[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also mit Frame Generation hat man den 90 bis 120 je nach Scene und Bereich!
Genau 200 Stück. Ich hab die 69 von 200. Scheinen pro drop immer 200 Stück zu sein.
Und wenn sie 400 hatten? Oder 600? Oder die 200 auf den Foxconn Paketen komplett irrelevant ist für die Lagermenge bei NBB? Nur weil da X/200 draufsteht heißt das NICHT, dass NBB immer 200 bekommt.
200Stck ist immer die Verpackungseinheit schätze ich. Die werden immer in 200 Stck pro Order geliefert. Kann auch sein, dass sie davon nur 100 verkauft hatten oder 2x200 hatten...
Ist doch gut falls es stutterfrei ist? Komme erst die Tage dazu es zu testen. Bin leider kaum zuhause :-(
In Novigrad auf dem Marktplatz hab ich zwar auch 80-90, dafür aber mit Frametimes frisch aus der Hölle.. spielt sich wie 25fps... aber, cdpr bleibt sich treu, ich mag ja Beständigkeit, da weiß man immer woran man ist.
Funktioniet nicht. Schon getestet. Die Mailadresse von GE und NBB müssen gleich sein. Gab wohl auch keine Invitelinks mehr. Letzt Woche haben sie ja massig FE's rausgehauen. EK ist immer noch voll.
Quatsch, ich habe mit verschiedenen Mailadressen in GE/NBB bestellt, ohne Probleme
nen Tip wie man am besten an nen Invite kommt ? So wie Du schreibst, hast Du ja mehrere Invites gehabt.
Shaderkompiler oder weis der Geier muss noch verbessert werden gerade neue Abschnitte gibt es mal nen kleinen Hacker !
Und das LOD ist Mega schwach.
Sonst würde das Mega rennen Frame Generation ist gefühlt ein gutes Feature.
Meine FE ist absolut lautlos.
Sie ist die schönste Karte und mit großer Sicherheit die wertstabilste 4090.
Das poste ich jetzt 3mal die Woche neben meiner Tankrechnung :fresse2:
#weihnachtsscherzchen
Meine 4090 FE ist wirklich bei 1.05v und 1.1v sehr leise - überhaupt kein Vergleich zur TUF OC, die war bei 0,875v so leise wie die FE bei 1.05v.
Aber dafür sind die Lüfter lauter - die stören mich aber weniger als das Spulenorchester.
Leider ist bei der FE der hintere Lüfter gefühlt 2 bis 3mal so laut wie der Vordere. Daher habe ich bei RayTracing Games (1.05v) ein Profil mit FanControl, dass der Vordere mit 60% und der Hintere mit 40% läuft.
Bei 0815 Games, wo 0,9v reichen, lasse ich es auf auto laufen.
Du musst bei der FE mal schauen. Beim Lüfter beim Auslass vibrieren als die Kühlerlamellen. Falls du das als störendes Geräusch war nimmst. Da hilft es die ein wenig die zu beigen und dann verschwindet das.
Hast du einen FPS limiter oder Vsync drin ?
Wen ja ausmachen!
Auf meinem OLED hab ich so zumindest kein Tearing was ich bemerken würde.
War dies bezüglich auch immer sehr empfänglich.
Auch bei Darktide empfinde ich so die Frame Times deutlich ruhiger.
Limiter und vsync funktioniert da noch nicht gut mit Framegeneration
Ja geilo, meine PNY 4090 ist endlich versendet worden von Amazon, am Wochenende bin ich dann endlich schlauer ob die der FE das Wasser reichen kann.
Wen ja ausmachen!
Ich hab auch nicht geschrieben das ich Tearing habe ^^
Und ein Framelimiter würde eh nichts bringen, da DLSS3 mit FG im Einsatz ist ;)
Hab ich auch nicht gesagt das du das geschrieben hast nur habe ich das vor weg genommen wen da wieder einer mit kommt dann hast du ja Tearing!
Dir geht es um das flüssige spielen bzw in deinem Fall Frametimes und da sagte ich Vsync aus und kein FPS limiter benutzen.
Aber das hilft nicht gegen die Ruckler wen gestreamt oder was auch immer wird die gibt es ja leider ab un an !
Und jetzt musste ich trotzdem schreiben...:shot:
Habe gerade auch mal Witcher 3 gestartet mit dem neuen Update. Alles auf max gestellt mit DLSS Quality. Ich habe so 60 FPS im durschschnitt in 4K.
Mit DLSS 3 bzw. Frame Generation werden dann ~100 FPS draus. Von gestiegenem Input Lag habe ich jetzt nichts gespürt, aber ist bei dem Game jetzt auch nicht so kritisch. Mit Windows 11 Auto-HDR auf einem 42" OLED ein sehr stimmiges Bild. Gerade die Raytracing Beleuchtung z.B. an den Novigard Docks zu unterschiedlichen Tageszeiten finde ich umwerfend. Besonders in der Nacht wenn die unfreundlichen Wachen mit ihren Fackeln umher ziehen.
witcher3_2022_12_14_11_19_42_595.jpg witcher3_2022_12_14_11_06_28_993.jpg witcher3_2022_12_14_11_07_16_111.jpg witcher3_2022_12_14_11_20_44_636.jpg
Asus TUF @ Galax Bios Powerlimit bei 350 Watt.
