[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich habe einen neuen OC Test gefunden:
Warhammer Darktide mit allen Settings auf Max mit FrameGen (Super Resolution off)
Wenn man eine Mission startet und es beim Missionsstart abschmiert (nach dem Ladescreen, wo die 4 Players sitzen) - kann man ganz schnell herausfinden, ob die Karte stable ist.
(die Scale Option für Decals von Medium übernehmen und den Rest von Hand hochknallen).
Aktuell mit Abstand der beste Test für mich. Wenn es nach dem Ladescreen crasht, ist vorbei.
Die TUF hat bei 0.900v den Ladescreen mit 2430 MHz überstanden.
Die FE kommt mit 2610 MHz durch.
15 MHz mehr und es knallt immer weg.
Mit dem alten Treiber gingen 30 MHz mehr bei der TUF - also 2460 MHz aber Nvidia hat mit dem letzten Treiber etwas dran geschraubt.
Mit der FE laufen 3.030 MHz bei 1.05v problemlos. Sind die Chips von Nvidia doch gebinnt :unsure:
Habs sehr häufig getestet:
Mit Stable-OC oder Stock läuft das Game einwandfrei mit FrameGen.
Jo das war bei meiner TUF auch so konnte man gut und schnell ausloten.
Genau die Scene die du beschreibst .
mir gings nun darum wie die Leute den Adapter von nvidia verlegt haben beim Vertical einbau um zu schauen obs noch bessere Lösugen geben könnte bei der Verlegung des Nvidia Adapters.
und das Stromkabel erzeugt ja auch wärme und wenn das dann nochmal zusätzlich durch den RAM erwärmt wird is das nich die beste sache
Und genau deswegen hatte ich danach gefragt wie ihr so den Nvidia Adapter bei Verticalem einbau so verlegt habt.
Den Adapter habe ich recht stark gebogen und hinter der Grafikkarte verschwinden lassen. Mit dem Cabelmod habe ich weniger Biegung und bin auch zufrieden.
09f07e44-a313-4800-8888-9a84d88c518e.jpg a900d1d0-f042-4172-8ba4-2396c4674a36.jpg IMG_20221208_195100.jpg
Oh ja .. das is wirklich sehr stark nach unten gebogen sind ja etwa 180 Grad bei dir ... ich versuch halt irgendwie jegliches biegen des Adapters so gut es in meinem Case geht zu vermeiden und das biegen meinen alt eingesessenen 8 Pin Steckern zu überlassen aber so sieht das dann immer scheisse aus weil alles direkt sichtbar im gehäuse hängt und man die Kabel nich verstecken kann... ... es is auch sau schwer die Adapter Kabel daran zu hindern in meinem Case sich seitlich wegzubiegen was man ja absolut unterlassen sollte das seitlich biegen.
Hatte auch erst überlegt ein Seil oder sowas oben an meinem Case drinne zu befestige und daran dann den Adapter aufzuhängen damit der immer grade nach oben geht und nich seitlich abfällt
aber das sehe dann sicher noch bescheidener aus als sowieso schon jetzt bei mir.
Aber vielleicht fällt mir da nochwas ein wie ich die Kabel bei mir besser verlegen kann sodass sie nich so präsent sind und dann auch nich die RGB Beleuchtung meiner RAM Riegel blockieren.
FG macht doch nur mit DLSS Sinn, bzw gehts nur mit DLSS und dann hast wieder Unschärfe
Nein! Dlss und fg sind 2 unterschiedliche schuhe. Fg verdoppelt nur die nativen frames. Dlss macht ein down und upsampling und ergibt unterhalb von qualität matsche. Ich würde es wie bei spiderman oder plaguetale immer erst mit fg probieren. Reicht die fps dann immer noch nicht kann man dlss quali dazuschalten. Was ich aber bei den beiden games nicht musste. Spiderman mit fg nativ 4k ist megascharf. Spiderman mit nur dlss quali ohne fg kommt nur auf ca. 80fps, wie nativ, weil die cpu bottlenecked. Fg löst alle probleme. Cpu und gpu bottlenecks. Jedes game ist so maxed out möglich. Meiner meinung nach seit jahren mal eine megainovation.
Meine boostet auch auf 2805Mhz aber ich dachte immer, dass das für 1.05V und 450W normal sei?
