[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sind 38006 Grafik Score. Kommt eher hin 😜
38000 ist schon heftig viel, würde sagen, dafür braucht die FE mindestens einen overclock von 220/1500
Joa sollte 133% können ^^
Deine original Curve zeigt 2760MHZ ungefähr an wenn ich das richtig mit dem Smartphone identifizieren konnte . Also die dünne Linie .
Dachte schon ^^
Das sind alle Regler wahllos verschoben gefühlt, was soll denn daran Stock/Out of the Box sein? Du siehst ja sogar wie deine Kurve nach oben verschoben ist.
Bye the way...Beim Tarkov spielen.....GPU ca. 41 Grad...Hotspot 47 Grad mit der Frostbite.
Wobei 2880MHZ ist auch ziemlich hoch ^^
Naja so die durchschnittliche Karte liegt so von 2700-2800MHZ @ Stock . Wenn man kein CPU Limit hat kommt man etwa im Bereich 36500 Grafikscore @ Stock .
Lade dir mal die neuste Beta vom AB . Dann sollte auch mehr gehen .
Bei mir ist der max wert 133% .
Wenn ich es im afterburner richtig sehe, macht meine 2820MHz
Naja wenn die Karten @ Stock einen hohen boost haben ist das auch ein Indikator dafür ,
dass die Karten @ OC was können , außer wie ***** schon erwähnte der Hersteller via Offset die MHz angehoben hat .
Meine hat Out of the Box 2700MHZ @ 1,05 und 2775 @ 1,1 V .
Meine packt 1,1V 3060MHZ in 3dmark Benchmarks und 3105 in Superposition .
Müsste deine denke dann mehr können
Ich habe die 4.6.5 16.358 Beta 4
Bei dir ist eh was komisch . Du hast irgendein Auto OC drinne . Bei dir ist etwas die Spannung angehoben . Die Curve hoch gezogen . Musste mal nachschauen bei dir .
Also habe ich eine einigermaßen vernünftige Karte erwischt?
Kannst es ja testen . Dann weißt wie gut deine Karte ist .
Du hast deine Karte übertaktet und scheinbar ist dir das nicht bewusst . Daher kein Plan ob da nicht noch eine zusätzliche Software bei dir läuft . Kann ganz normal das PT bis 133% erhöhen . Kann grad kein Bild machen , weil ich auf der Arbeit bin .
Mach mal per DDU den NV Treiber weg und einen Reinstall des NV Treibers danach.
Schaut nicht verkehrt aus. Mit Wakü bist du natürlich etwas besser dran, weil Sie nicht diese down steps ab 50°C macht. Aber normaler Range "out of the Box" für Karten die nicht cheaten (ASUS TUF/STRIX + Suprim mit+45/+60) ist 2700-2800 was ich so gesehen habe. Da ist dann 2835 minus 1-2 steps wegen Temp schon gut :)
Was ist denn Auto-OC?
Das Powertarget muss doch irgendwie zu erhöhen sein?
a) Kannst du mal auf "RESET" drücken und schauen ob sich die Kurve ändert?
b) Kannst du mal per DDU den NV Treiber entfernen und nach dem Reboot bei der Neuinstallation auch "clean install" auswählen? Vermute dass da mehr verwirrt ist.
Im time spy extreme im Notebook area51m mit spezieller alienware egpu schafft die 4090 ventus nur 19000 Punkte im ts extreme
Die Strix haben +45MHZ . Die TUF nicht . Auch die OC nicht .
Welche eGPU genau? Thunderbolt 3? Damit sinkt die PCI-E Bandbreite auf PCI Express 1.1 x16, was nach techpowerup in 4K 19% weniger wäre. Schätze der Rest ist dann wahrscheinlich eher CPU Limit bei einem 9900K mobile.
Ref: https://www.techpowerup.com/review/nvidia-geforce-rtx-4090-pci-express-scaling/28.html
My bad, korrigiert.