Anhang anzeigen 828021 Anhang anzeigen 828019 Anhang anzeigen 828020 Anhang anzeigen 828022
Was bringt dir das Galax Bios wenn du dein Powerlimit bei 350 Watt belässt?
Ich hatte einen Invite, hatte mich mit einer Mailadresse bei GF Experience für dieses Invite Programm angemeldet auf dem 2. PC mit verbauter 3090TI FE. 1-2 Stunden irgendwelche Games gezockt und am nächsten Tag war der invite da. Mit einem "alten" NBB Account mit anderer Mailadresse über den Link bestellt
Teste gerade auch, kann ich alles so bestätigen, Frame Generation fühlt sich deutlich besser an als ohne, läuft top!
Auch Asus TUF @ Galax und auf dem 42er OLED :) aber unlimited Power, zieht auch nur so 370-400 Watt @ 1.05V 2950 MHz, 120-140 FPS dort wo ich gerade unterwegs bin
Hast du auch die 2 Dateien im Witcher Ordner gelöscht damit der Afterburner geht?
Hat die Witcher 3 next Gen PC Version immernoch kein Nativ HDR auf dem PC ? (n)
Dachte die sollte nun entlich auch auf dem PC HDR bieten nachdem die Konsolen Version 2015 schon HDR hatte ...dat is ja dann entäuschend wenn die das immernoch nich gebacken bekommen haben
das HDR auf dem PC auch zu implimentieren und man auf Win 11 Auto HDR oder LGs HLG zurückgreifen muss um das Game am PC in "HDR" zu zocken
hmm :
"In addition to the above, the community manager also provided more information about the game's HDR feature, which will be automatically enabled if supported by your display. Momot also revealed that the team is planning to add an HDR calibration option to the next-gen version through a future patch.
"A word of clarification on the HDR feature in The Witcher 3 NG update for PC, PS5 & XSX|S", Momot explained. "For the release of the game it will be automatically enabled when connected to an HDR screen. We plan to add a calibration menu in one of the future patches. Thanks for your patience!""
Was bringt dir ein Ferrari, wenn du in der 30er Zone wohnst? :P haha
Man nutzt die Power, wenn man sie haben und nutzen will :)
Ich bin davon ausgegangen das er sein powerlimit dauerhaft bei 350 Watt belässt. Dann hätte es kein Sinn für mich. Aber ist wohl Auslegungssache. Man weiß nie was der Besitzer damit macht. Da hast du Recht. Deswegen hatte ich ihn ja gefragt.
  • Danke
Reaktionen: SH
Eigentlich hat es HDR, sobald du vollbild und mit aktiviertem HDR reingehst.. auch laut dieser Seite.
Edit: Ich denke aber, das Auto-HDR von Windows 11 nochmal mehr Punch hat in manchen Situationen. Dafür hat man öfter overshoot in manchen Fällen. Zumindest was mir bei Cyberpunk z.b. Aufgefallen ist. Besonders wenn man es nicht selbst nochmals in einem Menü kalibrieren kann.
Übrigens kann das ja jeder Prüfen der nen LG Fernseher dran hat.. spiel im HDR modus und Fullscreen starten und schauen ob der Fernseher halt im HDR modus läuft durch drücken der Zahnradtaste.
Auch sieht man das eigentlich sofort.. :)
Aber ohne >4080 nicht mit Raytracing richtig spielbar.. Mit DLSS + FG + alles MAX + Raytracing, find ich Witcher 3 richtig schön... Bei der einen Testversion von Cyberpunk musste ich FrameGeneration sofort wieder aus machen, wegen den Fehlern in Zäunen und bei den bewegenden Felgen beim Auto. War Gruselig. Aber durch das "langsamere Rollenspiel" ist es aber um einiges Angenehmer. Input-LAG merkt man auch nicht zu sehr. Nur bei den Schriftzügen der Gegnern über dem Kopf, sieht man bei schnellen Bewegungen die Fehler, die das FG macht. Die Schriftzüge "Ruckeln" und haben Artefakte.
Ja, ich habe die Datei umgenannt. Windows 11 läuft hier immer kalibriert im HDR Modus. Da gibt es auch ein neues Tool von Microsoft das gut funktioniert. https://www.pcgameshardware.de/Windows-11-Software-277633/News/HDR-Kalibrierungsapp-1404876/
Witcher 3 habe ich kein HDR Optionen Ingame gesehen, im Gegensatz zu CP 2077. Ich denke das es automatisch läuft. Kommt ganz gut.
@Galax Bios. Es läuft hier einfach am besten inkl. höchster Taktraten für GPU und Ram inkl. boost über 3 Ghz bei Teillast. Was ober oft genug in Spielen vorkommt. Ansonsten taktet es normal runter im idle, die Lüfterkurve ist auch prima. Bin mit der Lösung sehr zufrieden, aber da darf jeder gerne seinen eigenen Weg finden.
