[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich verstehe es nicht, kauft man sich eine 2000€ + Grafikkarte um dann den Idle Verbrauch zu vergleichen?
Macht Euch ruhig lustig, dieselben unsinnigen Kommentare bekommt man auch in Autoforen, wenn man sich einen Wagen mit leistungsstärkerem Motor gekauft hat und sich darüber austauscht, wie man ihn auch verbrauchssparend fahren kann.
Dass das eine das andere nicht ausschließt, versteht Ihr Vollchecker halt nicht, aber is ok. ;)
Im Enthusiasten-Bereich ist halt eh alles ein bisschen anders. Man gibt viel Geld aus um es auf eine bestimmte Weise zu haben, genau so wie man es will. Nicht umsonst tauschen hier Leute 5+ Karten (oder teilweise viel mehr) durch um eine "optimale" zu finden. Da eine Karte die im Idle weniger verbraucht objektiv "besser" ist will man das halt haben.
Ich will auch nix von dir. Ärgere einfach die anderen weiter. Tschö
verstehe dich noch immer nicht. Ist aber auch egal. Tschö
und erneut, wird mit Autos verglichen. Ist auch eine Sache die sich nie ändert.
Eher nicht, das ist ja ein komplett anderes Thema. Man kann ja auch die 4090 energiesparend betreiben. Das Problem ist eher das du und andere scheinbar meinen Beitrag nicht verstehen. Aber auch nicht verstehen wollen, da man sich ja direkt darüber das Maul zerreist statt überhaupt zu fragen wie es gemeint ist.
Meine zieht im Idle zwischen 15W und 25W. Angeschlossen ist 1x 4K 160Hz und 1x FHD 60Hz
Was die Diskussion anbelangt: Na und? Lass uns doch über den Stromverbrauch diskutieren? Tut keinem Weh und in Zeiten von utopisch hohen Strompreisen auch nicht ganz verkehrt. Denke nicht, dass es hier einem Weh tut, wenn die Karte statt 15W meinetwegen 45W im Idle verbrauchen würde. Darüber sprechen kann man trotzdem.
Da das ja scheinbar öfter bei dir passiert würde ich sagen du bist der gemeinsame Nenner und solltest deine Kommunikation vielleicht einfach etwas anpassen. In eine bestehende Diskussion mit "ich verstehe nicht warum ihr das diskutiert" einzusteigen ist vielleicht nicht der beste Weg um auf Verständnis der Teilnehmer zu stoßen :d
Jetzt reißt euch doch mal ein bisschen zusammen und das alles nur wegen paar Watt im idle, euer Ernst?
Setzt den cringemeister doch einfach auf ignore und gut ist. Sinnloses Getrolle.
Genau, man muss sich da allgemein nicht so drüber aufregen. Meine PNY braucht im Schnitt genauso viel wie die FE, TUF, KFA2 oder Gainward die ich hier hatte. Alle @Stock 4K@144Hz ohne irgendwas mit Tools rumzustellen. Alte Karte ausgebaut, neue eingebaut und nur die Treiber neu installiert. Und nun? Vielleicht liegt es halt an den unterschiedlichen Setups jedes Einzelnen.
Es geht nicht um den tatsächlichen Verbrauch einer 4090 im IDLE, sondern ob der Wert stimmt. Und der ausgelesene Wert per Software stimmt sowieso nicht.
erledigt. Viele Beiträge von dir hab ich eh nicht gelesen.
Das ist ein kleines Thema von vielen, man hat ja sehr viele Möglichkeiten worüber man bei der Karte reden kann ;)
Ja. Wenigstens scheint das Fiepen vom Tisch zu sein und das Heulen der Lüfter wenn man mit dem Ohr direkt an der Seitenwand hängt. Hoffentlich schickt jetzt keiner die Karte zurück weil er 3 Watt im Idle mehr brauch als der andere :)
Ich kann nur jedem empfehlen (den das interessiert), sich ein Strommessgerät zu kaufen, dass direkt an der Steckdose misst. Damit bekommt man natürlich nur die Gesamtsystem Leistung angezeigt, aber durch den Tausch einzelner Komponenten findet man da seht schnell die Unterschiede.
Wie gesagt, mit der FE ca 55W idle, mit der PNY weit über 60W. Alles andere inkl. Windows Einstellungen und Desktop natürlich identisch. Und natürlich geht es bei beiden sofort rauf, wenn man irgendetwas macht, logo. Was ich jetzt noch nicht gemessen habe ist, was die Karten so beim Abspielen von Videos oder Browsen verbrauchen. Kann ich aber auch erst vergleichen, wenn die FE wieder da ist.
Edit: was ich vielleicht mal machen kann, ist das System mit der iGPU zu messen. Aber ganz genau gibt das Delta dann auch nicht den Verbrauch der 4090 wieder, da die 730 ja dann auch mehr verbraucht als wenn die dedizierte Graka drin ist.
