[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Als ich vorhin das Apex installiert habe, habe ich beim Einstecken des beQuiet Kabels genau auf das Klick Geräusch geachtet sowie das haptische Feedback. Tatsächlich gab es ein Klicken und man merkte, dass der Adapter richtig eingerastet ist. Auch habe ich das Kabel nun schon sicher 10 Mal an- und abgesteckt und es sieht immernoch top aus, so wie die Buchse an der Grafikkarte auch.
Macht schon Sinn, fühle es da ähnlich. Glaube bei RT macht es auch einfach nen großen Unterschied welchen Monitor man betreibt. Ein OLED oder ein high end HDR1000+ Display macht da glaub ich einfach das RT erst so richtig gut.
Hehe... Na dann halt dich fest!
Ich nutze zufälligerweise sogar einen LG OLED C1 in 65 Zoll!! 😆👋
Und ich muss sagen, bisher bin ich von dem hochangepriesenem RT Effekt nicht wirklich begeistert. Es ist cool und macht was her! ABER es ist mir den Mehrverbrauch einfach nicht wert...
Mein Plan ist jetzt noch bis auf jeden Fall The Callisto Protokoll zu warten und es mir dort noch mal genauer anzusehen und einwirken zu lassen und dann entscheide ich mich auch endgültig. Bis dahin sollten auch handfeste Vergleiche zwischen allen Grafikkarten auf dem Papier liegen, sodass die Entscheidung wesentlich besser getroffen werden kann.
Nun ja, hahah, ich lebe halt manchmal frei nach dem Motto, erst schießen und dann fragen "how are you? " 😆
Meine @dante`afk hatte durch sein EKWB Sandwitch mehr erreichen können , aber bin mir grad nicht sicher.
Er hatte im Anschluss definitv sehr niedrige Vram Temps.
memory hat sich hier nicht geaendert, +1500.
gpu core konnte ich aber von luku auf waku von 250 auf 290 anheben.
Zum Verständnis, für jemand der manuell seine Karte tweaked hat das ganze "OC" oder "non OC" doch sowieso keine Bedeutung? Hab es immer so verstanden das nur Karten die ein Bios haben die ein höheres Power Limit erlauben so wirklich besser performen können. Schließlich kann ich auf ner TUF "normal" wie auch einer TUF OC einfach den Takt manuell anpassen?!
Das ist richtig. Finde es aber besser wenn ich weiß, dass Kühlpotenzial nicht verschenkt wird. Für die Lebensdauer und so weiter.
Wollte sowieso eigentlich auf die AMD Karten warten aber dennoch auch Raytracing endlich mal eine Chance geben nach meiner RX 6900 XT LC, die immer komplett ohne RT verwendet habe und merke jetzt einfach wieder wie egal mir RT ist und der Mehrbedarf an Strom es einfach nicht wert istbmit RT zu spielen!
Sehe das genauso. Sicherlich gibt es Titel wie CP2077, wo RT echt schick aussieht, aber mir ist der erhöhte Stromverbrauch für einen visuellen Effekt einfach nicht wert. Weißt jetzt nicht, wie das bei der 4090 aussieht mit RT/ Stromverbrauch, aber bei der 6900XT war der Unterschied gewaltig. In CP2077, Ultra-Preset (1440p) mit RT an, hing die GPU direkt im 290w PL, trotz UV. Mit dem Ultra-Preset, RT aus und FSR auf Auto waren's mal eben 150w weniger. (Details) SOTTR verhält sich da ähnlich mit den RT-Schatten. Optisch merke ich kaum einen Unterschied im Gameplay, aber die Karte zieht gleich 70-80w mehr mit eingeschaltetem RT + deutlich weniger FPS. Ich warte jetzt AMD's 7900XTX ab und entscheide dann, ob ich bei Team Rot bleibe oder wieder zu Nvidia wechsel.
Dann mache mal Screenshots von der Curve mit beiden BIOSen auf der selben Karte und achte darauf, dass die Temp nichts verfälscht.
Ist mir schleierhaft, warum man die Abzocke eines oder mehrere Hersteller versucht zu schützen.
Übrigens heißt es Aggrobirne :wink:
In Tekken 7 oder Dead or Alive verabreden und wie echte Zocker Männer klären würde ich mal sagen! 😆👏
Verstehe ich nicht? Warum bleibst dann nicht mit ner 2070 auf 1080p. Dann haste auch kein visuelles Upgrade und ganz viel Geld gespart :-)
Ich bewundere Leute, die gut in Beat'em Ups sind! Vor allem Fair und ohne Makros spielen.
Oder Starcraft 2 wie eine Künstliche Intelligenz spielen können.
Ich kann es aber nicht. Das braucht schon viel Übung und Training. Hoffentlich haben die nächsten Beat'em Ups RayTracing und nahezu fotorealistische Grafik.
