[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
1) Welches Kabel haben die verwendet? Den Nvidia-Adapter?
JA!
2) Haben die durch den Nvidia-Adapter 1450 W gejagt?
JA!
3) Wie viel Watt kamen auf der anderen Seite davon an?
Keine Ahnung. Schau es dir doch selbst an, hatte es dir ja verlinkt?
Du hast es also gar nicht gelesen? Das erklärt einiges.
Dass mit den temperaturbedingten Widerständen hast du aber verstanden, oder?
Ja und denkst du nicht, dass das Amphenol (dem Hersteller) auch bewusst ist und er nicht ohne Grund 105°C ins Datenblatt schreibt?
Wenn das Datenblatt 105°C vorgibt, dann muss das Kabel die 600W auch bei 105°C liefern können.
Alleine dieser Fakt widerspricht deiner Theorie schon.
Sry, frage mich echt gerade, wie doof man sein muss - dass man denkt, ich spreche von 100°C+ im Gehäuse.
Es geht um Widerstände, genau dem, was @Naennon geschrieben hat.
Um Widerstände bei steigender Temperatur, korrekt. Und das Kabel ist bis 105°C genormt und wurde bis 127°C getestet.
Diese Temperaturen werden aber nicht ansatzweise erreicht, wenn kein Defekt am Kabel vorliegt und wenn ein Defekt vorliegt, dann ist die Ursache nicht die Temperatur, sondern nur ein Symptom.
Dieser Power Adapter / Seasonic Kabel Fall ( Nr 28 ) is nun auch in die Liste mit aufgenommen worden : ( achtet aber auf den Text )
Der Text macht wenig Sinn irgendwie, "it failed before he bought the native.." was genau, der Adapter? Und er hat dann trotzdem das native Kabel noch reingeschoben?
Wenn man den Chinesischen Post von Chrome auf Deutsch übersetzen lässt kommen lustige Dinge raus :d
Ich find den Fall auch etwas undurchsichtig ... hier mal den Original Text in Englisch übersetzt :
Und hier das Original :
@owned139
Schick mir deine Adresse, anschließend lassen wir einen 6 Stunden Loop bei 500 bis 600w Verbrauch durchlaufen.
So überzeugt, wie du bist, spricht doch nichts dagegen, oder?
Hat HisN doch schon gemacht?
<-- hat seine TUF jetzt mal übers verlängerte WE falten lassen.
3 Tage lang 24/7 ...
Die Graka, die Stecker und ich leben noch.
Außerdem hat das Spulengeräusch nachgelassen.
Wie wärs, wenn du dir einfach mal das Datenblatt und den Test von Teclab anschaust und mir anschließend nochmal erklärst, wie das mit deiner Theorie zusammenpasst.
Du widersprichst mir vehement, aber hast dir weder das Datenblatt, noch den Test angeschaut. Trollst du?
Ja klar, er lässt seine Karte mit Richtung 600 W falten... Der wird eher eine effiziente Einstellungen zum 24/7 verwenden.
Das entnehme ich seinem Text nicht. Behauptest du also einfach? :lol:
Ist ***** der Zweitaccount von Thrawn?
@HisN wie hoch war der Verbrauch deiner Karte während des Faltens?
Ich habe mir da einfach selbst was zusammen gereimt. Ob es stimmt ? Keine Ahnung, bin weder Elektriker, noch habe ich einen Doktor Titel.
Steht das Kabel zu sehr unter Zug-Spannung (Biegeradius), ist der Kontakt nicht mehr 100% gegeben. Also wird entweder eine kleine Stelle viel stärker belastet oder aber es kommt zum "Funken-Flug". Der Funken-Flug ist natürlich für uns gar nicht wahrnehmbar, da es um Millimeter (wenn nicht noch kleiner) geht.
Vielleicht reicht das aber schon für den Temperatur Anstieg aus. Das normale Kabel / Stecker wird niemals 105Grad oder mehr erreichen.
Kabelbrand entsteht ja nur durch 3 Auslöser : Lockere/Lose Verbindungen , Kabelbruch oder Überbelastung. Hier würde ich als Laie auf Punkt 1 tippen.
