[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich überleg auch das MSI aber der Reddit Post mit den geschmorten Kabel von dem nt bereiten mir iwie sorgen
Deswegen habe ich die MSI wieder storniert. Ich suche endlich gute ATX 3.0 Netzteile. Aber kaum welche auf Lager von Be Quiet und Seasonic etc. Von Gigabyte und MSI traue ich nicht
Ah, Du hast evtl. sogar den gleichen Monitor wie ich :- ) (Dell UltraSharp U4021QW? oder was ähnliches), bei FS2020 sind 5-10 fps bei dem Spiel schon ne Menge, Danke für die Info
Nicht ganz, habe einen LG (siehe System) aber beide haben die gleiche Auflösung.
Es gibt natürlich auch Szenarien, wo es nur 1 oder 2 fps sind, wenn z. B. auf Cruising Altitude im Airliner bist. Generell lohnt sich das Upgrade aber schon, der 5800X3D ist momentan definitiv die beste CPU für den Sim.
Meinst du die Leute gehen mit einem Lötkolben in die Pins und bringen so das Plastik zum schmelzen? Für ein paar Klicks? :d
Erstmal würd ich sagen gibt nichts was es nicht gibt (im Internet). Andererseits habe ich in dem selben Reddit Thread noch dieses Video verlinkt gefunden:
Er hat es tatsächlich geschafft einen Schaden herbeizuführen in dem er den Adapter nicht sauber und gut reingesteckt hat, dadurch der Widerstand stark erhöht wurde an der Stelle wo es nicht richtig drinsteckt. Zusätzlich hat er noch 15000W durchgejagt.....
Normal reingesteckt kam der Adapter nichtmal bei 900W in 22 Minuten über ~62°C
Das Aufgrund der dicke des ganzen Kabels, der Rigidität und der teilweise engen Verhältnissen in einem Case, der Stecker nicht mehr richtig sauber in der Buchse sitzt an der GPU, kann ich mir aber auch durchaus vorstellen und so scheint tatsächlich ein Schaden entstehen zu können.
Am Freitag, 04.11. eine 4090 bei MediaMarkt bestellt und bezahlt.
Heute erhalte ich folgende Nachricht (nachdem die letzten Tage, nach meiner Bestellung, locker 10 weitere dieser Karten bei Media online gegangen sind und verkauft wurden)
Was würdet ihr machen?
Ist die ASUS 4090 TUF OC
Danke .. guter Fund !!
Sollte also diese Nachricht von Techfast.com.au echt sein fängt wohl Nvidia nun entlich an zu handeln .. wird auch langsam zeit.
Also werden nun alle Karten ( zumindest dort wo es noch möglich ist ) von Nvidia bzw den Boardpartnern erstmal zurückgehalten
bis die Adapter Kabel durch die einzelnen Boardpartner getauscht wurden durch die neuen Adapter Kabel ( die hoffentlich ne vernüftige Qualitätskontrolle durchlaufen sind und auch identisch zu einander sind )
und dann werden die Karten erst verschickt. ... das soll nun erstmal geschätzt bis Mitte November dauern bis der tausch vollzogen wurde und erst dann gehen die Karten raus.
Auch ne Frage wie lange das dann in Deutschland dauert bis die Karten mit den Getauschten Adaptern bei uns dann in Deutschland landen das wird sicher
nochmal um einiges länger dauern als nur 2 Wochen
Hier nochmal die Nachricht :
ein vermerk bei der Karte hab ich dort aber zumindest nich gefunden :
Aber da währen eben noch die bisher 2 Fälle vom MSI Netzteil wo der MSI Adapter bzw Natives 16 Pin Kabel geschmort hat .. ganz durch is das Thema dann also leider immernoch nich
da muss nun jeder Hersteller seine Adapter und Kabel und Netzteile nochmal durchchecken und die Fehler beheben bevor die Dinger zu den Kunden gelangen
damit wir dann irgendwann das Thema Verschmorrte Kabel und Adapter entlich mal zu Grabe tragen können. .... aber das wird nun also erstmal ne Zeit lang dauern.
Aber 12VHPWR bleibt? Nur die Adapter werden ausgetauscht? Weil habe meine RTX 4090 seit über 1 Woche hier rumliegen, bis ich endlich das passende gute ATX3.0 Netzteil habe mit guten 12VHPWR Kabeln
Am Freitag eine 4090 bei MediaMarkt bestellt und bezahlt.
