[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hab ein ganz komisches „Problem“ mit meiner Strix OC:
Sobald ich über den AB meine Voltage auf 1.1v erhöhe und dann auch in der Lage bin, mit der Karte viel höher zu takten habe ich einen erheblichen Schwund an Grafikkarten Punkten.
Die meisten Punkte erreiche ich mit 40 % Voltage also 1.070v.
Gibt es jemand mit einem ähnlichen „Problem“?
1.070v: https://www.3dmark.com/spy/32023890
1.1v: https://www.3dmark.com/spy/32201358
Mal ein kurzes Update für alle die irgendwann bald oder in ferner Zukunft vor einem ähnlichen Problem stehen.
Es scheint so als hätte die Strix hierbei ein Problem mit der Voltage, ob das jetzt nur meine Strix OC betroffen hat oder auch andere kann ich leider nicht sagen, auch wenn Roman „der8auer“ von ähnlichen „Problemen“ in seinen Videos berichtet.
Problemlösung: Strix OC verkauft, FE gekauft und siehe da: https://www.3dmark.com/spy/32243620
20 minuten Quake2 RTX / ekwb FE block
OT:
Plague of Requiem hat soeben seinen ersten großen Patch erhalten (immer noch ohne RT übrigens), hier die Patch Notes:
Patch Notes common to all platforms​
Changes & Updates​
  • Balanced difficulty in “Nothing Left” and “Dying Sun” final arena fights.
Optimization​
  • Optimized AI, rats, terrain and navmesh to reduce framerate drops and freezing issues.
Bug Fixes​
  • Fixed HDR issues creating crushed highlights (not applicable to Nintendo Switch).
  • Fixed random crashes or blockers that could happen in some chapters.
  • Fixed blockers or animation bugs that could happen during some crank interactions.
  • Fixed issue during reaction between Ignifer pot and Odoris in specific cases.
  • Fixed a script issue that could make the pine cones thrown by Hugo in “Under a New Sun” invisible.
  • Improved cart collisions to prevent going out of the map.
  • Fixed minor visual bugs in some chapters.
  • Fixed unexpected change of audio language when changing other options.
  • Fixed minor issues in German language.
Patch Notes specific to PC​
Changes & Updates​
  • The game is now compatible with Steam Deck.
Optimization​
  • Added new graphics options to improve visual and performance customizations (Frame limiter, Resolution optimizer, SSAO, DOF, Screen Space Shadows, Motion Blur).
  • Improved auto setting graphic profiles to better match PC configurations.
Bug Fixes​
  • Fixed specular flickering issues with DLSS.
Wegen ein paar Punkten hätte ich die Strix nicht verkauft. https://www.techpowerup.com/review/asus-geforce-rtx-4090-strix-oc/38.html
Ca. 21 Minuten gezockt. Mit 600 RPM der Lüfter und 2x 360 Radis. Man, habe ich das Spiel vermisst :)
Die Preise im ASUS Shop werden gerade von der 4090 STRIX geändert. Gleich ein Drop?
https://webshop.asus.com/de/90YV0ID0-M0NA00/kein-Name (Kein Name) :d
Betreibt jemand seine Karte mit einem Be Quiet! STRAIGHT POWER 11 ?
Ich habe jetzt des Öfteren hier gelesen, man solle die Kabel an PCIe1 & 3 stecken - ich habe mit den beiliegenden Kabeln jedoch nur die Möglichkeit alle 3 PCIe zu belegen, da ich drei Kabel nutzen müsste (siehe Foto)
Es gibt nur ein Kabel, welches sich in 2 x 8Pol spaltet - und ansonsten 2 Kabel, welche dann je nur EINEN 8 Pol haben.
Jetzt bin ich verwirrt, ob man das so machen sollte....
OT:
Wtf. Soviel also zu "shortly after launch".
Erst groß bewerben, dann nicht abliefern.
Enttäuschend. Das Thema haben sie zum Release totgeschwiegen gehabt (viele Leute auf Reddit haben sich gewundert, wo RT ist - und dann gab es ein paar Falschmeldungen ("go into the files and activate it manually" -> faktisch hat sich InGame dadurch nichts getan).
Statt einfach mal zu sagen "it's not done yet, we couldn't crunch that hard, we'll deliver it in aprox 2 month" - kommt so ein Müll bei raus, bei dem ein Entwicklerstudio (mal wieder) versucht, Probleme totzuschweigen.
Features zu Release zu bewerben und dann winzig im kleingedruckten zu verstecken, dass eines der zentralen Features nachgeliefert wird... sollte verboten gehören. Beworben zum Release sollte nur das werden, was auch tatsächlich verfügbar ist. INSBESONDERE bei einem Single-Player Titel.
Vermutlich ist hier Microsoft schuld, da man den Release Termin für das Thema Xbox-Game-Pass Library unbedingt wollte... hilft als Erkenntnis jetzt aber auch nichts. Feature ist nunmal nicht da - und Menschen wie ich, die das nutzen möchten, müssen nun eine unbestimmte Zeit länger warten.
Extrem ärgerlich ist das natürlich für jeden, der das Game - um das Studio zu unterstützen - für Vollpreis gekauft hat... und nun warten darf auf essentielle Features...
