[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
roman hatte die tage ein video zu LM auf Nickel. da hats den kühler gefressen. weis aber nciht mehr ob das zusammenhing ^^
Wenn du das Video mit der Zuschauer Post meinst.. "Kupfer" und "Aluminium" hören sich nicht so ähnlich an, dass man das verwechselt..
Deine Mudda ist kein Problem auf Nickel im Gegensatz zu LM kannst du watercool zurückschreiben (y)
1634428944791-png.680766
In Physik nicht aufgepasst? Bei dem kindischen Verhalten würde es mich nicht wundern. Nein, LM ist weiterhin kein Problem, weder für nickle plating noch pur copper.
stimmt, hast recht. war alu :d
Und wenn ich dir nen Video zeige, wo man sieht, dass etwas nach unten dropt, wirst du behaupten, es fallt nach oben.
Das was man auf dem Bild sieht: Es ist LM das sich ins Nickel gefressen hat. Die Shice bekommt man da auch nicht mehr raus, die Oberfläche ist nun rau.
Deine Mudda somit. (y)
Ja die Oberfläche wird zwar etwas "angegriffen", es frisst sich aber nicht durchs Material, es entsteht keine Reaktion. Es sieht halt unschön aus. Ich würde aber auch immer auf LM verzichten.
Wie ist das eigentlich bei der Gamerock - wird das PCB wieder gerade, wenn man den Kühler runternimmt und einen Wasserblock installiert?
Das PCB ist grade, die Backplate folgt dem freien Ende des Kühlers, und wenn dessen Heatpipes nicht 100% waagrecht sind, gibts den leichten Knick da wo die Ausfräsungen zum Durchblasen des dritten Lüfters beginnen. Absolut nebensächlich, wenn die Karte bekannt zu den leiseren Vertretern gehört.
Stuttering in Dead Space wurde mit einem 200mb Patch behoben.
Ebenfalls der DLSS Bug (nach Neustart von Quality auf Balanced).
OC Stabilitätstest Deluxe:
Dead Space in 6K (4K DLDSR 2.25) + DLSS Quality und alles auf Anschlag.
Die Auflösung ist hier entscheidend. 4K oder 5K via DLDSR 1.78 reichen nicht aus.
Man muss mit CRU die 4096er Auflösung killen.
BTW ich hab Dead Space 2 gezockt. In 5K mit RTGI (Ray Tracing via Reshade).
Meine 4090 hat 600w verbraten, als ich mit der RT Config in Reshade gespielt hatte ^^)
Am Ende nutze ich RTGI und Levels.fx
der patch ist aber bei Origin noch ned angekommen :) ) ps ., ich hasse diesen client )
Ui Patch ist bei Origin angekommen :)
Hallo.
GIbts eigentlich ein anderes Programm mit einem Curve Editor, außer dem MSI Nachbrenner, womit man eine RTX4090 optimieren kann?
MfG
Naja, der reddit thread ist da weit zutreffender, ich habe ja keine Crashes in Games, selbst mein zugemoddetes gta5 läuft problemlos und da zieht die 4090 (0.95v/2760mhz/90% PT) bis zu 380W bei 100% Load. Bei mir friert ja auch der PC nicht ein, nachdem blackscreen kann ich alt+f4 und enter drücken und die Kiste fährt normal runter.
Nach bisschen lesen werde ich jetzt mal HAGS deaktivieren in Windows und wenn es dann nochmal auftritt werde ich mir das 12pin Kabel meines tollen MSI NTs mal genauer anschauen, bei reddit konnten es wohl einige lösen durch einen Kabeltausch
in dem Thread den ich verlinkt hab geht es auch um Crashes auf dem Desktop/Idle.. das kommt bei einigen mit der 4090 vor, ich hatte das bei 5 Karten bisher aber zum Glück noch nicht....
Maan, ich hasse das. Wieso kommen andauernd Spiele raus, die am Stuttern sind zu Release und ein paar Tage später geht es dann?? Wieso nicht gleich so releasen? Man muss bei PC Releases mittlerweile einfach immer eine Woche drauf rechnen auf das Releasedatum. Hab gestern auch nochmal kurz reingeschaut und ja, Stuttering scheint fast komplett eliminiert zu sein und man kann endlich VRS aus machen, was die Optik nochmal verbessert. Nur wenn ich grade neu reingeladen bin hab ich für ein paar Sekunden noch ein paar Ruckler beim Umsehen.
Hallo.
MfG
Asus GPU Tweak III. Hat ein in meinen Augen schöneres Overlay und braucht kein RTSS dazu. Aber dafür ist die Curve-Handhabung leicht schlechter als in AB. Und das Übernehmen der Pforile auch etwas wackliger. Ich bin nach einem Monat (weil ich viel experimentiert habe und mir das auf den S... ging) wieder zum AB zurück.
Ich hatte ja das Problem, dass mein PC im Idle (und nur dort, in Games ist alles rockstable) irgendwann die Grätsche macht und nicht mehr reagiert/komplett eingefroren ist.
Lösung ist ganz banal:
Ich musste tatsächlich PT 90% + bissel OC (70/700) wieder zurück auf auf Stock schieben und habe nun seit 1 Woche keinen freezer mehr.
Kam gar nicht drauf, dass dieses minimale Pussy-OC (es ist ja schließlich eine Strix OC!) hier der Bösewicht sein könnte…
Wieder ein Paradebeispiel wie das Modell gar nichts mehr aussagt (in dem Fall Strix). :(
Können wir bitte wieder High End Modelle mit High End Binning kriegen?!
Cyberpunk scheint laut reddit Patch bekommen zu haben für DLSS3. Gleich mal nach der Arbeit probieren später. :) Ob es immer noch so flickern gibt bei Zäunen und den Radkappen beim Caliburn.
Mal ne Frage: Ist es möglich die Einstellungen aus MSI Afterburner irgendwie auf die Karte selbst zu übertragen? Via BIOS oder ähnlichem?
Vor paar Tagen tauchte hier ne Frage auf...aufheulen der Lüfter im Idle oder Youtube schauen bei der Gigabyte Gaming OC. Ist mir jetzt seit 22.10. nicht aufgefallen. Aktuell ist es mir tatsächlich bei der 200sten Stunde in Eldenring für eine sec. passiert. Kurz aufgeheult dann wieder normal und nur einmal. Hab immer noch das Auslieferungsbios drauf. Ansonsten funktioniert die Karte ohne Probleme. Dies geschah aber nach nem kurzen Win 10 und Geforce Experience Update und die Batterien vom Xbox Controller waren gerade leer. Keine Ahnung ob da ein Zusammenhang besteht.
Beste Grüße
nicht das ich wüsste.. Bin auch froh, das das nicht klappt. Was tun bei falschen OC Einstellungen. :)
Frame Generation benötigt wohl viel VRAM sodas bei einer 4080 schon upsampling empfohlen wird bei CP 2077
NOTE: it is recommended to enable upscaling (DLSS) on graphics cards with 16GB or less of VRAM and 1440p or higher resolution.
hä, DLSS3 ist doch schon ein Upscaler :unsure:
Ähnliche Themen
