[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gerade spaßeshalber mal auf 120Hz hochgestellt - innerhalb 10 Minuten ein Blackscreen. Es ist also 1000%ig das Kabel. Unfassbar, man kauft nen 1200€ Bildschirm und bekommt Schrottkabel mitgeliefert.
Moin,
hatte schonmal jem das Phänomen, dass die im Afterburner eingestellten Werte (GPU Core Clock, Memory usw.) von der Karte quasi ignoriert wurden?
Ich habe die Werte eingestellt, Benchmark laufen lassen, das Overlay vom AB zeigt nur die Standard-Stock-Werte an und das Ergebnis vom Time Spy Extreme ist auch wie bei stock.
AB und Treiber sind aktuell und bei einer anderen Karte läuft alles wie immer...
Jem ne Idee?
Danke
Hab ich auch. Bei mir liegts an der Palit eigenen Software. Die überschreibt beim Hochfahren die Afterburnersettings. Muss die Afterburnersettings immer extra neu laden. Und ohne die Palitsoftware bleiben die LEDs aus, auch doof.
Andere würden sich freuen wenn sie die LEDs der Karten überhaupt abschalten können. Du müsstest nicht mal eine Software dafür laufen lassen. Win Win eigtl.
habe mal einen asus pg279q (austauschmodell) erhalten und das ding hat sich bei 165hz auch ständig ausgeschaltet und auf 60hz zurückgestellt.
kabel war nicht schuld da ich 3 kabel getestet habe. dabei war auch das kabel welches bei den 2 vorherigen modellen sowie dem urmodell (mein gekauftes) funktioniert hat
Die ASUS eigene SW hab ich garnicht drauf und bei der Anderen funktioniert das ohne Probleme mit dem AB
Die Sache bei der 4090 in 4K ist , dass diese oft Overkill ist für viele Games selbst in 4k ,
ich finde die karte für 4k noch deutlich zu schwach ist. 4k 142 fps wird die karte nicht schaffen^^
Sei doch froh, dass es "nur" das Kabel ist 😉
Ich hatte dass auch schon mal mit einem HDMI 2.1 Kabel, alle paar Sekunden das Bild kurz weg. Dachte auch liegt an der Karte, aber es war tatsächlich das Kabel.
Bei der Palit liegt doch ein ARGB Kabel dabei, dann kannste die LEDs über die Mainboard Software steuern. Hoffe du hast kein ASUS MB :fresse:
Bei meinem MSI Board läuft das ziemlich gut mit der Suprim X. Nur wenn es ein Update fürs MSI Center gibt, muss man es meist nochmal neu einstellen, ansonsten aber sehr zuverlässig bisher.
Nur zum Teil wahr. Die Karte kann jedes Spiel mit relativ hohen Details in 4K auf 144Hz halten. Die Killer sind halt immer einzelne Einstellungen wie RT etc..
Allerdings ist es eben auch ein Unterschied ob ich RDR2 auf 45 bis 60 FPS spielen muss oder ob ich bei vollen Details bei 100FPS losgeht. Zu meiner 3090 legt die 4090 gefühlte 6 Schippen drauf.
Aber auch die Spieleprogrammierer dürfen gerne mal wieder ein bisschen besser optimieren.
Dito das HDMI Kabel zum LG C2 musste ich auch tauschen da es mit dem alten zu diesem Flackern kam.
Das ist auch angeschlossen, aber auch die MSI Software nervt mich. Meine ASUS Karte konnte ich über iCUE steuern.
Meine LEDs laufen auch ohne Palitsoftware🤷‍♂️
Meine nicht. Wenn ich die Palitsoftware kurz anschmeiße und direkt wieder beende, bleiben die LEDs bis zum nächsten PC Neustart an.
@Stagefire Warum hast du an deiner Strix nur 3x8pin? Falscher Adapter dabei?
Ich hab an meinem Netzteil nur drei 8 Pin Kabel drann daher 450 Watt max das is schon über 10 Jahre alt.