Wen es interessiert bisschen Spekulation zur 4080 und 7900 XTX
Igor mal wieder als großer Spekulatius Maestro^^
Die Modelle unterscheiden sich, schau auf der Website die Rail Aufteilung nach. Die stärkste Rail verbindest du mit deinem 2x 8-Pin, den Rest mit den einzelnen. Wenn alle Rails gleich stark sind, dann ist es egal.
  • Danke
Reaktionen: SH
Es kann auch sein, dass NVIDIA mit der RT Qualität und Leistung bisher nicht zufrieden ist.
Interessanter Spekulatius, wobei hier die Frage im Raums stehen darf, warum denen das fünf Minuten vor Release einfällt. Ich sehe hier als realistisch eher Microsoft als Schuldigen, der zwecks Game-Pass-Library unbedingt die Spiele verfügbar haben will und höchstwahrscheinlich auf Einhaltung der Verträge gepocht hat (wobei das Spiel unfertig ist/war). Am Ende werden wir die Ursache aber wohl eh nie herausfinden^^
Bevor ich's vergesse - in Anbetracht der grausigen Performance auf den meisten Systemen (Game ist extrem fordernd, siehe Benchmarks in Reviews), kann es auch einfach sein, dass das RT "zu gut" ausschaut/ist, d.h. dass die Features zuviel Performance fressen und man hier noch Optimierungen ("downgrades") durchführen muss, weil ansonsten bloß die 3090 (ti)/4090 Besitzer in 4K mit RT zocken können.
leute, atmet doch mal locker durch die hose. wenn ich so lese über was sich manche hier aufregen, ist mir echt ein rätsel. Wenn ihr so weiter macht landet ihr mit 45 im grab und habt nix davon.
Hat hier irgendwer die kfa2?
Wenn ja, wie viel pt kann man der geben?
leute, atmet doch mal locker durch die hose. wenn ich so lesen über was sich manche hier aufregen, ist mir echt ein rätsel. Wenn ihr so weiter macht landet ihr mit 45 im grab und habt nix davon.
Wenn ein Unternehmer ein Produkt bewirbt und hierbei mit bedeutenden Features wirbt, dafür einen Batzen Geld verlangt - das Feature aber nicht abliefert (und nichtmal in der Lage ist, konkrete Zeitpunkte zu nennen, ab wann das Feature erscheint) - dann ist das schlichtweg irreführende Werbung und jedem Verbraucher wäre dazu geraten, sich darüber Gedanken zu machen. Damit dieses Verhalten in der Industrie Konsequenzen hat. Damit solches Verhalten in Zukunft abgestellt wird.
Solches Verhalten ist sinnvoll und notwendig - Emotionen sind hier weniger nötig. Aufregen braucht man sich nicht.
Darüber hinwegsehen, so wie Du das vorschlägst, ist genau der Grund, warum die Industrie mit so einem Verhalten bisher durchgekommen ist.
Viele Verbraucher sind "zahm" geworden, lassen sich behandeln wie Idioten, denen nichts mehr zugetraut wird und die nurnoch still daneben stehen, wenn Unternehmer immer weiter ihre Produkte zum Schlechteren verändern (Features bewerben aber nicht abliefern, Verpackungsgrößen still und heimlich verkleinern ("39.5 gramm anstatt 42..."), Produktzusammensetzung mit billigeren Zutaten ändern ohne etwas zu sagen...)... die Liste ist lange. Am Ende wundern sich dann alle über die Ergebnisse. Absehbar war das... hätte es etwas mehr Widerstand gegeben, würden wir heute woanders stehen.
Wie ist das eigentlich mit den Lanes bei Corsair? Die Bedienungsanleitung hat dazu null Info.
Wenn ein Unternehmer ein Produkt bewirbt und hierfür mit Features bewirbt, dafür einen Batzen Geld verlangt - das Feature aber nicht abliefert (und nichtmal in der Lage ist, konkrete Zeitpunkte zu nennen, ab wann das Feature erscheint) - dann ist das schlichtweg irreführende Werbung und jedem Verbraucher wäre dazu geraten, sich darüber Gedanken zu machen. Damit dieses Verhalten in der Industrie Konsequenzen hat. Damit solches Verhalten in Zukunft abgestellt wird.
ja und dan gehste klagen oder was:) bringt dir bei MS nicht viel :)
Und hätten sie zum release den RT Patch mit rausgebracht und die performence wär unter aller sau, würde auch jeder sich aufregen. RT ist nicht da Genieße es oder geh klagen. Was anderes kann mann Aktuell eh nicht machen, und wie gesagt sich über sowas aufzuregen, ist mir mein leben zu schade dafür.
Gibt da schon Möglichkeiten ;-)
Hier scheint echt keiner Angst vor dem schmorenden 12VPHWR zu haben....es werden hier ja gezielt die Karten gekauft, die am meisten betroffen sind. :d
Meine FE kommt morgen, aber das Kabel steckt seit letzte Woche im DHL Lager und rührt sich nicht...dabei ist die FE durchs selbe Lager gegangen -.-
Kleine Wasserstandsmeldung: Die PCI-SIG hat einen technischen Änderungsantrag für den 12-V-HPWR-Kabelstecker eingereicht
  • Danke
Reaktionen: THK
Das ist aber nicht das be quiet Kabel? Habe auch ein Straight Power 11 mit dem be quiet Kabel und das spaltet sich auf zwei PCIe Stecker beim Netzteil.
