket 3rd and 2nd AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Chipset
X570
Memory
3rd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
2nd Gen AMD Ryzen™ Processors
4 x DIMM, Max. 128GB, DDR4 3600(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory *
4 x DIMM, Max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2800(O.C.)/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
Graphic
Integrated Graphics in the 2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI 2.0b with maximum resolution of 4096 x 2160 @ 60 Hz
- Supports DisplayPort 1.2 with max. resolution 4096 x 2160 @ 60 Hz
Multi-GPU Support
3rd and 2nd Gen AMD Ryzen™ Processors
Supports NVIDIA® 2-Way SLI® Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD 2-Way CrossFireX™ Technology
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)
2 x PCIe 3.0 x16 (x16 or dual x8)
1 x PCIe 3.0 x16 (x8 mode)
AMD X570 chipset
1 x PCIe 4.0 x16 (max at x4 mode) *1
2 x PCIe 4.0 x1
Storage
3rd Gen AMD Ryzen™ Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
1 x M.2 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 3.0 x4 and SATA modes) storage devices support
8 x SATA 6Gb/s port(s),
Support Raid 0, 1, 10
LAN
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
Anti-surge LANGuard
ROG GameFirst Technology
WiFi
2 x 2 Wi-Fi 6 (802.11 a/b/g/n/ac/ax) with MU-MIMO supports dual frequency band 2.4/5GHz
Bluetooth
Bluetooth® 5.0
Audio
SupremeFX 8-Channel High Definition Audio CODEC S1220A
- Dual OP Amplifiers
- Impedance sense for front and rear headphone outputs
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input
- SupremeFX Shielding Technology
- Supports up to 32-Bit/192kHz playback *2
Audio Feature :
- Optical S/PDIF out port(s) at back panel
- Sonic Radar III
- Sonic Studio III + Sonic Studio Link
USB Ports
3rd Gen AMD RyzenTM Processors :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, )
2nd Gen AMD RyzenTM/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s)
AMD X570 chipset :
1 x USB 3.2 Gen 2 front panel connector port(s)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (4 at back panel, , 3 x Type-A+1 x Type-C)
AMD X570 chipset :
2 x USB 3.2 Gen 1 port(s) (2 at mid-board)
AMD X570 chipset :
4 x USB 2.0 port(s) (4 at mid-board)
Special Features
5-Way Optimization by Dual Intelligent Processors 5
- Whole system optimization with a single click! 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ VRM, Fan Xpert 4, and Turbo App together, providing better CPU performance, efficient power saving, precise digital power control, whole system cooling and even tailor your own app usages.
TPU
- Auto Tuning, TurboV, GPU Boost
Gamer's Guardian:
- DRAM Overcurrent Protection
- Stainless Steel Back I/O
- Highly Durable Components
- DIGI+ VRM
- SafeSlot
- ESD Guards on LAN, Audio,and USB ports
ASUS EPU :
- EPU
AURA :
- Aura Lighting Control
- Addressable Gen 2 Header
ASUS Exclusive Features :
- USB BIOS Flashback®
- AI Suite 3
- Ai Charger
- ASUS NODE : hardware control interface
- BIOS Flashback® Button
ASUS EZ DIY :
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
5 x USB 3.1 Gen 1 Type-A
8 x USB 2.0
1 x Optical S/PDIF out
5 x Audio jack(s)
1 x Anti-surge 2.5G LAN (RJ45) port
1 x USB BIOS Flashback® Button(s)
1 x ASUS Wi-Fi Module
7 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
1 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-C)
Anti-surge LAN (RJ45) port
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
2 x Aura RGB Strip Header(s)
2 x Addressable Gen 2 header(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
2 x M.2 Socket 3 with M key, type 2242/2260/2280/22110 storage devices support
1 x SPI TPM header
8 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s)
1 x CPU OPT Fan connector(s)
2 x Chassis Fan connector(s)
1 x AIO_PUMP connector
1 x W_PUMP+ connector
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x Thermal sensor connector(s)
1 x Clear CMOS jumper(s)
1 x Node Connector(s)
1 x System panel connector
1 x T_Sensor Connector
1 x M.2 Fan Header
1 x USB 3.2 Gen 2 (up to 10Gbps) connector
1 x USB 3.2 Gen 1 (up to 5Gbps) connector support additional 2 USB ports
Accessories
User's manual
4 x SATA 6Gb/s cable(s)
1 x M.2 Screw Package
1 x Supporting DVD
1 x Strix door hanger
1 x ROG Strix stickers
1 x Cable ties pack(s)
1 x Wi-Fi Antenna(s)
1 x Extension Cable for RGB strips (80 cm)
1 x Extension cable for Addressable LED
1 x Thermistor cable(s)
1 x ROG Thank you card
BIOS
256 Mb Flash ROM, UEFI AMI BIOS, PnP, WfM2.0, SM BIOS 3.2, ACPI 6.2.
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note
*1 PCIeX16_3 slot shares bandwidth with PCIeX1_2.
*2 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors
4 x DIMM, Max. 128GB, DDR4 4600(O.C.)/4400(O.C.)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200/3000/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 5000 and 4000 G-Series Processors
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4466(O.C.)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3600(O.C.)/3466(O.C.)/3200/3000/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
AMD Ryzen™ 2000 and 3000 G-Series Desktop Processors
4 x DIMM, max. 128GB, DDR4 3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133, un-buffered memory
ECC Memory (ECC mode) support varies by CPU
Graphic
1 x HDMI 2.0
1 x DisplayPort
Expansion Slots
2 x PCIe 4.0 x16 (x16 or dual x8)*
AMD Ryzen™ 5000 G Series/4000 G-Series/ 2000 Series Processor
2 x PCIe 3.0 x16 (x16 or dual x8)*
AMD Ryzen™ 2000 G-Series/ 3000 G-Series Processor
1 x PCIe 3.0 x16 (x8 mode)*
AMD X570 Chipset
1 x PCIe 4.0 x16 slot (supports x4 mode)
2 x PCIe 4.0 x1
*PCIeX16_3 slot shares bandwidth with PCIeX1_2.
