[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Jup 400W Peak ist ein gutes Setting je nach Spiel ist das dann sogar deutlich weniger.
Wobei ich schau mir das noch genauer im Silent Modus an vielleicht geht ja auch noch 2900 mit 1V und 450 W.
Wie bekommt man den im AB die 3000mhz höher für die Curve hat da jemand eine Anleitung????
Mit Wasser hattest du im Bereich 300 - 350 Watt sicher dann 48 Grad oder weniger statt 58 Grad mit Luft und mit 380 - 400 Watt hättest du so 50 Grad statt mit Luft 60 Grad
10 Grad unterschied is nun nich viel aber können schon ein paar Taktstufen sein aber wenn dir das Aussehen der Strix so gut gefällt spricht ja auch nix dagegen auf Luft zu bleiben
Also mit Wasser sind es eher 30 K Unterschied und die 60 °C bei 400 W bezweifel ich mal. Welche Karte soll das bitte sein oder sitzt man im Pullover im Zimmer ?
Bezog sich alles auf die 4090 Strix mit Luft von Thunderburne die 4090ger haben nen dickeren Kühler die sind besser als die alten Karten
meine 3080 Strix war bei 72 Grad damals mit Luft und is nun bei 51 Grad mit Wasser aber die 4090er LuftKühler sind a besser siehe eben Thunderburns Karte
die bei 400 Watt 60 Grad warm wird mit Luft daher bringt dann ne Wakü weniger da der Luftkühler der 4090er schon besser geworden is bzw größer sind als die bei der 3000er Serie
und die 60 °C bei 400 W bezweifel ich mal. Welche Karte soll das bitte sein?
Oben die 4090 Strix @Luft von Thunderburne .. du siehst doch wen ich da zitiert hab
Der sitzt wohl mit dem Pullover im Zimmer, bei 20 °C
Ich habe jetzt die Gainward 4090 Phantom ne ganze Weile und will nur kurz mein Eindruck hinterlassen. Also meine hat gar kein Spulen fiepen und mein Lüfter hat auch kein Geräusch Problem. Der Kühler ist ziemlich gut und hält die Karte auf jeden Fall sehr Kühl ohne laut zu werden. Ich denke mal, das es immer Leute gibt mit Problemen bei jeder Karte aber ich kann Grad nur positives Sagen. Nach der 3080 hab ich wohl wieder ne guten Deal erwischt xD.
Das mag sein aber bei mir isses auch grad nich viel Wärmer mit 21 Grad Zimmertemp.
Ich halte das was er da geschrieben hat aber schon für Möglich da die 4090ger Stock Kühler ja schon größer Dimensioniert sind als die 3000er Lüfter
und darauf basierent hatte ich dann meine Temps für Wakü dazu geschrieben da ich meine 3080 Strix ja auch mit 400 Watt betreibe
mit nem EK Kühler ( kommt dann natürlich noch auf das Restliche an wie eben Zimmertemp und Wassertemp und Lüfter und Radi Fläche und Airflow im Gehäuse ) sollte halt nur als Richtwert dienen
Ich hatte hier auch damals mal den Vergleich mit 4090 FE und 4090 mit EK Block verlinkt da warns auch nur 8-14 Grad unterschied .. mal schauen ob ich den noch finde.
Ja aber dann sind 60 °C keine Kunst und für 21 °C sehr warm, mit Wakü wäre es bei 21 °C deutlich kälter.
Und die Rede ist ja immer von der Gehäusetemperatur und nicht Lufttemperatur, denn nur diese saugt die Grafikkarte an
Ich halte das was er da geschrieben hat aber schon für Möglich und darauf basierent hatte ich dann meine Temps für Wakü dazu geschrieben da ich meine 3080 Strix ja auch mit 400 Watt betreibe
mit nem EK Kühler
Dann hast Du ziemlich schlechten Kühler:
Also ich Persönlich spreche grade nur von der GPU Core Temp
Eiggentlich nich .. ich bin mit meinem EK 3080 Strix Block bei 48 - 52 Grad GPU Temp ( 400 Watt ) und in dem Bereich sind auch die Leute aus deinem Link mit 4090er
Fehlt aber die Wassertemperatur.
21 - 32 Grad je nach Jahreszeit Idle ... bei Last weiss ichs grad garnich glaub so 33 - 35 Grad dann oder so
1 x HWLabs 420 Radi
1 x EK Coolstrem 420 Radi
1 x EK Velocity CPU Kühler
1 x EK 3080 Strix Block
Lüfter im Idel 600 - 700 Umdrehungen und Lüfter beim Gaming 1200 - 1500 Umdrehungen
130 Liter Durchfluss
Für 21 °C wären aber 48 - 52 Grad GPU Temp dann wieder nicht gut.
