[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
3x8
TUF 4090 NON OC
hier nochmal, gibts Meinungen dazu? ist angeschlossen mit 3x8
tjoa..
diese 580W täten mich interessieren
Ich glaub bei Scrush seine TUF OC ist das auch so weil er auch mit 3*8Pin betreibt hat er auch 450 W vielleicht kann er das noch mal prüfen.
Aber das Maximal mit 579W ist komisch.
Kaufst dir ne Graka für 2k, ein geiles neues NT und einen Monat später...
Wird bei mir in HWinfo auch angezeigt. Bei mir steht aber "nur" 533W. Da es aber kein momentanen Wert hat, sondern nur min./max. denke ich, dass man es vernachlässigen kann!
Edit: Habe nochmal geschaut, der Wert passt 1:1 zu dem Wert "GPU Core (NVVDD) Ausgabe Energieverbrauch" - ist der NVVDD Wert des GPU Cores aber keine Ahnung, was das sein soll (wird an der Ausgangsseite des Spannungsreglers gemessen).
Erst eine 4090 kaufen und dann drauf und dran sein sie verzweifelt unter 200 Watt in 4K und 80 - 100+ FPS zu verwenden.
FPS limiert
Powerlimit auf 60% oder 50% herabgesetzt
Undervoltet und untertaktet...
Wozu holt man sich dann diese Karte überhaupt? 😂
Vielleicht ja für bessere Zeiten, die nicht so schnell kommen werden, wo Strom wieder verdammt günstig ist.
Da es offenbar noch nicht gepostet wurde:
Danke .. guter Fund !!
Sollte also diese Nachricht von Techfast.com.au echt sein fängt wohl Nvidia nun entlich an zu handeln .. wird auch langsam zeit.
Also werden nun alle Karten ( zumindest dort wo es noch möglich ist ) von Nvidia bzw den Boardpartnern erstmal zurückgehalten
bis die Adapter Kabel durch die einzelnen Boardpartner getauscht wurden durch die neuen Adapter Kabel ( die hoffentlich ne vernüftige Qualitätskontrolle durchlaufen sind und auch identisch zu einander sind )
und dann werden die Karten erst verschickt. ... das soll nun erstmal geschätzt bis Mitte November dauern bis der tausch vollzogen wurde und erst dann gehen die Karten raus.
Auch ne Frage wie lange das dann in Deutschland dauert bis die Karten mit den Getauschten Adaptern bei uns dann in Deutschland landen das wird sicher
nochmal um einiges länger dauern als nur 2 Wochen
Hier nochmal die Nachricht :
ein vermerk bei der Karte hab ich dort aber zumindest nich gefunden :
Aber da währen eben noch die bisher 2 Fälle vom MSI Netzteil wo der MSI Adapter bzw Natives 16 Pin Kabel geschmort hat .. ganz durch is das Thema dann also leider immernoch nich
da muss nun jeder Hersteller seine Adapter und Kabel und Netzteile nochmal durchchecken und die Fehler beheben bevor die Dinger zu den Kunden gelangen
damit wir dann irgendwann das Thema Verschmorrte Kabel und Adapter entlich mal zu Grabe tragen können. .... aber das wird nun also erstmal ne Zeit lang dauern.
Wenn du nur Spiele spielst und sonst nichts machst kann man nix besseres momentan machen als einen 5800X3D einzubauen. Meinen 5950x kann ich quasi 1:1 austauschen vom Geld her gesehen. Das reicht dann erstmal bis die 5090 rauskommt.
5800X3D kommt diese woche inklusive neues Torrent gehäuse :). Fehlt nur noch die 4090...und vorallem das Corsair Kabel.
Habe mir jetzt mal für 349 den 3d bestellt. Wenn der nicht besser als mein 5900x ist kommt der oder ein 5950x wieder rein und der 3d geht auf ebay.
Meine Videos kann ich eh mit der GPU rendern und wenn etwas mal 11 statt 9 Minuten dauert ist es auch nicht so tragisch.
Hoffe nur, dass der 3d nicht in einigen games langsamer als der 5900x ist.
Eigentlich erhoffe ich mir weniger low fps. den 120 FPS schafft auch der 5900x außerin spiderman und plague.
Ich kann mir jetzt auch noch schnell ein ATX 3.0 Netzteil kaufen und das Feuerzeug an den Stecker halten, soll nicht heißen, dass alle lügen, aber es würde mich nicht wundern, wenn da der ein oder andere solche Fall dabei wäre.
Hallo, das interessier mich sehr, weil ich auch vor allem auf den FS2020 gehe. In welcher Auflösung spielst Du (4k? oder sogar VR?) und wieviel hat das im unterschied ausgemacht (ich habe noch einen 5950x rumliegen, aber noch keine passende Grafikkarte. Auf welche fps Werte kommst mit der 4090? Danke und viele Grüße
In Verbindung mit der 4090 kann ich nichts sagen, die ist noch auf dem Versandweg aber mit der 3090 war das schon ein netter Sprung. Interessant ist vor allem, dass es deutlich weniger low fps sind und auch im Mittel sind die fps gestiegen. Je nach Situation würde ich sagen 5-10 fps.
Auflösung ist WUHD 5120x2160 bei mittleren bis hohen Einstellungen, mehr schafft die 3090 nicht wirklich. Ultra Preset geht nur flüssig in UWQHD (3440x1440).
Oha die 4080 setzt sich aber nich groß von einer 3080 ab
Also da meines Wissens noch nicht ein einziger YouTuber oder News-Outlet es bisher geschafft hat jeglichen Schaden am Kabel/Adapter hebizuführen, selbst mit übelstem Missbrauch dessen...... Kann mir gut vorstellen, dass das ganze Problem drastisch hochgebauscht wurde und da vielleicht sogar paar Faker mit dabei sind.