Storage
Supports 2 x M.2 slots and 8 x SATA 6Gb/s ports
AMD Ryzen™ 5000 Series/ 3000 Series Desktop Processors:
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
AMD Ryzen™ 5000 G-Series/4000 G-Series/ 3000 G-Series/ 2000 G-Series/2000 Series Processor
M.2_1 slot (Key M), type 2242/2260/2280/22110 (supports PCIe 3.0 x4 & SATA modes)
AMD X570 Chipset
M.2_2 slot (Key M), type2242/2260/2280/22110 (supports PCIe 4.0 x4 & SATA modes)
LAN
1 x Realtek 2.5Gb Ethernet
1 x Intel® I211-AT 1Gb Ethernet
Anti-surge LANGuard
1 x Intel® 1Gb Ethernet
WiFi
Wi-Fi 6E
2x2 Wi-Fi 6E (802.11 a/b/g/n/ac/ax)
Supports 2.4/5/6GHz frequency band*
Bluetooth
Bluetooth® v5.2
Audio
Realtek S1220A 7.1 Surround Sound High Definition Audio CODEC*
- Internal audio Amplifier to enhance the highest quality sound for headphone and speakers
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback output and 113 dB SNR recording input (Line-in)
- Supports up to 32-Bit/192 kHz playback*
Audio Features
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
USB Ports
AMD RyzenTM 5000, 5000 G-Series, 4000 G-Series, and 3000 Series Desktop Processors
- 4 x USB 3.2 Gen2 ports (4 ports at back panel, Type-A)
AMD RyzenTM 3000 G-Series, 2000, and 2000 G-Series Desktop Processors
- 4 x USB 3.2 Gen 1 ports (4 ports at back panel, Type-A)
AMD X570 chipset
- 1 x USB 3.2 Gen2 front panel connector
- 4 x USB3.2 Gen2 (at back panel, 3x Type-A, 1x Type-C)
- 2 x USB3.2 Gen1 ports (at front panel)
- 4 x USB 2.0 ports (at front panel)
Special Features
Extreme Engine Digi+
- 5K Black Metallic Capacitors
ASUS Q-Design
- M.2 Q-Latch
- Q-Code
- Q-DIMM
- Q-LED (CPU [red], DRAM [yellow], VGA [white], Boot Device [yellow green])
- Q-Slot
ASUS Thermal Solution
- M.2 heatsink
ASUS EZ DIY
- BIOS FlashBack™ button
- BIOS FlashBack™ LED
- ProCool II
- Pre-mounted I/O shield
- SafeSlot
AURA Sync
- AURA RGB headers
- Addressable Gen 2 headers
Back I/O Ports
8 x USB 3.2 Gen 2 ports (7 x Type-A + 1 x USB Type-C®)
1 x DisplayPort
1 x HDMI® port
1 x Wi-Fi Module
1 x Intel® I211-AT 1Gb Ethernet port
1 x Realtek 2.5Gb Ethernet port
5 x Gold-plated audio jacks
1 x Optical S/PDIF out port
1 x BIOS FlashBack™ button
Internal I/O Ports
Fan and Cooling related
1 x 4-pin CPU Fan header
1 x 4-pin CPU OPT Fan header
1 x 4-pin AIO Pump header
2 x 4-pin Chassis Fan headers
1 x 4-pin M.2 Fan header
1 x W_PUMP+ header
Power related
1 x 24-pin Main Power connector
1 x 8-pin +12V Power connector
1 x 4-pin +12V Power connector
Storage related
2 x M.2 slots (Key M)
USB
1 x USB 3.2 Gen 2 connector (supports USB Type-C®)
1 x USB 3.2 Gen 1 header supports additional 2 USB 3.2 Gen 1 ports
2 x USB 2.0 headers support additional 4 USB 2.0 ports
Miscellaneous
2 x Addressable Gen 2 headers
2 x AURA RGB headers
1 x Clear CMOS header
1 x Front Panel Audio header (AAFP)
1 x SPI TPM header (14-1pin)
1 x Speaker header
1 x 10-1 pin System Panel header
1 x Thermal Sensor header
Accessories
Cables
4 x SATA 6Gb/s cables
1 x Thermistor cable pack
Miscellaneous
1 x ASUS Wi-Fi moving antennas
1 x Cable ties pack
1 x M.2 Rubber Package
1 x M.2 Q-Latch package
1 x ROG key chain
1 x ROG Strix thank you card
Installation Media
1 x Support DVD
Documentation
1 x User manual
BIOS
Form Factor
ATX Form Factor
Note
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Chipset
X570
Memory
Graphic
Multi-GPU Support
Expansion Slots
AMD X570 chipset
2 x PCIe 4.0 x1
Storage
AMD X570 chipset :
1 x M.2 x4 Socket 3, with M Key, Type 2242/2260/2280/22110(PCIE 4.0 x4 and SATA modes) storage devices support
LAN
Anti-surge LANGuard
Audio
Audio Feature :
- Sonic Radar III
USB Ports
3rd and 2nd Gen AMD Ryzen™/2nd and 1st Gen AMD Ryzen™ with Radeon™ Vega Graphics Processors :
4 x USB 3.2 Gen 1 port(s) (4 at back panel, )
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
AMD X570 chipset :
Special Features
TPU
Gamer's Guardian:
- DIGI+ VRM
- SafeSlot
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Slot
- ASUS Q-DIMM
Gaming Aesthetics :
- AURA-RGB Lighting
Back I/O Ports
