[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@SH
Danke für den Tipp ... na, da bin ich ja mal neugierig, ob die kommt 😅
Oh Gott, was hab ich getan :shot:
Und wie finde ich raus ob Sie fiept, ohne Sie unter Wasser zu setzen? Eingebaut zurückggehen lassen ist ja assi.
Aber ich sehe, die ganze Charge geht wenn Sie kommt ins Luxx :d
In den anderen Shops teils nur etwas teurer, aber verfügbar:
Scheint also kein Preisfehler zu sein.
Dann haben wir wenigstens mal einen repräsentativen Fiep-Querschnitt zu dem Modell.
Wobei, wenn die arg fiepen sollte, geht die auch nach nem Underwater-Testlauf zurück. Da kenn ich nix 😅
Scheinen ja zumindest dieselben Spulen im selben Ausbau wie bei der Zotac Trinity draufzusein. Das stimmt mich schonmal erwartungsvoller, auch wenn meine Trinity hier eben kein Leisetreter ist. But lets see. Hoffentlich alle noch 20€ shoop mitgenommen :)
Bei Computeruniverse ist das Angebot weg. Bestellbestätigung hab ich bekommen. Jetzt heißt es abwarten, ob die Stückzahl ausreicht.
Natürlich ist das kein Preisfehler… man sieht doch ganz deutlich, dass die Nachfrage sinken ist bzw. eine gewisse Sättigung erreicht wurde.
Hatte nur auf einen Beitrag von vorhin reagiert. Aber deine Aussage stimmt insofern, da der Zenit der Nachfrage überschritten zu sein scheint. Die Enthusiasten und Rich-Kids scheinen größtenteils versorgt zu sein.
Oder sie testen eben die 4., 5., 6. Karte😁
Bin gespannt ob die 4090 Preise wirklich sinken. Ich mein die top of the line Karten wurden nie verramscht, auch bei wenig Nachfrage, was ja erwartet wurde. Ich denke also kaum, dass NVidia hier versuchen wird, über den Preis mehr Absatz zu generieren. Also vielleicht irgendwann noch einen 100er runter bei der FE, das wars.
Die Vendorkarten könnten sich vielleicht noch in die Richtung der FE bewegen, aber der Preisverfall kam erst wie erwartet kurz vor Release von Lovelace Ende Q3 22. Ich denke man wird sich so zwischen 1900 und 2000 einpendeln. Nur für die Manli wären noch 1700 zu viel. :fresse:
Das ist unterschiedlich, für die 4090 FE war der letzte Drop am Dienstag den 03.01.23. Davor war es der Montag den 05.12.22,
Am einfachsten ist es wenn Du der Telegram Gruppe für die Nvidia Drops folgst. So konnte ich am 03.01 auch eine ergattern.
Handy hat Alarm geschlagen für den Drop und direkt übers Handy dann zugeschlagen.
Würdet ihr 600W durch ne 16 Phasen-Karte jagen? Hätte schon bock das Bios meiner 4090 zu flashen :fresse:
Die frostebite ist halt selten. Preisfehler würde ich jetzt auch nicht sagen, aber wenn man sie will, sollte man zuschlagen. Denn die Karte ist halt selten und bietet schon Vorteile gegenüber dem Einzelkauf von Karte und Kühler.
Warum nicht? Ist ja nicht so als sei der ganze Kram eh overspecced. Ich garantiere auch jeden, meine Zotac wird bis zum Verkauf ohne weiteres halten, mit nem 666 Watt Bios und 14 Phasen.
Asus Ihr Volldeppen! Ein schwarzer Adapter zu einer weißen Karte? Ihr seid echt die dümmsten... allesfressenden Paarhufer. Man ey... :rolleyes:
@Gurkengraeber, schöne Karte.
Kannst ja mal berichten ob die Karte auch so doll fiept und schreit.
:d
Damit will dir Asus nur vermitteln, dass du den blöden Adapter gar nicht erst nutzen, sondern gleich was gescheites bei Cablemod bestellen sollst.;)
Also die Benchie Ergebnisse sind out of the Box ok. Boost bei 2795MHz.
Zirpt wie eine Grille. Ich glaube rasseln ist der falsche Ausdruck. Es hört sich so an wie ein kleines RC Car mit Mini Benzinmotor.
Aber die Karte passt wie gesagt nicht richtig ins Mesh 205, daher warte ich noch auf das H7 und werde es dann im geschlossenen Gehäuse beurteilen. Musste den unteren Intake Fan ausbauen. :lol:
Krass, dass Asus da solche probleme zu haben scheint. Ich hatte in den ersten 2-3 Tagen Spulenfiepen, jetzt ist es gegen 0. Fast nichts mehr.
Naja habe die Karte eben gerade bekommen. ;) Also werde die Widerrufsfrist ausreizen und die Karte wirklich testen. Vielleicht auch mal die Backplate etwas lockern oder so. Wenn sich das dann etwas beruhigt, alles gut. Vielleicht habe ich Glück. Wenn nicht tschö mit ö.
Meine neue Suprim X hat unterschiedliche Spulenfiep Geräusche wenn ich bei War Thunder das Thermalvisier an oder aus mache. Wenn ich im Thermal bin ist es eher ein fiepen, in der normalen Ansicht ein rasseln. Wie kann das bitte sein 🥹😂
Ähnliche Themen
Antworten
7K
Aufrufe
423K
