[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hmm, woran könnte das liegen? 🤔
Passiert gerne beim OC, wenn dann im Idle die VCore (OffSet) zu niedrig ist,
Auch RAM Inkompatibilitäten können die Ursache sein, auch wenn Memtest86 keine Fehler zeigt.
Letztlich kann auch ein Fehler im Os vorliegen...
Habe seit neustem folgendes Problem:
Mir friert der Rechner komplett im Idle ein, wenn ich den Rechner mal so ca 1 Stunde alleine lasse.
Spiele/Benchmarks dagegen frieren überhaupt nicht ein oder stürzen gar ab, auch nach vielen vielen Stunden nicht.
hast du einen ryzen undervolted oder curve optimized?
die gpu ist nicht das problem sondern die cpu. (witcher dx12). cdpr hat mist gebaut
Mist gebaut ist relativ- viele neuen RTX Spiele bremsen die CPu aus. Auch Spiderman. Denke für diese Dimension brauchen wir jetzt schnellere CPU's. Mal gespannt was der 7000x3D so kann... Dennoch ist FG eine gute Lösung um CPU / GPU Bottlenecks zu beseitigen. Reicht aber noch nicht für den witcher.
Hat von euch schon mal jemand geschafft vom Proshop ne Grafikkarte zu bekommen?
Heute E-Mail bekommen um 14.00 Uhr gibt es die weisse 4090 Strix..
8 Stück waren verfügbar vor 14 Uhr ....10 sec nach 14.00 Uhr Karten weg ohne jemals eine verfügbar gewesen zu sehen...
Der Shop ist doch der grösste Mist...
Dachte wenn ich hier ne Karte bekomme storniere ich meine von LDLC aber nun egal ist ja nicht so schlimm
@wolfplayer1
bei der weißen Strix gestern hab ich noch den grünen Bestellbutton klicken können, was dann aber nur zu einer Fehlermeldung geführt hat, das die Ware schon vergriffen ist.
Wenn man fix genug gewesen ist, war also etwas bestellbar.:rofl:
Wie macht sich das einfrieren bemerkbar schwarzes Bild oder einfach eingefroren.
Hast du Windows 11 neu drauf?
Windows 10 und wirklich OC habe ich nur auf dem RAM und das seit fast 2 Jahren nun mit den gleichen Werten. Neu ist nur die GPU, werde die mal komplett ohne UV im Stock laufen lassen.
Schwarzes Bild, bzw. kein Signal mehr, die Anzeige meines NZXT Display zeigt dann auch nur noch die gleichen Zahlen an und Maus und Tastatur blinken bunt als ob der Treiber nicht geladen wurde.
Das hatte ich einmal mit dem schwarzen Bild da kam ich auch irgendwann zurück und Bild war schwarz .
Nach Neustart war dann alles normal.dachte auch irgendwie Standby gegangen und dann hat das Display kein Signal mehr von der Karte bekommen .
Probiere Mal Standby ab zu schalten ob das dann noch passiert falls du es an hast also auch für den Bildschirm .
Vielleicht lässt es sich dann besser eingrenzen.
Ich hab jetzt auch vor das Win neu zu machen aber hauptsächlich nur weil ich auf Win 10 zurück will um zu checken ob das stimmt das die Spiele da besser laufen was Ruckler angeht.
Auch die Performance soll leicht höher sein einige Games sollen nicht mehr crashen usw. Vielleicht ist es aber auch nur ein Mythos.
Wow, NVidia hat mir als RMA Ersatz eine niegel Nagel neue Karte geschickt. Cool.
Was nu? Ebay oder auspacken? Ach, und wieviel kriegt man wohl für einen 4090 FE Karton und Zubehör? :d
Wow, NVidia hat mir als Ersatz eine niegel Nagel neue Karte geschickt. Cool.