1 x DisplayPort
1 x HDMI
8 x USB 2.0
5 x Audio jack(s)
4 x USB 3.2 Gen 1 (up to 5Gbps) ports
3 x USB 3.2 Gen 2 (up to 10Gbps) ports (Type-A)
Internal I/O Ports
1 x PCH_FAN
1 x AAFP connector
1 x SPI TPM header
1 x M.2 Fan Header
Accessories
User's manual
1 x Supporting DVD
BIOS
Form Factor
ATX Form Factor
Note
Chipset
X570
Memory
2 x DIMM, Max. 64GB, DDR4 4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3800(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory *
2 x DIMM, Max. 64GB, DDR4 3200(O.C.)/3000(O.C.)/2933(O.C.)/2800(O.C.)/2666/2400/2133 MHz Non-ECC, Un-buffered Memory
Graphic
- Support DisplayPort 1.4 with max. resolution 8 K 7680 × 4320 @60 Hz
Expansion Slots
1 x PCIe 4.0 x16 (x16 mode)
1 x PCIe 3.0 x16 (x16 mode)
Storage
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
1 x M.2_1 socket 3, with M Key, Type 2242/2260/2280 (PCIE 3.0 x4 and SATA modes) storage devices support
AMD X570 chipset :
1 x M.2_2 socket 3, with M Key, Type 2242/2260/2280 (PCIE 4.0 x4 and SATA modes) storage devices support
4 x SATA 6Gb/s port(s),
Supports channel bandwidth: HT20/HT40/HT80/HT160
Intel® Wi-Fi 6 AX200
Up to 2.4Gbps transfer speed
Bluetooth
Bluetooth® 5.0
Audio
Audio Feature :
- DTS® Sound Unbound
- LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
- Sonic Radar III
- Sonic Studio III + Sonic Studio Virtual Mixer
USB Ports
4 x USB 3.2 Gen 1 port(s) (4 at back panel, blue)
AMD X570 chipset :
4 x USB 3.2 Gen 2 port(s) (3 x Type-A+1 x Type-C)
AMD X570 chipset :
AMD X570 chipset :
2 x USB 2.0 port(s)
Special Features
TPU
ASUS EPU :
- EPU
AURA :
- AI Suite 3
- Ai Charger
ASUS EZ DIY :
- ASUS EZ Flash 3
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
1 x DisplayPort
1 x HDMI
3 x LED-illuminated audio jacks
4 x USB 3.2 Gen 1 (blue)
Internal I/O Ports
1 x HS_FAN
1 x PCH_FAN
1 x AAFP connector
1 x Aura RGB Strip Header(s)
1 x Addressable Gen 2 header(s)
1 x USB 3.2 Gen 1(up to 5Gbps) connector(s) support(s) additional 2 USB 3.2 Gen 1 port(s)
1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
2 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD)
4 x SATA 6Gb/s connector(s)
1 x Chassis Fan connector(s)
1 x Speaker connector
Accessories
User's manual
I/O Shield
2 x M.2 Screw Package
1 x Supporting DVD
1 x M.2 bracket
1 x AAFP Extension Cable
1 x Panel cable
BIOS
Form Factor
Mini ITX Form Factor
6.7 inch x 6.7 inch ( 17 cm x 17 cm )
Note
*1 Due to limitations in HDA bandwidth, 32-Bit/192kHz is not supported for 8-Channel audio.
*2 Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
Sound setzt aus oder knistert
Immer wieder USB Disconnects
Meistens tritt dieses Problem auf, wenn man einen hohen RAM Takt verwendet. In diesem Fall kann man versuchen die SOC Spannung auf 1.125V zu erhöhen. Sollte das nicht ausreichen, zusätzlich noch die VDDG CCD Spannung auf 1.00V (oder niedriger), sowie VDDG IOD Spannung auf 0.925V stellen.
USB Disconnects
Mit bestimmten UEFI/Agesa Versionen (v2 1.1.0.0/ 1.1.8.0) können sporadische USB Disconnects auftreten. Um dies zu umgehen bitte folgende Einstellung im Bios deaktivieren:
UEFI -> Advanced -> AMD CBS -> Global C-States deaktivieren
Der Verbrauch steigt dadurch um ca. 5Watt an aber ansonsten hat man keine weiteren Nachteile
USB Flashback funktioniert nicht
Bitte folgende Punkte ausprobieren:
- Datei richtig umbenannt? Vorzugsweise mit dem im BIOS Download enthaltenen Renamer
- Vor dem Flashen das BIOS auf Werkseinstellungen zurück setzen!
- Einen anderen USB Stick ausprobieren. Vorzugsweise ein USB 2.0 Stick
BIOS/UEFI Downgrade
Ein UEFI Downgrade ist ohne Probleme mit USB Flashback möglich, soweit vorhanden.
Ist der Chipsatz Lüfter regelbar?
Nein, dieser wird automatisch, je nach vorhandener Temperatur, geregelt. Bis zu einer Temperatur von 55 Grad ist der Lüfter deaktiviert. Bei höheren Temperaturen wird er stufenweise schneller bis er letztendlich bei 93 Grad seine Höchstgeschwindigkeit erreicht. Über selbst erstellte Bios Mods kann man jedoch den Lüfter auch nach seinen Wünschen einstellen.
