[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Da kannste auch auf Englisch im Shop switchen, dann brauchst Du nicht die planlose Google Übersetzung :d
Falls Dir Fiep- & Rasselfrei wichtig ist (die 4090er machen teils ganz schön Radau), dann würde ich Dir die Zotac Amp Airo empfehlen. Meine beiden sind auch unter Wasser schön ruhig bis unhörbar.
Ich schätze noch 2-3 Wochen warten, dann gibt es die auch knapp über 2K - sind zuletzt in DE nur noch im Preis runtergegangen. Wobei die 2179 € bei LDLC für aktuell schon gut sind - und ist lieferbar :d
Gibts bei NBB lieferbar um 2099.--
Konnte gerade eine 4090FE als B-Ware bei NBB bestellen. (Hier) Insgesamt heute zwei mal als B-Ware Verfügbar gesehen. Beim ersten mal war ich wohl zu langsam. Da ist es mir beim Bezahlen abgebrochen und danach war der Artikel nicht mehr im System verfügbar. Jetzt gerade nochmal als Verfügbar gesehen und bestellt. Soeben auch Auftragsbestätigung erhalten. Hoffe das die Beschreibung "Kratzer" sich im Rahmen hält. :-)
12 Pin Micro-Fit to 2x8 Pin PCI-E for NVIDIA 3000 FE Series (NOT 3090 Ti) (GPU) Ist das so richtig?
Brauche doch ein 16 Pin?! kann aber nur das auswählen.
Du musst an der Stelle "Cable Upgrades" rechts auf PRO drücken, da sind dann auch die 12VHPWR Kabel (16 pin Micro Fit) entweder auf 3x8pin oder auch auf 4x8pin verfügbar ;)
Dankeschön:wink: habe eins bestellt
Danke! Probiere ich gleich mal aus. Habe sogar ein Asus Mainboard
Ah ok. Dann kannst Du sogar die FE mit in Dein RGB Setup einbinden. Wäre zwar eh nur dezent, aber es ginge. (ja ich weiß du willst sie ganz aus haben, nur der Vollständigkeit halber. :) )
Du musst aber am Mainboard einen Rescan der RGB Komponenten durchführen.
Habe gerade meine 4090FE eingebaut und TimeSpy laufen lassen. Passen die Werte für einen 9900K @ 4900MHZ mit Stock 4090 FE ?
Score: 21.697
GPU Score: 26.584
CPU Score: 10.628
Max Takt: 2.820MHZ
Speicher: 1.313MHZ
Ist das nicht zu wenig ? :(
Sehr positiv: Kein Fiepen, Lüfter hörbar aber nicht störend für mich.
zu wenig für was?
wenn timespy einen cpu part hat, dann ist so ein ergebnis natürlich wenig aussagekräftig bzgl gpu
ram? vermutlich haben die anderen einen schnelleren und/oder manuell optimierten ram
mein 12700 non k mit 3200cl16 xmp wird von einem 9900k mit sehr schnellem ddr4 + optimiert geschlagen
Wie mache ich einen Rescan? Ich möchte eigentlich nur alles aus haben.
Hat die 4090 den Speicher nur noch auf der Vorderseite? Also sprich kann der dieses mal wieder von einem Kühlblock der nur einseitig an der Wakü hängt ordentlich gekühlt werden?
Das ist der Gesamt score vermutlich.
Score: 21.697
GPU Score: 26.584
CPU Score: 10.628
Max Takt: 2.820MHZ
Speicher: 1.313MHZ
Frag mal @Stagefire . Der hat auch ein 9900K .
Hatte mit dem 10900K @ 5GHZ auch deutlich mehr .
34K @ GPU Stock und 36K GPU @ OC
Dann hier nun ohne CPU Limit .
GPU Stock https://www.3dmark.com/spy/34357360
GPU OC : https://www.3dmark.com/3dm/86584554?
@Tundor Ja. Bereits mit der 3090 Ti wurden 2GB-Speicherchips eingeführt, sodass jetzt auch 24 GB auf der Vorderseite Platz finden.
Boah ist Hermes ein Saftladen.
Der Fahrer hat mich einmal verpasst und schaffte es nun schon drei Mal nicht vorbeizukommen, obwohl es angekündigt war. Hab 2x umsonst Stunden gewartet und wäre normalerweise weg gewesen. Frauchen ist gestern alleine los und ich hab hier gecampt. Nun dachte ich das käme dann heute (stand da gestern noch), ne, wurde nun heute morgen einfach auf Montag verschoben? (y)
Gerade noch mal refresht, jetzt steht da nur noch "bald":
Deswegen heißt er ja auch "Herpes" hier im Forum :fresse:
im nvidia CP vsync für alle anwendungen aktiviert. wetten?
VSync ist aus. Hatte noch Videobeweis an, aber nun ist alles aus, keine Framelimiter nichts....
So sieht es nun aus...
Also im seitlichen Menü links oben auf die Devices, dann auf Dein Mainboard. Da gibt es einen RGB Reiter wo du oben rechts den Rescan Button haben solltest.
AM5 wird gerade zsuammen gestellt 8-)
Werd mal mit Win11 frisch und AM5 nochmal testen. Wollte nur wissen, ob mit der FE alles io ist ;) Danke Euch
am besten einfach mit Timespy Extreme testen :)
