[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Keine Ahnung, ob ich hier richtig bin, wollte aber dafür keinen Extra Thread aufmachen.
Thema:
4090 und CPU.
Aktuell habe ich einen i7 8700k verbaut, auf einem Asus Z390 Gaming F.
Ich nutze meinen Windows PC ausschließlich zum Zocken, und sonst nichts, für alles andere ist mein Mac da, falls das eine Rolle spielt.
Ich weiß, dass das Z390 PCI 3.0 hat, was aber laut diverser Tests keine große Rolle spielt.
Wie sieht es nun mit der CPU aus?
Aktuell zocke ich auf WQHD, und ich bin mir nicht sicher, ob ich überhaupt auf 4k umsteigen würde.
Wie stark würde mein 8700k limitieren?
Achso, der geht ohne Probleme bis 5 Ghz, falls das eine Rolle spielt.
Frage an sich:
Einfach 4090 kaufen und glücklich sein, oder doch lieber gleich volles Programm, neues MB, 13700k CPU und DDR5 Ram?
4090 + 4k Monitor kaufen und glücklich sein. Wozu für wenige % direkt nen komplett neues Setup kaufen? Wenn in Spiel A die CPU limitiert, einfach DSR nutzen. Man muss sich nur zu helfen wissen. 🤣
Nen 8700K mit ner 4090 zu betreiben wäre tatsächlich Geldverschwendung. Ich bin mit meinem 10850K@5GHz schon brutal im CPU Limit :)
Ist halt sehr Game abhängig muss man ehrlich dazu sagen .
Hat jemand zufällig das 666w Galax bios auf einer Strix 4090 mit 2 HDMI Anschlüssen?
Bei mir gehen beide - habe heute mal den Tv an Nummer 2 angesteckt, ABER nur 1080p/60.
Falls jemand Lust hat das zu probieren wäre cool. Dann weiß ich es liegt am Bios und nicht an irgendwelchen Einstellungen…
Nur 6 Kerne, altes PCIe, weniger IPC, weniger Takt, weniger RAM Performance. Es gibt sicher Games, bei denen das noch ginge. Aber wir reden hier seit 2-3 Seiten von ziemlich flotten Systemen, die mit der 4090 in 4K noch limitiert sind.
2000€ GPU und nen 1000€ 4K Schirm und sich dann einreden weitere 1000€ für eine ordentliche Plattform spart man sich, ist doch schon irgendwie paradox.
Ein 8700K wird zumindest im Computerbase 13900 Test leider schon gar nicht gelistet. Wenn man will kann man den mit dem alten AMD 6Core aus dem Test vergleichen.
Schon jetzt wird so ziemlich jeder Konsolen Port den 8700 überfordern. HZD, Spidey, GOW um nur mal ein paar Titel zu nennen.
Ich würds nicht machen, da helfen auch 4K nicht.
Das ist wie nen 3000€ Kopfhörer an einer Gamingsoundkarte. Klar es wird funktionieren und wahrscheinlich ist man auch erst mal geflasht. Aber bleibt Shice.
Thema:
4090 und CPU.
Frage an sich:
Ich würde an deiner Stelle nen Monitor zwischen WQHD und 4k kaufen.
- Für 4k ist selbst eine 4090 nicht tauglich. Einfach deswegen, weil da noch ein paar Kracher rauskommen werden in den nächsten 2 Jahren. Wenn du auf diese Kracher verzichtest, dann kannst du aber auch bei 4k zugrapschen.
- Du kannst in Auflösungen unter 4k DL-DSR 2,25x reinwerfen und schon hast du dein GPU limit und bekommst in den meisten Spielen nen knackiges Bild. (y)
- Es kommt auf deine target-fps an. Wenn dein System zB +90fps im CPU-limit liefert und du damit zufrieden bist, dann ist auch dein 8700k ok.
Jetzt mal blöd gefragt:
Wer sollte mit zb. 90fps unzufrieden sein?
Online spiele ich überhaupt nicht, und ansonsten, was macht den über flüssigen 60fps überhaupt einen Unterschied?
Da hast du recht und würde da auch einen Rundumschlag machen.
Bin gerade am überlegen einen 13900KF zu bestellen oder noch den 7700X3d abwarten.
Ich bin unsicher....
Ich finde die Mainboards bei Intel mittlerweile echt frech teuer.. Sonst hätte ich längst den 13900k geordert
Wie gesagt, das musst du entscheiden. Jenachdem bei wieviel fps dir einer abged. (y)
Ich schaffe es die 4090 auch in 3440x1440 zu fordern. Einfach mit DL-DSR 2,25x. Und wenn nen CPU limit vorlag, dann waren es 110-140fps (141Hz Monitor-limit eingestellt). Reicht hier auch.
Sobald mir aber nen modernes AAA-Spiel unterkommt, was im CPU-limit ständig 50-60fps liefert, komme ich auch ins Grübeln und suche mir wohl ne noie CPU.
Brauchst jetzt nicht gegen die Meinungen, nach denen Du gefragt hast andiskutieren. Am Ende entscheidest Du. Wenn du nicht mehr als 60 FPS brauchst, brauchste auch keine 4090, dann würde ich mir einfach eine gebrauchte 3090 schießen und in 1440p glücklich sein.