Funken bei 12V... Ich denke eher nein
Was erwartest du um den Preis? Das sind €1949,-- UVP Karten
Das hat die Leute in den 4 Wochen davor auch nich gestöhrt .. da ging alles innerhalb von max 1 min weg auch wenn es über 300 Euro über der UVP war is also dann schon auffällig wenn nun etwas über 12 Stunden im Schop verweilt und immernoch verfügbar is wie nun bei Mindfactory .. das wird wohl ein Shop fehler sein.
Ich hab mit 2.7Ghz bei 0.95v aber mit offenem PT falten lassen. Natürlich nicht volle Pulle^^
Wie viel Watt hat die Karte gesaugt?
@***** ich jage meine Karte morgen gerne mal für 6h durch Furmark. Wenn nichts passiert, hörst du hoffentlich endlich damit auf die User hier mit deinen wilden Theorien verrückt zu machen.
Welche Seite ist das, wo man sehen kann wo verschmort ist?
Die Links findest du immer im Megathread
Nochmal extra für dich der Original Link :
Unnd nochmal der Megathread wo man die Liste der Fälle findet und die Links zu den Fällen
Ah du bist noch beim TUF Fall Nr. 26 dachte du meinntest nun den aktuellsten Fall Nr 28
Der TUF Fall Gestern war der hier :
Die Anderen Bilder findest du in den Kommentaren vom Thread ersteller :
Die Seasonic Netzteile kommen ja im Dezember weiß man da schon ein genaueres Datum?
Okay. Du glaubst wirklich dass in dem Bereich soviel Abwärme auf die Steckverbindung einwirkt, dass das eine echte Ursache sein könnte? Das müsste doch enorm viel Abwärme sein. Ich tue mich gerade schwer damit wenn ich an Temperaturen von 100°C+ denke.
Ich kanns nicht ausschließen. Ich bin kein Techniker. Aber irgendwie tue ich mich damit echt schwer.
400W sind 400W, egal ob die GPU 40°C oder 80°C ist und bei jeder AIB geht die warme Luft an den Stecker vorbei. Ausgenommen die FE und die von 4090 EVGA :d
Aber ich denke das der Fehler nicht daran liegt.
Ich glaube eher das der 12VHPWR Stecker, der auf den GPUs gelötet ist, fehlerhaft ist. Möglicherweise gab es beim Zulieferer der Stecker eine Charge mit Fehlern. Z.b. unreines Material in den Kontakten oder so.
Denn:
1. Es ist nicht nur der Adapter sondern es sind auch native Kabel von mehreren Herstellern betroffen.
2. Die Adapter und Co wurde ausreichend getestet und diese halten deutlich mehr aus als bei den Zwischenfällen.
3. Es sind nicht alle GPU Modelle betroffen, denn nicht alle GPU Hersteller beziehen ihre Bauteile aus derselben Quelle.
Es ist nur eine These, aber je man ich darüber nachdenke, ein Fehler am Adapter scheint es nicht zu geben.
Wenn in 1-3 Wochen einige Fälle mit CableMod Adaptern kommen, dann werdet ihr mir bestimmt Recht geben. :fresse2:
Die Strix von gestern wurde tatsächlich versandt. Jetzt bin ich mal sehr gespannt und in voller Vorfreude :banana:
Haben die Scalper keine Lust mehr oder werden nun die Scalper wählerisch ? Die Dinger sind immernoch lieferbar schon seit Gestern Abend ... vielleicht aber auch ein Shop fehler :
Naja, was erwartest du? Irgendwann ist der Markt halt mal gesättigt, soll nicht heißen, dass niemand mehr eine 4090 will aber mittlerweile gingen ja schon einige raus. Außerdem hat AMD letzte Woche eine gute Vorstellung von RDNA3 hingelegt zu interessanten Preisen. Spieler, die RT nicht brauchen sowie keine nVidia Features wie NVENC, werden sich wohl dahin orientieren.
Ich kotz im strahl... TUF im Asus Shop schon in der Kaufabwicklung, scheiterts an mäßiger internetverbingung und Paypal Confirmation SMS. War aber unter 2 Minuten. Keine Chance.
Fuck me, hat wieder nicht geklappt mit der TUF, hatte die schon im Warenkorb und dann war sie plötzlich weg…
Ganze Asus Seite ging fast in die Knie dabei
Ähnliche Themen
Antworten
7K
Aufrufe
587K