Idle 21 grad .. bei Last so 33 - 35 Grad .. da achte ich kaum drauf ich achte eigentlich immer nur auf die GPU Temp
Aber es geht ja auch grad garnich so sehr um meine Kiste sondern um die 4090 Strix bei Luft und wie die mit Wasser wäre
ich bekomm meine 4090 Strix erst nächste Woche geliefert
Ja und der Unterschied ist beachtlich, siehe Tabelle,
Hmm was meinst du nun ? Welcher unterschied nun ? Von Wasser ( 33 Grad ) zu GPU Temp ( 48 - 52 Grad ) ?
darun ist auch eine luftgekühlte TUF und die Kühler sind alles ziemlich gleich.
Und diese TUF dort hat 62 Grad und Thunderburns 4090 Strix 60 Grad aber diese 60 Grad hast du angezweifelt dabei is das doch plausible.
Und die TUF hat 62 Grad und Thunderburns 4090 Strix 60 Grad aber diese 60 Grad hast du angezweifelt dabei is das doch plausible.
Wieso habe doch den Link gepostet:
Habe nur gesagt der sitzt wohl mit einem Pullover im Zimmer, da die Ansauglufttemperatur bei ~ 20 °C liegt.
OK also dann is das ja nun alles ok .. die 60 Grad passen weils bei ihm dann wohl 20 grad im Zimmer is was ja normal is und nichts aussergwöhnliches.
und was meintest du nun wegen meinem System wegen "unterschied is beachtlich" ?
Meintest du von meine Wasser ( 33 Grad beim 400 Watt Gaming ) zu meiner GPU Temp ( 48 - 52 Grad beim 400 Watt Gaming ) ?
Find die 48-52 Grad passen doch sehr gut zu 400 Watt bei Wasser
siehe zb dein eigenen Eintrag spiegelt so ziemlich meine Werte mit meiner 3080 Strix und dem EK Block mit 400 Watt wieder : ( 33 grad wasser und knapp 50 Grad GPU bei dir )
Die Luftkühler der neuen 4090er Serie liegen 15-20 Grad unterhalb denen der 3090er Serie bei selber Verlustleistung und ca 10-15 Grad unterhalb der 3090ti Kühler die schon deutlich besser waren als die 3090er Kühler. Das ist schon enorm, muss man einfach mal sagen.
Beste Grüße
Habs wiedergefunden :
Wasser bringt 8 - 15 Grad kühlere Temps
Für den normalen Gaming Betrieb daher einfach unnötig.
wars bei den 3000er schon .. meine 3080 Strix lief mit 72 Grad mit Luft was ja auch noch ok is und nich weit weg von den 68 Grad der 4090 mit Luft
Also ich Persönlich bau halt auf Wasser um weils mir spass macht zu Basteln und wegen dem besseren RGB und besseren Temps und dadurch mehr Taktstufen die man behält
und das macht die Karte obendrein auch kürzer im Falle der 4090 Strix von 36cm auf 26cm
Fals jemand für seine Curve über 3000MHZ brauch .
Nabend,
bin jetzt am Freitag auch schwach geworden.
Wie sieht das denn jetzt mit dem 12VHPWR Stecker aus?
Was darf ich da alles nicht falsch machen?
Ich werde ein natives Kabel verwenden.
Einfach sauber einstecken und feddich. Diese ganzen (inzwischen ja nun auch relativierten) Horrorstories sollten Dich nicht verrückt machen.
Beste Grüße
Wie ich schon mal schrieb - die 3090-Serie hatte teilweise ein starkes, negatives Offset (bei meiner Strx OC 5K unter Wassertemperatur @idle)
Entgegen jeglicher Vernunft hab ich mir auch eine 4090er bestellt. Avisierter Versandtermin ist der 16. Dezember, falls AMD vorher also noch was zum Drama beitragen kann, ist noch Zeit zum Stornieren.
Aber nachdem ich den AMD 3900er gegen den 5800X3D tausche dachte ich mir: Das ist jetzt auch schon egal.
Und das ganze Theater nur, damit ich das aufpolierte Witcher 3 unter top Bedingungen zocken kann. Hätte ich mir die Version für die PS5 oder Xbox Series X auch holen können, aber bei der 4090 läuft das sicher optimaler. Reflektiert nachdenken sollte man über einige Entscheidungen nicht zu lange.
