[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe dort das erste mal bestellt. Die bestellung ist schon seit längeren offen, deshalb wundere ich mich nur ein bisschen.
Weil BeQuiet nicht aus dem Quark kommt und Ewigkeiten braucht, um so ein Kabel zu produzieren.
Habe gestern angerufen und mir wurde gesagt, dass sich die Lieferung etwas verzögert, aber spätestens heute kommen soll. Warte schon seit 2 Wochen.
Ich schon fast 4 Wochen. Auch bei CU bestellt?
Bestellt am 14.10 als die auf lagernd standen
Ich spiele @1080p
Ah thx, mich hatten die 30Fps+ und mehr gewundert beim Wechsel von 5900x auf 5800X3D, aber bei 1080p ist das natürlich logisch, dachte schon bei 4K gäbe es so einen Schub, dann hätte ich auch gewechselt.
Spiele halt nur und ausschließlich in 4K, da scheint es sich dann nicht wirklich zu rentieren.
Ich habe bei Cablemod letzte Woche bestellt (4x 8Pin auf 12VHPWR für Seasonic/Asus) und wurde gestern schon verschickt. Mal sehen wie lange es jetzt noch dauert aber schneller als ein Monat wird es denke ich schon.
Ich habe mein Kabel 3x 8Pin auf 12VHPWR am 26.10 im EUstore bestellt, bisher ist nichts passiert "estimated shipping date" ist der 09.11. :d
Jo wenn man natürlich zu 100% im GPU Limit hängt, macht eine bessere CPU kaum mehr aus. In MMO´s ist das halt anders, da Spieler (u.a. Städte, Raids. PvP) meistens durch die CPU berechnet werden. Kann mir auch gut vorstellen, dass WoW nun derbe crank läuft. Hmm muss ich wohl doch mal Dragonflight anzocken :unsure:
Scheint das selbe BIOS zu sein wie V1 , weil er kein Update macht .
Die V2 wurde bei mir aber installiert. Was es genau bewirkt, dazu gibt Asus keine Information. Ich habe bemerkt, daß die Karte beim Nichtstun auf unter 10 Watt fällt (Board Power), daß war vorher glaube ich etwas mehr.
Bei mir wars der 22.10. ESTIMATE Date 05.11. Seitdem ist das Datum verschwunden und steht auf processing und danke für ihre Geduld. Nervt nur noch...
Ich habe vor gut 2 Wochen bei Cablemod einen 4x8 Pin Kabel (Corsair) bestellt. Wurde am 03.11 versendet, hängt aber nun in Guangzhou mit dem Hinweis "local delay". Mal schauen wann es denn hier ist.
Und so kann es nun natürlich auch locker 2 Monate dauern bis das Kabel von Cablemod dann tatsächlich beim User ist…
Wo kannst du denn den Sendungsstatus sehen? In dem Tracking von Cablemod geht es nur zu DHL Express bei mir mit dem Status "Sendungsinformationen übermittelt". Status ist aus Eindhoven. Ich hatte das so verstanden, dass man es tracken kann ab dem Zeitpunkt wo es in Europa übernommen wurde.
Und hier deine Bestellnummer und Mail-Adresse eingeben.
Achso, dann hast du ja schon eine Sendungsnummer von DHL Express...dann musst warten bis es da im Eingang gescannt wurde.
Ich hatte das selbe Kabel schon vor 3 Wochen gehabt, hat aber leider nicht funktioniert obwohl alle Kabel Durchgang hatten. Da muss cablemod irgendwas falsch belegt haben. Es waren vom 8-pin auch alle 8 in der Netzteilseite belegt, was seltsam ist, da dort normalerweise immer nur 6 belegt sind. Mein Ersatzkabel sollte morgen oder übermorgen mit fedex geliefert werden…. Hoffentlich haben die den Fehler gefunden 😅
hier mal ein interessantes bild, das die DIE sizes/den Ausbau der einzelnen Generationen bzw. stufen (90er, 80er, 70er karten...) gegenüberstellt (jeweils im Vergleich zum Vollausbau aka 100%), hieran kann man leicht erkennen, wie groß der Unterschied zwischen den Generationen ist - und wie "tief" NVIDIA diesmal bei der Ada Generation pokert (versus Vollausbau)
Und nun bahnt sich auch schon Fall Nr. 28 an diesmal mit nem 16 Pin Kabel von Seasonic :
Shit. Dann ist also nicht nur MSI mit ihren nativen Kabeln betroffen.
