[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Es ist immer noch egal wie das Kabel geknickt wird, solange du das Kabel wirklich richtig eingesteckt hast.
Alles klar, richtig drin ist es 100%, auch eingerastet.
Ich habe "penibel" darauf geachtet.
Hatte nur etwas bedenken wegen der doch hohen "wärme" unter 450W Last, das sogar das Gals sehr warm/heiß war. Das waren ja "nur" 7min TimeSpy.
Hallo, ich hätte mal eine Frage an alle Eigentümer einer Gigabyte 4090 Gaming Oc:
Die geringstmögliche Lüfterdrehzahl, die ich einstellen kann (Afterburner/fancontrol) sind 63%, mit denen die zwei vorderen Lüfter auf ca. 930 RPM drehen, der hintere (unter der Aussparung der Backplate) aber mit ca. 1170RPM. Wenn ich den hinteren per Hand etwas verlangsame oder ganz abschalte, ist alles flüsterleise... aber den stärker drehenden Lüfter hört man sonst leider deutlich (und dann läuft er ungünstigerweise noch etwas unrund)
Könnt ihr mal schauen, ob ihr das Verhalten bei euch auch beobachten könnt?
Bin dadurch ehrlichgesagt schon recht entäuscht von der Karte, denn meine alte Palit 1080 war selbst unter Vollast kaum wahrnehmbar...
(Klar, selbst für 300W Powertarget mag die Mindestdrehzahl nicht ganz reichen, aber gibt ja dann doch auch das ein odere andere Spiel, das etwas anspruchsloser ist)
Caseking halt! Der steht auch noch in einem Jahr so da
Aber irgendeiner wird’s schon kaufen 😀
Notfalls Ratenzahlung 🤪
Ich habs bei mir gefühlt 10x befummelt bis ich mir sicher war.. oh und bei mir wurde das Fasgear Kabel auch recht warm, wird aber an der Karte selbst liegen. Durch die Location kriegt das Kabel sehr viel Abwärme ab.
Ja, ich habe auch gefühlt 10x richtig gedrückt und geschaut das es 100% safe drin steckt, auch wenn es beim 1x schon klick gemacht hat und sauber drin war. :d
Aber, sicher ist sicher.
Ich hoffe einfach das CableMod fix ihre Winkeladapter rausbringen (Ende Feb. soll es wohl so weit sein). Und ich hoffe es passt auch auf die AMP Extreme; bisher ist keine Zotac da gelistet. o_O
So gaaaanz wohl fühle ich mich nicht, wenn das Kabel so warm/heiß wird, das die Seitenscheibe an der Stelle auch recht warm wird. :d
Langsam bin ich das Warten auf den nächsten Drop echt Leid. Viele AIB 4090s auch zu besseren Preisen verfügbar.
Ich glaube, dass der Preis der FE bald runter gehen wird. ASUS passt seine ASUS TUF non OC Karten meistens der UVP an und kostet nun 1799 Euro im ASUS Shop. Schauen wir mal beim nächsten Drop :)
Ich bin echt froh, die AMP Extreme Airo 4090 für 1990€ + 10% Cashback über Shoop bekommen zu haben. (168€)
Also effektiv "nur" 1822€; + meine 3080Ti wird ja auch noch verkauft.
Aber dennoch ein sehr teurer Spaß/Hobby. :fresse2:
Ja genau! Die Karten blasen einen mehr oder weniger großen Anteil ihrer warmen Abluft gegen die Seitenscheibe. Dadurch kann man nicht wirklich feststellen, ob der Stecker nun von innen oder außen erwärmt wurde. Es sei denn, man hat einen Wasserblock drauf.
Bei mir ist dann auch nur die kleine stelle am Glas so warm/heiß wo das Kabel anliegt/drückt.
Der rest der Seitenscheibe ist sogar sehr kühl.
Ich werde nachher mal das Frontglas entfernen und am Kabel selbst testen ob es sich zu heiß anfühlt, wenn TimeSpy läuft.
Welcher Shop hat aktuell 10%??
Er meint den Cashback über das Portal "Shoop" ;)
Das ist mir bekannt. Man kauft die Karte aber nicht bei shoop sondern in ringm Shop und den Namen möchte ich wissen.
Edit. Ich bin mit Shoop schon vertraut aber die 10% CB sind mir durchgegangen.
Den Rabatt gab es vor zwei Wochen bei Galaxus via Shoop. War ne Sonderaktion.
Preis für die Amp Extreme Airo geht mom auch mit 1965 EUR aber ich warte Jetzt auf ne FE aber auch nicht ewig die Airo hatte ich schon die Lüfter sind echt unangenehm.
was jetzt Passiert grade ne GameRock reingekommen bei MF Schnapper 3234,41 EUR xD
Laut der Liste https://www.hardwareluxx.de/communi...tx-4xxx-coilwhine-fiep-rassel-thread.1324904/ sind bei 50% der Leute die Lüfter nervig.
Meine ist zum Glück absolut top. Lüfter waren unter Last bei 30% (1000-1100rpm) und absolut Top. Kein Brummen etc, halt nur sehr leichte Lüftergeräusche wenn sie laufen.