Ah, Du hast evtl. sogar den gleichen Monitor wie ich :- ) (Dell UltraSharp U4021QW? oder was ähnliches), bei FS2020 sind 5-10 fps bei dem Spiel schon ne Menge, Danke für die Info
"Such 3DMark TimeSpy scores put the card higher than Geekbench tests. We are looking at 51% to 54% higher performance than RTX 3080 12GB model (which had more cores than 10GB). Alternatively, RTX 4080 is 32% faster than RTX 3090 Ti in both presets. The RTX 4090 appears to be 36.8% faster than RTX 4080 in Extreme 4K preset."
Nicht groß?
Du musst dich noch mehr einlesen
Nich jeder Adpater brennt gleich .. es gibt da ein paar Adapter im Umlauf die scheisse verlötet wurden .. auch die Lötung ansich varriert gibt bisher 4 bekannte Versionen wo unterschiedlich verlötet wurde ,
dazu kommt noch das 1 Adapter mit 150 Kabel ausgestattet ist aber der nächste mit nem 300er Kabel ...zur erinnerung das sollte eigentlich ein Serien Produkt sein und somit immer gleich sein.
ja hab die 90 TUF NON OC 3x8
ich warte mal bis jemand mit 4x8 nach ner Weile HwInfo laufen lassen seinen Screen postet
Diverse YTuber haben mittlerweile 5 Videos zum Thema gemacht und melken den Train halt auch gut zum eigenen Vorteil.
Soll das Problem nicht verharmlosen, ich pers hätte schon Bedenken mit einer 4090 ob ich mir damit was abfackel.
Aber wie schnell da bei div YT immer noch mal ein Video kam, hat sicher auch wenn es allen zur Information dient, so einen gewissen Geschmack. Das 3., 4. und 5. Video waren dann auch hier und da nicht mehr ganz so informativ.
@MAX25
@SH
@xl_digit
Mich würde ja vor allem mal ein Vergleich der Speichertemperatur von Luft und Wasser interessieren.
Meine mit Luft und der Inno 3D :
Testprogramm: MSI Kombustor 4.1.17.0
Benchmark: Preset: 2160
Auflösung: UHD
GPU Takt: 2820 MHz
RAM Takt: 10502 MHz
Leistung: 425 - 432 W
Gehäuselufttemp: 26 °C
GPU Speicher Junction Temp. 68 °C
GPU Temp: 71,5 °C
Hotspot: 80,9 °C
Welche Werte erreicht Ihr bei euren Karten mit dem o.g. Test ?
Danke schon mal.
Da hast du absolut Recht. Das ist auch sicherlich zumindest eine sehr fragwürdige Praxis. Dennoch hat bisher niemand einen Schaden reproduzieren können, egal mit welchen Mitteln (teilweise 50% der Kabel einfach abgemacht am Adapter und solche Sachen).
Nicht groß?
Es is natürlich schon ein unterschied aber der unterschied zur 4090 is halt schon derbe höher.
Das war von der 3080 zur 3090 eben weniger unterschied
Meine 3080 Strix 10 GB Model : ( weiss grad nichmal ob das mein bester Score is ) --------------------------------------------------------------------- Die 4080 :
Link zu meinem Score :
FPS limiert
Auch mit 60% PL (~270W) ist die Karte umdie 50% schneller als ne 3090Ti mit 450W...DARUM.
Und ich komme von einer 3090. Im Sommer waren schon die 350W zuviel für das Zimmer, da musste ich schon auf 70%PL runterregeln. :d Und ich meine Zimmer, nicht PC. Die PC Temp blieb im Rahmen.
Komisch, da noch kein Fall mit einer Gainward Karte bekannt ist...möglicherweise ist das eine Ausrede, weil sie die Lüfter wechseln müssen. Die Lüfter waren eher der Anstoßpunkt bei den Karten...
Wir tauschen den defekten Nvidia Adapter aus hört sich besser an als, wie tauschen unsere defekten/lauten Lüfter aus.
Die Preise auf EBK werden Steeeeeiiiiiiiigen
Restbestände werden niedrig...nach dem nächsten drop geht es weiter runter.
10.000 vs 14.000 sind halt glatte 40% Mehrleistung. Und ich geh davon aus , dass dein Run OCed und optimiert ist.
50-60% mehr Leistung...aber zum Vergleich 799€ zu 1469€ siehts nicht gut aus... Da wäre die 7900XT deutlich besser...
Aber nicht für 900 Euro. Thats the problem
Sibertablett für amd
Meinst du die Leute gehen mit einem Lötkolben in die Pins und bringen so das Plastik zum schmelzen? Für ein paar Klicks? :d
Absolut .. aber so 4000 mehr punkte reissen mich persönlich halt nich so vom hocker wie die Werte von der 4090
.. wissen wir ob der 4080 Run Optimiert war ? Könnte sein aber schätze mal das war Stock.
"However, the card tested is most likely a factory-overclocked variant, as the leaker shared pictures of Inno3D’s RTX 4080 iChill X3 packaging earlier."
Sieht man nun von Ray ab und hätte man interesse in diesem Bereich würde ich auch eher zur AMD karte raten ( stand jetzt )
Für mich is von der 3080 kommend aber nur die 4090 interessant da die anderen Karten mir einen zu kleinen Sprung bieten und die 4090 bleibt dann für 4 Jahre im meinem PC
Die halt auch Ihre 1300€ kosten wird, evtl sogar noch ein bissel mehr.