Chipsatz Temperatur zu hoch?
Wem das Optische nicht so wichtig ist, kann die Lüfterabdeckung vom Chipsatz beim X570-E oder x570-F entfernen. Dadurch staut sich die warme Luft nicht an, sondern kann direkt entweichen.
Des weiteren kann man im Bios unter "Onboard Devices Configuration" die vorhandenen Steckplätze (PCIe X16, X1, M.2, SB Link) manuell auf PCIe 3.0 umstellen, sofern man keine PCIe 4.0 Karte verwendet. Bei Auto Einstellung wird automatisch PCIe 4.0 angelegt, was zu einer höheren Last führt.
Kann ich ein altes Bios Profil mit einer neuen Bios Version nutzen?
Nein, es ist zu empfehlen kein altes Profil mit einer neuen oder älteren Bios Version zu nutzen. Dies endet meist mit einem Blackscreen. Nach jedem Bios Flash bitte die Einstellungen neu vornehmen. Selbst wenn sich ein Profil laden lässt, kann es trotzdem zu Instabilität führen.
Rechner bootet nicht, wenn eine Soundkarte verbaut ist
Dieses Problem kann mit dem Bios 1404 oder höher (Agesa 1004b) auftreten. In dem Fall bitte in dem AMD CBS Menü die Option "PCIe Ten Bit Tag Support" auf Disabled stellen. Sollte das nicht ausreichen, dann zusätzlich noch unter dem Menü Advanced -> Onboard Devices Configuration -> die Option PCIEXxxx (den Slot auswählen, in der die Soundkarte steckt) von Auto auf Gen3 ändern.
Tach zusammen, hat einer von euch auf dem x570-e gaming wifi ii 128GB Speicher über 4000mhz laufen und wenn ja, welcher Speicher? Würde gerne aufrüsten aber denke das ich wenig Chancen habe bei 128GB mit über 4000mhz..
Da es für DDR4 keine Comsumer 64GB Riegel gibt, sondern nur ECC mit niedriger Taktung, müsste man schon 4x32GB nehmen. Mit 4000MHz Garantiert, gibt es gemsamt nur noch 4 Kits. Da 4x8GB teilweise schon schwer stabil zu bekommen ist und 4x16GB bald schon gar nicht bei dem Takt, würde ich nicht erwarten, dass auch nur einer 128GB bei 4000MHz fährt. Wozu auch 128GB bei ner normalen Consumer Plattform? Da wäre Intel Hedt oder Eypc schon sinnvoller.
Danke euch! Auf dem Board ist ein 5750ge zwecks stromsparendem KVM Server, deswegen der RAM.
Falls jemand noch Erfahrungen mit höheren Taktraten bei 128Gb gesammelt hat würde ich mich freuen wenn ihr berichtet
Wie dick müssen beim ROG Strix X570 E-Gaming die Wärmeleitpads für die M.2 SSDs sein?
Ich hab alle möglichen Dicken von 0,5 bis 3mm hier, aber ich will nicht erst alles zurechtschneiden, um dann festzustellen zu dick oder zu dünn.
Da ich ne WaKü im Rechner hab, ist auch das Ausbauen des Boards zum Prüfen nicht ganz so einfach.
Ne konkrete Angabe für die Dicke konnte ich gestern in ner 30 minütigen Googlesession nicht finden. Nur so aussagen ich benutze XY mit Amazonas Link zu M.2 Pads in Multidicken Pads.
Halte es für nahezu unmöglich so viel RAM bei der Taktrate zum laufen zu bekommen. Schon 2 8GB Riegel sind nur bei den wenigsten Chips ohne WHEA lauffähig. Bei 4 Sticks ist in aller Regel bei 3800 Schluss.
Wenn du dann auch noch high densitiy Sticks hast kannst froh sein wenn du 3000 oder 3200 zum laufen bekommst. Immer vorausgesetzt du setzt brauchbare Timings an die die Sticks bei ~8ns laufen lassen.
Mit Timings jenseits von Gut und Böse, z.B. 3600CL42 kann man natürlich viel zum laufen bekommen. Hast dann aber keinen Vorteil gegenüber Base 2400.
Wenn die Chips auf den Riegeln dann auch noch kein Micron E-Die oder Samsung B-Die sind, dann kannst es gleich lassen. Hynix kannst in aller Regel direkt vergessen wenn es um hohen Takt mit brauchbaren Timings und viel RAM geht.
Hynix DDR4 ist, meiner Meinung nach, generell Schmutz. Nur Probleme mit Hynix Speicher bisher gehabt. Unsere Kisten laufen deswegen alle auf Micron E-Die, auch weil Samsung B-Die einfach unverschämt teuer war im Vergleich
Moin zusammen Ich hab seit einigen Tagen ein Problem mit meinem X570-F Gaming, evtl. hat da jemand einen Tipp für mich.
Ich hab die Tage routinemäßig das BIOS auf den neuesten Stand gebracht (4602). Ansich hat das alles soweit funktioniert und der Rechner läuft auch einwandfrei, allerdings tritt seitdem ein seltsames Problem auf, welches ich mir nicht ganz erklären kann.
Sobald ich den Rechner einschalte krieg ich von der GPU schlichtweg kein Signal. Bildschirm bleibt also dauerhaft schwarz. Ich muss dann einmal den Reset-Knopf drücken, danach krieg ich ein Bild und der Rechner fährt ganz normal hoch. Und das passiert komischerweise bei jedem Einschalten des PCs. Da das Update auch das BIOS auf Default-Konfiguration zurückgesetzt hat könnte ich mir auch vorstellen, dass es irgendne BIOS-Einstellung gibt, die ich korrigieren müsste. Irgendwer spontan eine Idee woran das liegen könnte?