Hab vorgestern aber nun ein neues ATX 3.0 Netzteil bestellt mit Nativ 16 Pin Stecker aber selbst damit is dann bei mir bei Games bei 400 Watt ende nur fürs Benchen geh ich dann damit höher
Wie man rechts schön sieht...
Mit max. Kühlung sind max. Takt und durchschnittlicher Takt exakt gleich 😍
Jupp mit LN2 bei beiden die 3.700 mhz erreicht
Und bei Luft und Wasser sinds dann wohl so um die 3.200 mhz die man erreichen kann.
Wenn ich mein Wakü Block und ein neues Netzteil hab sollte ich bei beiden dann auch die 3.165 Mhz halten können .. und vielleicht is da auch noch eine oder zwei Taktstufen mehr drinn mal schauen.
Gibt es hier noch jemanden, dessen 4090 nicht mehr als +850 auf dem Speicher packt ?
Der Chip boostet mit Galax Bios stabil auf 3150 Mhz, aber beim Speicher bekomm ich bei +900 schon erst grobe Artefakte und ein paar Sekunden später stürzt es dann ganz ab. Sehe hier fast immer +1400 und mehr auf dem Speicher.
@Stagefire 2x8pin Buchse am Netzteil sollte doch kein Thema sein, sofern die Leistung vom Netzteil passt. Die 16pin Ersatzkabel von Corsair, Seasonic, be Quiet usw. sind ja auch nur so angeschlossen.
Direkt ein ATX 3.0 Netzteil ist natürlich auch ne Lösung ;)
Bis zu 600 Watt durch 2 x 8 Pin durchzujagen da fühl ich mich nich wohl mit auch wenns geht ... und wie gesagt is mein aktuelles Netzteil schon älter als 10 Jahre glaub das is von 2007 das wird also Zeit für ein neues.
Mein Aktuelles :
Mein zukünftiges :
Jupp da ich mir eh ein neues Netzteil kaufen wollte in nächster Zeit da meins eben schon über 10 Jahre alt is hab ich nun direkt ein neues ATX 3.0 genommen mit etwas mehr Watt als Reserve
Ja, in der Bibliothek steht bei mir die Normale. Wollte gestrern installieren, brach aber immer mit Fehler ab
Die bei Epic haben Mist gebaut und wollten die 3x teurere DC nicht rausrücken
Also ich can gar nicht ausrechnen wieviel teurer die 6EUR DC ist im Vgl zur normalen, die gratis war. 0 x 6 = X? :o
Habe mir auch die normale geholt und 6EUR für die DC draufgeballert, hauptsächlich wegen dem UWQHD Support. ^^
Mein Aktuelles :
Mein zukünftiges :
Silverstone machen auch Top Netzteile.
Nutzen ja auch glaub ich die selben Teile wie die Seasonics die gut sein sollen bzw is wohl ein Seasonic Rebrand so wie ich das zumindest hier die letzten Wochen über verstanden hab
irgendwie sowas jedenfalls .. mal schauen wann dann das HELA 1200 bei mir ankommt .. warscheinlich kommt erst der EK 4090 Strix Block und dann das HELA 1200 bei mir an sodass ich
2 mal umbauen muss :rolleyes2:oder ich warte bis alles bei mir is und baue dann alles zusammen um nur hab ich halt Bock meine 4090 Strix schnellstmöglich auf Wasser umzubauen
2 mal umbauen muss :rolleyes2:oder ich warte bis alles bei mir is und baue dann alles zusammen um nur hab ich halt Bock die 4090 Strix schnellstmöglich auf Wasser umzubauen
Ist ja Modular kann man ja auch noch Später einbauen das NT.
So kannst du vielleicht auch noch nachträglich ne Korrektur vornehmen wen sich ein Fehler einschleichen sollte.
