[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Meint ihr Nvidia passt bei aktuell steigendem €:$ Kurs die Preise eventuell zeitnah an?
Nein, es gibt keinen Grund dazu. Zumal Nvidia die Preise nicht macht. Die Preise machen die Händler.
Asus macht seine Top Modelle ja bereits billiger (nur unter 1950€ dürfen die denke ich einfach aktuell nicht gehen)
Wie meinst du das? Was wird denn da billiger? Preislich sind die Karten genau da wo die immer waren. Zumindest direkt bei ASUS. Was die Händler machen ist ein anderes Thema
und AMD hat Erfahrungsgemäß (bei RDNA2) die Karten ständig dem Kurs aktuell gehalten und so sollte eine 7900XTX bereits für aktuell 1150€ erhältlich sein.....
Wovor müsste man denn da fürchten? Ist kein 4090 Pendant und wird in Deutschland sowieso teurer sein. Da auch AMD keine Preise macht, sondern die Händler.
Ist eigentlich recht einfach gesagt: Da wird sich preislich wie immer nichts tun. Ich gehe sogar eher davon aus das es teurer wird weil wir aufs Jahresende zugehen.
Grüße, also es wurde ja schon erwähnt, dass die Punkte auf dem Kabel wohl von der Produktion stammen (China Ding-Kabel).
Ich vertraue dem Kabel genauso viel/wenig wie dem beiliegenden Nvidia Adapter, da beide aus China kommen! Ja, auch der "originale" Nvidia Adapter ist ein China Ding!
Dennoch wirkt für mich das "gecrimpte" China Amazon Kabel wertiger als der Nvidia Adapter...
Ich habe auch ein Seasonic Original Kabel geordert, ebenso eins von Cablemod. Bis eines von Beiden ankommt, wird das schon gehen. Btw hab ich ein Seasonic PX-850 Netzteil, Single Rail, da ist es egal ob ich 4 oder 2 Kabel rein Stecke für die Karte
Natürlich ist alles China Zeug - der Adapter ist, so wie er ist, von Nvidia freigeben und auch ausgiebig getestet worden. Wie ich schon mal schrieb, die Sache mit dem Löten ist, wie man so schön sagt, nicht die feine englische Art, dennoch ist es nicht das verursachende Problem. Im Gegenteil, siehe Bild, der Stecker des Adapters ist am Ende komplett vergossen, da kann man im übertragenen Sinne nen LKW dran hängen. Und die direkt gecrimpten mit diesem kleinen Stecker verursachen ja eine noch größere Last auf die dünnen Kontaktstecker im Inneren, wenn man diese nach unten oder oben biegt, das ist mit dem Adapter z. B. schlicht nicht möglich, weil der ganze Stecker durch das vergossene Endstück viel massiver ist. Deswegen hat das Cablemod-Kabel z. B., siehe weiter oben die Bilder, ja auch so einen massiven Stecker, was qualitativ gut aussieht. Das Problem sind hier Leute wie dieser unsägliche Igor usw., die mit ihrem Clickbaitartikelmüll, die zwar in Teilen nicht komplett falsch sind, ein Problem unnötig pushen, das schlicht in einem so kleinen Ausmaß existiert, dass es im Grunde nicht der Rede wert ist.
ich hab jetzt das 2. mal innerhalb von wenigen stunden nen bluescreen beim aufwecken aus dem energiesparmodus bekommen. ich drücke den einschaltknopf am gehäuse. er wacht auf, ich sehe den windows login und zack bluescreen.
ich hab die tage nur open rgb installiert, windows 11 updates sowie den aktuellen nvidia treiber..
jemand ähnliches beobachtet?
Ich versteh nicht wie Ihr alle zufällig so große Gehäuse hattet, dass die 4090 platzmäßig kein Problem darstellt. Nutzt hier keiner mehr Midi Tower? Laut Lian Li passt bei mir nur die FE und das noch nicht Mal mit dem Standard Adapter. Wahrscheinlich werde ich den dann so knicken müssen. Also falls ich eine bekomme. Aber n neues Gehäuse deswegen kaufen und alles umbauen?
Hat das hier jemand für die Karte gemacht?
Sogar mehrere, wenn ich das hier richtig gesehen habe.
Hatte bei mir nach dem dem letzen Midi Gehäuse echt kein Bock mehr auf die kleinen und das ewige Gefummel dort…schön viel Platz zu haben ist was feines. 🙏
ich hatte 2 monate vorher ein meshify 2 mini gekauft. das war noch vor dem bekanntwerden wie groß die teile werden.
Phu... also:
Nvidia und AMD machen für ihre Referenzkarten die Preise selber. AMD hat bei RDNA2 sogar die Preise ständig dem $:€ Kurs aktuell gehalten und so hatte die 6800XT zB jede Woche einen anderen Preis im AMD-Shop. Asus hat am Montag die Strix 4090 non OC noch für 2340€ angeboten und am Freitag wurde die selbe Karte bereits auf 2277€ reduziert. Weist auch auf eine Anpassung an den $:€ Kurs hin.