Servus, ich habe ein seltsames Problem (seit neuerem) mit meinem Strix-E X570, einem Ryzen 9 3900X sowie 2x16 und 2x8 GB 3200er Ballistix RAM: Speichertaktraten von über 3000 MTs = Der Rechner kann nicht mehr rebooten, sondern hängt beim Start. Mal Error Code 14, mal 01 (glaube ich). Da der RAM offiziell 3200 schafft und auch schon längere Zeit mit 3600 lief... Installiert ist das neuste BIOS 4602. Mit nur einem Paar Riegeln (egal welchem) sind 3200 kein Problem, da startet der problemlos.
Ok, und nun sind sogar 2800 MHz / MT wie auch immer ein Problem. Die Timings können dabei auch gern auf Auto gestellt sein, das System schafft es nicht. Aber Memtest bei 3200 MHz, kein Ding.
Habe jetzt mal alte BIOS-Versionen probiert... mit Versionen bis einschließlich 4021 bootet das System auch bei 3600 MHz, ab 4204 ist das Limit 2733 MHz. kA was ASUS da wieder geändert / kaputt gemacht hat.
Ja memtest lief problemlos durch. Und manuell oder DOCP, habe beides probiert.
Hatte das System jetzt scheinbar stabil gehabt (mit dem älteren BIOS), nachdem ich den Lüfter wieder auf dem CPU-Kühler hatte (dabei zieht der Lüfter einen der RAM-Module in Richtung Rückseite des PCs) war das Gerät sofort wieder instabil. Leider hat auch das Entfernen des Lüfters nicht geholfen. Habe jetzt einen 12 cm montiert, damit hat der RAM genug Platz. Aber eine Position, wo das System nicht nach ein paar Minuten Idle abstürzt finde ich nicht mehr
Ich denke ich hab also zwei Probleme gehabt: Das neuere BIOS und der Slot, der möglicherweise nicht mehr den besten Kontakt herstellt.
Same here. Such' mal im Thread nach meinen Kommentaren, ist bei mir genau dasselbe. Allerdings sind das die schlechtesten RAM, die ich je hatte und überhaupt nur mit mehr Strom bei lächerlichen DOCP Werten stabil zu bekommen.
Tach all, do any of you have on the x570-e gaming wifi ii 128GB memory running over 4000mhz and if so, what memory? Would like to upgrade but think that I have little chance at 128GB with over 4000mhz.
It won't be possible with 1:1 on the IF, so it's a bad idea.
Stick with 3200-3800.
With four CPU's tested on 5 boards (5700, 5800x, 5900x, 5800x3D), I've never been able to get above 3866 (1933 IF) stable on any of them
3866 was stable with four ranks, but not 8 ranks - you're likely to be stuck at 3200 to 3600 with 128GB, but you should only need to raise your SoC voltage to around 1.15v to achieve that with no other effort.
I'm on my third CMOS battery on my X570-F, they don't last forever. Some are 1-2 years, others are 10 years.
I've noticed default SoC voltages are changing on all brands of AM4 motherboards, use Zentimings to check your SoC voltage between BIOS versions.
1.10v should be enough for 4 ranks at 3600, with 1.15v to 1.20v for users with 8 ranks (or pushing to 3866)
Memtest programs only show memory errors - you should check HWinfo64 for WHEA errors to spot instability from the Infinity Fabric/SoC/Memory controller.
Hallo!Habe einen 3950x auf dem Strix X570-E und JEDE Biosversion nach 4021 hat Probleme gemacht! RAM- und/oder CPU mit und auch ohne OC liefen nicht mehr stabil oder beim Starten geht für ca. 1 Sekunde alles an gleich wieder aus und dann normal an. Meine 4x16GB Trident Z NEO 3600 16-19-19-19-39-58 laufen auf 3733@1,45V 16-19-19-19-39-58 trfc600 CR1mit einer SoC -Spannung von 1,125V LLC 5 Extreme. LG Stephan
ASUS got in trouble on AM5 for voltages being higher than reported, you may need to set higher voltages now - They've been forced to be more honest and accurate with what the user sets.
You could use Zentimings to compare if any secondary timings changed
After the AM5 issues were found out, new AM4 bioses have had different default SoC values on multiple vendors - but i'd only seen it on ASUS at the time of that post.
My Gigabyte x370 was 0.950v on launch through 1.2.0.6, but now on 1.2.0.8 it's at 1.09v SoC at optimised defaults - i'm not sure if AMD enforced these changes or the board makers did, but changes to default voltages can definitely explain why users cant clock as high with the 'same' settings since some are actually different.
That's why i suggested Zentimings screenshots of old/new BIOS for those users at the highest speed they can get into windows stable, as they can see what timings and voltages have changed and manually set those that are now different
ich habe zur Zeit eine NVDIA 1660 im obersten PCI Slot, dahinter einen 8x LSI HBA Controller und um 3. PCI Express Slot eine NVME Festplatte
Der NVME Controller und GPU wird erkannt, aber der HBA Controller taucht nirgends auf. Sowohl im BIOS kommt keine Meldung um ins HBA BIOS zu kommen, als auch in Unraid taucht der HBA Controller nicht auf.
Kann ich überhaupt beim x570 f Gaming 8x 8x 4x fahren? Laut Handbuch steht das als Möglichkeit zur Verfügung. Mit dem hacked Bios taucht aber auch die Option "PCIEX16_2 Bandwidth" mit der Option X8 Mode gar nicht auf.
ich weiß nicht ob ich mich verrückt mache mit der Performance und den CB Punkten, aber seit ich das 2812x Bios hatte, komme ich mit meiner CPU nicht mehr an die 7.500 Punkte ran, sondern dümple gerade im Bereich 6.900 -7.000 herum.
