[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also den FE Drop habe ich wieder mal verpasst, war beim Arzt...
Macht ja nichts ich habe eh schon eine vom Scalper gekauft >_< ...bei mir lagen die Nerven blank und ich konnte nicht länger warten... Selbst wenn ich jetzt keine gehabt hätte, hätte ich die heute wieder verpasst.
Aber als Anmerkung an diejenigen, die eine gekauft haben.
Meine 4090FE ist vom 2.11 und auf der Verpackung stand X von 200 GPUs der Lieferung. Demnach sind es nur 200 FEs auf einmal. Und hergestellt wurde die warscheinlich schon September bei Foxconn.
Wie bereits beschrieben hat auch bei mir Nvidia sofort gesagt ich darf mein BeQuiet Kabel nicht benutzen.
Die sind da aktuell sehr vorsichtig.
Spannend wenn jemand ein ATX 3.0 Netzteil hat braucht der dann einen Adapter für den Adapter ;-)
Ich hatte diesbezüglich mal direkt bei BQ angerufen.
Also Garantie seitens des Herstellers der Karte ist wie oben beschrieben und aus dem Grunde des Betriebs außerhalb der Spezifikation raus.
Gegenüber BQ hättest du eine Haftung nach Profukthaftungsgesetz, da allerdings bedenken, dass du 500€ Selbstbeteiligung hast und der zu erstattende Restbetrag sich auch nur am Zeitwert orientiert.
Also wenn dir das Ding abtaucht bekommst du realistisch vielleicht noch 800-1200€ ausgezahlt nach ewigen hin und her…
Oder man hofft auf die Kulanz und den guten Ruf von BQ das es einfach unbürokratisch erstattet wird :)
So, ich habe die MSI SuprimX auf Wasser umgebaut. Warte aber noch auf eine zweite Pumpe bevor Ich sie verbaue. :)
Jetzt hat es geklappt mit der Strix, geht doch.
Apple Pay war die Lösung, ging sofort durch.
Und die hat tatsächlich 2x HDMI 2.1?
Stand bei mir bei der ersten Charge (Release) ebenfalls. Wird vermutlich die Menge sein, die NBB pro Lieferung bekommt/ evtl. ganz Europa.
Bei der Umverpackung von Foxconn steht auf einem kleinen Lila-Aufkleber (unter PCB) das Date. Daran kannst Du ganz einfach ablesen, von wann die Karte ist.
Da gibt's auch Informationen zu Memory Art, BIOS REV, Rev der Karte selbst (bei mir war T - S) und anderem Kram.
Wie breit ist die Karte denn mit dem Block? Inkl. Terminal ab PCIe?
Ich kann nur wiederholt sagen, dass im Vergleich zu meiner 3090 Strix mit P-Bios Mode die 4090 FE deutlich kühler, effizienter, laufruhiger, weniger Spulensurren, wertiger und schöner ist. Ich könnte einfach nur den ganzen Tag schwärmen. 🥰 Ich hatte Glück eine zu bekommen und bin absolut happy damit und möchte sie nicht mehr missen. Die Temps sind btw. absolut super, auch wenn die ein oder andere Custom Karte kühler ist.
Kanns kaum erwarten meine 3090 Strix hat so krankes Spulenfiepen... das Umbauen auf Wasserkühlung hat das dann nochmal extra hervorgehoben :rolleyes2:
Habe den Originaltext von dem Supportchat mit NVIDIA gefunden (der OP im Reddit Thread hatte seinen Post aus nicht Bekannten Gründen gelöscht, über die timebackmachine gibt's aber kein Löschen von Informationen im Internet^^)
Die sollten alle mit 3x 8 Pin laufen.
Danke dir 🙏
Hmm mal schauen ob ich die behalte, oder doch gegen eine (sehr leise) TUF eintausche. Erst mal gucken ob mein Netzteil auch diese Karte packt und ob sie nicht kreischt wie blöde…
Der Kühler der FE ist richtig schlecht, der schlechteste von allen.