Sehr cool 😎
Ich liebe Tekken seit meiner Kindheit und seitdem täglich am Verprügeln oder werde verprügelt jetzt auch am PC! Habe selber früher Kampfsport und Tanzen (Gogo und Strip 😎🤭😆 ach ja by the way war sogar mal bei den in Deutschland in der Szene sehr bekannten Sixxpaxx mit auf Tour😍💪) gemacht und würde es sehr gerne weiter machen aber es ist ja alles irgendwie tot... Deshalb eben virtuell weiter ausleben 😆
Einfach nur genial online bei Tekken 7. Es spielt sich so verdammt smooth und sieht immer noch sehr gut aus in nativen 4k maxed out. Freue mich extremst auf Tekken 8, welches tatsächlich in Unreal 5 Engine und selbstverständlich mit Raytracing daher kommen wird 🤭
Und damit mein Beitrag nicht ermahnt wird sage ich mal lieber dazu, dass es sicherlich verdammt geil sein wird auf einer RTX 4090 😍🤣👏
Danke, dass du mir Tipps geben möchtest, wie man Geld spart. Insbesondere in diesem Thread und bei deinem Namen :LOL:
1. Mag ich Hardware
2. Stelle ich Stromverbrauch/ FPS - Effizienz immer an erster Stelle und optimiere nun mal gern
3. Möchte meine Ziel-FPS auch mit sehr hohen-/ Ultra-Einstellungen erreichen, auch für zukünftige Titel
4. Ist eine 2070 für meine Anforderungen keine geeignete Karte für 1440p oder 4K
5. Besitze ich keinen 1080p Monitor
Nur weil meine Anforderungen nicht deinen entsprechen, musst du jetzt nicht den Forenclown spielen und mir irgendeinen Dünnsch*** empfehlen. Das kannst du gerne auf deinem YT-Kanal machen.
Da sind wir leider aber weit von entfernt /:
Zum Release konnte man sie relativ einfach bei MM bestellen. Kollege hat sie dann mit seinem Mitarbeiter-Rabatt von 10% geholt für mich. 😍
Kleiner Fun Fact am Rande... da der Spaß mit der 4090 (Zotac Amp) von kurzer Dauer war (Freezes, auch in Windows Desktop) und ein neues Spielzeug wohl erst am Samstag kommt hab ich mal die IGP vom 13900K ausprobiert. Mein VR-Zeug brauch ich natülich nicht anfangen aber Forza Horizon 4 auf der HD Glotze läuft gut. Detail u.s.w. auf minimum runter, OC auf 2100 Mhz und der macht 50 FPS/50Hz mit gelegentlichen Framedrops. Absolut spielbar, Spaßfaktor uneingeschränkt. Über AA oder so reden wir mal lieber nicht. Also weshalb will hier jeder ne 4090? :ROFLMAO:
So bin jetzt auch stolzer Papa einer 4090FE. Aber das Baby schreit und fiept :d
Ich glaube, das ein paar Finnen im Luftstrom vibrieren und ein vrrrrr erzeugen, das schon bei 30%RPM.
Direkt nach dem Einbauen gab es auch Spulenfiepen, aber das war nach ein paar Durchläufen weg bzw ich höre es mit Kopfhörer nicht.
Das "Fiepen" hört sich aber an wie eine leise HDD :d
Und was den Adapter angeht...der ging leicht rein und war sofort bündig abgeschlossen....nur beim reinstecken der 8-Pin in den Adapter musste ich kämpfen, da ein paar Pins vom Adapter krumm waren.
Wie sind so eure UV-Settings? Ich habe 900mv bei 2600Mhz und +1000 Mem schnell reingemacht ->24100 Punkte und unter 315W, bei 875mv und 2600Mhz geht Port Royale nicht durch.
Edit: Unter 875mv will die Karte nicht.
2700MHz bei 0,925Volt gehen bei mir ohne Probleme. 0.875Volt bei mir ebenfalls nicht.
Was für ein Prügel oO
Oben 3090 Strix mit WB, 3090FE und 4090 Strix.
Adapter ging ziemlich schwer rein ist aber bündig:
Wenn ich nicht stark gedrückt hätte, wäre er nicht bündig!
Außerdem weiß ich nun, was LianLi meint, dass die Karte mit Adapter nicht ins O11XL passt:
Also Du hättest die Bilder besser in 4K Auflösung gepostet. Man kann kaum etwas von dem Kabelsalat erkennen. :rolleyes2:
UV unter 875mV geht wohl nicht.
Ich lasse meine FE bei 875mV @ 2500MHz & +1500MHz RAM bei PL 70% laufen... ist in vielen Spielen irgendwas zwischen 200 und 250 Watt an Leistungsaufnahme. Fiepen tut meine auch, aber "wahrnehmbar" erst bei ca. 200FPS oder so. Es ist bei den 175Hz des Alienware zumindest nicht störend und ich müsste schon ganz genau hinhören, um überhaupt was mitzubekommen.
Falls jemand überlegt sich ein neues Asus Thor 1000W für die 4090 zu kaufen - es besteht eine große Chance, dass das 12+4 Kabel nicht dabei ist. Laut Asus Website soll es dabei sein, kann aber sein, dass es bei älteren Netzteilen nicht dabei ist.
Habe meines letzten Samstag bekommen, abends den Support angeschrieben und Montag kam die Antwort und Mittwoch war das passende Kabel da. :)
Also echt super. 👍🏻