Habe vorhin das neuste Bios mit dem Mod hier drauf geknallt und die RAM-Settings übernommen sowie ander Werte, hat aber nichts gebracht.
Stock habe ich nun sogar paar Pünktchen mehr gehabt vorher als nach dem OC (sogar erst nur 6.500 Punkte).
Ich teile meine Settings mal mit euch und vielleicht habt ihr konkrete Vorschläge für mich?
Habe nicht so viel Ahnung von dem Thema und mag ungern mehr Zeit verschwenden, weil alles nicht so läuft wie ich es lese (vielleicht liegt es ja an mir).
LG
Luke
Code:
[2023/07/10 14:30:47]
Ai Overclock Tuner [D.O.C.P.]
D.O.C.P. [D.O.C.P DDR4-3000 15-16-16-35-1.35V]
BCLK Frequency [100.0000]
BCLK Spread Spectrum [Disabled]
Performance Enhancer [Auto]
Memory Frequency [DDR4-3600MHz]
FCLK Frequency [1800MHz]
CPU Core Ratio [Auto]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX1 Ratio [Auto]
CCX0 Ratio [Auto]
CCX1 Ratio [Auto]
TPU [Keep Current Settings]
Performance Bias [Auto]
PBO Fmax Enhancer [Enabled]
Precision Boost Overdrive [Enabled]
Precision Boost Overdrive Scalar [Auto]
Max CPU Boost Clock Override [200]
Platform Thermal Throttle Limit [Auto]
DRAM CAS# Latency [16]
Trcdrd [20]
Trcdwr [18]
DRAM RAS# PRE Time [18]
DRAM RAS# ACT Time [32]
Trc [80]
TrrdS [7]
TrrdL [8]
Tfaw [20]
TwtrS [4]
TwtrL [14]
Twr [27]
Trcpage [Auto]
TrdrdScl [5]
TwrwrScl [5]
Trfc [561]
Trfc2 [Auto]
Trfc4 [Auto]
Tcwl [16]
Trtp [14]
Trdwr [8]
Twrrd [4]
TwrwrSc [1]
TwrwrSd [7]
TwrwrDd [7]
TrdrdSc [1]
TrdrdSd [5]
TrdrdDd [5]
Tcke [1]
ProcODT [43.6 ohm]
Cmd2T [1T]
Gear Down Mode [Enabled]
Power Down Enable [Disabled]
RttNom [RZQ/7]
RttWr [RZQ/3]
RttPark [RZQ/1]
MemAddrCmdSetup [Auto]
MemCsOdtSetup [Auto]
MemCkeSetup [Auto]
MemCadBusClkDrvStren [Auto]
MemCadBusAddrCmdDrvStren [Auto]
MemCadBusCsOdtDrvStren [Auto]
MemCadBusCkeDrvStren [Auto]
Mem Over Clock Fail Count [Auto]
Voltage Monitor [Die Sense]
VDDCR CPU Load Line Calibration [Auto]
VDDCR CPU Current Capability [100%]
VDDCR CPU Switching Frequency [Auto]
VRM Spread Spectrum [Disabled]
VDDCR CPU Power Duty Control [T.Probe]
VDDCR CPU Power Phase Control [Standard]
VDDCR SOC Load Line Calibration [Auto]
VDDCR SOC Current Capability [100%]
VDDCR SOC Switching Frequency [Auto]
VDDCR SOC Power Phase Control [Standard]
VDDCR CPU Voltage [Offset mode]
VDDCR CPU Offset Mode Sign [-]
VDDCR CPU Offset Voltage [0.05000]
VDDCR SOC Voltage [Manual]
VDDCR SOC Voltage Override [1.10000]
DRAM Voltage [1.40000]
VDDG CCD Voltage Control [1.000]
VDDG IOD Voltage Control [1.000]
CLDO VDDP Voltage [0.950]
1.0V SB Voltage [Auto]
1.2V SB Voltage [Auto]
VDDP Voltage [Auto]
CPU 1.80V Voltage [Auto]
VTTDDR Voltage [Auto]
VPP_MEM Voltage [Auto]
VDDP Standby Voltage [Auto]
CPU Core Current Telemetry [Auto]
CPU SOC Current Telemetry [Auto]
Security Device Support [Enable]
SHA-1 PCR Bank [Disabled]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
TPM 2.0 UEFI Spec Version [TCG_2]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Selects TPM device [Enable Firmware TPM]
Erase fTPM NV for factory reset [Enabled]
PSS Support [Enabled]
NX Mode [Enabled]
SVM Mode [Disabled]
SMT Mode [Auto]
Core Leveling Mode [Automatic mode]
CCD Control [Auto]
SATA Port Enable [Enabled]
SATA Mode [AHCI]
NVMe RAID mode [Disabled]
SMART Self Test [Enabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
HD Audio Controller [Enabled]
PCIEX16_1 Mode [Auto]
PCIEX16_2 Mode [Auto]
PCIEX16_3 Mode [Auto]
PCIEX1_1 Mode [Auto]
PCIEX1_2 Mode [Auto]
M.2_1 Link Mode [Auto]
M.2_2 Link Mode [Auto]
SB Link Mode [Auto]
CPU PCIE ASPM Mode Control [Auto]
PCIEX16_1 Bandwidth Bifurcation Configuration [Auto Mode]
PCIEX16_2 Bandwidth Bifurcation Configuration [Auto Mode]
PCIEX16_3 4X-2X Switch [Auto]
When system is in working state [Aura Off]
Q-Code LED Function [POST Code Only]
Realtek 2.5G LAN Controller [Enabled]
Intel LAN Controller [Disabled]
Wi-Fi Controller [Enabled]
Bluetooth Controller [Enabled]
USB power delivery in Soft Off state (S5) [Disabled]
ErP Ready [Enable(S4+S5)]
Energy Star Ready [Enabled]
CEC Ready [Disabled]
Restore AC Power Loss [Power Off]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
