[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibt es hier im Forum eigentlich schon jemand mit verschmortem Adapter?
Bin grad am Überlegen ob es Sinn macht den 3x8 Pin Adapter der bei Inno3D beiliegt überhaupt zu verwenden...
Inno kann nur 450 W und da hat es noch niemanden geschafft, nach meinen Kenntnisstand, den zu verschmoren. Bei 450 W kann auch ein Kabel vom Pad abreißen, wäre kein Problem. Da es kaum ATX 3.0 Netzeile gibt. Corsair es nicht auf die Reihe bekommt den Type 4 600 W zu liefern, wird es auch der Aapter tun. Immer wieder erstaunlich wie manche hier es sich antun mehrmals das System umzubauen, bis dann mal irgendwann alles da ist, wäre mir zu blöd. Vor allem warum kommen die ATX 3.0 Netzteile erst nach der Veröffentlichung der Grafikkarte. Es muss genau anders sein, vor allem war das ja schon lange mit dem Anschluss bekannt.
Bei 450 W gibt es aber selbst mit den schlechten Adapter keine Probleme und auch hier müsste man den erst einmal ordentlich biegen, bis ein Pad abreißt. Das war ja das Hauptproblem. Ein Pad reißt ab und ein "Verrückter" will aber nun doch die vollen 600 W fahren.
Ein User hat's zu Beginn, als die ganze Adapter-Story losging, hier im Thread behauptet, war aber wohl Fake. Wollte im Nachgang aus irgendwelchen Gründen keine Fotos liefern und auch seine Beträge aus der Vergangenheit sprachen jetzt nicht wirklich für Nvidia. Ansonsten ist mir hier aus dem Forum kein Fall bekannt, hab aber auch nicht jede Seite hier mitgelesen.
Er hat auch eine, oder vielleicht dieselbe Karte who knows :d
In der Liste von reddit sind 3 Karten die nur ein 3x8Pin Adapter genutzt haben, also ist das Problem schon mit maximal 450W aufgetreten.
Stimmt, aber drei Fälle weltweit wären mir zu wenig und keiner dieser handwerklich begabten Spezialkameraden berichtete davon wie er beim biegen den Stecker ordentlich vergewaltigt hat. Bei 450 W müssen gleich mehrere Kabel abgerissen sein, das muss man erst einmal schaffen. Ist natürlich unschön und so ein Stecker sollte auch für den größten "DAU" bestehen, ich denke mal aber diese sind wohl kaum ein Maßstab.
Statt ihn einfach sofort zu installieren und gut ist? Hmm, na wenn du meinst 😂
Und was machst du bitte mit der deutschen Sprache? Ist ja kaum lesbar der denglische Kauderwelsch.
Alles qool, bin gerade nicht moti4t da irgendwas zu installieren, dauert zu lange und nervt, mache ich dann, wenn mir langweilig ist als Therapiemaßnahme. :o
Bist du wegen deiner Schriftform in Therapie und helfen Installationen dabei?
Die EVGA wäre echt nice gewesen... verdammt tragisch das Ganze, einfach sad :heul:
Aber jetzt mal was erfreuliches, naja halbwegs. Nach 3 Stunden Geficke beim CPU Wechsel dank Wärmeleitpaste von Noctua NT-H2 bin ich echt am Arsch. Ich kauf das Zeug nie wieder! War erst 1,5 Jahre alt und das Zeug ließ sich einfach nicht mehr verstreichen und nein auch nicht mit kochend heißem Wasserbad... Am liebsten hätte ich das Zeug Noctua in die :fresse: geschmiert. Kann Jemand ne gute bzw. stets streichfähige Paste empfehlen?
Schlussendlich bin ich echt geflasht vom X3D (y) In New World habe ich in der Stadt 30-40 fps mehr :eek: Elite auf der Station sind es auch ca. +30 fps. Ich musste mehrfach nachschauen und die Einstellungen prüfen ob das wirklich sein kann. Abartig! Wird zwar 83 Grad heiß das gute Stück aber die CPU ist mal crank :fresse2:
Star Citizen insgesamt wesentlich mehr fps vor allem die lows, allerdings in Orison vorm Hotel warens dann doch nur 5 fps mehr (da limitiert dann der noch nicht perfekte Gen 12 Renderer). Aber hey damit habe ich echt nicht gerechnet.
Edit: Achja einmal in Elite hat der hintere Lüfter (also Gehäuse Rückseite) der 4090 FE auf 2200 RPM kurz hochgedreht. Dachte mir was ist denn jetzt los... Hat das Jemand mal gehabt?
Power Adapter Fall Nr. 27 :
Und nun bahnt sich auch schon Fall Nr. 28 an diesmal mit nem 16 Pin Kabel von Seasonic :
Wohl der Original Beitrag mit mehr Bildern :
Guten Morgen. Ich habe mal noch zwei Fragen:
Haben hier so viele bequiet Netzteile oder warum ist von dem Adapter ständig die Rede? Sorry, ich bin da nicht up tondate ;)
Zweite Frage: Weiß jemand, ob ich das Seasonic Kabel auch gegen Zahlung bestellen kann? Mein Prime TX 1000 ist älter als ein Jahr und auf der Seite steht ja was von maximal 1 Jahr alt.
Danke schonmal :)
Welche CPU hast du den vorher gehabt, damit man das gelesene mal in Relation setzen kann? Und in welcher Auflösung zockst du?