Ich weiß nicht, wie lang das PCB der 3090 TUF ist, aber die 4090 TUF ist nicht mal 23cm lang :fresse:
Der Byksky-Block, der 3090 Strix misst ca. 25cm und der für die 4090 TUF 22,5cm
Du nimmst auch die schlechtesten Werte...
Gehäusetemperatur = Raumtemperatur. Die Grafikkarte saugt stets die aufgewärmte Gehäusetemperatur an und da bezweifel ich das bei längere Last und 20 °C Raumtemperatur die Gehäusetemperatur kaum höher ist.
Der Unterschied ist beachtlich: Und 18,9 K sind noch nicht mal die Bestwerte, auch 15,4 sind möglich. Also in diesem Fall dann gerade mal 38 °C GPU Temperatur und keine 62 oder 65 °C.
UserKühlungModellWasserkühlerPØ [W]GPU Takt [MHz]VRAM Takt [MHz]Durchfluss [L/h]Gehäuselufttemp. [°C]Ansaug Luftemperatur [°C]Wasser GPU Einlass [°C]Wasser GPU Auslass [°C]GPU Speicher [°C]GPU [°C]Hotspot [°C]dT Speicher [K]dT GPU [K]
"hithunter"LuftINNO3D iChill X3
425​
2820​
10502​
26​
68​
71,5​
80,9​
42​
45,5​
YoungtimerLuftAsus TUF
427​
2700​
10502​
20​
62​
62,7​
73,4​
42​
42,7​
1972erWasserKFA2Alphacool Referenz
395​
2970​
11501​
122​
22​
22,1​
30​
41​
47,6​
7,9​
18,9​
Und wer angeblich bei 20 °C Raumtemperatur eine Gehäusetemperatur bei 20 °C und 400 W halten kann, der soll das bitte vormachen. Bei einer Wasserkühlung ist das mit externen Radiatoren kein Problem. Man beachte einfach nur die Temperaturdifferenz, Ende der Diskussion.
Der EK 4090 Strix Kühler is halt 26cm lang sind halt 3cm mehr und kommt wohl daher da EK hinten noch son Schwarzes Plastik Teil drann hat also der Block is etwas größer
als die eigentliche Karte daher is der halt 3cm länger ... aber dennoch is ja 26cm besser als 36cm ... bei mir is halt bei 33cm die Grenze wegen meinem AGB .. wird nächste Woche
lustig die 4090 Strix erstmal Provisorisch in meinem Gehäuse unterzubekomen da mir mein AGB halt sehr viel Platz wegnimmt ich ihn aber nich umsetzen will daher wird das
erstmal bis ich den EK Block hab ne Frankenstein Aktion bei mir um die 4090 Strix in mein Gehäuse zu bekommen ... aber is ja dann nur für ein paar Tage oder max ein paar Wochen
je nach lieferbarkeit des EK Strix Blocks ud je nachdem ob meine 4090 Strix was das fiepen angeht für mich okay is.
Bleib mal locker warum gleich so pissig ? Is doch nur ne normale Diskussion und kein Angriff von mir
Ich kann halt nur sagen wie es bei mir is und ich bin auch kein Wakü Pro sondern nutze Wasserkühlung erst seit 2018
... wie da nun die Gehäuse Luft is weiss ich nich da hab ich kein Temp Sensor .. jedenfalls is meine Zimmer Temp immer so 19-21 Grad und mein Wasser beim Zocken
mit 400 Watt so bei etwa 32 - 35 Grad ( gemessen durch meine D5 Next Pumpe ) und die 7 x 140mm Lüfter drehen auf 1200 - 1500 Umdrehungen je nachdem und meine GPU Core bei 48-52 Grad
Is halt nich das beste Wasserkühlsystem was ich hab aber das hab ich auch nie behauptet und ich raff nun auch nich was dein Problem is und warum du gleich so pissig bist ?
Mein Aktuelles System noch mit der 3080 Strix ( Nächste Woche dann mit der 4090 Strix )
... nich besonders schick aber Funktional. .. Case is das Cooler Master Cosmos 700M ( Ohne die Front die hab ich abgemacht is dann ne Mesh Front )
Ohne ABP nehme ich an?
Mit ABP stelle ich mir den Ausbau extrem aufwändig vor, um an den sch… Entriegelungshebel zu kommen
Ähnliche Themen
