[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja, bei Verwendung G-Sync muss V-Sync muss im Control Panel aktiviert sein + FPS Limiter, damit du nicht aus der Range kommst.
Oftmals braucht man bei manchen Monitoren keine Frame-Limiter sogar. Mein 144Hz- G-Sync bleibt von allein ein paar Hz unter dem Maximum bei im Treiber aktiviertem V-Sync.
Habt ihr auch hin und wieder bei einigen Games Tearing obwohl ihr einen G-sync fähigen Monitor/TV habt und VRR?
Verstehe nicht warum ich bei meinem LG OLED C1 in manchen Games immer wieder Tearing habe und V-Sync einschalten muss... Jemand eine Idee?
@Slipknot
Habe mich bei der Gigabyte Gaming OC bei 60% Lüfterstärke eingependelt, finde ich genau richtig, GPU wird in Games keine 60° C und Lüfter sind nicht laut. Gefällt mir auch eher wenn ich sie etwas höre, dann weiß ich die 4090 ist gut gekühlt.
Fps 2 unter max range cappen und vsync ingame an.
Nimm fürs cappen rtss
Das geht on the Fly, glättet die frametimes und du musst nicht jedes mal das game Neustarten.
Bei 120hz bei 118 cappen im rtss unter global und wenn du ein Spiel hast welches die 118 fps nicht hält dann eben dort cappen was gehalten wird. Sonst hast du Gummiband Effekt
weil hier niemand jemals seine superdollen "secrets" verraten will und so tut als haette er gold gefunden;
Anhang anzeigen 812743Anhang anzeigen 812744Anhang anzeigen 812745
260/1400 nur. jemand dessen mem mehr takt macht, kann sich damit easy die #1 holen :)
Das hat dir der Teufel gesagt ;-) 😂😂
Ist schon sehr sehr sehr alt das hier oftmals noch der ein oder andere Punkt versteckt war …
@Scrush Guter Tipp! An der Stelle wird die Einstellung für das FPS cap gemacht. Ist auch mein Rezept gegen Spulenfiepen.
@dante`afk Danke, ich kannte das noch nicht. Erklärt natürlich einiges.
Hat rtss Limit gravierende Vorteile?
ja es geht on the fly
wenn du z.b. ein spiel hast welches du nicht ausmachen willst aber mal kurz was anderes machen willst kannst du alt tabben, fps auf 10 und surfen. gpu geht in zero fan mode und das spiel läuft aber weiter :) ist meistens ein vorteil bei games, deren menü 3d ist -.-
bei manchen games klappt das aber nicht immer
ansonsten beim settings finden eines neuen spiels kannst du dein fps cap schneller einstellen als jedes mal das game neuzustarten. bei manchen games dauert so ein spielstart und laden bis ins game ja ne halbe dekade
Ich hab noch einen Hotkey an fürs kappen, dann ist es noch komfortabler an und abzuschalten on the fly.
jupp das kann der afterburner ebenfalls :) braucht man fürs testen/benchen
ich auch nicht^^
das treiber vsync hab ich dewegen nicht an weil das wieder global gilt außer man macht es im treiber für jedes game einzeln^^
Nachricht gelöscht
war zu erwarten ja. macht aber nix. am ende muss der preis stimmen.
Battlenonsense hatte auch einmal gemessen, dass man mit einem 4 FPS cap einen niedrigeren Input Lag sowie Latenz hat als mit einem 2 FPS cap unter der max range.
Ich cappe z.B. bei 144 Hz bei 140 FPS und nicht bei 142 FPS. Da ist man auf der sicheren Seite und selbst, wenn es nichts ausmacht - die 2 FPS weniger merkt man eh nicht.
Da hier noch niemand den Link gepostet hat, hier:
Fahre ich schon seit 5 Jahren so mit meinen Gsync Monitoren und TV‘s.
Hmmm, hier sagen sie wieder 3 FPS:
Ich cappe einfach weiterhin mit 4 FPS, dann bin ich auf jeden Fall safe. ^^
V-Sync muss ich im Treiber und im Game auf "an". Dann cappt er automatisch bei 116fps und alles läuft optimal
Habe dazu ein video gemacht.
GPU: Nvidia Founders Edition ---- kann sich sehen lassen ;)
PS:
Zur Vervollständigung oder falls jmd kein Bock zum lesen hat zum Thema G-Sync:
(Gibt’s auch auf deutsch oder sogar tirolisch das Video 😏)
Das ist keine wirklich gute Idee, hier würde ich mich für eine Methode entscheiden, doppelt hält hier nicht besser, sondern du hast mit dieser Methodik mehr Input Lag.
Dazu muss aber zugleich das hier an sein, damit er das macht:
Und das funktioniert nicht in allen Spielen (z.B. DirectX 12 Games).
Das Video hier erklärt alles ziemlich gut, wie man es am besten machen sollte:
edit: Da war @ssj3rd schneller ^^
Da sagt er beispielsweise auch mit VIER FPS cappen und nicht mit 2 oder 3 FPS.
Bin schon seit den ersten GSync Monitor dabei AOC 2460PG , PG27AQ , Acer X34P und aktuell PG32UQX.
Beste war bisher immer im Treiber zunächst Vsync auf "ein" bei globale Einstellungen
Dann im Game Vsync in der Regel aus . Im Game FPS limititer verweden und -3 FPS @ max. HZ einstellen .
Oder wenn Game Nvidia Reflex unterstützt dieses einstellen und es macht automatisch -6 FPS @ max. HZ .
Ansonsten je nach Game einfach im Profil des Games im Treiber ein FPS limit setzen, wenn es keinen eigenen ingame Limiter hat.
Früher habe ich es mit RTSS gemacht , aber mittlerweile gehts ja auch über den Treiber.
Memory Overclock:
Da Afterburner 1000Mhz eigentlich 2000Mhz sind, während 1000Mhz in GPUTweak tatsächlich 1000Mhz sind, würde es mich interessieren, was ihr eigentlich unter +1500 versteht?!
Sind das dann 24000Mhz oder 22500Mhz? :-)
Das selbe trifft auf +240Mhz Core zu…wäre viel besser wenn wir uns auf eine Voltage (1.05, 1.1) einigen und den entsprechenden Takt nennen…weil meine Strix braucht „nur 180“ um 3090 bei 1.1 zu erreichen…
Die meisten nutzen Afterburner , weil da auch die Spannung höher eingestellt werden kann.
Das wäre jetzt +250 Core Clock und +1500 MHZ Vram
Im Overlay wäre es dann statt 10500 MHZ , dann 12000 MHZ
Ich habe das gesehen aber ich verstehe immer noch nicht warum der Fernseher es nicht schafft kein Tearing zu verursachen :/
G-SYNC und VRR muss das doch locker regeln können, dass absolut kein Tearing entsteht, wenn zwischen 1-120 FPS bei 120Hz dargestellt werden.
Ähnliche Themen