Also wenn 4090 dann auch gleich n schickes System dazu, sonst verschwendest Du einfach Geld. Wenn Du die 90er jetzt haben willst um dann einfach später den Rest des Systems nachzuschieben, geht das natürlich auch, aber dann lieber einfach noch warten, denn die 4090 fällt vielleicht auch noch etwas im Preis.
Wie gesagt, Deine Entscheidung, Meinungen dazu haste nu einige. :)
:fresse:
Ja, nachdem ich nun ein paar Seiten durch habe, bekomme ich mehr und mehr das Gefühl, dass es bei mehr FPS nur darum geht, mehr zu haben, ohne wirklichen Sinn dahinter :d
Aber gut, da ich sowieso ein neues Gehäuse kaufen muss, da ich beinahe nicht glaube, dass ich eine 4090 in mein DB700 bekomme, baue ich vielleicht tatsächlich ein komplett neues System auf - mag ich ja eigentlich schon sehr gerne, die Bastelarbeiten, hat halt irgendwann mal nachgelassen :)
Brauchst jetzt nicht gegen die Meinungen, nach denen Du gefragt hast andiskutieren.:)
Ähm, "ja und amen" ist nicht so mein Ding, ich diskutiere nicht dagegen an, ich versuche zu verstehen ;)
Sicherlich könnte es mir auch genügen, wenn du mir sagst, das 2 + 2 = 4 ist, dennoch weiß ich dann ganz gerne warum.
Joa habe mir 13900KF ,Apex z790 , Teamgroup 7200er Kit und ne Fire Cuda 530 4 TB in den Warenkorb gepackt,
aber fühle mich nicht wohl. Hat man einmal ne Situation wo das mit dem CPU limit bisschen krasser war schon dreht man durch :d
Ne schalte jetzt einen Gang zurück und warte den Januar ab wie sich 7800X3d und 7900X3d machen.
Dann bewerte ich das nochmal neu. Ich will mich nachher nicht ärgern.
:fresse:
Och so ein wissbegieriger bist Du? Klasse, das Internet steht bereit, gibt 100e Artikel und Videos zum Thema.
Und wenn man sich das Apex in den Warenkorb packt, ist es klar dass man sich nicht wohl fühlt. ;)
Uuuund los! :d
Du hast doch noch guten DDR4.
Intel 13700K 450€
Asus Z690 D4 330€
Dazu verkaufst deine alte CPU mit Mobo als Bundle.
Ein APEX Z790 und 13900 sind halt auch maximal unvernünftig.
Mit solchen Beiträgen verlässt du besser diesen Thread. Sowas geht garnicht…
Ich stelle hier eine ganz normale Frage, höflich, darauf bedacht, alle möglichen Informationen mitzuteilen, dann kommt Meister Gurkengräber, und schreibt mit mir auf eine überhebliche Art und Weise, ob er einen 12-Jährigen vor sich hat - DAS geht ganz und gar nicht.
Ich bin schon ein paar Tage hier im Forum, und habe noch nie jemanden persönlich angegangen, oder gar beleidigt, ich behandele jeden mit der gebührenden Höflichkeit, und dann erwarte ich auch, dass man vernünftig mit mir spricht, bzw. schreibt.
Ich habe weder seine Frau noch seine Kinder beleidigt, aber die Antwort, die er mir geschrieben hat, würde zu einem Kind passen - oder zb. einer technisch unbedarften Ehefrau, die quengelt, warum man soviel Geld für Hardware ausgibt, und es dann eben keinen Sinn macht, es ihr "rational" zu erklären.
Kann es sein, dass du in meine Aussage eventuell zu viel reininterpretiert hast?
Ich komme nicht aus dem Ghetto, und bediene mich keines Vokabulars ala f*ck deine Mutter oder sowas.
@Gurkengraeber
Ich wollte dich damit auf keinen Fall angreifen, oder gar beleidigen, noch wollte ich deine Frau oder Kinder angreifen oder beleidigen.
Falls ich mich da missverständlich ausgedrückt habe, möchte ich mich in aller Form bei dir entschuldigen.
Bloß so wie du mir geantwortet hast, sorry, das mag ich nicht, und das war auch von dir nicht die feine englische Art.
Ich wollte dich lediglich bitten, mit mir vernünftig zu schreiben, und nicht, als ob du einen 12 Jährigen vor dir hast, oder es dann lieber gleich ganz zu lassen, wenn du es nicht kannst.
Ich hoffe, ich konnte nun das Missverständniss aus der Welt räumen.
War bei mir auch so, der extra HDMI nur mit 1080p/60hz
0 Verfügbar :fresse2:
Auf die Weise kannst du mit deinen Kindern oder deiner Frau kommunizieren, sofern vorhanden, mit mir unterhalte dich ordentlich, oder lass es ganz bleiben.
Danke!
LoL, nönö, passte schon.
Z790 Boards im passenden Format gehen erst ab 350€ los. :d
Gehen damit auch 8.000MHz RAM oder braucht es da das Z790 für ~750€?
Man zahlt ja ungerne mehr, wenn ein 300-350€-MB reichen würde
Andererseits könnte AMD ruhig bissl Gas geben mit den 7xx0X3D-CPUs
Zudem hab ich keine Lust auf ständig neue Sockel von Intel, die nur dafür dienen uns Euros aus den Rippen zu schneiden
AM4 war 5,5 Jahre alt, als AM5 im Sep. rauskam. Damit kann ich leben...
Ähnliche Themen
Antworten
7K
Aufrufe
583K