@ Stock auf über 2800MHz boosten ist ja schon krass gut. Meine bleibt bei 2715MHz. Dass es da solche Unterschiede gibt...
Ok, krass, das wusste ich nicht. Naja gut ich lass die Karte sowieso auf Stock laufen und mit den 450W wäre wahrscheinlich eh nicht mehr drin aber dann ist der Chip anscheinend von mir wenigstens gut :).
Komme mit der fe stock auf 2730.
Meine 2. Tuf ging nur bis 2655
Meine erste tuf 2780.
Denke mit 2800 kannste glücklich sein.
meine macht 2970 bei 80%PT bei 97%Auslastung ingame, vielleicht noch mehr....
Klar. 😀 Und die kurve mal um 200 mhz hoch geschoben... oder wie?
Curve habe ich noch garnicht getestet bei der 4090 zum UV, wird langsam Zeit , einfach PT auf 80% gesetzt und etwas OC;)
Und was hatte das dann mit dem Thema zu tun? Es ging um Stock boost Werte.
Dachte wir reden von stock. Oc ist kurve hochschieben.
Oc und pt runtersetzen hat so viel sinn wie bei einem auto den turbo zu tunen aber einen zylinder abzuschalten 😅
Keine Ahnung ob es schon gepostet wurde:
:love:
Ach Mist, zu lang und zu hoch für mein Gehäuse. Sonst aber optisch top.
Bei Mindfactory gibt es aktuell die Gigabyte Gaming OC 4090 günstig für 2079€. Ist da aktuell billiger wie die Windforce 😂. Hab die Gaming OC selbst seit ein paar Tagen und kann die nur empfehlen. Sehr leise Karte, Spulenfiepen/ Rasseln so gut wie nicht vorhanden und die Lüfter sind mit eigener Curve auch nicht hörbar. Endlich eine Leise 4090 nach Gainward (Lüfter) und vor allem der Tuf mit Spulenfiepen des Todes.
Lass dich nicht irritieren. Inzwischen nimmt das Thema jeder auf die Goldwaage. Die Sockets zentrieren sich automatisch.
Meine 4090 ist inzwischen auch eingebaut. Bin allerdings mit dem Vertical Einbau sehr unzufrieden:
A) Die FE sieht so eingebaut einfach nicht schön aus..
B) Die Karte kommt mit der Länge immer weiter nach vorne an die Scheibe und ist nicht 100% gerade. Das Riser Kabel dahinter wirkt wie eine Feder gegen die Halterung.
Mich nervt es unglaublich das die Karte nicht in das "alte" Lian Li O11 passt. Bin kurz davor mir das Lian Li O11 Evo zu kaufen.. was aber eigentlich totale Geldverschwendung wäre. Habe die böse Vermutung das selbst der 90° Adapter von Cablemod nicht zwischen Karte und Scheibe passen wird.
Bei so viel Geld für eine Grafikkarte, will man am Ende einfach ein perfektes Ergebnis, auch wenn es da nur um die Optik geht.
Noch ein paar Worte zur Karte: Bin sehr zufrieden, insgesamt sehr leise und wenig bis kein Spulenfiepen. Auch der Lüfter eiert nicht.
Mit dem CM Mini case gibts hier keine Probleme. Schon witzig das einige der dicksten Cases die Karte nicht fassen können aber son Zwerg schon 🤣
Vram OC:
Lange die Karte nur +999 laufen lassen. Heute mal ganzen Abend +1499 in COD probiert, das einzige Game das ich kenne, das die vollen 24GB Vram belegt.
Wenns zu viel Takt ist, gehen entweder die FPS runter (Fehlerkorrektur), es gibt Artefakte oder es crashed instant, richtig?
Muss mich mal noch weiter hoch tasten. Vram OC ist eine gute und Energiekosteneffiziente Möglichkeit Performance zu holen.
Das FPS zu Watt-Verbrauch Verhältnis ist das wikrlich gut, im Vergleich zu Core OC. 1 FPS / Watt bekommt man aus dem Chip leider nicht raus beim OC. :ROFLMAO:
@***** schau doch mal in den casual oc thread von mir und lass deine FE durchlaufen. Scheint ne sehr gute Karte zu sein. Du hast ja 60-75 MHz mehr stock boost als meine aktuelle.
Ähnliche Themen