Schon Wahnsinn wie viele Rückläufer der Artikel doch hat. Würde auch erklären warum so ganz spontan immer mal wieder einzelne Modelle verfügbar sind.
Ja ich suche auch….werde jetzt aber erstmal als Zwischenlösung nen bequiet atx 2.x holen und den Adapter dazu…vielleicht bleibe ich auch dabei. Seasonic hätte ich am liebsten
Gut was sollen sie sonst machen ?
Die werden nun sicher nich alle karten nochmal umbauen auf die alten 3 oder 4 x 8 Pin ... das mit dem 16 Pin Stecker zieht Nvidia nun durch das is klar.
Der 16 Pin Stecker an sich is ja auch garnich so das Problem sondern eben die Qualitätskontrolle der Adapter und Kabel ( zumindest stand jetzt )
und die nutzung unterschiedlicher Kabel bei den Adaptern ( 150 und 300er ) sowie eben 4 unterschiedliche Löt Versionen statt nur 1 Version wie es bei einem Serien Produkt eigenntlich sein sollte
Die meisten Adapter sind ja ok aber es sind halt bei der Qualitätskontrolle einige Adapter durchgegangen die hätten garnich in den Verkehr gebracht werden dürfen
und das sind eben die die verschmoren .. is grad halt ein Glücksspiel ob ma einen Adapter erwischt der ok is.
Ich würde mal höflich anfragen, ob sie dir eine Gutscheinkarte (o.ä.) mit dazugeben könnten, da es sich ja demnach nicht mehr um Neuware handelt. Fragen kostet schließlich nichts.
@D3NN15
Kommt darauf an, wie dringend du die Karte möchtest?
Schon Mal nach einem kleinen Rabatt gefragt?
Ansonsten halt nehmen und ggf. Widerruf. Könnte ja auch das nicht-fiepende OC Wunder sein...
So die iChill Black kam vorhin glücklicherweise an :). Verpackung von Caseking TOP, Karton von außen versiegelt, Karte im perfekten Zustand, so wie es auch sein sollte! Die Karte ist sehr wertig verarbeitet, sieht etwas nach Custom WaKü aus. Es war nicht so einfach allein die Karte einzubauen und anschließend an der Gehäusewand den Radiator. Dieser ist übrigens um einiges dicker, als die normalen CPU AIOs. Dagegen sieht der 420er Radiator meiner H170 wirklich dünn aus :d. Karte läuft perfekt und die Pumpe ist nicht hörbar. Die Lüfter drehen im Idle auf 200rpm. Spulenfiepen konnte ich bei 144fps nicht feststellen, mehr habe ich noch nicht getestet. Die Pumpe der Corsair AIO ist auf jeden Fall das Lauteste in meinem System nun.
Kurze Frage, ist die Postion des Radiators so in Ordnung, bezüglich der Luftblasen? Karte mit Pumpe soll ja nicht der höchste Punkt sein.
Edit: Bin sehr froh, dass ich lange warten musste und die Suprim X dann doch nicht die Karte für mich war. Manchmal braucht es eben einen Wink des Schicksaals :). Inno3d und Artic haben da echt was Feines auf die Beine gestellt 8-). Die Nvidia Adapter war ein 3 Stecker, also sollte die Karte, so wie die Frostbite, 450W PL haben, was für mich mehr als ausreicht und auch das Stromkabel schonen sollte :d. Jedoch war es etwas schwerer, als bei der 3090Ti, das Stromkabel richtig reinzustecken. Musste am Ende nochmal deutlich schieben, bis es dann richtig fest war. Also falls jemand auch eine Inno3d Karte hat, überprüft das nochmal!
Passt alles. Es sollte immer oberhalb der Karte sein. Viel Spaß mit der Karte :)
@hithunter
Hab nur noch die letzten Timespy Werte im Kopf @ komplett default,
das waren:
GPU Takt: 2835 MHz
RAM Takt: Default
Leistung: 423 W
Wassertemp: 27 °C
GPU Speicher Junction Temp. 45 °C
GPU Temp: 43 °C
Hotspot: 52 °C
Wie oft willst Du as noch posten, was Du kannst, kann ich schon lange:
3x 8 Pin:
Hättest Du mal GPU_Z simultan geöffnet, erkannt man sofort das es ein BUG ist. Ursache geklärt.
Kann man so pauschal nicht sagen. Bei Aktuell steht nix weil es ein Sammler ist der jetzt mal ausgeklappt wurde. Sieht man auch in anderen Bereichen.