Mein 5900X fliegt obwohl er oft die 4950 Mhz macht demnächst gegen einen 5800X3D raus. Warum? Weil der X3D in manchen Games geil ist. Für Star Citizen z.B., welches ich aktuell sehr intensiv spiele, soll er auch gut was bringen. Ich freu mich und wenn die DHL Packstation mir nicht den Zugang verwehrt hätte, würde er seit Montag bei mir laufen. Hab jetzt nochmal neu bestellt, da der Preis ja auch nochmal runter ging und ich vermutlich vorher auch nicht an den Inhalt der Packstation komme.
Auch wenn die Frage schon 1000 mal gestellt wurde, schließe ich das Kabel von BeQuiet an V1 und 3 oder 5 und 6 an?
Danke schonmal :)
Einfach mal kabel bei Seasonic beantragen…. Meins ist schon zwei Jahre alt und kabel wurde trotzdem genehmigt
Werde meine Zotac RTX 4090 Trinity ohne OC wohl solange im Schrank packen, bis das Problem mit den 12VHPWR Kabeln egal ob als Adapter oder nativ, bis das Problem behoben ist allgemein.
Ich würde sie einbauen und mit 70% Powertarget laufen lassen :) die 300W werden schon okay sein und Leistung reicht immer noch dicke. Siehe Seite 1 👍😃
Rdr2 hab ich gestern getestet mit 70 % und 100%
71 vs 74 fps.
3440x1440 plus 200% Skalierung.😅
Mit etwas oc gleicht man das wieder aus.
Zocke aber mit dlss quality. Fsr 2.0 ist sehr nah an dlss in dem Spiel. Aber man muss bei für die nachschärfubg etwas mehr anziehen als bei dlss
Die RTX 4090 FE stößt im vertikal verbauten Zustand im Lian Li O11D schon fast an die AiO der Kraken.. Des Weiteren ist das Kabel, unabhängig ob Nvidia oder BeQuiet, für die vertikale Platzierung optisch ein absolutes NoGo!! Das Kabel kann man garnicht schön hinbiegen bzw. soll man auch nicht... Leider muss ich wohl die Karte normal verbauen :(
Noch eine blöde Frage am Rande: Reden wir von "guten" RTX 4090 Karten mit 3000 Mhz GPU Clock im Stock- oder OC Modus?
Müsstest halt warten bis CableMod hier mal ausm Quark kommt...
Also bist du dir sicher das du einen Adapter bekommen hast der defekt ist ohne es zu testen? Und du bist dir auch sicher das die nativen Kabel auch eher schlecht sind weil es 2 Fälle mit einem bestimmten Netzteil gibt? Was ist denn mit den ganzen Beiträgen das alles super ist?
Ich denke es ist wirklich am sinnvollsten erstmal abzuwarten in diesem Fall. Passieren wird zwar nichts, aber das wirst du sowieso nicht glauben. Die Frage ist nur woran du fest machst ob das Thema wirklich behoben ist. Denn was passiert wenn jetzt neue Adapter verschickt werden und danach wieder ein Fall kommt weil einer behauptet den neuen Adapter genutzt zu haben, aber den alten genutzt hat? Wirst du jemals die 4090 nutzen?
Ich hatte deswegen mitte Oktober bei Seasonic angefragt, da war die Aussage das sie versuchen das noch im Dezember möglich zu machen, aber realistisch muss man wohl bis 2023 warten bis man das Seasonic Kabel kaufen kann.
Bestell dir lieber ein Cablemod Kabel, das wir sehr sicher schneller da sein.
@coldfingers
Ah ok, dann hattest du wie ich einen 5900X gehabt, nice. Nur die Frage nach der Auflösung wurde noch nicht beantwortet? 1440p nehme ich mal an?
Soo viel schneller nun auch nicht, dauert ja knapp 1 Monat bis das Kabel von der Bestellung bei dir zu Hause ist, dann sind wir auch bereits bei Mitte Dezember…
Ich habe bei Cablemod letzte Woche bestellt (4x 8Pin auf 12VHPWR für Seasonic/Asus) und wurde gestern schon verschickt. Mal sehen wie lange es jetzt noch dauert aber schneller als ein Monat wird es denke ich schon.
@coldfingers
Ich spiele @1080p z.B. New World wobei das nun mit der 4090 @4k spielbar ist. Die Städte sind weiterhin CPU lastig und da reißt es nun der 5800X3D raus. The Outer Worlds @4k vorher mit einer 3090 nicht möglich bzw. halt low fps, jetzt mit der 4090 ein absoluter Traum! Cyberpunk mit RT kein DLSS @1080p vorher mit der 3090 60-70 fps jetzt 90-110 fps. ESO @4k, lief aber vor dem Upgrade schon top. Elite Dangerous @4k sonst flimmerts wie Hölle, noch zu wenig gespielt aber die Frames auf der Station waren krass. Star Citizen @1080p, da das Game in höheren Auflösung ekelhaft läuft. Also ich schau halt, dass ich immer so mindestens um die 100 fps habe, alles andere spielt sich zäh.
Also ich glaube so einen geilen Gaming PC hatte ich in den letzten 20 Jahren nicht. Das macht nach so kurzer Zeit schon extrem Spaß und der Winter wird ausgiebig genutzt endlich mal paar SP Games abzuschließen!
Ähnliche Themen
Antworten
7K
Aufrufe
586K