Above 4G Decoding [Enabled]
Resize BAR Support [Auto]
SR-IOV Support [Disabled]
Relaxed Ordering [Enabled]
Extended Tag [Disabled]
No Snoop [Enabled]
Maximum Payload [Auto]
Maximum Read Request [Auto]
ASPM Support [Disabled]
Extended Synch [Disabled]
Link Training Retry [5]
Link Training Timeout (uS) [1000]
Unpopulated Links [Keep Link ON]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
Generic STORAGE DEVICE TS22 [Auto]
USB Device Enable [Enabled]
U32G2_4 [Enabled]
U32G2_1 [Enabled]
U32G2_2 [Enabled]
U32G1_11 [Enabled]
U32G2_C9 [Enabled]
USB3 [Enabled]
USB4 [Enabled]
U32G2_C8 [Enabled]
U32G2_5 [Enabled]
U32G2_6 [Enabled]
USB_1_2 [Enabled]
Network Stack [Disabled]
Device [WDC WD40EFRX-68WT0N0]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
PCH Temperature [Monitor]
T_Sensor Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
M.2 Fan Speed [Monitor]
W_PUMP+ Speed [Monitor]
AIO PUMP Speed [Monitor]
PCH Fan Speed [Monitor]
CPU Core Voltage [Monitor]
3.3V Voltage [Monitor]
5V Voltage [Monitor]
12V Voltage [Monitor]
CPU Q-Fan Control [Auto]
CPU Fan Step Up [0 sec]
CPU Fan Step Down [0 sec]
CPU Fan Speed Lower Limit [200 RPM]
CPU Fan Profile [Standard]
Chassis Fan 1 Q-Fan Control [Auto]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [0 sec]
Chassis Fan 1 Step Down [0 sec]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Profile [Standard]
Chassis Fan 2 Q-Fan Control [Auto]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [0 sec]
Chassis Fan 2 Step Down [0 sec]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Profile [Standard]
WATER PUMP+ Control [Disabled]
AIO PUMP Control [Disabled]
M.2 Fan Q-Fan Control [Auto]
M2 Q-Fan Source [CPU]
M.2 Fan Step Up [0 sec]
M.2 Fan Step Down [0 sec]
M.2 Fan Speed Low Limit [200 RPM]
M.2 Fan Profile [Standard]
PCH Fan Q-Fan Control [PWM Mode]
PCH Fan Step Up [0 sec]
PCH Fan Step Down [0 sec]
PCH Fan Speed Low Limit [Ignore]
PCH Fan Upper Temperature [93]
PCH Fan Max. Duty Cycle (%) [100]
PCH Fan Middle Temperature [60]
PCH Fan Middle. Duty Cycle(%) [40]
PCH Fan Lower Temperature [55]
PCH Fan Min. Duty Cycle (%) [0]
Above 4GB MMIO Limit [39bit (512GB)]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Normal Boot]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Bootup NumLock State [On]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
AMI Native NVMe Driver Support [Enabled]
Setup Mode [Advanced Mode]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
SATA Support [All SATA Devices]
NVMe Support [Enabled]
VGA Support [EFI Driver]
USB Support [Full Initial]
Network Stack Driver Support [Disabled]
Flexkey [Reset]
Load from Profile [1]
Profile Name [3600 RAM]
Save to Profile [2]
DIMM Slot Number [DIMM_A1]
Bus Interface [PCIEX16_1]
Download & Install ARMOURY CRATE app [Disabled]
Overclock [Auto]
Power Down Enable [Auto]
Cmd2T [Auto]
Gear Down Mode [Auto]
CAD Bus Timing User Controls [Auto]
CAD Bus Drive Strength User Controls [Auto]
Data Bus Configuration User Controls [Auto]
Infinity Fabric Frequency and Dividers [Auto]
ECO Mode [Disable]
Precision Boost Overdrive [Advanced]
PBO Limits [Manual]
PPT Limit [W] [142]
TDC Limit [A] [95]
EDC Limit [A] [125]
Max CPU Boost Clock Override [200MHz]
LN2 Mode [Auto]
SoC/Uncore OC Mode [Disabled]
VDDP Voltage Control [Auto]
VDDG Voltage Control [Auto]
NUMA nodes per socket [Auto]
LCLK DPM [Auto]
LCLK DPM Enhanced PCIe Detection [Auto]
Core Performance Boost [Auto]
Global C-state Control [Enabled]
IOMMU [Auto]
TSME [Auto]
Custom Pstate0 [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
Core Watchdog Timer Enable [Auto]
Power Supply Idle Control [Auto]
SEV ASID Count [Auto]
SEV-ES ASID Space Limit Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
MCA error thresh enable [Auto]
PPIN Opt-in [Auto]
Indirect Branch Prediction Speculation [Auto]
DRAM scrub time [Auto]
Poison scrubber control [Auto]
Redirect scrubber control [Auto]
Redirect scrubber limit [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
1TB remap [Auto]
DRAM map inversion [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