@hithunter
das waren:
GPU Takt: 2835 MHz
RAM Takt: Default
Leistung: 423 W
Wassertemp: 27 °C
GPU Temp: 43 °C
Hotspot: 52 °C
4090 Frostbite mit 3 Minuten 100% Benchmarkauslastung.
3x 8 Pin:
steht aber GPU Leitungen da, wenns so einfach wäre würde ich nicht fragen
@D3NN15
Vielleicht hatte die eine oder andere Hand hier diesen Rückläufer schonmal gehabt.
Würde es mit einem Preisnachlass probieren.
Ja, Plague ist echt Krass. Marktplatz Szene nur 60FPS mit der 4090 und meinem Ryzen 3700X ;)
Aber die Frage ist, 5800x3D, oder lieber auf 7800X3D warten ^^
Wieso warten? Beim 3700x würde ich sofort den 58003d kaufen. Bis der 70003d kommt dauert. Dann muss man noch pl beachten.
Zum einen hat mir die Support Dame was anderes erzählt und zum anderen steht auf der Webseite wie heute hier schon einmal zitiert:
"PCIe Gen 5.0 Ready
Jedes ROG Thor 1000W Platinum II Netzteil wird mit einem 16-Pin-PCIe-Kabel geliefert, das bis zu 600W Leistung an PCIe Gen 5.0 Grafikkarten liefern kann. Mach dich bereit für die Zukunft der Stromversorgung.
*Wenn Sie ein ROG Thor 1000W Platinum II-Netzteil erworben haben, das nicht mit einem 16-poligen PCIe-Kabel geliefert wurde, wenden Sie sich bitte an Ihren ASUS-Kundendienstvertreter vor Ort."
Quelle: https://rog.asus.com/de/power-supply-units/rog-thor/rog-thor-1000p2-gaming-model/
Du wirst so ein Kabel für dein 1000er bekommen, das lag meinem 1200er Thor bei: Klick mich
Was denkt ihr, kann man die Kabel hier statt dem Adapter verwenden?
Du weißt schon das es die 300W Version ohne Sensepins ist oder? Damit läuft die 4090 nicht.
Asus hat neben dem Loki nun ein weiteres ATX 3.0 Netzteil angekündigt.
Wenn du nur Spiele spielst und sonst nichts machst kann man nix besseres momentan machen als einen 5800X3D einzubauen. Meinen 5950x kann ich quasi 1:1 austauschen vom Geld her gesehen. Das reicht dann erstmal bis die 5090 rauskommt.
5800X3D kommt diese woche inklusive neues Torrent gehäuse :). Fehlt nur noch die 4090...und vorallem das Corsair Kabel.
Ok. Also weißt du noch gar nicht ob es was bringt. Dann berichte mal wenn es so weit ist...
Erst eine 4090 kaufen und dann drauf und dran sein sie verzweifelt unter 200 Watt in 4K und 80 - 100+ FPS zu verwenden.
FPS limiert
Powerlimit auf 60% oder 50% herabgesetzt
Undervoltet und untertaktet...
l
Wozu holt man sich dann diese Karte überhaupt? 😂
Vielleicht ja für bessere Zeiten, die nicht so schnell kommen werden, wo Strom wieder verdammt günstig ist.
UV und PL senken macht auch keinen Sinn allg das PL senken ist doof. Lieber UV ameine Suprim macht ja ohne Problme 0,89mV bei 2600 Mhz und +1000 Mhz Speicher mit. Natürlich kann die im Standard über 2800 Ghz boosten, macht sich aber nur im Stromverbrauch von ~150-200 Watt mehr bemerkbar. Komplett unnötig. Da die FPS ja quasi gleichbleiben.
Nehmen. Kannst doch umtauschen wenn es probleme gibt.
Die basieren sicher auf den Seasonic Vertex :d
Brauchst dir eig. nur Reviews anschauen (720p) dann weisste wie viel schneller er ist wie nen 5950x. Vorallem in Frametimes viel stabiler.
13900K vs 5800X3D
Hier zb. nen vergleich mit nem 13900k vs 5800x3d ... viel fehlt da nicht kommt halt auch aufs Spiel an.
___
5800X vs. 5800X3D
Hier der alte 5800X (kann man auch als referenz für 5900/5950 nehmen da die mehr Kerne eh nix bringen) gegen 5800X3D beachtlich was der selbst in 4K auf manchen Games drauflegt an Leistung.