Der Kühler der Palit ist echt ziemlich stark. Hab jetzt eine Stunde FH5 gespielt und nie über 61°C gesehen. Wohlgemerkt bei nur 1150rpm/30%. Die Karte ist extrem leise. Verbrauch ist mit (ausgelesenen) maximalen 240W echt beängstigend gut für die Leistung. Hab mit der undervolteten 3080 nicht viel weniger gebraucht, hatte aber teilweise unter 40FPS. Jetzt sinds durchgängig 120-130.
Habe heute auch Darktide installiert und 3 Stunden gezockt.
Macht schon laune das Game. Total die Zeit vergessen^^
Was mich nur wundert , dass das Game kein HDR Intern hat , weil fragte mich schon warum der Auto HDR Modus angesprungen ist.
Wenns wirklich nur "paar" Watt wären...^^
Mein Idle Verbrauch (Gesamtsystem) waren 152Watt :fresse:
Also ich musste gerade feststellen, dass mein Undervolt von 0,95mV@2745MHz dem Idle Verbrauch ziemlich weh tut...
Idle zw. 150-160 Watt laut Strommessgerät (Sys1)
CPU (5800x3D)zwischen 28-35 Watt laut HwInfo
GPU (4090 Suprim X) bei 71 Watt laut HwInfo
= 103 Watt
Die restlichen 50-60 Watt würde ich als plausibel empfinden, oder wie seht ihr das? Für:
6x 140er Light Wings, 1x 140er Silent Wing, AIO Silent Loop 2, 2x M2 NVMEs + 2x SATA3 SSDs, 4x 8GB DDR4 mit XMP 3600MHZ CL16
(Was so gut wie gar keinen Unterschied gemacht hat waren; Gsync an oder aus, Energiesparplan von Höchleistung auf Ryzen balanced und im NV Treiber von Maximale Leistung auf normal
EDIT: HDR an/aus sind schon ca. 5-6 Watt Unterschied)
Als Software läuft nur MSI Center, kein Wallpaper Zeug etc.
Auf Stock ist die Karte jetzt bei 36W (1x 4k@120Hz) was auch noch deutlich zu viel ist, wie ich finde.
Beim Undervolt mit ihren 72Watt blieb sie in GPU-Z auch konstant auf PCIE 4.0 @x16 4.0
Auf Stock geht sie da halt auch runter auf
@x16 1.1
Also bei meiner 4090 werden im Idle 14 Watt angezeigt bei einem 4k OLED TV. Zumindest wird das von HWINFO so ausgelesen.
Lg C1 48 zoll TV OLED . So sehen meine Werte aus bin auch zufrieden damit.
MSI RTX 4090 Suprim X - G-Sync aktiv
Lg
Doch, mir tut's weh! Aber nicht weil ich Sorgen vor absoluter Armut und ein Leben in nem Pappkarton unter einer Rheinbrücke habe, sondern aus Prinzip! Ich will verstehen, wieso meine GPU sich zwischen 40°-80° gönnt, wenn die Regel 10-20 Watt lautet^^
@AzRa-eL
Ich hatte mit meiner TUF und Strix nach einbau immer 46-48 W.
Ich weiß nicht warum aber erst wen ich RBAR aktiviere im Bios von meinem X570 ging die Karte auf 12-22 W runter.
RBAR ist bei mir aktiviert laut BIOS und GPU-Z bestätigt es auch.
hast mal spaßeshalber des Ambilight deaktiviert/abgestöpselt?
Und mach mal bitte ne statische Farbe oder Beleuchtung aus und schau dann.
Hab es ausgestöpselt und Software auch beendet.
Immer noch 40°. Was ich ganz seltsam an der Sache finde ist, dass ich ja jetzt eine GameRock Non OC habe und vorher noch eine Banana OC und bei der OC erinnere ich mich, dass die Karte im Idle an die 24 Watt zog. Seitdem hat sich nichts am System verändert bis auf die Karte.
:rolleyes:
Hab nochmal HWinfo angeworfen, da steht bei mir auch was von 33-34W Idle. Scheint normal bei der GameRock zu sein. GPUZ zeigt anscheinend nur den GPU Core Stromverbrauch an.
Wenn ich die LEDs abschalte gehts runter auf 29W :fresse:
Lg
Da komm ich mit G-Sync und HDR an jetzt auch hin.
Aber hab jetzt bemerkt, das HDR doch 5-6Watt macht. Ohne HDR bin ich bei 27/28 Watt.
@AzRa-eL Ich kann das gut nachvollziehen. Bei mir zieht die CPU im Idle gute 20 die GPU etwa 30 Watt. Also in der Regel 50-60 Watt nur um hier einen Beitrag im Forum zu lesen. Wie viel Energie braucht ein modernes Tablet für solch einen Job?
Schön wärs. Bildschirme, Tastatur etc.. Da biste locker bei über 100-120W im Idle. :fresse2:
Hobby ist hobby, mir egal.
nächste Stromrechnung nochmal so teuer wie eine 4090. Egal. Hobby ist Hobby :bigok: Bin voll dabei
AutoHDR von dem Spiel ist leider auch kaputt.
Ähnliche Themen
Antworten
7K
Aufrufe
589K