Was nu? Ebay oder auspacken? :d
Oho, sogar in Seidenpapier eingewickelt. Das hatte meine FE nicht, obwohl sie direkt aus dem ausgeklügelten Versandkarton kam. Lag auch ein Entschuldigungsschreiben von Nvidia bei? :fresse2:
Auspacken natürlich! 😍
Auf eBay (Kleinanzeigen) gehen wahrscheinlich nur noch 2.000 Euro. Das wäre noch ein akzeptabler Preis für ne 4090 (v.a. für die Founders).
Einbauen und glücklich sein .
FE bietet das beste P/l Verhältnis .
Sieht gut aus bleibt kühl und hat ein gutes PCB Design .Ne TUF oder Strix ist vom Kühler und Lüfter besser , aber der Kühler der FE ist dagegen dafür recht kompakt , wenn man das so sagen darf ^^
Also ich kann nur an den Grund erinnern, warum ich einen RMA Antrag gestellt habe. Einige sehen das hier nicht so, aber der Brummlüfter ist für mich selbst bei 30% völlig inakzeptabel. Bei 40 und höher ist dann sowieso schon Hopfen und Malz verloren. Die PNY, die aktuell gerade im Case werkelt, ist da wesentlich angenehmer. Ich überlege überhaupt noch, weil es ja den Ghettomod gibt. Sonst wär das Ding direkt bei Ebay.
Entsteht das Problem deswegen , weil die Spalt Maße zwischen Lüfter und Lamellen zu gering ist und der Lüfter durch Unwucht gegen die Lamellen streift ?
Also es sieht nach ersterem aus. Denn ein erhöhter Abstand zwischen Lüfter und Lamellen löst das Problem anscheinend zum Teil oder schwächt es zumindest ab. Insgesamt also kein mechanisches Problem mit dem Lüfter selbst, sondern einfach eine Fehlkonstruktion. Da es aber nur von einem! Reviewer erwähnt wurde und auch hier viele der FE einen ruhigen Betrieb bescheinigen, scheine ich da wohl die Ausnahme zu sein. Aber selbst bei 70% (ca 2500RPM) laufen die PNY Lüfter mit einem angenehmen Luftrauschen, während das dann bei der FE nach einem ekelhaften Rasentrimmer klingt. Und ich übertreibe hier nicht. Bei 50% (ca 1740 RPM) kann man die PNY gar nicht mehr von den Case Fans unterscheiden und bei 30% (1000RPM) ist sie komplett leise. So erwarte ich das von einem 2.000€ Produkt.
sorry überlesen :d ... 50€?
Ich glaub ich lass ihn einfach mal als Aktion laufen. Ich selbst würde keinen Cent für sowas zahlen, aber n 100 sollte da schon bei rausspringen. Irgend ein Schmierlappen braucht sowas bestimmt für seine Be.trügereien. :fresse:
7800X3D oder 13900K für möglichst niedriges CPU-Limit?
Die aufgerissenen Tütchen auch bitte... :fresse:
Will sehen, ob es auch dafür kranke Käufer gibt :haha:
Möglichst niedrig? Dann einen 1800X oder Core2Quad 6600 :-)
Sonst glaube ich 7800X3D abwarten für ein „hohes“ CPU Limit. Der 5800X3D kann in vielen/manchen Spielen den 13900K leicht überbieten. Der 7X3D wird sicher noch ein deutlicher Sprung sein.
Nee, doch kein 7800X3D - es soll wohl doch einen 7950X3D geben :fire::fresse2:
Aber ich hoffe nicht, dass er viel später erscheint, wie damals der 3950X
Gab es doch auch bei Ampere schon, dass die OC günstiger waren. Hatte meine 3080 TUF OC auch nur deswegen gekauft, da die non OC zu dem Zeitpunkt 150! € teurer war.
So hoch wie die Wahrscheinlichkeit ist das die singt müsste die 1859 kosten.
Ich fordere Sie ja schon lange, die Fiepobergrenze für Grafikkarten!
Ähnliche Themen
