[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Falls es dich interessiert. Im ab gibts noch nen 2ten mem wert. Der ist der richtige. Kann es gerade nicht checken. Bin rechnerlos....
Hab ich gesehen, aber wieso der "richtiger" sein soll, wenn ich Gesamt sehen will ist die Frage :)
Wenn man nur die eine Anwendung checken will okay, aber wenn man wissen will wieviel "Luft" da noch ist bringt mir der Gesamtwert mehr.
Aber wäre interessant zu erfahren wie die die Nutzung/Prozess ermitteln...
Und das bietet HWInfo an:
Hab das hier aus dem Thread übernommen , damit ich vergleichen kann.
Hier passiert ja leider wenig zum Thema OC
Komme immerhin noch mit PCI E 3.0 16x noch auf brauchbare Punkte .
Mit PCI E 4.0 wäre in 3dmark sicher mehr drinne , aber bin ganz zufrieden mit dem Ergebnis und der Karte .
Seit dem letzten Bf2042 Update performt das Game richtig gut .
Kein CPU limit mehr in 4K und meistens 138 FPS außer die GPU kommt ins limit , aber hält sich in grenzen.
Allerdings schluckt der 10900K jetzt auch mal locker 160 Watt in BF 2042 . ^^
Ja das meinte ich...
Windows, browser usw..
Wie ist denn die differenz bei dem game? Dann weißte ja wieviel andere sachen fressen.
DAS VRAM wird übrigens genau wie das RAM behandelt. Alles was nicht dringend gebraucht wird, kann ins RAM ausgelagert werden.
Selbst wenn man 20GB "Schrott" in das VRAM packt. Sobald man ein Game startet ruckelt es kurz, und dann sind die 20GB Schrott im RAM (sofern man genug RAM hat) und das Game läuft völlig Problemlos.
Ich dachte ihr redet von einer anwendung. Es ging doch um den vramverbrauch der 2 games...
Vielleicht wird es über den windows resourcenmanager ermittelt. Der kann ja alles einem prozess zuordnen?
In dem Fall macht das sicher Sinn richtig, wobei der Gesamtwert wenn beide diesen angeben auch reicht um einen Vergleich zu ziehen... außer jemand hat 5 Spiele gleichzeitig am laufen oder GPU Heavy Tasks :d
@HisN Ist es nicht der Videospeicher? Und der Arbeitsspeicher? :d Es ist immer grauenvoll deutsche Artikel mit englischen Begriffen zu jonglieren :d
Ens CPU :fresse:
Achso, schade
Was hast du denn für eine Karte?
Hast ja ziemlich gutes Ergebnis vom GPU Takt her.
Hätte gedacht mit PCI E 4.0 käme man ggf. über 21 K .
Scheint dann doch nicht so viel in 3dmark auszumachen , weil hast gut 75 MHZ mehr , aber gerade mal 177 Punkte mehr.
Man sagt ja laut Test´s so 2-3 % Mehrleistung .
Da müsste ich bei meinem Ergebnis auf 21300 Punkte ca. kommen, wenn man danach geht.
upgraden kommt eh erstmal nicht in Frage , weil im Alltag @ 4K 144 HZ sehe ich da kein Sinn drinne.
WQHD 240 HZ wäre da was anderes.
die cpu weil DIE UNIT (EINHEIT)
@Gurkengraeber
Bei mir alles genau wie im Artikel beschrieben. Also nicht kaputt, sondern works as designed. Damit für mich inakzeptabel.
Falls Ihr das mit dem Lüfter anheben beheben könnt, bin ich dabei. Aber ansonsten fliegt sie raus. Geht auf Dauer einfach nicht für mich. :(
[/URL]
[/URL]
Eine TUF Non-OC…
Mit kalter Luft komme ich über 3.100MHz (peak)
Aber 21K GPU-Score konnte ich noch nicht knacken. Mit Wakü wird das klappen :)
Wenn ich an die ganze zeit denke informationen anderer user zu bekommen, karten hin und her schicken / 😙verkaufen, videos, jetzt zum austausch geschickt und nun wieder versuchen die karte zurückzubekommen um dann letztlich festzustellen, dass alles "normal ist". Sehr zeitintensives hobby. 😀 ich modde jedenfalls die fe mit der schwarmintelligenz von hier leise.