Bei dem Diagramm muß man aber mitbeachten das dies ein Diagramm bei genormten 35dba 450 Watt sind. Das sagt über die mögliche Kühlleistung des Kühlers nichts! aus. Es ist vielmehr ein Diagramm der dir sagt wie laut die Karte ist man kann daran aber nicht erkennen wie gut die Karte in der Lage ist zu kühlen. Es könnte beim Thema geringst mögliche Temperatur wenn die dba Grenze wegfällt so sein das die Founders, Zotac, Gigabyte etc. die beste ist die Kühlt z.B. Also auf dem Diagramm sieht man das Founders und Zotac die lautesten Lüfter haben aufjedenfall.
Moin, ich würde gerne mal eure Meinung hören zum Thema FE vs. Partner:
Ich habe aktuell eine Gainward non GS verbaut, und muss sagen dass ich super zufrieden bin. Die Temps sind top und die Lautstärke ebenfalls. Somit würde ich eigentlich sagen, never change a running system :)
Da aber ja dieses Video von Buildzoid herumgeistert, in dem er die PCB Designs/Komponenten der Palit (aka Gainward?!) stark kritisiert und ihnen im Grunde nur den Garantiezeitraum als Lebensdauer bescheinigt, frage ich mich ob ich nicht lieber auf eine FE umsteigen sollte?
Angenommen ich komme beim Tausch auf +-0, das Aussehen der FE ist meiner Meinung nach Hammer, aber soll nicht der ausschlaggebende Grund sein. Was meint ihr, was würdet ihr machen?
Dazu muss ich noch sagen, dass ich eigentlich absolut keine Overclocking-Ambitionen mitbringe, die Karte soll einfach laufen.
Viele Grüße
Um ehrlich zu sein, verstehe ich nicht, warum ASUS die Preise um knapp 70-80 Euro gesenkt hat. Aber natürlich nett von ASUS :)
Paypal macht mich fertig, wollte jetzt wegen dem Aquacomputer Waterblock ne Strix holen. Direkt bei Benachrichtigung bin ich rein, war bereits bei PayPal eingeloggt und musste mich nicht verifizieren, also direkt gezahlt, dann 2-3 Minuten "warten auf PayPal" und "Ihr Warenkorb ist leer"
Shops sollten mal hinkriegen den Warenkorb zu reservieren wenn man bereits bei der Zahlung ist.
Mal ganz abgesehen davon, dass der FE Kühler von den Ausmaßen viel kleiner ist als riesige Brocken wie die Strix, ähnliche aber leicht schwächere Leistung zu erzielen ist hier also positiv und nicht negativ^^
Und mal davon abgesehen, dass das Teil ausschaut wie ein Designerprodukt, und nicht wie ein Kindergartenprojekt mit Wassermalfarben.
Die 3090 Strix sah besser aus als das 4090 Pendant. Warum die das Produkt für die 4090 kaputt-designed haben, verstehe ich nicht.
Eine bekommen? :) War ziemlich lang verfügbar (Wenn man direkt vor dem PC sitzt)
Meinst du die TUF?
Musste die kleine von der Schule abholen :cry:
Für Leute mit vollem Familien Alltag ist das eine Katastrophe etwas zu kaufen .
Wie neulich mal hier jemand schrieb das müsste mal für Paar Stunden verfügbar sein.
Ach du scheisse da gab es ne Strixx vor 30 min :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :mad: :kotz::kotz::kotz::kotz::kotz::kotz::kotz:
Bin echt bedient !
Fu**
€ ist wieder auf Talfahrt…
Der € ist aktuell so stark wie schon seit Monaten nicht mehr
Wenn die Geschichte so weitergeht, und der € steigt, hat AMD kein Argument, bei uns die Preise um 20% im Vergleich zur US MSRP zu heben.
Wir werden also sehen, ob es tatsächlich um Conversion Rates geht, oder nur um Ausreden, aus Gier die Preise nach oben zu treiben...