ACPI SLIT Distance Control [Auto]
ACPI SLIT remote relative distance [Auto]
GMI encryption control [Auto]
xGMI encryption control [Auto]
CAKE CRC perf bounds Control [Auto]
4-link xGMI max speed [Auto]
3-link xGMI max speed [Auto]
xGMI TXEQ Mode [Auto]
PcsCG control [Auto]
Disable DF to external downstream IP SyncFloodPropagation [Auto]
Disable DF sync flood propagation [Auto]
CC6 memory region encryption [Auto]
Memory Clear [Auto]
Overclock [Auto]
Disable Burst/Postponed Refresh [Auto]
DRAM Maximum Activate Count [Auto]
Cmd2T [Auto]
Data Poisoning [Auto]
DRAM Post Package Repair [Default]
RCD Parity [Auto]
DRAM Address Command Parity Retry [Auto]
Write CRC Enable [Auto]
DRAM Write CRC Enable and Retry Limit [Auto]
Disable Memory Error Injection [True]
DRAM ECC Symbol Size [Auto]
DRAM ECC Enable [Auto]
DRAM UECC Retry [Auto]
Data Scramble [Auto]
DFE Read Training [Auto]
FFE Write Training [Auto]
PMU Pattern Bits Control [Auto]
MR6VrefDQ Control [Auto]
CPU Vref Training Seed Control [Auto]
Chipselect Interleaving [Auto]
BankGroupSwap [Auto]
BankGroupSwapAlt [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Rm [Auto]
SPD Read Optimization [Enabled]
MBIST Enable [Disabled]
Pattern Select [PRBS]
Pattern Length(MTS) [3]
Aggressor Channel [1 Aggressor Channel]
Aggressor Static Lane Control [Disabled]
Target Static Lane Control [Disabled]
Worst Case Margin Granularity [Per Chip Select]
Read Voltage Sweep Step Size [1]
Read Timing Sweep Step Size [1]
Write Voltage Sweep Step Size [1]
Write Timing Sweep Step Size [1]
Precision Boost Overdrive [Auto]
FCLK Frequency [Auto]
SOC OVERCLOCK VID [0]
UCLK DIV1 MODE [Auto]
SoC/Uncore OC Mode [Auto]
LN2 Mode [Auto]
ACS Enable [Auto]
PCIe ARI Support [Auto]
PCIe ARI Enumeration [Auto]
PCIe Ten Bit Tag Support [Auto]
Max Voltage Offset [Auto]
cTDP Control [Auto]
EfficiencyModeEn [Auto]
Package Power Limit Control [Auto]
APBDIS [1]
DF Cstates [Auto]
Fixed SOC Pstate [P0]
CPPC [Enabled]
CPPC Preferred Cores [Enabled]
NBIO DPM Control [Auto]
Early Link Speed [Auto]
Presence Detect Select mode [Auto]
Preferred IO [Auto]
CV test [Auto]
Loopback Mode [Auto]
SRIS [Auto]
Discrete GPU's USB Port [Keep Default Setting]
Discrete GPU's SSID/SVID [Keep Default Setting]
MITT/WITT Selection [Both disable]
PCIe/GFX Lanes Configuration [x16]
PM L1 SS [Auto]
Data Link Feature Exchange [Disabled]
Unused GPP Clocks Off [Enabled ]
Clock Power Management(CLKREQ#) [Disabled]
Adjust APU VDDP [Disabled]
Adjust V1.8 [Disabled]
AddCmd MemVref Adjust [Disabled]
External Clock Gen [Disabled]
PCIE REDRIVER TX (J3600) [Enabled ]
Equalizer Setting (db) [1.8_2.7_3.9_7.0]
Flat Gain Setting (db) [1]
Swing Setting (mVp-p) [1200]
PCIE REDRIVER RX (J3600) [Enabled ]
AMD Fan Policy [Air Cooling]
AMD KVM Mouse Protocol [Auto]
M.2 NVMe/SATA Switch (J3705-Slot2) [M.2 NVMe/PCIe]
M.2 NVMe/SATA Switch (J3706-Slot3) [M.2 NVMe/PCIe]
Ohne Overclocking und/oder Optimierung kannst du ja nur PBO/DOCP (XMP) ein und ausschalten.
Der Rest ist wie er ist.
Subjektive Meinung: Ich habe ein performantes Win11 UEFI drauf welches meine 5900X auch unterstützt und gut ist.
Ramm hab ich zeitaufwändig auf 1900/3800 IMC/Memory (14-14-14-32) rumprobiert und so läuft das (schon sehr lange) unverändert.
Sollte mit irgend ein W11 Patch, oder Update einens Benchmarks Punkte klauen - dann soll es so sein.
Sollte tatsächlich fühlbar fehlende FPS, Systemleistung, Bootloops usw auftreten, dann klar...
Bis dahin mach ich mich nicht bekloppt und fummel mit anderen (neueren) UEFI die cl 14@3800 raus.
Das ist es oft nicht wert.
Edit:
Das ist bei mir die
4021 aus 2021/08/26
Ich habe "PBO Fmax Enhancer" = Disabled, Massives Clockstretching beim 5950x. Telemetry ausloten sollte bei Cinebench nahe 100% sein. Habe auch Bios 4021 aktuell.
"1. Update AGESA version to ComboV2PI 1.2.0.A
2. Mitigate the AMD potential security vulnerabilities for AMD Athlon™ processors and Ryzen™ processors
3. Improve system stability
Seit dem letzten Bios, läuft das Brett mit DDR4 4000 und 18ner Timings stabil. 24/7. SoC (CPU-VDDNB) steht sogar auf Auto, sprich 1.087~1,097v.
