[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hast noch aus anderen Winkeln Bilder?
Wie ist denn die Temperatur jetzt so? großartig besser wird die ja wohl nicht ausfallen... Was für einen Radiator verwendest du?
GPU Temp unter Last 60-65 °C bei 520W und 33°C Wasser...
Hab den Kühler jetzt nochmal neu montiert, aber auch da keine Änderung...
Mora 360 LT + Airplex Modularity 360...
Das ist schon echt schwach...
Das ist der Bykski oder ?
Wie fandest du die Montage ? Überlege mir auch ein paar Euro zu sparen und dieses Mal Bykski zu nehmen, nachdem die Karte schon so teuer war...
Montage war sehr einfach, aber aber das ist auch alles postitive an dem Block...
Danke für deine Ehrlichen angaben !
Endlich mal einer der ordentlich Saft reinbläst!
So ein UV Profil ist zwar nice aber so sieht man mal was der Kühler kann oder auch nicht!
Nein, das war der günstigste Preis den es bisher gab, mit einer UVP hat das nichts zu tun...
Der PG48UQ hat eine UVP von 1999 und kostet im Asus Shop aktuell 1692,90 €...
(Nur weils der ASUS Shop ist definieren die nicht die UVP ständig neu, ein Shop der alles nur zur UVP verkauft kann nicht überleben, selbst wenn ASUS drauf steht...)
Aber ja, alle paar Seiten erzählst du uns ja, dass du maximal 2500 € für eine Strix ausgeben willst und jetzt wohl 2266,90 € und keinen Cent mehr...
Ihr könnt das alle natürlich halten wir ihr wollt und ich will euch hier nichts vorschreiben ... für mich aber is das die UVP und ein sehr guter Richtwert was mein Limit angeht was ich bereit bin für die 4090 Strix zu zahlen
und 2500 Euro is über mein Limit seit dem ich nun weiss das die Karte 2266 Euro kostet
Da schwingen mal wieder bad Vipes mit bei deinem Text muss doch nich sein oder ?
was "keine Cent mehr" angeht solltest du dir nohmal meinen letzten Beitrag durchlesen da hatte ich dazu was geschrieben.
"geht die UVP runter geht mein Limit auch runter was ich bereit bin noch oben drauf zu legen um eine zu bekommen "
Ich kann dich beruhigen, dass hat nichts mit Bad Vibes zu tun… ;)
Du hast auch sicherlich schon einiges an sinnvollen Beiträgen geschrieben, ich könnte schwörn sogar schon mal auf „Danke“ gedrückt zu haben… 😅
Aber du beist dich immer an Sachen fest und wiederholst es dann Gebetsmühlenartig alle paar Seiten…
Bei der 4090 zuerst die schmorenden Adapter und jetzt die Asus Verkaufszahlen/Strix Preise…
Wenns Leute hier Hilfreich finden: Bitte gerne, aber ich finds einfach ermüdend…
Mir geht's ganz ähnlich (FE mit EKWB Kühler). Ich hab die Karte nochmal komplett auseinandergenommen um zu sehen, ob ich was falsch gemacht habe. Bei der Gelegenheit hab ich ein paar Pads getauscht und von den Spulen ganz weggelassen.
Es ist ein wenig besser geworden, aber nur wenig unter Deinen Temperaturen. So 58° bei 500W.
Ich werd den wohl jetzt erstmal drauf lassen und dann auf den AC Block wechseln…
Mein erster und letzter Bykski…
Ja, ich werd das auch so machen.
Allerdings ist es wohl auch so, dass bei mehr als 500W nicht zu erwarten ist, eine Kühle Karte zu haben. Wasserkühlung hin oder her.
Da wird schon fein Tunning notwendig!
Schrieb vor Paar Tagen schon mal Liquid Metal usw.
Aber verstehe das wen die Leute sich nicht trauen.
Mit Passte holste bei über 500W keinen Blumentopf mehr.
Aber der Bisky und der EK sind auch nicht gerade dafür bekannt die Leistungsfähigsten zu sein.
Mir schwant Böses, wenn dann mal der EKWB für meine Gaming OC kommt... Lies dir mal das hier durch, vielleicht ist das ein Ansatz: Klick mich
Dünnere Pads könnten eine Lösung sein.
Vielleicht mal Ultra Soft Pads kaufen .
Von ALC soll es da was gutes geben.
Hätte jetzt mal 10°C weniger geschätzt.
Ist ja kaum besser als der Luftkühler im Performance Mode.
Hast du mal die Pad dicke von den Luftkühler gemessen ?
Ne, Aufwand/Nutzen rechnet sich nicht. Zumal ich die Karte ja auch nicht permanent an die Grenzen jage sondern eigentlich nur in Ruhe zocken will. Dafür reichts. Beim Spielen bleib ich ein gutes Stück unter 50°.
Welcher Aufwand drauf und fertig das Zeug bekomme ich leichter aufgetragen als irgend eine Paste :fresse:
Schaut man sich mal die Wärmeleitwerte an dann erkennt man auch den nutzen.
Die Tatsache, dass man das nicht mehr Rückstandsfrei von der GPU bekommt, schreckt mich schon richtig ab. Und wie gesagt, wenn man das zum ersten Mal macht, ist auch das Risiko nicht so klein. Die Karte war schweineteuer, .wenn sie nur €400 kosten würde, würde ich es mir zum Experimentieren ja noch überlegen...
Kannst aber gern zu mir nach München kommen und mir helfen :sneaky:
Da rum hab ich das auch geschrieben.