Scheint also doch ein genereller (Teil)Defekt innerhalb der gesamten Spezifikation/Revisionsnummer zu sein.
Die Frage ist natürlich jetzt nurnoch, welche Chargen sind betroffen...
Hier sind ich ein paar Bilder der EVGA 4090 zu sehen, falls jemand nicht so auf Bewegtbilder steht.
Sieht schon sehr clean aus die Vorderseite, ohne einen Stromanschluss. Aber keine Ahnung, ob das dann der Weisheit letzter Schluss gewesen wäre, mit dem Anschluss an der schmalen Seite, bzgl. Platz zu den Frontlüftern.
Eigentlich müsste der Anschluss für die Stromversorgung auf die Rückseite, zu den HDMI/DisplayPort-Anschlüssen...
Richtig - es sind definitiv verschiedene Kabel von Seasonic im Umlauf. Hier ist der kritische Bereich sogar sicherheitshalber vergossen/verklebt. Biegen kann man sicher erst dahinter...
Es wäre auch interessant, ob die bisherigen Fälle nicht zumindest zum Teil vom User verursacht wurden. Ich meine, wir hatten hier im Thread auch schon nicht ganz eingerastete Stecker und sogar zurückgeschobene Pins. Beides wurde nicht gleich bemerkt und sorgt dann bestimmt für Übergangswiderstände.
Soll jetzt kein Strohhalm sein, denn wenn es so wäre, hätte das Nvidia schon lange verkündet. Nur wäre es wirklich interessant ob solche Fälle auch dabei sind. Nur um es eben zu wissen. Man weiß ja aktuell generell sehr wenig.
lol? Warum nutzt du so nen Schmutz? Sehr viele, mich eingeschlossen, benutzen die Kryonaut von Thermal Grizzly - nicht die Extreme kaufen!!
Im gleichen Zug als Erwähnung:
Zum entfernen alter Paste verwende ich reißfestes, originales Zewa mit Isopropanol -> mindestens 99,9%
Warum kein TG Extreme? Hab’s bei mir am CPU und auf der 3090 gehabt und fand die sehr gut zu verarbeiten. Gelide Extreme war dagegen zäh wie verrückt…
Ich habe hier eine 5,5g Tube von Kyronaut...die liegt schon 6 Jahre hier. Ich habe die vor kurzem noch genutzt und war alles ok.
Zum Entfernen nutze ich Arctic Silver ArctiClean mit Zitronen/Orangenen Duft :d Ein paar Tropfen reichen. Ebenfalls 6 Jahre alt und funktioniert noch.
Problem ist am Ende, dass die Umgebungstemperatur des Steckers zu heiß wird. Gerade die Abwärme der Grafikkarte bei 400+ Watt oder gar Richtung 600w bei nur durchschnittlicher Gehäuselüftung kann dem Stecker bei längeren Sessions schnell zum Verhängnis werden.
Interessant wird es dann im Hochsommer :)
Gerade die Leute mit Glasbrutkästen werden Grund zur Freude haben :fresse:
Auch eine Theorie.
Bestätigt mich dann wieder mit dem Torrent. Wenn ich will (Lüfterkurve) kann ich im Sommer etwas weiter aufdrehen. Gefällt mir aktuell wirklich gut.
Ich hatte deswegen mitte Oktober bei Seasonic angefragt, da war die Aussage das sie versuchen das noch im Dezember möglich zu machen, aber realistisch muss man wohl bis 2023 warten bis man das Seasonic Kabel kaufen kann.
Bestell dir lieber ein Cablemod Kabel, das wir sehr sicher schneller da sein.
Von wegen... Warte seit 4 Wochen und habe seit 2 Wochen eine Tracking Nummer die mir immer nur Anzeigt das irgendwann etwas in den Netherlands ankommen soll aber nix passiert,
Soviel zu Cablemod. Ganz zu schweigen von den horrenden Lieferkosten.
Haben ganz viele..ist halt aufm Schiff unterwegs wie es aussieht 😅
Ähnliche Themen