Habe gestern die gigabyte gaming oc erhalten. Bin echt positiv überrascht.
Rennt top das Teil und optisch kann man auch nicht meckern.
Spulen hört man keine, aber die hat ja auch kaum welche 🤣. Ne, also echt gut die Kiste.
Macht Spaß. Ist kein Taktwunder aber auch keine Gurke. Also wenn die mal im Angebot ist, kann man da mmn bedenklos zugreifen.
Rgb soll bei denen ja nen Graus sein, also einfach auf wasser umbauen 😝.
und dieses Laufgeräusch finde ich Übel, selbst bei 30% Video gucken im Idle schon genervt und war das lauteste im System sonst war das abgesehen davon ne Top Karte.
Vieleicht Dropt ja heute mal ne 4090 Founders wäre mal schön aber glaube nicht dran. Mom leider komplett ohne GPU nie wieder NE CPU ohne IGP. Muss hier auf dem 13 Jahre alten Acer mit kaputter Tastaur rumeiern
und dieses Laufgeräusch finde ich Übel, selbst bei 30% Video gucken im Idle schon genervt und war das lauteste im System.
Hmm, also im Idle ist die bei mir nie an, egal was ich mache. Streams, Videos, Surfen etc.
In WoW Dragonflight ist sie sogar nur semi aktiv. (Gut ist ja nicht wirklich ne Last für ne 4090 in 1440p)
Aber wenn sie mit 30% läuft, ist es bei mir nur wahrnehmbar wenn ich alles auf mute stelle.
Das ist von 1h 30min WoW und 3-4x raus tabben in Chrom Tabs switchen.
bei mir ging sie an aus wie sie grade bock hatte, habe sie zurück gegeben, evt hatte sie ja einen weg. Geld von Medimarkt war jedenfalls innerhalb sek drauf und jetzt brauche ich halt wieder eine am liebsten halt ne FE aber wenn das nix wird, wirds wohl wieder ne AMP
Okay, das hört sich eher nicht normal an und würde mir auch mega auf den Sack gehen. :rolleyes2:
Hier mal was zu AMD's Sales Strategie (ab 02:30) aber ich poste es bewusst hier, weil ich keinen Bock auf AMD Fanboy Attacken habe. Wie man sieht, die geben sich alle nix. Jedenfalls kann man deswegen aber auch nichts auf Verkaufszahlen geben. Macht NVidia sicherlich ähnlich, aber AMD sagt jetzt "kann jeder wissen, uns doch egal". :fresse:
@Gurkengraeber
Und was ist daran nun die Nachricht? Das ist nun mal eine der möglichen Reaktionen auf ein stark geschrumpfte Nachfrage.
@Gurkengraeber
N offizielles Statement habe ich bisher dazu noch nicht gesehen, nur Gelaber diverser Fanboys. Insofern ist eine Bestätigung eines Gerüchts für mich eine Nachricht, vorher war alles nur Geblubber.
Dass das grundsätzliche Vorgehen nichts neues ist, ist klar. Jedoch sollte man eben daher auch bezogen auf Verkaufszahlen vorsichtig sein. Einige sahen NVidia schon in den Bankrott gehen, weil die Lovelave Karten ja angeblich so "schlecht" laufen. Vielleicht tun sie das, weil es NVidia (und eben AMD) so wollen.
@Tomcat66 + @Emosch
Die deutlich wärmeren Stellen sind bei mir das PCB an der Buchse und am PMD-USB mit der Corsair-12VHPWR-Kabelpeitsche
Momentan mit Benchtable, aber der Kram war im Case verbaut und zeigte keine kritischen Temperaturen
Furmark mit ca. 600W Last
@Tomcat66 + @Emosch
Ich habe selbst einmal gemessen; aber nur mit einem normalen Infrarot Thermometer. Aber selbst wenn man 1-2°C Toleranz drauf addiert, sollten es akzeptable Werte sein die real nicht weit abweichen. (die haben ja eher 0,x°C Toleranz)
>Einmal mit offenem Seitenfenster und so gut wie keiner Biegung gemessen.
Am Stecker; bzw. wo die einzelnen Adern noch sichtbar sind, bevor der Sleeve kommt sind es 40-43°C
>Und einmal mit geschlossenem Seitenfenster und der Biegung wie es halt geht, aber die Front im O11 XL offen, damit ich da reinfassen/fühlen und Messen konnte.
Da waren es eig. die gleichen Werte.
Beides gemessen im GPU Test vom TimeSpy run bei 450W 100%PT. (So nutze ich die Karte mit 80%)
Gefühlt war aber die Backplate nähe des Steckers wärmer als das Kabel selbst.
Ach, und bei mir war das Seitenfenster auch so warm, da die GPU seitlich echt gut Hitze abgibt.
Laut be quiet sind bis 60°C für Kunststoff kein Problem.
Das ist mal ganz schön blöd mit dem Kabel.
Habe zum Seitenteil hin so gut wie gar kein Platz. Meint ihr man kann es so stark biegen??
Ähnliche Themen
Antworten
7K
Aufrufe
586K