Leider komme ich nicht aus deiner Gegend wäre es so aber gewesen hättest nur nen Kaffee :coffee3:machen müssen.
Ich kann dich beruhigen, dass hat nichts mit Bad Vibes zu tun…;)
Hmm okay dann is ja jut.
Soll ich mich nun echt hier erklären ? :d
Also ja ich bin jemand der sich gern mal in etwas verbeisst das hat aber oftmals nen Hintergrund.
Wegen der Adapter Sache : Jup ich wollte halt berichten von den Fällen war halt ein Brandaktuelles Thema und ist es auch weiterhin da immer noch nich alles zu 100 % aufgeklärt ist.
Und mir wurde das hier damals zu doll runtergespielt da wollte ich ein Gegenpol zu bilden. ( hatte ich auch damals hier schon geschrieben ) Mut zur Lücke.
Was die verkaufzahlen angeht : Damit will ich einfach nur mein Unmut ausdrücken das die Strix 2022 so extrem selten is im gegensatz zu anderen Top Karten anderer Marken wie zb die Suprim.
Strix Preis : nunja das is halt der Günstigste Preis bisher gewesen und dieser kamm von Asus direkt und die sollten ja wissen was ihre UVP is .. jedenfalls kann man sich gut an diesen Preis orienntieren
und mit anderen Preisen der anderen Shops vergleichen und dan entscheiden ob man den Aufpreis dazu zahlen will oder eben nich ... von 2266 Euro aus gesehen währe ich zb bereit noch 2400 zu zahlen
aber 2500 währ mir dann zuviel ausgehend von 2266 Euro da ich so ja dann so 240 Euro den Scalper Shop in den Rachen stecken würde und für diese 240 Euro bekommt man schon nen Wasserblock für die GPU.
Ich finde 98 % des inhalts hier im Thread ermüdent .. nur schreib ich das halt nich so wie du das mich das ermüdet ( mit der ausnahme von diesem Beitrag jetzt was aber nur zur aufklärung dient grad )
ständig die UV Diskussionen usw aber hey einfach überlesen so mach ich das auch mit dem ganzen UV kramm der mich 0 interessiert
und wo ich dann eben auch garnich drauf eingehe weils mich ebe 0 interessiert aber eben andere und das is für mich absolut ok also lass ich sie einfach reden und halt mich da raus
und mecker die Leute eben nich an das mich das ermüdet ... das würde mir auch garnich in den Sinn kommen das zu schreiben und es steht mir auch nich zu das zu sagen da es On Topic is
Und ich hatte das damals hier schon gesagt ihr könnt hier den Leuten halt auch nich vorschreiben über was sie schreiben dürfen und über was nich ( sofern es on Topic is )
Also lass mich einfach weiter mein Mumpitz hier schreiben und überlese das einfach so wie ich es bei den ganezn UV Sache zb auch mache. ( klingt nun ernster als es gemeint is :d )
Und hättet ihr euch nich so an meinem Post zur UVP der Strix aufgehangen müsste ich hier diesen misst erst garnisch schreiben und es währe bei diesen 1 Post geblieben ihr habt
das auch ein bischen selbst in der Hand
To Long to Read :
Sofern es On Topic ist lasst die Leute einfach reden über das worüber sie reden wollen. .. werdet einfach lockerer die Welt is schon scheisse genug und lasst unnötige Anfeindungen sein
Ich dreh noch durch...
Mir fehlt nur noch Isolierlack (wegen LM), aber egal, was ich bei Völkner/SMDV eingebe, dort gibt es sowas nicht :heul:
Oder Q Tips zum Auftragen vom Liquid
Geht wieder (waren Wartungsarbeiten)...
Edit: Leider nur für Gewerbetreibende :rolleyes2:
Hier hab ich bestellt...
"Electrolube APL" -55°C bis +125°C - 15ml für 16,67€ (inkl. Versand)
Thermal Grizzly "Nagellack" -20°C bis +110°C - 5ml für 18,13€ (inkl. Versand)
Wie findet ihr diesen Block für die Strix/TUF?
Preis liegt leider bei 350€ (inkl. Versandkosten). Lieferzeit 3 Wochen
Anhang anzeigen 821593Anhang anzeigen 821594Anhang anzeigen 821595Anhang anzeigen 821596Anhang anzeigen 821597
Schade - muss nachbearbeitet werden...
Yep! Es liegt am FSR... Hatte FSR eingeschaltet und seitdem lief es nicht. Hab eben in der Config Datei FSR=0 und nun läufts wieder.
Also das ist Absicht. Wenn der Treiber erkennt, dass du AMD Features anschaltest ist der raus. Da spielt der nicht mit ^^
Eigentlich witzig, dass die derzeit noch fehlende Funktion des Pin S2 für CARD_CBL_PRES am 12VHPWR-Stecker dafür verantwortlich sein soll, dass erkannt wird, ob der Stromstecker korrekt angeschlossen ist. :ROFLMAO:
Weiteres dazu hier.
Man weiß ja noch garnicht was alles so noch kommt in bezug auf Mainboards etc.
Der 24 Pin sollte ja auch mal abgelöst werden.
Würde auch nicht einfach fix das NT tauschen, wenn das alte noch genug Leistung hat und noch nicht sooo alt ist.
Gibt es eigentlich für die Gainward Phantom 4090 schon einen WaKü-Block? Lt. Startpost ist das ein Custom-Design.
Ähnliche Themen