Das mag so sein aber am Ende wäre ich die ganze Zeit unzufrieden und das bei einem 2000€ Produkt... kann ich nicht machen. Die PNY werde ich in jedem Fall nochmal probieren. Schließlich ist die FE hier die erste 4090, die ich hatte. Also von Karten hin und herschicken kann da bei mir noch keine Rede sein. ;)
Dauert aber sicher noch, bis ich eine für ein gutes Angebot finde, also falls Ihr vorher moddet und es funktioniert, versuche ich es bei meiner auch.
Der artikel untertreibt. Der sound gewinnt an oberhand 😀
Was wäre ein gutes angebot für die pny?
@MS1988
Einmal deine Auflösung und einmal native 4K
So um die 2.000€ wäre ok.
Für mich persönlich müsste es ein Plexi Top sein, aber das Design hat schon was! Relativ einzigartig am Markt, viel besser als einfach nur ne schlichte Acetal Platte.
Besser? :) (leider nur Renderkram)
So, wie er hier zu sehen ist + Versandkosten = 441€ :oops:
Kann sein, dass da noch Zoll drauf kommt. Dann wäre man bei ~500€ :cry:
Hätte dir sonst meine tuf anbieten können. Aber warte lieber auf die modded 4090 fe. Habe da schon einige ideen. Nur material muss noch organisiert werden... bis dahin nagel mit dem ab den oberen lüfter auf 31% fest. Wird kaum wärmer. Und probier den fliesmod. Der bringt echt was. Da das ganze gehäuse dann nicht mehr resoniert.
Da ich mit der 4090 sonst ja nur PUBG low res/settings zock, komme ich jetzt mit KENA erst dazu sie mal weiter zu testen..
Spiele gerade mit dem UV rum. 2805@0.96v laufen jetzt schon eine ganze Weile. Werds weiter testen. 3000@1.1 machen ja nun leider gar keinen Sinn. Die 3000 würden mir schon gefallen.
0.95v ist ein guter sweetspot. 0.96 ist auch ok. Alles darüber verpufft in wärme und effiziensverlust. Eine 4090 für pubg low setting? 😃 reicht da nicht ne 3070/80 ?
Hmmm, also im Grunde ist es egal, ob 2.700@0.95 oder 2.800@0.96. Leistung steigt leicht, Verbrauch bleibt gleich, Temp steigt aber auch leicht. Im Grunde aber wayne welches der beiden Settings ich nutze. 2.800 ist die schönere Zahl :)
Warum 3.000 so fucking ineffizient sein müssen ... :cry:
Die differenz ist nicht groß. Aber der verbrauch steigt definitiv. Sonst würde es nicht wärmer werden 😉. Außer du hast ein perpetomobile modell erwischt.
Was hast du für eine cpu und welche hattest du vorher?
Und warum ist deine gpu so kühl?
Also ich habe auch mit 0.95V und 2700MHz getestet, und das waren auch bis zu ~50W mehr die da drauf gingen für 2% - 3% Leistung im Vergleich zu 0.91V und 2610MHz das ist es mir nicht wert :)
Ich lasse meine RTX 4090 mittlerweile nur noch bei 0.865V und 2505 MHz laufen. Das ist die niedrigste Spannung, die meine Karte annimmt (nach Laden des Profils ingame wird die Spannung angelegt, die 0.879V hier im idle haben nichts zu sagen). Speicher-OC ist bisher komplett stabil, keine Abstürze oder dergleichen.
Ich habe alles durchprobiert, hoch bis 1.1V und 3060 MHz. Zwischen max. UV und max. OC liegen bei mir maximal 15% Leistungsunterschied. Wenn ich mit der Performance in einem Spiel nicht zufrieden bin, dann bin ich das auch mit 15% mehr Leistung nicht. Dann werden die Regler bedient oder das Game wird halt auf der nächsten GPU gezockt, ganz pragmatisch.
Kommt mir ähnlich vor, ich denke ich ticke auch so wenn es um die große 3 geht ;)
Du kannst ja mal mit reduziertem Powerlimit, statt fixer Kurve testen. Meine TUF läuft im Alltag so und erreicht auch regelmäßig die 3 GHz bei max 340 Watt Verbrauch.
Ähnliche Themen
Antworten
7K
Aufrufe
591K
