[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Grafikkarte ohne Wakü geht gar nicht :giggle:
Die Zotac unter Luft hört sich an wie ein angeschossener Braunbär:lol:
:lol:
... der gleichzeitig tierische Zahnschmerzen hat 🤣
Wenn man ihn nicht, für mich fast noch einfacher, direkt unter Wasser abkühlt :bigok:
Soo, heute kommt meine Gaming OC, ich stell mich schon mal auf das schlimmste ein 😆
Die Lüfterkurve ist n Problem, der Rest der Karte war zumindest bei mir top. Ich drück dir die Daumen.
Hab eine 4090 von Gigabyte (Gaming OC).
Ist das normal, dass die Karte ohne Belastung am Desktop ca. 50 Grad (Hotspot 58) hat mit GPU Clock 210?
Bei den Bechmarks und Spielen geht sie auf 68-70 Grad und Hotspot 78-80° hoch (Lüfter bei 1300rpm).
Finde ich schon sehr hoch.
Meine 4090 Gaming OC hatte beim Benchen max 60 Grad auf der GPU und 70 Grad Hotspot. Deine Werte sind heftig hoch finde ich. Idle lag übrigens bei etwa 30 Grad.
wenn der kühler nicht gut sitzen würde, wären die last temps auch nicht gut.
60-70 halte ich mal für ganz gut.
PT auf 100% oder niedriger?
mein tuf idlet bei 33grad aktuell
:lol:
Und ob das sehr gut geht!
Hatte vorher die Asus Rog Strix RX 6900 XT LC und jetzt die RTX 4090 Gaming OC und die läuft wesentlich Kühler und leiser. Nehme keine Lüftergeräusche wahr und auch kein Spulenfiepen.
Bei meiner Gaming OC ebenfalls so 👌👍
Ich vermute auch fast, dass der Kontakt zur GPU nicht gut ist.
Habe hinten mal probehalber die 3 von 4 Schrauben festgeschraubt. Konnte da noch 2 Umdrehungen machen, jedoch sind die Schrauben ja überfedert.
Die mit dem Siegel wollte ich nicht angreifen. Temperaturen haben sich minimal verbessert (kühlt schneller nach Last ab).
Ich denke aber, dass die WLP schlecht verteilt wurde. :rolleyes2:
@Scrush sind die Temps nach einer Belastung (Zocken,...) oder frisch nachdem der PC gestartet wurde?
Keine Karte unter Luft ist im Vergleich zu Wakü unter volle Leistung leise.
Vorallem wenn man möglichst viel Leistung rausholen will.
Selbstverständlich!
Bei den alten Strompreisen würde ich eine RTX 4090 zu gerne mit einem MoRa unter Wasser setzten... Aber bei der derzeitigen Lage wird sie bei mir bis kurz vorm Absaufen undervolted und auf den letzten FPS reduziert, der gerade so eine flüssige Darstellung ermöglicht!
Ja es wäre schlauer gewesen eine 4080 zu holen aber ich wollte die 4090 haben.
Die wird bei mir selten über 60° C heiß und die Lüfter sind immer auf 60%, die ich sehr angenehm finde, sogar bei meinem an den Seiten komplett offenen Gehäuse.
Die wird bei mir stock nie laufen, also macht es keinen Sinn für eine Wasserkühlung und nach 2-3 Jahren wird sie eh gegen eine 5090 ersetzt und muss noch die Garantie behalten.
Selbstverständlich!
Hab gerade die Lüfter auf 60% geregelt und für mich sind die Lüfter weit weg von leise.
Wie schonmal gesagt, jeder nimmt die Geräusche anders wahr.
Heute konnte ich die Karte unter Wasser setzen.
Die Kühlleistung ist enorm. GPU bei über 500 Watt und 18° C Wassertemperatur nur 37° C.
VRAM etwas weniger. Habe die Alphacool SoftPads genommen.
Die Karte hängt etwas durch, aber sonst nice and clean(y)
Ein Tick kürzer wäre der Schlauch schon passender. Vielleicht liegt es aber auch am Winkel der Aufnahme.
Die sollen lieber mal ein gutes Angebot für die Gaming X Trio 4090 raushauen, die Karte dümpelt immer für um die 1950 - 2000 rum, so 1899 wäre gut.
Würde mit 2 90 grad Adapter hinten in den das Gehäuse reingehen und unten wieder in die gpu rein, wirkt, denke ich, cleaner
Ähnliche Themen