Das Problem is da weniger das Netzteil sondern meine Gehäuse Bodenplatte die ich entfernen muss um das Netzteil da vernünftig einzubauen
nur is da dann meine GPU im Weg um die Platte vernünftig auszubauen .. sprich baue ich die 4090 strix vorher auf Wasser um muss ich sie danach wohl
nochmal ausbauen um die Boden Platte vernünftig rauszubekommen um das Netzteil einzubauen .. aber mal schauen vielleicht bekomm ich die Boden platte
auch so raus .. sind halt 2 teile die zusammengesteckt sind und dann verschraubt werden am Gehäuse is etwas fummeliger.
Dazu kommen noch 3 Kabel die oberhalb der Bodenplatte liegen müssen und wenn da noch die GPU im Weg is hab ich weniger Platz zum arbeiten das machts halt schwerer.
Daher wäre es sinniger zu warten bis alles da is und dann nur einmal umzubauen statt zweimal ... aber erstmal muss der Kramm bei mir sein und vielleicht geht das alles
ja doch leichter einzubauen als ich dachte ich muss dann einfach mal schauen :d
Bei mir waren es sogar 666W mit Furmark :fresse:
Temperatur am Stecke hab ich noch nicht gemessen
Machts halt für mich nich grad besser :d
Ihr könnt das ja alle so machen aber ich nehm da dann lieber nen ATX 3.0 netzteil mit Nativen 16 Pin Kabel bzw momentan halt mit 3 x 8 Pin auf max 450 Watt.
Fürs Gaming werd ich aber so oder so auf max 400 Watt bleiben ich geh nur höher fürs Benchen.
Schade das so wenig Leute bisher geschrieben haben was ihr Max takt is mit Max OC bei der 4090 .. bisher erst 2 Reaktionen auf meine Anfrage
währ mal interessant gewesen ne kleine Statistik zu haben was die Leute so max bei ihrer 4090 so erreichen beim Max Takt bei Max OC
Bisherige 4090 max Core Bestenliste :
1. Stagefire mit ner 4090 Strix = 3165 mhz
2. s L i X = 3045 mhz
3. Gurkengräber = 2950 mhz
Deine 3165 mhz sind sehr, ich sag mal dynamisch.
Starte mal eine Quake 2 RTX mit Vulkan oder OCCT Stresstest der die 4090 so richtig hart ran nimmt.
Oh weia, deine 3165 mhz sind sehr, ich sag mal dynamisch. Starte mal eine Quake 2 RTX mit Vulkan Pathtraycing oder OCCT Stresstest der die 4090 so richtig hart ran nimmt.
Spul mal 2 Seiten zurück da war genau das schonmal thema .. es geht mir nur um max takt bei 3D Mark und nich was im durschnitt anliegt sondern maximal anliegt
mehr watt ( kann ja grad nur 450 watt max ) und ne bessere Kühlung ( Wakü statt Luft ) und schwupps is mein Durschnitt auch höher als momentan .. aber darum gehts mir grad nich wie gesagt
möcht halt wissen was die Leute hier so als Max erreichen .. is doch ne Simple Geschichte weiss nich warum ihr das nun immer verkomplizieren wollt
Oder schaust mal in den TimeSpy Sammler. Da kannste auch entnehmen, was die Leute da so aus der Karte rausholen. Die meisten liegen zwischen 3000-3100.
Ein anderes kabel hat dein gsync flackern beseitigt?
Meine erste tuf machte auch ab 900mhz einen desktopcrash / blackscreen.
@pajonk Absolut, das neue Kabel hat das Flackern beseitigt. War aber auch ein eher günstiges HDMI Kabel, dafür aber als 2.1 beworben. Funktioniert.
@s L i X Ich behaupte mal frech das alle 4090 mit 1.1v die 3Ghz schaffen. Richtig gute Chips packen auch 3.1Ghz aber das ist meiner Meinung nach Lotterie und hat nichts mit Strix, Suprim oder den günstigeren Zotac oder Palit Karten zu tun.
Ähnliche Themen
Antworten
7K
Aufrufe
586K