Wo du recht hast (zumindest teilweise) sind die anderen Shops alle. Hier macht grundsätzlich der Shop den Preis aber wie teuer der Distributor vorher die Karten einkauft für den EU-Markt ist vom $:€-Kurs abhängig. Dadurch verändert sich auch hier der Einkaufspreis für den Shop abhängig vom aktuellen Kurs. Änderungen dauern hier natürlich länger bis sie beim Endpreis in diversen Shops ist...
Dann guck mal mit dem nirsoft bluescreenviewer was es ist. Bei mir wacht er ohne fehler auf.
Ähm doch! AMD vertreibt seine Referenzkarten im eigenen Shop und da machen sie auch die Preise.
Gleiches gilt für die FE von Nvidia
Korrekt, nur die FE Karten. Sonst keine. Hier ging es aber z.b. um Customs unteranderem. Ich dachte es wäre selbstverständlich das damit die Karten aus dem Hauseigenen Shop bei AMD sowie die FE bei NBB ausgenommen sind. Aber offensichtlich nicht. Muss ich zukünftig dann nochmal dazu schreiben.
Nutze sogar ein SFF-Gehäuse :d NR200P - Hier passen nur wenige Modelle rein und mir Standard-Adapter bekommst du das Seitenpanel (im vertikalen Einbau) auch erstmal nicht mehr zu bis es die 90° oder 180° Adapter von cablemod gibt....
"Erstellung einer Abbilddatei aufgrund eines Fehlers beim Erstellen der Abbildkopie fehlgeschlagen."
:fresse2:
Da ich die Frage gestellt habe weiß ich denke ich worum es ging und was ich geschrieben habe. Ich habe nicht ausdrücklich irgendeine Karte spezifiziert und ich bin nicht begeistert wie du einfach frei alles auslegst um deine eigenen Aussagen als korrekt hinzustellen. Es ist okay manchmal nicht recht zu haben oder was falsches gesagt zu haben weißt du?
EDIT: Und wie sich der Währungskurs auch auf Custom-Modelle auswirkt habe ich denke ich auch zusätzlich anschaulich erklärt....
Meint ihr Nvidia passt bei aktuell steigendem €:$ Kurs die Preise eventuell zeitnah an? Asus macht seine Top Modelle ja bereits billiger (nur unter 1950€ dürfen die denke ich einfach aktuell nicht gehen) und AMD hat Erfahrungsgemäß (bei RDNA2) die Karten ständig dem Kurs aktuell gehalten und so sollte eine 7900XTX bereits für aktuell 1150€ erhältlich sein.....
Edit: Wenn ich bedenke das 3090 MSRP 1499$ Dollar war und wir damals die FE für 1499€ bekommen haben..... Eine 4090 für 1500€ junge das wäre was gewesen :d
Kommt darauf an...
es ist unwahrscheinlich, dass NVIDIA selbst hier auf Geld verzichten möchte. Allerdings importiert NVIDIA keine Karten direkt in die Verkaufsländer, sondern nutzt Händler dazu.
Wenn es um die Steuern geht (Umrechnungskurs), so spielt es keine Rolle, was wir jetzt haben - es kommt auf den Zeitpunkt an, wann die Karten die EU erreichen und welche Steuern dann fällig werden (Umrechnungskurs). Das heißt, wenn z.B. Gigabyte noch 50000 Karten auf Halde hat, die sie Mitte letzten Monats eingeschifft haben, werden sie selbstverständlich jetzt nicht den Preis senken (sofern sie das überhaupt wollen).
Preis senken muss man als Händler in aller Regel nur, wenn die Verkaufszahlen nicht gut ausschauen. Da die 4090 jedoch weggehen wie warme Semmel...
Oh das sieht gut aus. Mir ist nämlich selbst der Midi Tower noch zu groß. Nutzte vorher auch ITX Gehäuse. Möchte mich nur für diese Karte auch wirklich nicht vergrößern.
Also mit 90° Adapter passt hier eine FE?
Da sind wir halt auch wieder beim hauseigenen Shop. Ich glaube nicht das wir deswegen von einem Preissturz reden können. Aber das wird einige nicht abhalten. Der letzte Preissturz war ja als RDNA3 vorgestellt wurde, den gab es auch nie. Wir werden es erleben.
Hier!
Allerdings wollte ich eh ein größeres Gehäuse wegen Temps.
In mein altes Gehäuse hatte die FE gerade noch reingepasst. Hatte aber zunächst die Zotac und somit war dann schnell klar, dass jetzt der Zeitpunkt da ist, was neues zu kaufen.
Es ist auch okay manchmal einfach damit leben zu können das man eventuell falsch liegt wenn man mal wieder behauptet das die Preise sinken. Das Problem ist doch eher das dir die Antworten nicht gefallen und deshalb deine Meinung einfach über meine stellst. Natürlich würde es dir viel besser gefallen wenn ich geschrieben hätte "Jawohl, die Preise sinken". Das ist mir durchaus bewusst.
