[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nein, nur das Stückl MDF, nix anderes.
Man kann auch Plastik nehmen, völlig egal.
Vielleicht wäre es auch eine Möglichkeit die Finnen unterhalb des Lüfters etwas in Drehrichtung der Lammellen zu biegen, das die rotierende Luft besser ddrübergleitet und nicht gegen einen grat stösst der evtl. das Brummen verursacht.
Da fragt man sich doch wirklich, was die Ingenieure bei Nvidia den ganzen Tag so treiben, wenn ein Endkunde quasi dazu "gezwungen" wird an seiner 2000€ Karte herumzudoktern, um Lüfternebengeräusche zu minimieren/eliminieren. :fresse:
Schon richtig, aber wenn das wirklich so einfach ist, ziehe ich das der weiteren Suche nach der Nadel im Heuhaufen (andere leise 4090) vor. Denn ansonsten ist meine FE wirklich top.
An den Finnen werde ich nix abfräsen oder verbiegen oder sonstwas. Daher wäre mir so ein zu 100% rückgängig machbarer Lüfter"mod" sehr recht.
Nein, kannst du wie schon erwäht easy mit nem anderen Lüfter ausprobieren.
Lass den Laufen und geh mal nur mit dem Finger nah an den Lüfter, da hast du sofort Verwirbelungen/Lärm.
habe ja schon genug ausprobiert :-)
Und ein brechen des Schalls oder des Luftzuges ändert da schon was:
Wenn das Flies schon reicht um so besser. (y)
Ich hatte da noch ne andere Idee...
an so was dachte ich auch. Sieht nur nicht schick aus. Wenn man den Lüfter unterhalb anbringen würde wäre es annehmbarer.. Wo hast Du denn den Lüfter angeschlossen? An der Graka?
Edit: Achso, der ist ja unten. Und der bläst dann durch? und so ist sie auch ruhig?
Das mit dem Flies hat mir optisch aber auch nicht gefallen... :-) Möchte die Karte ja aus optischen Gründen (und wegen der hinteren Wärmeabführung)
Hier hatte doch mal jemand das pcie 3 / 4 bzw 8/16 lanes problem?
Hallo zusammen,
keine Ahnung ob hier im Thread der beste Platz für meine Frage ist aber ich hab bisschen den Überblick verloren.
Hab mir am Freitag eine Zotac Gaming GeForce RTX 4090 AMP Extreme AIRO bestellt, sollte Dienstag kommen.
Keine Ahnung ob das eine gute Idee war, war fast schon eine Kurzschlussreaktion. Hatte zwar gelesen das sie wenig Spulenfiepen hat
aber irgendwie übersehen das die Lüfter scheiße sein sollen.
Jetzt mach ich mir ziemlich sorgen das sie Laut ist wie ein Traktor. Deswegen meine Frage, kann man die Lüfter tauschen, falls es so ist?
Oder wird es vieleicht bald AIO Wasserkühlungen für die Karte geben, wie wahrscheinlich ist das? Kann mir da jemand was zu sagen?
Und wenn ich schon am Fragen bin. Wollte mir noch ein neues Netzteil dazu bestellen aber find gerade nix was mich überzeugt.
Ein paar neue Modelle sind ja angekündigt aber bis es soweit ist, kann ich solange mein bequiet STRAIGHT POWER11 650W
nehmen und die Karte undervolten?
Wenn ich auf meinem System Cinebench23 laufen lasse, brauch ich 205 Watt aktuell. Bisschen Luft ist ja schon noch da.
Was meint Ihr?
Vielen Dank euch
Woher weißt du denn vorher schon wie laut die Karte fiept?
Es ist stand jetzt völlig random
Also ich habe gestern einen neuen Peak was den Verbrauch angeht mit meinen UV Settings gesehen :d
In RE2 Remake mit RT und DLDSR (5160x2160) in der "Cutscene" in der Tankstelle, als der Zombie dem "Sheriff" in den Hals beißt... da ging der Hotspot schlagartig (wenn auch nur kurz) auf 92°C und der verbrauch auf 400W (mit 0.91V und 2610Mhz), das höchste was ich bis dahin gesehen hatte waren 350W im TSE GT2 hat mich schon etwas überrascht.
Allgemein auch auf 120 FPS limitiert ist der Verbrauch im Schnitt in dem Game recht hoch (280-320W)
Ja the Division 2 ist auch so ein Game nur liegen die Peaks dort öfter vor !
Ich lese ja nun seit Seite 1 mit und hab nun auch mal nen Benchmark laufen lassen, was ist eure Meinung gute Karte oder ehr bäh?
@ Netleader
0815 Karte, müsstest du aber doch selber am besten wissen, wenn du tatsächlich seit Seite 1 dabei bist…
Heute Morgen war das nur ein Bug , dass der Takt nicht weiter stieg.
Hier habe ich bislang mein bestes Ergebnis mit meiner Karte .
Mehr GPU Takt geht nicht https://www.3dmark.com/3dm/83972164?
3060 MHZ ist absolute max. Beim Ram geht vielleicht noch was .
Bei Superposition geht auch mehr durch , aber dann mit Grafikfehler .
Man sieht dann auch das zwischen fehlerfreien Durchlauf @ 3060 und 3105 MHZ nicht mehr so viel Unterschied bei den Punkten gibt.
Das liegt vielleicht an deinem Ton.
Ja ja, entspannt euch. Ich hatte eben schlechte Laune, sowas kommt vor. Seit Wochen klingelt ständig das Phone wegen 4080er “Deals“ die keine sind. Dann kommt ein Mal ein guter 4090er Strix Deal und man verpasst ihn, weil genau dann der Bot leider nicht läuft.
Kann man halt nichts machen, nichts für ungut.
Nutz doch distiller.
Aber entspannen müßtest du dich wenn du doch genervt bist 😀
Ich lasse mir nur Gesamt anzeigen.
Falls es dich interessiert. Im ab gibts noch nen 2ten mem wert. Der ist der richtige. Kann es gerade nicht checken. Bin rechnerlos....
Guckt ihr euch den gesamtverbrauch des rams an oder nur den für den prozess zugeteilten?
Allocated und dedicated. Sicherlich ist das der Gesamtverbrauch aber was soll neben dem Spiel schon groß VRAM auffressen.
Warum diese seltsame Auflösung und nicht native 4K?
Ähnliche Themen
Antworten
7K
Aufrufe
591K
