[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was ist von der Palit Gamerock OC zu halten? Könnte die für knapp 1.900 EUR erhalten. Hat im Gegensatz zu der Manli 500W, 4 Stecker und 5 Jahre Garantie, wenn ich das richtig sehe?
Höhö, ich hab meine TUF für 1999 EUR vom Asus Shop letzte Woche zurück geschickt.
Selbst bei 50% Auslastung, und Simulator spielen, bei jedem Scrollen, dieses Rassel/Fiep Geräusch, nein danke^^
Heute kommt meine Gigabyte ausm Mindstar Shopping :d
Habe eine Gigabyte 4090 goc, leider sind die Spulen nicht so geil, bei der Gigabyte 4080, diese waren super, null Komma null zu hören.
Behalte sie dennoch, da sie nur 1580€ kam.
Ich hatte sie kurz, in der NON OC Variante mit dem 3er Stecker. War sehr leise und hatte kein Spulenfiepen bei mir. Die 4090FE die ich jetzt habe, ist da schlimmer. Aber war eine Bananenkarte und heftig gebogen. Der hintere Teil des Kühlers.. nicht das PCB. Hab hier in dem Thread auch einige Bilder gelassen. Ansonsten haben ein paar gute Erfahrungen mit der Palit gehabt. Was noch war, glaube da gab es eine art Lüfterrasseln bei Gainward und Palit.. am hinteren Lüfter. Weiss aber nicht, ob dies noch Bestand hat.
Falls noch jemand im CPU Limit hängt. ;)
Ab heute gibt's den 13900KS mit 150W TDP für 699 US-Dollar.
"Der 13900KS ist ein besonders gut vorselektierter 13900K, der mittels Intel Thermal Velocity Boost („TVB“) erstmals überhaupt mit 6 GHz in den Werkseinstellungen daher kommt und damit insbesondere Spieler und Enthusiasten adressieren soll." :fresse:
Naja mal sehen, wie diese Selektion so aussieht. Da es noch einen Raptor Lake Refresh (Ende Q2) geben wird, ist der KS eigentlich total uninteressant. Er würde sich ggfs. nur lohnen, wenn die P-Cores eine SP von 120+ haben. Mal sehen, was die ersten Tests so sagen :).
Edit: Bei einem Review hat dessen KS eine Overall SP von 115, was schon recht hoch ist. Im Review von Hardware Unboxed ist der KS auf jeden Fall schlechter, als mein K aber dort weiss man die SP nicht. Bei einem anderen Review hat der KS nur eine Overall SP von 107, was meinem K entspricht. Daher wäre es wieder Glück, eine KS zu bekommen, welcher besser ist, als ein guter K.
Weiß jemand ob die GPU Mounting Löcher bei der 4090 anders als bei der RTX 3090 sind? Ich habe nämlich ein Auge auf die "aktive Universalbackplate" von Bykski von nem Freund geworfen, die wird ja nur mit den 4 Schrauben vom GPU Die befestigt.. 🤔
Tritt dieser VRAM Cold Bug auch bei Custom Modellen auf? Kannte das bis eben nicht, hab ich es richtig verstanden, dass da der VRAM bei einer gewissen Temp runtertaktet und deswegen instabil wird?
@Tundor Meine TUF habe ich Anfang der Woche umgebaut. Wie unter Luft +1700mhz auf den Vram möglich, auch bei Temperaturen unter 20°C.
Anbei mal die Temperaturen bei 350, 400 und 450 Watt Last. Ein Delta Wasser zu GPU um ca. 20°C sollte man bei der 4000er Generation schon einplanen. VRAM ist top, da hab ich mit den 1mm Pads nur 6°C Delta zum Wasser.
Die Seitenwand geht nach zwei Monaten auch endlich wieder zu
ich glaube ich werde den vorerst nicht ordern außer ich wechsel das case
das nzxt h7 hat 190mm. das cablemod kabel passst da lockerst :)
Ich vermute leider, dass ich selbst mit dem Cabelmod Kabel das Gehäuse nur schwer zu bekomme. Das O11 XL hat halt nicht sooo viel Platz.
Ist jetzt auch nicht soo tragisch weil das Ding eh zur Wand steht aber sollte es diesen Adapater mal geben wäre das vermutlich die Lösung.
Die Cablemod Kabel sind jetzt auch nicht so platzsparend finde ich. Mit nem schön aussehenden Bogen geht bei mir das Asus Helios knapp zu mit der FE. Vllt noch 2-3mm Platz und das Case ist schon recht groß. Das native Kabel von meinem Asus Netzteil konnte man deutlich platzsparender anbringen
Gibt's eigentlich irgend ne Alternative für diesen scheinbar angekündigten aber nie gelieferten 90° Adapter? https://www.computerbase.de/2022-10/cablemod-12vhpwr-adapter-geforce-rtx-4000/
Ja, bei https://www.moddiy.com/ gibts Ultra Flexible Kabel... das ist quasi 90° ^^
Ich hab das O11 (non xl) und da klappt es ohne Probleme, mit dem Kabel (s.o.)
Er hält den Takt stabil, aber wegen den Wassertemps kann es sein dass du 100-300MHz verlierst beim VRAM OC. Es scheinen nicht alle betroffen zu sein und wenn, dann ist der Graka-Hersteller egal.
Meine Suprim X ist jetzt auch unter Wasser. Gedrosselt auf 60% circa 300Watt da mir noch der Seasonic Stecker fehlt. Ansonsten alles auf Stock, CPU per Curve Optimizer (Auto) -30
GPU-Z Max Clock 2835 Max Temp 35,3 Max Hotspot 41,8 läuft natürlich permanent ins Powerlimit.
Meine FE ist jetzt auch eingebaut, naja sie fiept, leicht mehr als die Phantom, aber das Lüfterbrummen (ist ja an sich nicht der Lüfter aber das hatten wir ja schon) geht einem ja schon bei 30% ordentlich auf den Sack :d, werd ich wohl modden, oder Retour gehen lassen müssen.
Ähnliche Themen
Antworten
7K
Aufrufe
584K