90° Adapter wird knapp. Einer der User hat ausgemessen und es sind wohl ziemlich genau 22-23mm bis zum Seitenpanel Platz. Cablemod gibt den 90° Adapter mit 22.6mm an :d Wenn dann also knappe Geschichte haha. Der 180° Adapter wird aber auf jeden Fall passen. Jemand hat sogar den normalen NV Adapter reingepackt.... sieht aber ungesund aus: https://www.reddit.com/r/pcmasterrace/comments/yfwnk4/my_4090_nr200p_build_with_watercooled_12900k/
Insgesamt hat dieser Threead einen schönen Überblick dazu: https://www.reddit.com/r/NR200/comments/y42tej/list_of_4090_gpu_fits_nr200p_in_horizontal/
Ich glaub der Pixelgott will mir einfach nur in die Stiefel pissen. Das erste 4090 hat nen Hardwarefehler und hätte eh nicht gescheit ins Gehäuse gepasst. 4 Wochen versucht ne FE zu bekommen, incl. VIP Platz bei der Stornoparty. Jetzt hats ja nun geklappt mit der FE, die morgen an die falsche Adresse zugestellt wird und ab dem Wochenende dann in meinen Rechner darf. Und was passiert? Liebesbrief vom Stromlieferanten:
Also doch weiter Forza auf der iGP zocken? 🤣 🤣 🤣 🤣
Wir hatten 2 Jahre ne Feldstudie mit Ampere zum Thema Angebot und Nachfrage.
Wir hatten den EVGA-Exit und in Kombination damit sind einige Geschäftsgebahren von NV mal wieder ans Licht gekommen.
Dann gabs noch das Jayz2cents Video, in dem erklärt wird was Nvidia auf der Angebotsseite macht (Auslieferungsstop) wenn der VK der 3000er Karten zu sehr sinkt.
Und dann gibts noch mehrere Quellen, die belegen wie seitens NV im Rahmen des NV-Partnerprogramm Druck auf Preise zu Releasemodellen und Kundentäuschung ausgeübt wird, indem es Sondermodelle gibt die zu Launch für 1 min verfügbar sind, und die dann sofort abgelöst werden und EOL gehen.
Um es kurz zu machen, auch für die Begriffsstutzigsten unter euch:
Die Preise für alle Karten sind exakt da wo NV sie haben will. NV tut alles um euch zu verarschen und die Preise in die Höhe zu treiben.
Ihr könnt noch so viel über minimale Preisschwankungen diskutieren... oder ihr könnt das was es ist akzeptieren. Und euch überlegen wie ihr persönlich damit umgehen wollt.
Wer Angebot und Nachfrage, in einem Markt wo der Anbieter das Angebot nach belieben manipulieren kann weil ein Monopol existiert, nicht verstanden hat dem ist einfach nicht zu helfen.
Sorry womit genau liege ich denn falsch und an welchem Punkt machst du fest das ich so große Hoffnungen habe das ich mit korrekt argumentierten Antworten nicht leben kann? Alles was du bisher geschrieben hast bis auf "die Händler machen ihre Preise" (wenn auch stark vereinfacht und kurzsichtig) war bisher schlicht falsch und ich habe auch genau erklärt warum.
Großteil deiner Posts versucht hier einfach auf biegen und brechen deine persönliche MEINUNG ohne gute Argumentation durchzuschlagen und das auch noch auf eine extrem unhöfliche Art. Langsam nervts.
Ouch, das tut natürlich weh. War mir gar nicht so bewusst das die regionalen Unterschiede (ich gehe aus du bist beim Grundversorger? sonst mal nachgucken die könnten durchaus günstiger sein aktuell) so groß sind. Ganz im Westen von Deutschland bin ich grad bei ~33cent/kWh beim Grundversorger.... Mit 24.13 warst du bisher aber echt günstig muss man auch fairerweise sagen :d
Wenn man sich eine GPU für fast 2K gönnt, dann sollte meiner Meinung nach auch noch genug monatliches Budget für die Stromrechnung vorhanden sein. Tipp von mir: Mal den Grundversorgungstarif prüfen und dann ggf. den Vertrag kündigen (falls Du noch nicht in der GV bist).
Nee, ist enviaM... ich kenne das Prozedere, bin ein Optimierer und mir tuts finanziell auch nicht weh - die FE kommt rein und das Powerlimit auf. Der Post war zur allgemeinen Erheiterung, da der Brief quasi Zeitgleich mit der Auftragsbestätigung für die FE kam ;) Aber schon krass wie es jetzt rein haut und wie wenig Alternativen es gibt - jetzt kommt ne Zeit in der man Strom zu wertschätzen beginnt!
Stimmt bedingt. Letztendlich hängt alles davon ab ob die endkunden kaufen. Tun sie es nicht funktioniert auch diese strategie nicht. Aber das ist wunschdenken. Habe ja selbst gekauft.
Luxus GPU brauch Luxus Stromkosten :d
Aktuell ist B-Ware bei NBB für mehr als Neuware. Wollen wir wetten wie lange die lagernd ist?
Ähnliche Themen
Antworten
7K
Aufrufe
588K
